05-07-2008, 10:24 AM
#1051
@PontiacGA
under output are you using "Nullsoft DirectSound Output"
I don't need a line in plugin as long as I use this for output
But if I use "Nullsoft Waveout Output" then I would need it
05-07-2008, 02:07 PM
#1052
Vehicle: 2003 Pontiac Vibe GT/93 Pontiac Grand Am
Quote: Originally Posted by Machinehead
I had that problem and it was related to the sound card, which I replaced with a higher end solution.
I have limited space. I doubt a full sized sound card will fit.
Quote: Originally Posted by mnickolson
Quote from the doc's:
"The solution
It will never be possible to eliminate the delay, but... you can minimize it."
As the author of the plug-in has said there is no way to eliminate it. As in no way to fix it completely.
Edit: As I assume you are using the Linein Winamp plug-in as you posted earlier.
Yeah, read that. Well, if I cant get rid of the stupid echo.... I dont wanna my stereo to sound like a music hall that turned out bad.
Quote: Originally Posted by filjoa
Hi
what I need make for solve this problem? some one can help me please?
I *think* the solution to this is posted on the first page, second message.
Quote: Originally Posted by overlander
How is everyone browsing the web in this skin? I can't seem to find a browser in it.
You have to change one of the buttons. Just 'click' and hold the button on either of the menu's and a list of different buttons will pop up. Just choose the 'browser' button.
CWorks:I think I have to use the line-in utility, or I only get 2 speakers working.
05-07-2008, 02:32 PM
#1053
Vehicle: 1999/Nissan/Almera
Hi
but I install flash player...
now I have other problem... when start RR CPU go to 100% and dont exit ...
have some solution?
05-07-2008, 02:34 PM
#1054
Vehicle: 1994 Sport Trac
I would be curious to know which card you used as I tried 3 diffident Sound Baster card and all with the same out come. I had also tried the Wimamp plug-in and well it lasted all of 3 minutes and out it went. The delay drove me nuts.
2004 Sport Trac PC Project.
05-07-2008, 07:24 PM
#1055
Vehicle: 2004 / Acura / TL 6sp Dyanmic
Quote: Originally Posted by BREWDOG52
you have to change the menu layout to "stationary logo" ....then change the logo
Sorry for the noob question: Where can we change that??
rr.ini Checked
skin.ini Checked
VmtSquad - I sold my soul to Honda!
CarPC progress: 15%
05-07-2008, 09:40 PM
#1056
Vehicle: 2007 Gmc Yukon Xl
A question.
Is there anyway to get more room for XM channels on the XM skin.
I have 12 favorites which is what the other skin I use allows on one page without scrolling. But DigitalFX3.0 only allows 9 and you have to scroll to see the rest.
Is there anyway to have 12 showing? Maybe smaller fonts or get rid of the satellite signal bars and make more room?
Also can a clock be added in the XM skin ?
Thanks and thanks for the wonderful skin.
05-08-2008, 04:48 AM
#1057
Vehicle: 2008 Volkswagen R32
rr.ini Checked
skin.ini Checked
Settings --> DFX Skin Settings
CarPC Specs - AOpen MiniPC w/ Celeron Proc, 1GB RAM, 160GB HD, Holux Mouse GPS Receiver GR-213, Pinnacle PCTV Tuner USB, RadioShark, Dynamix 816 8" Touch Screen LCD, Carnetix CNX-P1900 DC-DC Regulator. Digital FX 3.0
05-08-2008, 09:55 AM
#1058
Would someone let me know what I'm doing wrong to get my cpu and hardrive temp to display correctly. Using speedfan and showspeedfan, I renamed my readouts per showspeedfan in the speedfan config and in the menu and menu2 skin files I changed the Temp1 and Temp2 variables as such:
F,240,413,319,73,"BDCompass.swf"
IMG,269,166,255,255,"BDLogo.png",
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT2","left"
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial", "=Computer:","right"
L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," =Interior:","right"
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT0","left"
L,0,0,0,0,#DFX1R#,#DFX1G#,#DFX1B#,0,"Arial","GPSSP D","CENTER"
Now when I run RR, the menu displays "Interior = Left Computer= Left". I'm sure this is simple, so what did I do wrong?
Thanks in advance. This skin rocks.
05-08-2008, 09:58 AM
#1059
Vehicle: 2005 Chrysler 300
Copy and paste this code and it should work.
Code:
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","SFT2",
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","=Computer:",
L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","=Interior:",
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","SFT0",
L,0,0,0,0,#DFX1R#,#DFX1G#,#DFX1B#,0,"Arial","GPSSPD",
Sorry, forgot, you can NOT justify those speedfan labels....
05-08-2008, 10:22 AM
#1060
Code:
still not working. I don't get it. should I be changing the skin in the DFX root folder, or all the skin files in the DFX\menu subfolder? I actually changed them all, and still getting "left" as a value. what would cause that?
05-08-2008, 10:37 AM
#1061
Update: Ok, it's working now. I see I had to not only change the temp1 and temp2 values, but also delete the "left" and "right" values as well. All is well. thanks alot-I knew it had to be simple.
05-08-2008, 10:42 AM
#1062
In the DFX folder is file called "SpeedFan.skin". Change your labels in there.
Don't put "LEFT" or "RIGHT" or "CENTER" after that.
05-08-2008, 11:32 AM
#1063
Hello everybody
I just like to say this is a great skin and it looks fantastic and it works excellently thumbs up to you John,
I don’t like to ask for help as the fun is to see if I can do it myself but I’m stuck I would like to get rid of that annoying ring when I get a phone call, I have looked for the sound in the skin but cant seem to find it if any one no`s where I can find it can you please let me no as it make me jump all the time I get a call.
Thank you for any help.
05-09-2008, 05:48 AM
#1064
Road Runner Moderator
Vehicle: 99 Mitsubishi Eclipse
I'm afraid I cant help with that one, as I do not use the CarPC for my phone.
It would help to know what you are using for phone though... Phoco, FreePhone, RRMobile ect.
05-09-2008, 07:47 AM
#1065
Hi john sorry I should have made it clearer I am using the free phone that is in your skin, I don’t use the carpc as my phone as I have a Nokia hands free kit which is blue tooth, the phone connects to the hands free kit and to the pc so when I get a call I can answer the call by pc or by Nokia kit, so this means I don’t need the pc to be on all the time or have RR running, I have used Steve’s (CDR)over on DC FreePhone stand alone and it dose not have that screen that comes up when you receive a call that shows a picture of who is calling so I put it down to be in the skin.
Thanks for your help
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
NIKFCSM
| Thread Tools |
| Display Modes |
Linear Mode
