The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 05-09-2008, 10:37 AM   #1066
My Photos: (0)
Hi
Sorry john I am using freephone, this dose not come up when you use the stand alone version so I put down to the skin that’s all I can think of. Ill try and put a picture up.
Thanks.....
Huss is offline   Reply With Quote
Sponsored Links
Old 05-09-2008, 11:02 AM   #1067
My Photos: (0)
I have one question.
When i try to browse music nothing shows up.My directory in RR setting is that folder but no music appears in music player.My dir is My doc and folder named music
One more.
Whats the best Win amp to use?
chvybeatsford is offline   Reply With Quote
Old 05-09-2008, 12:09 PM   #1068
Raw Wave
Blue ZX3's CarPC Specs
Blue ZX3's Avatar
Vehicle: 01 Ford ZX3
My Photos: (16)
5.13...Nothing newer, Nothing Older! Has been tested to be the most stable and most compatible with this skin..
Blue ZX3 is offline   Reply With Quote
Old 05-09-2008, 12:27 PM   #1069
dmistry's CarPC Specs
Vehicle: 2007 Honda Accord LX
My Photos: (0)
anyone think about developing a skin for Garmin Mobile PC?
My Accord 2007 install worklog
http://www.mp3car.com/vbulletin/work...e-install.html
dmistry is offline   Reply With Quote
Old 05-09-2008, 12:54 PM   #1070
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
I'm not going to be skinning the new Garmin app anytime soon, so someone else is welcome to.
Main reason it uses the same maps iGuidance uses (Provided by iNav Corp.), and iGuidance is natively supported in Road runner.
Another good reason is the Garmin app does not even have an OSK, thus not very CarPC friendly really.
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0
7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD
Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 4.0 Skin www.johnwpb.com
JohnWPB is offline   Reply With Quote
Sponsored Links
Old 05-09-2008, 01:52 PM   #1071
My Photos: (0)
Thanks........I also did a fresh install of windows so hopefully everything pans out but again thanks......
Old 05-09-2008, 02:30 PM   #1072
My Photos: (0)
Question can't get HDRadio to work in dfx 3.0 skin
hi, i tried and tried but not luck. i followed the directions on how to install dlls from mitch........... (make sure
HDRadioComm.dll
RegAsm.exe
RunMe1st.cmd
UnRegMe.cmd
are in the same directory
and run RunMe1st.cmd
this will register the .dll as a com object
and generate a .tlb for programming
a good dir is
C:\Program Files\Common\MJS Gadgets\
-Mitch i did this over and over and still no luck. i could play my visteon hd radio with the HDRadio PCR Program outside of roadrunner and dfx 3.0 skin no problem but, it won't work inside rr. What could i be doing wrong? Please Help......... Thanx a Bunch.
THEREALRAWPWR is offline   Reply With Quote
Old 05-09-2008, 02:37 PM   #1073
My Photos: (0)
OK still the music browser shows no music......Im missing something i jus know it
Old 05-09-2008, 02:41 PM   #1074
DaveDog's CarPC Specs
DaveDog's Avatar
Vehicle: Baja 302 Compensator
My Photos: (1)
did you set the audio file types in rrconfig?
you need to add at least .mp3
Why is my laptop all wet?!
DaveDog is offline   Reply With Quote
Old 05-09-2008, 02:49 PM   #1075
DaveDog's Avatar
My Photos: (1)
HDRadioComm.dll
RegAsm.exe
RunMe1st.cmd
UnRegMe.cmd
a good dir is
check your rr.ini file for radiomode=8 and hdradioport=? (whatever port # you are connected to)
Old 05-09-2008, 03:24 PM   #1076
My Photos: (0)
Yes its set. The only way to get anything to play is if i open win amp before RR and move files into there then open RR i can play the files but browser still empty.
Old 05-09-2008, 03:24 PM   #1077
My Photos: (0)
Question HDRadio still won't work.......
hi, davedog thanks for helping but i still can't get hdradio to work. this is whats in my rr.ini file - [Radio]
radiomode=8
allowallfreqs=true
radiatorpath=C:\Program Files\Radiator\
radioline=1
uselineinplugin=true
lineinpar=line://title=Radio,srate=44100,bps=16,nch=2
resetradio=
userbds=false where is hdradioport= ? it's not in the rr.ini file .i did everything i was suppose to do right? i was wondering if you could type down in easy to do steps on how you made hd work . as i said it works ok outside rr and dfx 3.0 . i need this to work i don't want to use radiator and d-link radio anymore which suck ***. thanx again.
Old 05-09-2008, 03:28 PM   #1078
hailrazer's CarPC Specs
hailrazer's Avatar
Vehicle: 2007 Gmc Yukon Xl
My Photos: (0)
I have come to the conclusion that there is a configuration problem somewhere in the DigitalFx Hd Radio skin.
I can get HD radio to work perfect in every skin I try EXCEPT the DigitalFx 3.0 skin.
Must be a problem with certain settings. I'm running Vista so that may be a problem also.
My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
hailrazer is offline   Reply With Quote
Old 05-09-2008, 03:35 PM   #1079
DaveDog's Avatar
My Photos: (1)
radiomode=8
allowallfreqs=true
radioline=1
resetradio=
add the line
hdradioport=x
to the rr.ini file. this needs to be done manually, x= the com port number, i.e. 3
my rr.ini file reads as follows
[Radio]
radiomode=8
allowallfreqs=false
radioline=5
userbds=false
hdradioport=3
Old 05-09-2008, 03:44 PM   #1080
utd09bry's CarPC Specs
utd09bry's Avatar
Vehicle: 2002 Ford Explorer
My Photos: (12)
yeah you need to add the hdradioport line... its not automatically there.
utd09bry is offline   Reply With Quote
Sponsored Links
Currently Active Users Viewing This Thread: 6 (5 members and 1 guests)
docbreezy, figfry, GF-ler, Ramanator, swj123
vB code is On
Trackbacks are Off
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
