The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 02-21-2008, 10:33 AM   #1
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
Change background without using xternal scripts
Ok, this is something that has bugged me for a while, and one of the reasons iDrive transparent hasn't been released yet.
I wanted a way of changing the background without
1. using an external script or program
and
2. using the picviewer skin/screen.
And also allowing for seperate picture and backgrounds locations.
I have now got it working. I think.
Note: Assumes you have a backgrounds folder in the root of RoadRunner, which is where I recommend everyone has it rather than a backrounds folder in each skin.
in exectbl.ini have the following
Code:
"ONSKINSTART","BYVAR;strt;AUDIO<<load;background.skin||SETVAR;strt;0" "TIMER","SETVARBYCODE;LISTTEXT;LISTTEXT||SETVAR;bground;$rrpath$backgrounds\$LISTTEXT$",BACKGROUND.SKIN .
in your background.skin
Code:
TMR,1 B,x,y,w,h,"PGUP","" B,x,y,w,h,"UP","" B,x,y,w,h,"DOWN","" B,x,y,w,h,"PGDOWN","" B,x,y,w,h,"SETVARBYCODE;LISTTEXT;LISTTEXT||SETVAR;bground;$rrpath$backgrounds\$LISTTEXT$||SAVETOSKIN;background;$rrpath$backgrounds\$LISTTEXT$||SETVAR;strt;1||RELOADSKIN","" SD,x,y,w,h,"$rrpath$backgrounds\","*.jpg",false S01,x,y,w,h,",255,255,255,000,000,000,000,000,000,255,255,0,TRUE,18,"Tahoma:B" I,210,050,580,360,"FILE;$bground$" .
Ok, I'll try to explain what happens
The onskinstart line is done such that if the variable strt is zero it goes to the AUDIO screen (this is of course optional and up to you, change or delete as necessary) whereas if it is 1 it goes to the background skin, this is so that once you have changed the background, the skin needs to be reloaded and if so you want to come back to the background screen.
The main button line is the one that sets the background variable in your skin.ini and also sets the strt variable to 1.
Now the TIMER sets a timer up in the background screen to set the bground variable to the currently selected file in the list.
The result of this is that every second (TMR,1) this variable is updated and list variable is used in the Indicator line to display that image.
This will not work on the last December RR release as thei is a bug in the indicator function, but should work in the previuos release (november) and the new one when Guino releases it.
If this is any good to you great, if not then sorry to have wasted your time with my inane babbling.
As a side note I also added a similar button in my picviewer.skin so that A picture from the pictures folder can be set as background.
<post subjected to editing once I have reread it a number of times to see if it makes sense>
Enforcer is online now   Reply With Quote
Sponsored Links
Old 02-21-2008, 11:24 AM   #2
Sal R.'s CarPC Specs
Sal R.'s Avatar
Vehicle: 2001 A4 1.8TQMS
My Photos: (33)
If you want to take it up a notch, I can show you how to update the the whole background.skin with the background image and skin on-the-fly so you get a fullscreen preview.
MicroXP / RR v11/04/2007 / Winamp v5.13 / MMIv2
RR Album Art Browser
Sal R. is offline   Reply With Quote
Old 02-21-2008, 06:29 PM   #3
blk02si's CarPC Specs
blk02si's Avatar
Vehicle: '06 Triple Black Mustang
My Photos: (0)
Shock V 6.x uses very similar code, and background.skin instead of picviewer.
Might want to take a gander.
My carPC - www.shocknet.us
blk02si is offline   Reply With Quote
Old 02-22-2008, 01:19 PM   #4
Confusion Master
Enforcer's Avatar
My Photos: (1)
Hmm don't tell me, I'll go and have a play.
Sponsored Links
vB code is On
Trackbacks are Off
Change Log iamgnat CarFrontEnd 12 03-19-2008 10:33 PM
Digital FX 2.0 Transparent Released JohnWPB RR Skins 3759 03-07-2008 12:23 PM
Shock Skin v3.0 Transparent Released (fast, GDI) blk02si RR Skins 145 09-09-2007 10:38 PM
Program to change background at a certain time? Telos Software & Software Development 2 04-15-2007 02:15 PM
ebay change of password cruzc_99 Off Topic 1 01-22-2002 03:43 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
