Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 03-29-2008, 04:20 PM   #631
Confusion Master
Enforcer's Avatar
Not sure id this is relevant.
The other day I installed DigitalFX3.0 onto my C: drive at work.
Road runner is not installed, I just wanted to check some files so I did a dummy install.##Now today AVG decided that two files had Trojans in them and cleaned them out (no idea why it didn't do it when I installed it or until now)
the files were
movietimesnav.exe
albumviewer.exe
Now whether you AV programs spot these when you download and kill them and then the installer chokes because it expects to find them and doesn't, I don't know.
Enforcer is offline   Reply With Quote
Old 03-29-2008, 05:52 PM   #632
muldrick's Avatar
Wow, glad you posted that.
On my home PC:
OK, I deleted everything. DFX2.0, DFX3.0, and RR.
I disabled my McAfee, reinstalled RR. But it asked me to install in Program Files/RoadRunner, not Program Files/Road<space>Runner. I changed it to Road<space>Runner.
I then installed DFX3.0, and all works now. However, with the DFX install I noticed it asked to install into Program Files/Road Runner, not Program Files/RoadRunner/skins. I just clicked ok...it installed in C:\Program Files\Road Runner\skins.
I also did not get anything in my "Start> All Programs" menu. I went into the folder and created desktop shortcuts for RR and RR config.
Now...to try this on my carputer. I have no anti virus on it...different problem anyway.
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 03-29-2008, 06:03 PM   #633
muldrick's Avatar
Ya'll think I can just copy my entire RR folder to my car PC?
EDIT:
Did just that, now it works...except it won't show album art
Old 03-29-2008, 09:30 PM   #634
Raw Wave
Blue ZX3's Avatar
Let me speak up about the installer that John is using and why it defaults to only the "Program Files\RoadRunner" instead of "Program Files\RoadRunner\Skins". The main reason is because that john tries to install eveything that the skin requires to run correctly and with using the installer, you can only tell it where you want the files to be placed From Parent install folder. So if he changes the parent path to the "Program Files\RoadRunner\Skins" then he won't be able to add/install anything one directory back.
So now you all know why he has it setup this way and if you just leave it to install in all the "default" locations then you shouldn't have any problems. Just as a side note, I have been running RR w/ 3.0 from a "RR Testing" folder on my desktop at home and at work w/o any problems.
Blue ZX3 is offline   Reply With Quote
Old 03-29-2008, 09:42 PM   #635
Confusion Master
Enforcer's Avatar
Blue,
it should install to Program Files\Road Runner by default, not Program Files\RoadRunner.
It's the space which is important.
Old 03-29-2008, 09:44 PM   #636
Raw Wave
Blue ZX3's Avatar
[Edit]
"Instruction Manual"....I don't need no stink'n Instruction Manual...
Old 03-29-2008, 10:16 PM   #637
Confusion Master
Enforcer's Avatar
Actually, you're right, you Amerikans can't use stick shift
Old 03-30-2008, 03:10 AM   #638
Boooh......I've never own a Sissymatic in my life.
Dougw133 is offline   Reply With Quote
Old 03-30-2008, 07:40 AM   #639
muldrick's Avatar
... and if you just leave it to install in all the "default" locations then you shouldn't have any problems. Just as a side note, I have been running RR w/ 3.0 from a "RR Testing" folder on my desktop at home and at work w/o any problems.
I was installing it the default way, I was not changing anything during the install, it still was getting stuck at 30%.
I finally got it installed installed on my home pc by putting the files in the skin folder. I then copied the entire RR folder to my car PC.
Old 03-30-2008, 07:56 AM   #640
jumbodogs's Avatar
I justed installed DFX 3.0 on my home computer and I also noticed that AVG tagged albumviewer.exe as a Trojan Horse.
Also I was wondering if anyone is using T-Mobile cell for there interntet connection. I have it setup so I can get online and browse from both IE and Firefox but I can't update weather or get CNN podcast in DFX 3.0
My RAMPUTER
jumbodogs is offline   Reply With Quote
Old 03-30-2008, 03:23 PM   #641
Are you using folder.jpg for album art? If so, have you included *.jpg in the Album Cover File box in music settings in RRConfig?
kbreeden is offline   Reply With Quote
Old 03-30-2008, 04:12 PM   #642
muldrick's Avatar
I used Zortam to get all my album art, I could never get album art cover to work right.
I guess Zortam uses the ID3 tags?
I did have my album art showing before with the Teknik2 skin and intermittently with the DFX Beta3.
Old 03-30-2008, 04:15 PM   #643
I know it's a pain to add the art manually by using folder.jpg, but it works flawlessly.
Old 03-30-2008, 04:22 PM   #644
muldrick's Avatar
OK, so I have Sade.
I downloaded a Sade .jpg image and put it in my Sade folder. I have included *.jpg in the Album Cover File box in music settings in RRConfig. (was already there).
Still no album art
Old 03-30-2008, 04:24 PM   #645
OK, so I have Sade.
Still no album art
Rename the file "Folder.jpg"
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
laor
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
