02-09-2008, 07:21 PM
#46
High Voltage
Awesome! looks great EL, only error I get is the "IG_hider" menu is off by about 30 pixels but I'm sure that can be adjusted in the CWiG.exe
Also In order for this to work properly you need a blank float_menu.png. If you just drop these files into the carwings skin it uses the float_menu in the skin that has the text already on it, and the CWiG text renders over it.
Very nice expansion though, much appreciated!
02-09-2008, 07:58 PM
#47
Raw Wave
@Blk02si
If you get a chance, could you post that blank png of float_menu, please. I saved one out from the psd but i can't seam to get it to size correctly. It don't look the same as the original even after i re-sized it from 800x600 to 504x471.
02-09-2008, 08:19 PM
#48
High Voltage
Also I noticed you have the code for the "down" button press implemented EL, can you share the button art so that we can get the press effect
02-10-2008, 12:46 AM
#49
For now I ditched the preset buttons until I can work on the art a bit.
This is what I am using for now. Please feel free to make suggestions.
02-10-2008, 01:36 AM
#50
High Voltage
Looks good Fixer!
The bars curved vertical bars seem a bit thinner but I assume you made it that way for a reason.
The menu flows much better with the skin now, the multi-color art just looked too busy IMO.
Only other thing I can suggest is perhaps go orange on the antenna level indicators, and remove the HD indicator from the top since it will never be active in XM.
02-10-2008, 02:22 AM
#51
High Voltage
@EL Camino
Started digging into your scripts a bit more and just wanted to let you know I like the way you laid it all out, very easy to customize!
Here is a screencap of my custom menu and the only issue im having, which is the 'wait' menu is off a bit. I wanted to take a look at the AUtoIT code but I cannot decompile the exe. I'm using Exe2Aut and it says only 3.2.5.1 scripts or earlier are supported. So you must be using a newer version. Perhaps you can post the au3 file so I can see if I can get the wait menu to line up.
02-10-2008, 04:28 AM
#52
Very , Very nice work just need it with green text to match ford and that would super nice  (hint, hint)
02-10-2008, 09:06 AM
#53
The only thing I would change is to find a way to squeeze in the channel art for the current channel.
Maybe replace the EQ button with that.
I also agree with blk02si, that you should change the signal meters to orange.
02-10-2008, 09:56 AM
#54
High Voltage
Green is the next color I am going to work on, my interior is also Green
02-10-2008, 10:39 AM
#55
Raw Wave
Blk - That "please wait" is off center on my test machine but it centers perfect in the truck - leave it alone and try it in your car.
02-10-2008, 11:07 AM
#56
ok, for a limited time offer heres the source, and with the pressed effect.
02-10-2008, 11:26 AM
#57
High Voltage
Thanks EL Camino, I like the addition of the "ONSKINSTART","RUNQ;$GPSPATH$" in ExecTBL, makes the transition smoother.
Your code looks tidy and organized, thanks for sharing, its helping me understand AUtoIT much better!
I am still not getting the highlight on button press though, I think im missing the press art, when you first started working on CWiG you sent me a sample that had one of the buttons working on the menu. Here is the file that you sent 'btn1.png', I assume you have 7 files, one for each button?
02-10-2008, 11:47 AM
#58
not using that, i use the labels now, is faster and use less cpu, AND the way you have the skin, the labels change color on button press, so i use that, even my via m10k has no problems this way.
02-10-2008, 01:16 PM
#59
I've started work on movie times plugin screens here is my first SS. Any comments I think the menu on the left make take up to much room not sure.
BTW the space under zip is going to show the current zip code you are searching.
Truckputer Progress
Black = Completed
Planing [----------] Buying [----------] Installing [----------]
02-10-2008, 01:33 PM
#60
High Voltage
I am also running the m10k  I compiled the au3 files from your source and it works perfect! Even the 'wait' pic is now right. Thx again EL.
Movie menu is looking good Andrew.
Here is a IG_hider that matches the skin a bit better, right click, save as
Reason: Adding ART
| Thread Tools |
| Display Modes |
Linear Mode
