03-09-2008, 10:23 PM
#136
Vehicle: 2003 Nissan Xterra
Sweet.. thanks brewdog. I wish I knew I could do that a long time ago. Never messed around with skin editor before.. if I did I wouldn't have known what to do without that explanation.
Would it be at all possible to embed a small GPS screen in the middle along with the speed? When I say this, I mean like you can do in the Audio page.
03-09-2008, 10:33 PM
#137
^^ nevermind about the gps thing.. that'd make it cluttered. added a Nissan logo
thanks for the speedo though
03-09-2008, 11:00 PM
#138
Raw Wave
Vehicle: 01 Ford ZX3
Quote: Originally Posted by Enforcer
turn The F3kcing Volume Down
Really, I thought that it personally could have gone a little bit louder myself!! LOL
03-09-2008, 11:02 PM
#139
Confusion Master
Vehicle: 1997 BMW E36 328I
Nah!
Don't want it clashing too much with your shirt.
03-09-2008, 11:04 PM
#140
Vehicle: 93 Taurus SHO
Quote: Originally Posted by JohnWPB
Holy lemon and Cherry Batman!!!!!!!!!!!
 I thought you would like it John.
 I always get that from the old fogies  ,
winamp is like 1 notch above mute( headphones plugged in right now,so a little different settings then my car.
your welcome tigergibb, glad to help.
03-09-2008, 11:16 PM
#141
Vehicle: 2004 kia Sorento
Hey I am new and have no talent like you guys but i think i may have confirmed that the 3d logo wall clock "_Clock_B&W_Wall.swf" is closing becuase it is setup as a button click.
how i came to solution 1 renamed another clock to it and it launched that clock.. the renamed one opened up with no problems as it should. But the "_Clock_B&W_Wall.swf kept crashing or closing RR no matter what name it had.
2. i then opened up so think swf decompiler and looked at that clock and and the _Clock_B&W_Wall.swf it appears "_Clock_B&W_Wall.swf" has a button in the resource file button 41.. when clicked it closes the clock thus closing RR.. No biggie because john has provided many other choices..here is the action script in the swf file and that references button 41 "the entire clock"
"// Action script...
on (release)
fscommand("close");
Now back to fighting my winamp muting issues. Is anyone using a dell gx260.
do you put a check in ignative if using the road runner config app file. Or do you just set it in the dfx3.0 skin. I have tried both and I am getting very mad.. Iknow its possible just cant figure it out.. hmm mayble disable dualmon??
Reason: add script
03-09-2008, 11:51 PM
#142
Road Runner & Mp3car Gatherings Moderator
Vehicle: 99 Mitsubishi Eclipse
Quote: Originally Posted by nigwhyrito
I then opened up so think swf decompiler and looked at that clock and and the _Clock_B&W_Wall.swf it appears "_Clock_B&W_Wall.swf" has a button in the resource file button 41.. when clicked it closes the clock thus closing RR.. No biggie because john has provided many other choices..here is the action script in the swf file and that references button 41 "the entire clock"
on (release)
fscommand("close");
Good Find! I just removed the action script on button 41 and it is still closing for some reason. So there has to be something else in there. I just am not good at flash!
03-10-2008, 12:13 AM
#143
Vehicle: 06 accord
I need help from the seasoned road runner users.. I have the newest vesrion of rr i have flash and shockwave, i have winamp 5.13 active winamp and i have blue zx3 config file..
I had dowloaded 2.5 as test and still cannot get it to work .. so i went to 3.0
what I cant get to work is the auto mute or pause music when IG 4.0 is giving directions.
The auto switch works, the volume just fights the current song or video volume..
Question if i use dfx 3.0 should i still use blue zx3 config app. I have ig set to external i have ignative checked all 3 options checked. i have my winamp volume at 100% i have my wav volume at 60% i have adjusted the auto switch and pause in the dfx skin and in the config app. I have also adjusted the volume in IG ..
I had the same problem.
use navimon2, works the very first try.
03-10-2008, 12:31 AM
#144
03-10-2008, 12:37 AM
#145
Vehicle: 06 accord
how do I change the temperature from f to c on the system diagnostic?
I don't find anything on rr.ini and rrconfig.
03-10-2008, 01:35 AM
#146
Vehicle: 1999-5 Nissan Pathfinder XE
Quote: Originally Posted by jbradshw
Pretty cool skin - I'm not familiar with older versions but I'll most likely use this when my carPC is ready to go.
One question though - Under Weather/Live, how do I change the default location where it's zoomed to?? Everytime I move it to where I live and close RR, when I re-open it its always back over Florida. I looked around in .ini files for a possible setting but couldn't find one.
OK I found out where this setting is at - it's in the Weather_Interactive.skin file. You'll see the latitude/longitude coords in there as well as the zoom level.
I have another issue - I changed the general.ini file so the skin will show for 800x480 which works fine from what i can tell, except for one thing: The main menu buttons at the bottom, the print is too large (except for the MENU button on the far left) and part of it is displayed off of the buttons themselves. Not sure if this was supposed to get scaled down or what not. I didn't know if the font size was a RR setting or a skin setting but I looked all over the place to try and find where to change it. It seems the rest of the text in the skin at that altered resolution looks ok, though overall I'd like to lower the font size a notch or two.
03-10-2008, 02:51 AM
#147
Vehicle: 2002 BMW 535
Hi John,
congratulation, verry nice an verry good.
03-10-2008, 03:53 AM
#148
Well i know nothing about flash or any programming lang but i got it too work just dumb luck i guess
step1 okay i decompiled the swf with sothink decompiler i unchecked the button41 and then i unchecked the action script associated with button41. then exported the fla and the resource to desktop
step2 open adobe flash 8
import saved .fla
there was another instance of button41 i tried deleting that didnt work..
what worked was clicking on the btton 41 and changing the action of it.. to a graphic.
it asked did i want to lose all action script associated with it.. i clicked yes and then published as a swf file and tested in DFX3.0..
IT worked.. the clock no longer kicks me out when i click it..
Newbs luck.. anyone want the clock file..
oh and brewdog i will try navimon2 later today thanks
using Mobile Impact,Waiting on the rds radio.
Reason: express thanks
03-10-2008, 06:35 AM
#149
Raw Wave
I'd say pm john and get him the file so that on the next update it will be included. Along with some other nice things...hint...hint
03-10-2008, 07:27 AM
#150
Vehicle: 1994 Sport Trac
First thanks and a Great skin. I have every thing working but Traffic Cams 1.2.7 and just seem to be missing something. Trafficams installed in RR dir and DLL's reg.
INI file
[General]
Width=800
Height=586
Delay=60
Country=US
Skin=DigitalFX 3.0
Update=4
Xpos=50
Ypos=150
Keep getting error:
Run-time '76';
Path not found
If I change the skin to default or idrive which are in a sking dir in the Traffic Cam dir it work and used thos skins. Any ideas what I'm doing wrong. I looked at the help file in DigitalFX 3.0 but nothing in there. Any help would be great.
2004 Sport Trac PC Project.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
| Thread Tools |
| Display Modes |
Linear Mode
