05-16-2008, 09:50 AM
#1141
Vehicle: 2005 Chrysler 300
If you have iG4 then you have the UMPC version already, as it comes with the regular version, the UMPC version and the Pcket PC version.
05-16-2008, 09:52 AM
#1142
Vehicle: Impreza 2005 Wagon
In the Speedfan skin, half of the time the font seems to be "Arial" and the other half, "Ariel". Is that normal?
05-16-2008, 10:04 AM
#1143
Vehicle: 2004 / Acura / TL 6sp Dyanmic
Thanks MGD, i'll go ahead and get the 4th version !!!
VmtSquad
#1144
I am preaty sure that this is a spelling error as windows does not have the ARIEL font and will default to ARIAL. Just change it in the skin to ARIAL.
05-16-2008, 10:06 AM
#1145
Quote: Originally Posted by treetop777
It's best to try to go by the instructions in the help file and if you get stuck, then ask specifics.
Quote: Originally Posted by VmtSquad
So I basically need to download the UMPC version or is there a simple patch that we can install ??
When you install iGuidance, you have a choice whether to install Desktop, CarPC, Laptop. You want to choose CarPC.
05-16-2008, 10:31 AM
#1146
Yeah I did choose CarPC during install, but I have the IG3 version, does it make a difference??
I'll try to find the 4th version and give it a try !
Thanks guys!
05-16-2008, 04:09 PM
#1147
album art?
How and where do you get the album art like shown here in your pictures of the skin?
I have tried to DL a program for album art but it didnt work. Im thinking about switching skins I havent had much luck with this one. Im just not sure how to do that...
05-16-2008, 04:22 PM
#1148
Vehicle: 1981 Ford F-100
DL Tag&rename; you'll have 30 days to get your collection done. You can either embed the art into the track itself or place a jpg in a folder with the tracks.
05-16-2008, 07:43 PM
#1149
Album Art Aggregator is freeware and works well enough.
05-17-2008, 09:39 AM
#1150
Vehicle: 2001 Audi TT 225 QC
Quote: Originally Posted by JohnWPB
Nice install tabamoura! Unfortunately the fonts are not scaling correctly in Road Runner. Road Runner is scaling everything else correctly, but not the font sizes for some reason. The skin was created to work at an 800 x 600 resolution, and the fonts just do not scale to the correct location at non standard resolutions. (640 x 480, 800 x 600 & 1024 x768 all work correctly)
John , I'm using 800X600 . I found out my problem wat that I had the fonts DPI size set to 120 instead of the Normal 96 under the "display properties " " settings" and "advanced " .
Fabio
Vectra E-pc 42 Pentium 1.6 ,512 Ram, 100G HD
Road Runner by Guino with Digital FX by JohnWPB
Belkin 100m BLuetooth adapter
linksys G uSB adapter
Iguidance with clear ( Street and Tips ) pharos receiver
05-17-2008, 02:15 PM
#1151
Ok I finnaly got the iGuidance 4 and it works like a charm, im speechless lol...
Then again I got another question regarding the GPS data. Im using Xport to split my COM ports and it works perfectly. Where can we specify the COM port for the GAUGES page? I checked the help file but I didnt get it to work!
Thanks for help!
VmtSquad - I sold my soul to Honda!
CarPC progress: 15%
05-17-2008, 02:20 PM
#1152
Raw Wave
Vehicle: 01 Ford ZX3
That gauages screen uses the GPS data from RR. If that is not working then RR is not receiving the gps data. Recheck your RR/xport settings
05-17-2008, 02:36 PM
#1153
I understand that, my COM port is set in RRconfig and my GPS is working flawless. I get all the data in the GPS info without efforts. But when I go in Gauges....nothing.
Xport config
GPS pluged in COM3 (XPORT Input)
Enabled ports Output
COM4 -- for iGuidance program (working)
COM6 -- for RR (working without Gauges)
COM7 -- free
Anybody know why my GAUGES still doesnt work even if my GPS is working in RR ??
Thanks again!
CarPC progress: 15%
05-17-2008, 02:56 PM
#1154
Hi again,thanks everyone here for all your help.but i still have issues. I have iGuidance working great but when i turn on carpc from hibernation the GPS does not seem like it's working (direction pointer not green) an gauges not doing anything either. plus my mp3's won't play at all. after reboot ,everything is back to normal.is there something i'm missing here in setup? also i notice that my gps receiver stays blinking (red led indicator) after i hibernate or shut down pc.Is this normal ? The red led indicator should stop blinking right? I asked this before but.......
05-17-2008, 03:04 PM
#1155
Raw Wave
You might want to try and older version of xport, some versions work better for some than other versions.
And you GPS receiver is fine if it still blinks after you hib, this just means that it is still being powered and has sats locked, it doesn't req that much power at all, so don't really worry about it draining anything. It also helps when you come out of hib as it won't be a cold start to lock sats either.
| Thread Tools |
| Display Modes |
Linear Mode
