Quote: Originally Posted by
Enforcer
Don't have IG but the 'floating' menu above Destinator 6 still looked cool, although it obviously couldn't control it.
If you tweak the CWiG autoit file you can send commands to Destinator, Just need to specify the window title and define the commands. I don't have Destinator to test with though but it can be done without too much coding, just switching a few lines.
brandensin
blk02, simply elegant and beautiful...
Couple of issues when i display this in 800 x 480... If this isn't meant for that resolution, then nevermind.... I'll point them out for your info anyway...
In navigation view, the left navigation menu didn't get resized accordingly...
In video, viewable area didn't get resized accordingly which makes the bottom navigation part floating about inch above from the bottom...
That's all for now..^^
Oh by the way, just for my curiosity, when i click zoom in.. it runs an extra script which I can see on the task bar.... but i don't see that when i click zoom out... It works great, just puzzles me a little bit what the difference would be..
The skin is not compatible with resizing... yet! Since the navigation pane is essentially another program, it is not aware of RR resizing. I am sure the CWiG could be coded to read the general.ini skin settings and size itself accordingly.
The extra script you see running on 'Zoom In' is the start of the button push indicators code for the CWiG script.
I've also noticed a small issue with IG while navigating, The turn by turn arrows get partially covered by the menu. Its not that big of a deal but I am going to ResHack IG some more to move the display location of those boxes, and maybe even remove the arrows from the map and place them on the skin somewhere.
Thank you all for the compliments!! I'm glad you guys are enjoying the skin! I agree it is a fresh look, and I love how much depth and dimension there is to it, espicially running it in the car on a xenarc. If possibile, can one of you guys with a g35 or maxima photograph it in the Nissan enviroment?
