The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 05-14-2008, 04:32 PM   #1111
MGD
MGD's CarPC Specs
MGD's Avatar
Vehicle: 2005 Chrysler 300
My Photos: (0)
Look in your RR.ini file for those lines.
[Radio]
radiomode=8 >>HDRadio
hdradioport=1 >> Your Com Port
allowallfreqs=false
radioline=3 >> Line In or CD Volume
userbds=true
MGD is offline   Reply With Quote
Sponsored Links
Old 05-14-2008, 04:47 PM   #1112
My Photos: (0)
Also, if you use iGuidance, it lowers your line-in volume to 0 for some reason (I started a thread on that problem). So make sure that your line-in volume is correct.
Dgege is offline   Reply With Quote
Old 05-14-2008, 05:48 PM   #1113
randyre's CarPC Specs
My Photos: (0)
DFX3 and MP3/Radio display data at top of screen
When I change to another screen from say radio, to GPS, the status screen at the top still shows the last MP3 I was playing even though I'm on the radio, I would like it to show the current station along with the RBDS data instead, Is this possible?
BTW, HD radio works great and rocks!, as well as does this skin.
randy
randyre is offline   Reply With Quote
Old 05-15-2008, 05:37 AM   #1114
Cob94500's CarPC Specs
Vehicle: 1998/Ford/Fiesta
My Photos: (0)
Lyrics
How does it work? I've already embed lyrics in my songs. and now?
Cob94500 is offline   Reply With Quote
Old 05-15-2008, 06:09 AM   #1115
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
Unfortunately that is the way the plugin works. It only displays the information on the HD Radio skin.
You should be able to just click the song name in any of the skins, and then click lyrics at the bottom.
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0
7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD
Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 4.0 Skin www.johnwpb.com
JohnWPB is offline   Reply With Quote
Old 05-15-2008, 11:16 AM   #1116
Pseudo Nim's CarPC Specs
Vehicle: Impreza 2005 Wagon
My Photos: (1)
Hey all,
Having a strange issue. Searched the thread, but don't seem to be an answer for this. Basically, I get no MP3s in the music browser. Nor do I get any directories. Nor does the playlist window work (and it locks up if I use it). If I switch to the BMV2 skin, I have no problem picking music etc. If I then switch back to DFX3, it _has_ the playlist and it _will_ play music but if I go to the Audio Browser, the screen will be empty; and if I go to the Playlist Editor, the controls stop responding and I can't click anything anymore.
Anybody encountered this?
-pN
Doko ni datte, hito wa tsunagatte iru...
My Subaru Impreza install (now fully RAAMmatted!)
Realtime audio freestyle hiphop battles online - www.letsbeef.com!
Make beats? Know Rockwilder? Battle him! www.rocbattle.com.
Pseudo Nim is offline   Reply With Quote
Old 05-15-2008, 11:19 AM   #1117
My Photos: (0)
Quote: Originally Posted by Pseudo Nim View Post
Hey all,
-pN
Probably a problem with iLists. Disable that and check if it works. If so, then make sure you isntalled DirectX and the latest drivers for your video card. I had the same problem (I hadn't installed DirectX).
Old 05-15-2008, 11:57 AM   #1118
My Photos: (1)
CDMA Phone/Dial Up Network support?
I have been using a CDMA phone for my internet access. Any way or maybe in the next release to support the connection? ie. A connect and disconnect button/screen? Thanks a lot...
Dougw133 is offline   Reply With Quote
Old 05-15-2008, 12:24 PM   #1119
My Photos: (1)
I'll take a look. Should have DX installed.... then again, I'm running TinyXP so who knows. Is iLists a separate plugin I should install btw? For some reason I thought that was part of everything, but if it's not, oh boy will that be silly
Thanks!
-pN
[EDIT] Just reinstalled DirectX and checked for updated drivers - no luck. Turning off iLists fixes everything, but I kind of like the idea (I don't know what they do, just suspecting).
Any ideas why iLists might be broken? I did a full install of Winamp 2.95 with RR.
[EDIT #2]: After having found this post, I turned off ID3 tags, and now things work fine. Looks like it was related.
Thanks!
[EDIT #3]: Very weird. Still, in some places, the skin stops responding to mouse control. I just went to Task Manager, and in the window that popped up, I couldn't click on anything, and I had to use Windows Key + Shutdown + Reboot to get something back. Anybody seen something like this happen? I'm a bit worried how the car will perform, seeing as I don't have a keyboard handy....
Old 05-15-2008, 12:43 PM   #1120
My Photos: (0)
OK, sort of got this fiured out, I was able to cut and past and modify from the radio skin, but this all makes it real permamnent. Is there any way for it to use a variabe and know weather its an MP3 or the radio playing and use the proper display?
Sponsored Links
Old 05-15-2008, 01:10 PM   #1121
MGD
MGD's CarPC Specs
MGD's Avatar
My Photos: (0)
I don't have that poblem with my skin as it displays the the radio frequecy and the station name in the GPS screen when I play radio. If I switch to Audio and then to GPS it shows the trackname of the mp3 file playing.
Open up skin editor and select the External_Music_Gps.skin and change the top line from
"/ ||TAGARTIST||= - ||TAGTITLE||=" to
"TRACKNAME", then it displays the radio frequecy and station name while playing radio.
Old 05-15-2008, 01:52 PM   #1122
My Photos: (0)
OK, got it working!. added the folowing lines in place of all the county, city zip code stuff. since I could not get it to display anyhow.
L03,89,4,498,34,#DFX1R#,#DFX1G#,#DFX1B#,19,"Arial" ,"TRACKNAME","SCROLL-LEFT"
L03,70,30,763,27,#DFX1R#,#DFX1G#,#DFX1B#,12,"Arial ","BYIND;HDACTIVE;RDSTEXT<<HDARTIST1||= - ||HDTITLE1" ,"SCROLL-CENTER"
L03,84,45,766,27,#DFX1R#,#DFX1G#,#DFX1B#,12,"Arial ","BYIND;HDACTIVE;=<<HDARTIST2||= - ||HDTITLE2" ,"SCROLL-CENTER
Now I get the radio station and RDBS data while in GPS mode. Now to go bac and fix the menu.skin file to do the same.
Thanks for the help. Now if I could just get the radio to come back on by itself.
Old 05-15-2008, 05:40 PM   #1123
My Photos: (0)
Hi all ,Thanks for everything ,I have everything up and running great! But i have just 2 questions - (1) when I open Xport window it shows at the bottom like it's scanning but never stops,is this normal? My input line is #3 and my outputs are #5,6. and it shows that #5 is checked(dot) but not #6,why? is this normal also? - (2) i notice my red led light on my GPS usb unit keeps on blinking when i shut off or hibernate my carpc.is this normal? Thanks again.........
THEREALRAWPWR is offline   Reply With Quote
Old 05-15-2008, 07:51 PM   #1124
utd09bry's CarPC Specs
utd09bry's Avatar
Vehicle: 2002 Ford Explorer
My Photos: (15)
Just means your motherboard is still supplying it with power to operate. Depending on your power supply and shutdown controller, it should either turn off after a minute (or any other specified time period) or only shut down if it detects a low battery situation.
utd09bry is offline   Reply With Quote
Old 05-15-2008, 08:15 PM   #1125
My Photos: (0)
ok utd09bry,where do i find these settings? i own a via MII10000 Board....... also anyone know the answer to #1 question???..............
Sponsored Links
vB code is On
Trackbacks are Off
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
