Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 12-15-2007, 04:04 PM   #16
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
@DavidP - how come you input a GBpath in extras when there is a BG path you can set in RRConfig??
Can you post your background.skin with the changes you made; seem I'm the only one can't get it to work!
@Blk02si - Aside from my BG problem, everything else in Shock works perfectly. The info bar is a great addition.
treetop777 is offline   Reply With Quote
Old 12-15-2007, 04:15 PM   #17
High Voltage
blk02si's Avatar
blk02si will become famous soon enoughblk02si will become famous soon enough
Hey Treetop,
RRconfig does not write the background variable line to rr.ini correctly.
You need to manually add the:
backgroundpath=xxx in your rr.ini
or use the extras section to manually add it to rr.ini
Davids code is the same with the exception of the slash angle on the last line of code in background.skin.
blk02si is online now   Reply With Quote
Old 12-15-2007, 04:24 PM   #18
Raw Wave
treetop777's Avatar
Quote: Originally Posted by blk02si View Post
Hey Treetop,
Ok. let me try that. will report back.
Old 12-15-2007, 05:34 PM   #19
Raw Wave
treetop777's Avatar
Finally!
Old 12-16-2007, 12:43 AM   #20
davidp is an unknown quantity at this point
Hey Treetop,
exactly, rrconfig writes the line "background="
also, im not sure if the angle of the slash matters, i was just guessing and checking till it worked, lol.
david
davidp is offline   Reply With Quote
Old 12-16-2007, 10:19 AM   #21
High Voltage
blk02si's Avatar
I knew your background.skin dilemma would come to a close in v 6
Looks great treetop!
Old 12-16-2007, 10:51 AM   #22
Raw Wave
treetop777's Avatar
Indeed, we can now all use a backgroung.skin with a central BG folder thanks to you. However, in light of this http://www.mp3car.com/vbulletin/road...ml#post1153986 post #442, we should make the changes necessary in the BG.skin code to make it use the line that is written CORRECTLY by RRConfig in rr.ini and not have to input anything manually - that should be simple, right?
Old 12-16-2007, 11:57 AM   #23
High Voltage
blk02si's Avatar
I suppose it would be as easy as changing all the $backgroundpath$ to simply $background$ in the skin file.
This is strange because when the first thoughts of adding this to RR the variable was known as backgroundpath, and it has to be in RR somewhere because it works great!
Ill test it out, see if it works.
Old 12-16-2007, 07:06 PM   #24
Raw Wave
treetop777's Avatar
I tryed changing them and rr just locke-up so i'm going to leave well alone.
Old 12-16-2007, 08:08 PM   #25
wingnut75's Avatar
wingnut75 is an unknown quantity at this point
We'll I had it working and then I did a fresh install on my cf and this is what I get. I have updated the flash and the lastest RR. I also updated the ExecTBL.ini file. I can change to DFX 3.0 and it looks right. I'am missing something just don't know what. Any help would be great. Thanks
Why buy it if you can build it? Even if it cost twice as much to build.
wingnut75 is offline   Reply With Quote
Old 12-16-2007, 08:28 PM   #26
Raw Wave
treetop777's Avatar
Maybe this http://www.mp3car.com/vbulletin/road...ilist-bad.html
Old 12-16-2007, 08:30 PM   #27
wingnut75's Avatar
@Treetop - Thanks I will give a look now.
Old 12-16-2007, 08:36 PM   #28
wingnut75's Avatar
@Treetop- Went to my display properties > settings > color quality and changed from 16bits to 32 bits and that fix it. Cool thanks for the link
Old 12-16-2007, 09:26 PM   #29
another thing that can cause the pink ilists is if the bmp isn't big enough to cover the area it's supposed to. i ran into this in my skin, and the best way i found to overcome it is to make the ilist bmps 800x600 resolution, that solved it for me.
david
Old 12-16-2007, 09:35 PM   #30
wingnut75's Avatar
I see the following sel.bmp, selBK.bmp, selDL.bmp, selPL.bmp are these the one's you are referring to.
EniCar the RR Clone enitalp Software & Software Development 296 12-13-2008 05:12 PM
"Avic'ted" - Pioneer Styled Skin monkeyracer RR Skins 36 10-19-2007 10:08 AM
Vicky Skin (v2) released Valheru RR Skins 7 10-19-2007 04:12 AM
Hard drive shock / vibration thoughts S11D336B General Hardware Discussion 60 09-26-2006 11:40 PM
Honda skin that released with RR 93blacksrv RR Bug Tracker 1 04-08-2005 02:37 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
