The only thing I can think of as far as the skin's side is to disable the ReloadInfo in the ExecTBL.ini. This is used to update the gas and weather data at startup. Look for the following and just add / to disable.
I have a command setup in the ExecTBL.ini. I had it setup in an older file, I will look for the skin file and post back.
Quote:
/, Set Bellow the Path to the Rainlander plugin (if used)
"CALENDAR","LOAD;Rainlander.skin;Rainlander;$skinp ath$\Rainlendar\Rainlendar.exe;Rainlendar"
Why buy it if you can build it? Even if it cost twice as much to build.
I'm fairly new to all of this, but have a couple of questions..
1. I can't seem to get the video playlist to come up. I can play it by playing it in another application and then opening RR, but can't bring up the list of video. I have set my video playlist path in the RR config. Help!
2. I would like to remove the compass but don't know how. Can anyone lead me in the right direction?
Cheers!
Braiden.
__________________ 1994 ED Ford Falcon GLi Classic Hardware: Acer Travelmate 3200, Car Charger, Lilliput 7" Software: Roadrunner (Simplistique), WinXP Pro, ShutControl, Speedfan
[MachineHead]
I haven't used this skin since version 3, I'm quite impressed with how far things have come since then.
I have a little issue with the 6.1.1 version. When I have my GPS set up properly with a port dedicated for RR, the skin locks up on startup. It's fine if I have the GPS com port set to 0 but obviously the compass and other indicators won't work in that case. I haven't played with it much, so it's probably something obvious.
In settings.txt i don't see where the external gps screen can be configured independently; what i want to do is put IG shortcuts across the top bar just in the external GPS screen..can it be done?
