Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Notices
Old 04-02-2008, 12:44 AM   #691
BREWDOG52's Avatar
Quote: Originally Posted by JohnWPB View Post
I'm not sure of all the specifications and such, but it appears just to be a re-branded NavTeq map set, just like iGuidance. They have skinned it, which makes it look a little different, but it appears to be running on the same exact back end as iGuidance 4.0.
Why do you think that it's a re-branded ver. of NavTeq? I couldn't find any info or good screen shots of it, just the two screen shots showing it running on a laptop.. do you have some links of better screen shots or info? Thanks John
BREWDOG52 is offline   Reply With Quote
Old 04-02-2008, 01:45 AM   #692
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
Well looking at this image, it definately looks like iGuidance, even though the small screen cap is hard to see:
But the real give-away is the small logo at the bottom of that page
Front End of Choice: Road Runner (Is there anything else??? )
& Powered by the DigitalFX 4.0 Skin
Available at www.JohnWPB.com
JohnWPB is offline   Reply With Quote
Old 04-02-2008, 01:49 AM   #693
funkyphil's Avatar
Hey guys, got a few quick questions. I just installed my Iguidance 4.0 and seems to be working ok, however got a few problems.
1. Everytime I go an click on the icon for GPS it opens GPS MAP but it is not sized correctly in DFX SKIN. I kinda thought it would be FIXED inside of the GPS PAGE. (Kinda like how when you click on music or photos or the web nothing moves just stays in one place.) So if i click by mistake just below the map window, the map window disapears and i have to reload rr all over again. John, I watched your video and in the video you say if you save the screen even if you get out of it, It will still be the same as you set it. But it doesn't stay. Did I miss something?
2. And when I click on gas prices, weather, and gauges, nothing works. Example, Gas prices will only find the nearest gas station if i put in the zip code. (WHAT IF I AM SOMEWHERE I DON'T KNOW THE ZIP RIGHT? LOL) Gauges, the compass on the gauges does nothing other then read NORTH all the time. do i need so set something for the GPS to correct this? WEATHER, at the top right of the weather, it reads GPS Weather, does this change on location of the car? I will be driving to TX in two weeks and was wondering if this would change as I drive?
Thanks if anyone can answer these questions that would be very cool!
Thanks again
Phil
funkyphil is offline   Reply With Quote
Old 04-02-2008, 03:02 AM   #694
I am still reading (Page 26) but I searched on this with no luck.
I use RDP (Remote Desktop) to configure my carpc from inside. DFX 2.0 was just fine with this but 3.0 makes it very difficult.
For instance, music browser does not display anything in the list (unless I turn iLists off). However, jukebox does nto display anything with iLists on and when I turn them off and access jukebox roadrunner freezes.
Any ideas on how I can get this to work with RDP. I love to setup and test everything that way.
Thanks, Lew
lewcamino is offline   Reply With Quote
Old 04-02-2008, 04:04 AM   #695
BREWDOG52's Avatar
oh, I missed that....but really that logo could mean anything
Old 04-02-2008, 07:18 AM   #696
I downloaded the skin
But I got some problem with the interface. The skin appears almost in white, when I move the mouse around, it start coloring the part (revealing the true color of the skin). when I click mouse it appear a red ball. When I move mouse and keep clicking it, the red ball mouse with the mouse pointer slowly with a long tail.
Why really happens here? Any ideas?
Duy Nguyen
(duyusa)
http://www.umpcbusiness.info
"Why do I have to keep learning everything since it is never enough to know anything? But because of insufficient knowledge about anything, everything needs to be learned."
duyusa is offline   Reply With Quote
Old 04-02-2008, 07:32 AM   #697
hello i want to ask you 3 questions
1. how can change the font style ?
2. how can rename to translate to greece title of the bottoms?
3. how can work the roadrunner digitalfx 3 with my voice???
thanks.
kostas_lion is offline   Reply With Quote
Old 04-02-2008, 08:53 AM   #698
Machinehead's Avatar
Thanks again
Phil
Your issue is related to embedding IG4 into RR. It's not skin specific. Do a search on IGNative.
Machinehead is online now   Reply With Quote
Old 04-02-2008, 08:54 AM   #699
It's not iGuidance, but Garmin (new PC software about to be released in a few days). Lookout iGuidance!
http://www.laptopgpsworld.com/garmin...mobile-pc.html
edit: whoops, after reading some threads back looks like you already knew that.
BlackStealth is offline   Reply With Quote
Old 04-02-2008, 08:55 AM   #700
The red ball issue is related to gestures, they can be turned off in RRconfig.
The color issue I believe is related to something not being correctly registered.
Old 04-02-2008, 08:59 AM   #701
Other than the software is Navteq which is the same thing Iguidance uses.
Old 04-02-2008, 09:00 AM   #702
the_crooked_toe's Avatar
Thanks again
Phil
1. how is it not sized correctly? can we get a screenshot. Also, John has included many different options to fit iGuidance into your screen to your liking. There is an indicator on the GPS page. Have you set Iguidance to native in RRConfig?
2. are you using XPORT or GPSGate to split your GPS ports? are the GPS ports lower than 9? make sure you are not using the same GPS port for both RR and iGuidance.
the_crooked_toe is offline   Reply With Quote
Old 04-02-2008, 09:02 AM   #703
Thanks, Lew
how about you go test inside the car now. then that will let you know that it will not work using RDP. I would use VNC if i were you. www.realvnc.com
Old 04-02-2008, 09:03 AM   #704
Good catch on that, I forgot who we were dealing with for a second there. Better post links to both while you're at it.
Old 04-02-2008, 09:04 AM   #705
update flash using Internet Explorer.
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 06:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 06:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 06:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 02:50 AM
