Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 03-19-2008, 06:59 AM   #211
Machinehead's Avatar
I don't have radio in my setup, that's why there isn't a radio button in that menu. You can make that menu yourself with the SDK. But if I remember tonight, I'll whip up a menu for you.
Machinehead is online now   Reply With Quote
Old 03-19-2008, 12:22 PM   #212
thanks i tried to start the sdk but it dont like my vista pc so i cant change it
Xargon321 is offline   Reply With Quote
Old 03-19-2008, 08:47 PM   #213
All set Xargon. That should do it for you.
Old 03-19-2008, 08:57 PM   #214
You Are the Man!!!
Old 03-19-2008, 09:26 PM   #215
heres a quick question how do i get the hd radio to work under roadrunner?? i dont hear the relay click when i go to the hd radio tab
Old 03-20-2008, 05:45 AM   #216
You probably need to configure it, blk02si has it, I'm sure he can point you in the right direction, the other option is to search the main RR forum for information.
Old 03-20-2008, 09:51 AM   #217
treetop777's Avatar
Set the comm port is the first thing come to mind.
treetop777 is offline   Reply With Quote
Old 03-20-2008, 10:12 AM   #218
well treetop that would be nice but there is no port setting in the config prog. i found i might have to add a command to the rr.ini Hdradioport=2 or what ever poet i need ill try this and see if it works
Old 03-20-2008, 11:34 AM   #219
well got that taken care of it works on the the next thing. with is there a way to get audio stream switching within the skin? i have alot of anime that is dual audio and would like to beable to get the media player classics menus or have a decicated button to switch streams also a way to disable subtitles. also it possible to have a playlist style setup where you start one video file and it automaticly plays the next one?
Old 03-20-2008, 12:07 PM   #220
Well after messing around with the skin editor i got it to work do now i can add stuff if i figure it out.
with mpc i know the key binding to switch audio and subtitles but i dont know how to format them to use in the skin editor
i know its "sendkey" but after that i dont know
shift a
shift s
how do i format them to work when i press them in the skin?
Old 03-20-2008, 12:54 PM   #221
treetop777's Avatar
shift a
shift s
Shouldn't be that complicated, have you been here http://www.mp3car.com/vbulletin/user...les-ready.html every possible broblem with the HD radio have been discussed there. (then again, i'm assuming you have a Vestion HD Radio).
Old 03-20-2008, 02:17 PM   #222
i got the hd Radio working fine now im asking how to code shift s and Shift s as buttons in the video player skin
Old 03-20-2008, 02:33 PM   #223
Sal R.'s Avatar
"SENDKEY;+a"
"SENDKEY;+s"
nLite'd XP Pro / RR v09/10/2008 / Winamp v5.13
Sal R. is offline   Reply With Quote
Old 03-20-2008, 04:51 PM   #224
i mean somthing like "sendkey;Shift+a" is that the correct formatting?
Old 03-20-2008, 05:04 PM   #225
john05srt4's Avatar
Whenever RR starts i get a windows error that Iguidance3.0 must restart.. only with this skin..why?
My Accord CarPC
john05srt4 is offline   Reply With Quote
Teknik v1.0 & v2.0 - RELEASED ... Valheru RR Skins 407 10-05-2008 02:55 AM
[WIP] cwings - Nissan Carwings skin for CF marazi CF Skins 15 09-28-2008 08:43 PM
Teknik v2.0 - RELEASED Valheru RR Skins 0 12-04-2007 10:22 AM
MobileWeb v1.0 for MediaCar Released stevieg MediaCar 143 06-21-2007 03:46 PM
FrodoSkinner v1.0 Released Jawbreak FrodoPlayer 21 12-30-2004 12:34 PM
