02-09-2008, 12:29 AM
#31
who ever wants the script for the gps screen, i made it the way, that the text can be changed, and the 7 buttons can be set to execute any command. position and size are adjustable as well, all thru an ini file, also the iG shortcuts are now in a separate script with some more added. as i needed different shortcuts.
02-09-2008, 12:35 AM
#32
Raw Wave
really nice....
a couple of things...
1. NUMBER OF STREAMS, really subtract 1, dont ask why its +1, but when it says 3, it means there are 2 HD streams avail.
also... when i click on a preset, it saves it, i cant figure out how to get it in recall
(me dummy with roadrunner)
this interface is SO CLEAN, you did a great job... im very UI fussy
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
02-09-2008, 01:31 AM
#33
High Voltage
XM art looks great Fixer!
Quote: Originally Posted by Machinehead
Or how about the guy with the Xterra?
Heck ya an Xterra will work, just wanted to see how it looks in a Nissan interior!
Thanks again El Camino for your work on the CWiG script, I would probably still be working on it without your help
Quote: Originally Posted by mitchjs
really nice....
1. NUMBER OF STREAMS, really subtract 1, dont ask why its +1, but when it says 3, it means there are 2 HD streams avail. Ive noticed this also, seems to be a RR issue.
(me dummy with roadrunner) Just click the number and it will take you to your saved preset
mitch Thanks mitch, This means a lot to me from the creator of the HD cable. I use the HD so much now I forgot what its like not to have a high quality tuner
Quote: Originally Posted by hari-bhari
any shots of the library and audio screens? lookin goooood except maybe i would do away with the orange dots on the main screen next to the text
This can be easily done with the PSD to suit your taste. Here is a pic of the audio browser.
02-09-2008, 01:38 AM
#34
Hot skin, looks nice in the Ford, easy to use, only problem is GPS, because it does not size to the window, you can't control anything else.
Question, can you add a media copy feature (in DFX 2.0). A nice feature, I use this to copy music from my jump drive to my music and videos to my Carpc. Just a suggestion.
My Fav feature is the HD Radio Perfect, easy to control, The Best
02-09-2008, 06:34 AM
#35
Very, very nice.
One bug though - Cwig.exe does not obey the xposition setting in the skin's general.ini. I'm running RR on my laptop's 2nd monitor output and I ended up with a floating collection of button on the main window.
I realize not a lot of people are using an auxiliary monitor for their CarPC, but it's kind of nice to do all the setup/config on a regular screen, with RR on the little screen.
Anyway, keep up the good work, this is by far the best-looking skin yet.
02-09-2008, 08:20 AM
#36
Quote: Originally Posted by fixerofallthing
i worked on this a bit tonight. Which setup do you like better.
I like the first one because there is more real estate for the channel lineup and station info.
The second looks more like the FM radio screen.
Attachment 47909
Attachment 47910
I agree, first one because of more info display real estate.
02-09-2008, 09:52 AM
#37
Quote: Originally Posted by blk02si
If possibile, can one of you guys with a g35 or maxima photograph it in the Nissan enviroment?
I'll take a some photos here shortly (Maxima) and post them. It does look really nice in the interior. I've switched to this from DFX2.0. I like some of the features of DFX, but this skin is just so 'simple' and clean, as well as super fast that in my opinion there really was no choice
awsome job
:EDIT: dangit...maybe later today...can't find what my wife did with the flash card for the camera
02-09-2008, 10:54 AM
#38
High Voltage
This is really good news! Can you post up your newer script? The CWiG is a really nice menu feature that would also work on things like an embedded applications menu.
@Fixerofallthings - I decided I like the second one better because the station art is proportionate, you can tell its stretched in the first. I'm also wondering how desaturating the logos to B&W would look. Either way, thank you for tackling the XM!
02-09-2008, 11:32 AM
#39
Raw Wave
Post it post it!
02-09-2008, 11:33 AM
#40
Raw Wave
blk02si, the number of streams is NOT a RR issue, its the value that the tuner actually supplies!!! and its +1 for some reason... maybe it counts the analog, dont know... anyway... subtract 1 from it, when you display it
also, when i click on a number, it stores the preset, everytime... i can never recall
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
02-09-2008, 11:38 AM
#41
High Voltage
Thanks for the info mitch, I will see if there is a way to -1 in the code label.
The way the presets work is click and hold to set, then just tap quick to recall.
But first try deleting the skin.ini file from the skin directory, I forgot to clear out the cache in that file from my system before zipping it up. Just delete it, when you set the new presest it will generate a new skin.ini and you will be in business!
02-09-2008, 01:02 PM
#42
I have to play with my setting some more, but when I come back from hibernate the play list in MP3 mode is blank. I have to re-load the skin or exit and re-load RR to get it back.
blk02si, this got lost in the shuffle, I haven't figured out how to fix it yet.
02-09-2008, 01:06 PM
#43
High Voltage
Sorry I missed that Machinehead, I believe that is an issue with iList and hibernation, not a skin issue. I have read some other threads describing that same behavior. I can think of 2 fixes, one, remove the ilist code, or two don't hibernate. What version of RR are you running? I built Carwings on the 12-13-2007 release.
02-09-2008, 02:28 PM
#44
I'm using the 12-13-07 release. I can always add a skin reload line into my ExecTBL.ini.
Hibernate is such a PITA sometimes.
02-09-2008, 06:51 PM
#45
here we go, copy all to carwings folder, for the labels text follow the examples. is just like in a RR .skin file, just no quotes at all. i didnt add any error checking as this is not going to be adjusted every day. if wanted i can use a .skin file instead of the ini.
EDIT:for the popup that hides iG menus, you need to make one to match your skin, i included the one i been using in mine, so you can test, all works in a 800x600 for now.
| Thread Tools |
| Display Modes |
Linear Mode
