The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 02-15-2008, 08:07 AM   #151
fixerofallthing's CarPC Specs
fixerofallthing's Avatar
Vehicle: 2004 GMC Canyon
My Photos: (20)
Quote: Originally Posted by Machinehead View Post
Well yea, I tweaked all the skin commands to the Sirius ones. i.e. SRReload, SRFav, etc, etc, etc. That part is east and always works fine. But the sat and ter bars don't work. There must be more to it than just switching all the XMs to SRs. I'll have to do some more research.
Just a though, is there a specific path that I need to put your indicator images into?
I think just switching XM to SR should work.
From "skin Commands.txt" "SRSAT" - SIRIUS Satellite Signal Quality
"SRTER" - SIRIUS Terrestrial Signal Quality
Is the folder called slider_battery in your carwings directory? If it is not, copy it from the DFX folder to the carwings folder and that should fix it. That is the path I used for the XM signal. Do you have the recolored slider images? If you don't I will post them tonight when I get home.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Sponsored Links
Old 02-15-2008, 08:14 AM   #152
Machinehead's CarPC Specs
Machinehead's Avatar
My Photos: (0)
I have to look, but I think I'm a dummy and forgot to copy that folder into my carwings directory.
That's what I get for working on this at 5 in the morning.
Machinehead is offline   Reply With Quote
Old 02-15-2008, 08:38 AM   #153
venealis's Avatar
Vehicle: 2005 Dodge Ram "Yep it Does"
My Photos: (0)
Quote: Originally Posted by Enforcer View Post
Can you tell what it is yet?
Looks like screen lock control
venealis is offline   Reply With Quote
Old 02-15-2008, 08:51 AM   #154
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
Sort of, it's Access Control (the title in the picture kinda gives it away )
Anyway here is the main screen of Traffi Cams. It woul look nicer if we could get the floating menu over it but trouble is when it switches screens you would need to change the icons and functions in the floating menu, and traffic cams would need to be able to accept commands from RoadRunner. Hmmmmmm
Enforcer is online now   Reply With Quote
Old 02-15-2008, 09:00 PM   #155
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
Kind-a begs for those numbers to be bigger. IMO
treetop777 is offline   Reply With Quote
Old 02-16-2008, 01:12 AM   #156
blk02si's CarPC Specs
blk02si's Avatar
Vehicle: '06 Triple Black Mustang
My Photos: (0)
Looks really good Enforcer! I am very interested in the Upd8 menu.
Just so you know the floating menu is all AUtoIT. The script sends commands directly to iGuidance, it does not use RR to send the commands at all. AUtoIT is quite clever in how it can pass commands to other windows applications, so the only thing RR needs to handle is the embedding. As long as the traffic CAM app has a window title and some way of passing key strokes, mouse clicks, shortcuts, etc. to it the floating menu would work as is does in the CWiG script.
I want to add a left menu to the mixer screen, and also am going to experiment with having a float menu over the video screen.
The buttons for the #'s are much larger than the # itself.
My carPC - www.shocknet.us
blk02si is offline   Reply With Quote
Old 02-16-2008, 07:46 AM   #157
My Photos: (0)
Alright, I finally finished modifying Fixer's XM screens to Sirius. The screens are attached.
I'm going to take a run at Coverflow next.
Edit: I noticed that the date position didn't match the other screens. I fixed it.
Old 02-16-2008, 08:02 AM   #158
My Photos: (20)
That looks nice! I see you got the sat signal issue sorted out. Great Job!!
Old 02-16-2008, 08:02 AM   #159
Confusion Master
Enforcer's Avatar
My Photos: (1)
I have taken the NUMOSK graphic and and used that to keep it standard with the rest of the skin, as blk02si says the buttons extend to the lines and meet halfway between each other.
Well for it to work with traffic cams it would also need to be able to receive commands to tell it to change graphic when TC switches screen.
Here's the two screens
The first is the main camera screen (of which there are three, but the buttons on the left stay the same) then second is the search screen which has different buttons and therefore button codes, these are screens within my program not RoadRunner screens, so the floating menu would have to notified that which screen my program is in and then charge appropriately.
Old 02-16-2008, 10:00 AM   #160
My Photos: (0)
It's amazing what happens when you actually copy everything over.
All the credit goes to you, I just worked with your code.
Sponsored Links
Old 02-17-2008, 08:21 AM   #161
My Photos: (0)
Here you go; coverflow for Carwings. I haven't tested it in on my carPC yet, just on my desktop. I turned off reflections to improve performance. I also created a carwings background and deleted all the others.
If you've never used coverflow for RR before, I'd recommend reading the plugin thread by moahdib.
Enjoy!
Old 02-17-2008, 11:14 AM   #162
Confusion Master
Enforcer's Avatar
My Photos: (1)
One screen today.
Upd8 config screen.
Old 02-17-2008, 12:42 PM   #163
blk02si's Avatar
My Photos: (0)
I like the coverflow! Looks like the left buttons should be a curve menu though to fit the rest. Either way Very nice development Machinehead!
Old 02-17-2008, 12:47 PM   #164
My Photos: (0)
Thanks. I was going to make some changes to it but the flash file is locked and can't be edited. At the very minimum I was going to change the blue highlighted buttons to orange highlights. No dice though.
I'm going to play with a few other album browser options. I know not everyone can run coverflow due to how resource heavy it is.
Old 02-17-2008, 02:09 PM   #165
jonessc's CarPC Specs
jonessc's Avatar
Vehicle: BMW 320D M-Sport
My Photos: (0)
I aint too clever @ skinning... although i get the basic principles using the skin aditor, and just started using Adobe CS2
How does everyone create logos/icons on there buttons?
Like the folder icon on this image...
This skin is coming along nicely, glad to see everyone chipping in...
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Teknik v1.0 & v2.0 - RELEASED ... Valheru RR Skins 312 06-25-2008 04:26 PM
[WIP] cwings - Nissan Carwings skin for CF marazi CF Skins 14 04-07-2008 02:11 AM
Teknik v2.0 - RELEASED Valheru RR Skins 0 12-04-2007 10:22 AM
MobileWeb v1.0 for MediaCar Released stevieg MediaCar 143 06-21-2007 03:46 PM
FrodoSkinner v1.0 Released Jawbreak FrodoPlayer 21 12-30-2004 12:34 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
