12-17-2007, 11:07 PM
#31
High Voltage
Those are the bitmaps used for the iList. Each one matches the list size exactly. Ive noticed that if you scale the skin in general.ini to say 1024 x 768 the iList does not like this and will turn pink. When I was coding the iList I used the bmp method because I could not get the other way to work. Some of the lists share these bmps but here's how they are used:
sel.bmp - Random lists like skin browser
selBK.bmp - background.skin browser
selDL.bmp - Directory lists
selPL.bmp - Playlists
I like the idea of making the bmps 800x600, then you have all the bases covered, good suggestion david.
12-18-2007, 09:31 AM
#32
Thanks for the info and I will try it out later to night.
Update: I changed the .bmp's to 800x600 and this fixed the problem. Thanks David & blk02si
Why buy it if you can build it? Even if it cost twice as much to build.
12-21-2007, 09:51 AM
#33
High Voltage
How is HD menu working for you guys who downloaded the skin?
12-22-2007, 09:10 PM
#34
I'am trying to get the HD Signal and I'am having no luck. Here is what I have so far.
radio_player.skin
S01,607,98,57,28,015,352,254,035,H,01," ",015,"HDSIGNAL","Master"
Y01,"Installs\slider_signal\slider_*.gif"
Were the gif's are filed : $SKINPATH$\Installs\slider_signal
12-23-2007, 10:45 AM
#35
High Voltage
Are you trying to add a slider bar for signal strength?
I was considering doing this but all my stations come in so clear it would probably be at full signal all the time.
Let me know if you get this to work wingnut, would be a nice addition to the HD menu.
12-23-2007, 07:15 PM
#36
radio_player.skin
Try this:
Y01,"\Installs\slider_signal\slider_*.gif"
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
12-23-2007, 08:50 PM
#37
Sal R. >> I moved the Y01 above the slider bar and it's working now.  Thanks for the info.
blk02si >> I'am still working on some more things (AM/FM) and I will post asap.
12-24-2007, 11:28 AM
#38
beautiful. I changed my mind on the menubar
I need to email you the FINAL release files of the wireless.
edit: sent, ported for v6.0
updates:
added WORKING enable/disable wifi for PCI AND USB wifi cards
changed to NEW wifi_man.exe and wireless.exe files
fixed some buttons being slightly too small for the newer .pgn file
12-26-2007, 09:06 PM
#39
High Voltage
Hey pwntbypat
Thank you for the comments. I did not get your newest wifi code in my email so you can resend if you get a chance.
Your original code that you sent me was modified for v 6.0. I cleaned up the code base and the buttons/art for the shock v 6.0 release. If you have newer code def send it my way!
Thx again for the great addition!
01-02-2008, 10:03 AM
#40
High Voltage
What do you have cookin wingnut?
I've been coding more since i've been  'd in. Beats watching TV
01-03-2008, 12:35 AM
#41
I took some screen shots on what I have so far.I have been pulling my hair out trying to get the AM part working, *start with the tune button* lol. All the mod. codes came from the New Age skin by ThunderStick. I also added a gasnav sceen and somemore eye candy to the menu skins. I love how you can build onto this skin so easy. I did try out the coverflow plugin but thats just to much for my m10000.
01-03-2008, 12:48 AM
#42
High Voltage
Wow! Looks awesome man!! Can you share the main menu and HD radio code? Really like your work.
Also, are you having any trouble with your presets sticking?
01-03-2008, 12:11 PM
#43
Ohhh I like the compass...is that on the main menu? Please do share your code!
01-03-2008, 09:43 PM
#44
Thanks for the comments, I hope this helps. blk02si that new skin your working on is looking sweet.
Not that I have seen.
01-03-2008, 10:54 PM
#45
High Voltage
Awesome work wingnut!!
You have added a ton of features, scripts, art and code plus a menu_3.
Really like your additions, just playing around and I am quite impressed, I almost cannot believe you packed in so many features and managed to stay around 11mb size.
This skin version has just become the proud member of the shock series, thank you for your contribution. I like to leave shock skin code "open" as possible to encourage the community to build as you did wingnut.
HD presets now work in 6.1.1! Also great layout and function, the radio menu is a big step from v6.0
 Added mirror in first thread
| Thread Tools |
| Display Modes |
Linear Mode
