Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 01-03-2008, 07:39 AM   #1
GPS Indicator not working
I try to put an GPS indicator on my skin, but I can't get it to work.
This is what I've put in my skin-file:
Code:
/, Y, Back Slider file path Y01,"gpsslider\slider_*.gif" /, x y w h x1 y1 w1 h1 O Style Pointer file path h2 Code tooltip /, --- --- --- --- --- --- --- --- - ----- ----------------- --- ----- ------- S01,671,007,028,022,661,007,028,022,H,01,"gpsslider\pointer.gif",01,GPSSIGNAL,""
Within the skin folder I have created the folder gpsslider. It contains an completely transparent pointer.gif and 20 slider files (slider_0.gif to slider_20.gif).
-slider_0 to slider_2 indicate a bad signal
-slider_3 and slider_4 indicate medium signal
-slider_5 to slider_20 indicate a good signal
The GPS signal in RR is working, I've lock to 5-6 satellites, still my skin shows the symbol for a bad signal.
Konrad is offline   Reply With Quote
Old 01-03-2008, 10:29 AM   #2
GF-ler's Avatar
Code:
first question, is the box you want to show 28x22 pixel.
why you want a pointer, who should be 1 pix high, when you split the signal into 20 screens ?
S01,671,007,28,22,661,007,28,22,H,01,"",28,"GPSSIG NAL",
thats enough.
GF-ler is offline   Reply With Quote
Old 01-03-2008, 10:41 AM   #3
Its not really a slider, but just a sattelite symbol in red, yellow and green. The pointer isn't required, but I guess you need to supply one for sliders, don't you ?
Old 01-03-2008, 10:54 AM   #4
GF-ler's Avatar
no you need no one.
dont forget the "Anführungszeichen" in front and behind GPSSIGNAL and all will work.
Old 01-03-2008, 11:03 AM   #5
Well, duh ! How could I miss this ^^ ? Ok, I'll try, thank you .
G4 GPS stopped working spiro Mp3Car Infill G4 - Double Din Car Computer 5 12-18-2007 02:23 PM
NMEA GPS not fully working stric FreeDrive 3 03-07-2006 04:25 PM
MapMonkey Gps working but not on map BOND007BE Map Monkey 8 03-11-2005 09:02 AM
Deluo Gps not working juixy GPS 9 07-26-2004 05:16 PM
Got GPS 16 working tekknikal General Hardware Discussion 9 06-16-2002 06:55 PM
