The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 12-31-2007, 05:58 PM   #1
blk02si's CarPC Specs
blk02si's Avatar
Vehicle: '06 Triple Black Mustang
My Photos: (0)
Advanced Skinning Question
Well I'm not sure this is even possible, and I think I've tried about everything from skin commands.txt to achieve this look without luck. I've never seen it done in a RR skin, but I know RR is powerful and it may be possible so here is what I want to do.
I am currently coding a Carwings replica skin for RR and I am on the GPS menu and I have it mostly done but I am trying to get a very accurate look so here goes:
Have the GPS art as normal with an embedded application (iGuidance) inside of it. Then I want to draw the menu "over the top" of the embedded application. Ive tried using the IMG command and it works but iGuidance still takes precedence and shows on top of everything including my menu. I've tried messing with the "SETTOPMOST" and "SHOWWINDOW" commands without luck. So is what I want to do within the limits of RR?
Since pictures are worth a thousand words here are 2,
first one is an actual screencap of RR running the carwings skin and the second is a photochop of what I would like it to look like.
Any help is welcomed and thank you in advance for even any ideas. I know there is some real talent out there!
My carPC - www.shocknet.us
blk02si is offline   Reply With Quote
Sponsored Links
Old 12-31-2007, 06:45 PM   #2
davidp's CarPC Specs
Vehicle: 08 Dodge Avenger R/T
My Photos: (5)
i dont think that roadrunner can do that yet, at least not unless it was added very recently. skin is looking great by the way
david
davidp is offline   Reply With Quote
Old 12-31-2007, 07:00 PM   #3
Sal R.'s CarPC Specs
Sal R.'s Avatar
Vehicle: 2001 A4 1.8TQMS
My Photos: (36)
LS figured out a way to put an IG .exe plugin over the IG area with corresponding icon.
Might want to try asking him or checking out his skin.
MicroXP / RR v11/04/2007 / Winamp v5.13 / MMIv2
RR Album Art Browser
Sal R. is offline   Reply With Quote
Old 01-01-2008, 06:26 PM   #4
EL CAMINO's CarPC Specs
EL CAMINO's Avatar
Vehicle: 1981 chevy el camino
My Photos: (0)
is possible, i did it in my old elco media skin, is a very old threat, LS has a script called igControl, and flashdeck has it also.
EL CAMINO is offline   Reply With Quote
Old 01-01-2008, 06:56 PM   #5
blk02si's Avatar
My Photos: (0)
These items are still square though. FlashDeck & IGcontrol. I am attempting to get a curve overlay using art rendered by RR if possible. If I have to use/write another app to make it happen I will, just wanted to know if this type of rendering is possible just using RR.
Old 01-01-2008, 07:26 PM   #6
tundra2000's Avatar
Vehicle: 2004 Ford F150 FX4
My Photos: (2)
flash. thats the only way its possible. draw your overlapping picture in photoshop and save it as a png. swishmax can do it, if it is possible.
tundra2000 is offline   Reply With Quote
Old 01-01-2008, 07:30 PM   #7
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
If you were using FreeDrive I would suggest having the FreeDrive skin do the curved bit. However you are not so I won't.
Enforcer is offline   Reply With Quote
Old 01-01-2008, 10:39 PM   #8
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
Liquid Smoke has some code to do this. His latest code supports PNG's for use with AUtoIt. Basically AutoIt places the image at a defined X/Y location. With the PNG support, you can simply make the "outter curve" of the image overlay transparent.
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0
7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD
Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 4.0 Skin www.johnwpb.com
JohnWPB is offline   Reply With Quote
Old 01-02-2008, 12:21 AM   #9
tundra2000's Avatar
My Photos: (2)
taht would work too, clever.
Old 01-02-2008, 07:27 AM   #10
Vehicle: 91 Ford Probe
My Photos: (0)
Can't you just open a MENU with transparent .PNG-files ?
Konrad is offline   Reply With Quote
Sponsored Links
Old 01-02-2008, 08:54 AM   #11
blk02si's Avatar
My Photos: (0)
You can but the embedded application still overpowers it and comes up on top.
I installed AUtoIT last night and did all the tutorials so I am going to try that route. Its actually a very powerful program, I wish there were more tutorials. I noticed liquid smoke uses AUtoIT quite a bit in his newest release. I looked at the IGCONTROL to get a feel for what is involved.
Something tells me RR can do this somehow but at the same token I want to learn AUtoIT.
Old 01-02-2008, 12:51 PM   #12
C4DAO's CarPC Specs
C4DAO's Avatar
Vehicle: Citroen C4
My Photos: (0)
I'm sure you'll knock something up that's suitable in double quick time
C4DAO is offline   Reply With Quote
Old 01-02-2008, 09:10 PM   #13
blk02si's Avatar
My Photos: (0)
Well been hackin away at autoIT. Here is how far I've gotten:
Old 01-03-2008, 11:05 AM   #14
C4DAO's CarPC Specs
C4DAO's Avatar
Vehicle: Citroen C4
My Photos: (0)
Interesting...I take it you just need to place it further to the left of the screen and you'll have the result your looking for?
Old 01-03-2008, 05:19 PM   #15
EL CAMINO's Avatar
My Photos: (0)
wow, i didnt know how old was my AI version, i can see GDI+ is native in AI now, time to play.... a way to place your png would be reading from your .skin file. that way will be place in the right position. but if LS has this working ask him you might get some help from him.
Sponsored Links
vB code is On
Trackbacks are Off
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 05:15 PM
Paint And Polish Question gboy Fabrication 8 08-13-2005 07:22 PM
Skinning question Jackboot FP Skins 3 07-28-2005 11:57 AM
Photoshop skinning question wysocki RR Skins 4 07-26-2005 04:31 AM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 09:03 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
