The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 01-06-2008, 07:55 AM   #1
Custommx3's CarPC Specs
Custommx3's Avatar
Vehicle: 2007 Mazdaspeed6
My Photos: (7)
Repeat/shuffle indicators
Can someone mind explaining how to add repeat/shuffle indicators?
Adding the command to a button is easy, but I cant seem to locate the command for those inidicators. Iv e searched, checked the skincommands.txt, Unless Im totally blind I cant see it. Ive searched with no luck, and even downloaded a few skins to see how, but unfortunatley most skins dont have it, or its in flash
Help would be greatly appreciated.
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Sponsored Links
Old 01-06-2008, 08:03 AM   #2
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (129)
you want a command or an indicator? Your thread is confusing. The indicators are just "REPEAT" and "SHUFFLE". You only need add them in the position of your choice to the .skin file then have your "ON" image reflect your indicator status. If you're looking for a command just use SHUFFLE or REPEAT again.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 01-06-2008, 08:12 AM   #3
Custommx3's Avatar
My Photos: (7)
ya know what..
I didnt realize that the commands were the same, just specify its an Indicator not a button!
Thanks!! I shoulda did a little harder digging i guess....
2007 Mazdaspeed 6
Old 01-06-2008, 01:12 PM   #4
GizmoQ's CarPC Specs
GizmoQ's Avatar
Vehicle: Several
My Photos: (78)
I also learned yesterday that you can define a text indicator using a label command line. If your button command is "SHUFFLE/REPEAT", you can define a label "SHUFFLE/REPEAT" and place it as your indicator. Same applies for button "SHUFFLE" - label "SHUFFLE", and button "REPEAT" - label "REPEAT".
I personally see no need for two separate buttons for shuffle and repeat so I use the combo button. The label will then toggle from OFF/SHUFFLE/REPEAT. Whereas the non combo buttons toggle OFF/SHUFFLE and OFF/REPEAT respectively.
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline   Reply With Quote
Old 01-24-2008, 06:36 AM   #5
My Photos: (12)
Can anyone explain to me how you can make an indicator work like a button?
Ie. you can click the indicator for repeat and it turns it on and lights the indicator...
I tried adding a button on top of the indicator on the skin, that didn't work it just seemed to light the indicator until another button was touched - and it didn't releate to the status of repeat in winamp..
Next I tried putting "Exec;Repeat||Repeat" in the code of the indicator - that didn't work either..
Anyone know if its possible to do ?
swift_gti is offline   Reply With Quote
Old 01-24-2008, 07:40 AM   #6
MySQL Error
My Photos: (129)
i seem to remember guino adding clickable indicators but a quick run thru skin commands.txt revealed nothing.. check the release threads from the last few months and you should see something there.
03 Acura RSX Coupe
Old 01-24-2008, 08:11 AM   #7
Vehicle: 91 Ford Probe
My Photos: (0)
Indicators are clickable.
Konrad is offline   Reply With Quote
Old 01-24-2008, 04:09 PM   #8
My Photos: (12)
Excellent, care to explain how to do it ?
I've had a look through the release notes I can find but only see the latest ones..
Cheers!
Old 01-24-2008, 04:59 PM   #9
My Photos: (0)
Just create an indicator .
I have a shuffle button and of course a shuffle indicator on my skin. It took me some time to find out, that clicking the indicator will also enable/disable shuffle .
Old 01-24-2008, 05:00 PM   #10
My Photos: (12)
Oh right! I see what you mean..
I figured that an indicator was just that.. and needed extra tweaks to work like a button!
Thanks for the pointer, i'll give it a shot when I get home
Sponsored Links
vB code is On
Trackbacks are Off
Visual indicators VS. Number indicators XxAndyxX Centrafuse 2 12-08-2006 02:46 PM
Indicators with text Chuck Road Runner 6 09-06-2006 06:19 PM
indicators with variables feature.. whats it about? Sonicxtacy02 Road Runner 11 09-06-2006 10:28 AM
Why are the direction indicators not working with RR and FD ? tolisn RR Skins 5 10-05-2005 10:34 AM
Direction indicators in flash - help pls MC_Stoo Road Runner 11 07-19-2005 07:50 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
