Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 05-24-2008, 07:27 PM   #1201
Thanks man ...I found it.
cameronlazzari is offline   Reply With Quote
Old 05-25-2008, 12:59 PM   #1202
john05srt4's Avatar
GREAT SKin.. thank you very muuch..
But on the VIDEO player how to i change the RIGHT and LEFT buttons to change to next video or back a video not just a 5 sec jump?
Basically instead of fast fwd to next video?
My Accord CarPC
john05srt4 is offline   Reply With Quote
Old 05-26-2008, 11:09 AM   #1203
VmtSquad's Avatar
SEARCH IS YOUR BEST FRIEND!!!
Post : #847
Keep on searching!!
Vmt
VmtSquad is offline   Reply With Quote
Old 05-27-2008, 06:27 AM   #1204
I am having some problem getting some of the 3D logos to work, I have the latest flash player installed but some 3D logos such as the Mazda Nissan2 and a few others Do not work any help appreciated.
itech is offline   Reply With Quote
Old 05-27-2008, 09:22 AM   #1205
I upgraded DFX 2.0 to DFX 3.0 but for some reason I'm seeing it's running slower (lagging). Anyone else have the issue?
Also, is there a way to change the font to White just like the DFX 2.0?
sonvan is offline   Reply With Quote
Old 05-27-2008, 12:03 PM   #1206
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
It should be running the same, as there really is nothing CPU wise that should change between 2.0 and 3.0.
To change the font color, go to Settings, DFX SKin Settings, Change skin colors. Then pick a color, and click the "Change font color" button.
Front End of Choice: Road Runner (Is there anything else??? )
& Powered by the DigitalFX 4.0 Skin
Available at www.JohnWPB.com
JohnWPB is offline   Reply With Quote
Old 05-27-2008, 10:59 PM   #1207
JohnWPB's Avatar
In case anyone did not see it, check the stickies at the top of the RR forums. A new beta has been released that fixes the weather.
Old 05-27-2008, 11:04 PM   #1208
is it possible to embed 2 GPS apps into the skin? For example, I use iGuidance most of the time, but I'm also trying out Garmin MobilePC as well. Garmin needs a larger screen area to play with as compared to iGuidance.
What I was thinking was using the iGuidance_wide skin only without the top set of buttons (forgot what those were atm). None of the iGuidance buttons work for Garmin anyway so basically a bottom row of buttons to go back to the main menu and for music control.
This possible? Point me in the direction of how/where to do it? I tried messing around in the new skin editor .71 but Vista is giving it the beat down so I'm loading XP in a virtual machine to mess with it.
thanks,
nst6563 is offline   Reply With Quote
Old 05-27-2008, 11:37 PM   #1209
There is something really wrong. it may be my setup because I went ahead and uninstall RR, uninstall DFX, removed all files and reinstall RR and DFX3 and it's still lagging. When I revert back to DFX2 it's all good
Really weird.
Old 05-28-2008, 02:39 AM   #1210
Same here. In DFX3 i can push a button and it may or may not work. Especially on the GPS wide screen. If I use DFX2 I do not seem to have this problem. It's to the point of, I may just start using DFX2 again.
kyjoe is offline   Reply With Quote
Old 05-28-2008, 06:56 AM   #1211
Machinehead's Avatar
thanks,
There was a thread on this a little while back; http://www.mp3car.com/vbulletin/road...setup-but.html
Machinehead is offline   Reply With Quote
Old 05-28-2008, 08:06 AM   #1212
damn... must not have searched with the right keywords
Old 05-28-2008, 08:19 AM   #1213
No biggie. That doesn't solve the issue of how to implement it in DFX though.
Old 05-28-2008, 11:49 AM   #1214
So I've created new .skin files (Garmin_WIDE.skin - based loosely off the IGuidance_WIDE) which allow more screen area for the Garmin app. Also removed the buttons which don't offer any function to Garmin (which was basically all of them for now). Edited the exectbl.ini with the following lines (section listed above the line):
/----------------- Dynamic Menu Buttons -----------------------
/ RR Command to execute when button is pressed
"MyApp48","Load;Garmin_WIDE.skin;Garmin;C:\GarminM obilePC\Que.exe;Garmin"
/----------------This is the label that is displayed on the Main Menu Buttons ----------------
"SetAppLabels","SETVAR;ButtonLabel;=MUSIC<<=RADIO< <=VIDEO<<=DVD<<=XM<<=SIRIUS<<=PHONE<<=UTILITIES<<= RIP CD<<=TV<<=WEATHER<<=PICTURES<<=GAMES<<=GAUGES STATS<<=BROWSER<<=SETTINGS<<=GPS<<=GPS<<=GPS<<=GPS <<=GAS PRICES<<=CAMERA<<=TRAFFIC CAMS<<=CALENDAR<<=MEDIA COPY<<=COLORS<<=LOTTO<<=NET RADIO<<=RADAR<<=SCANNER<<=HD RADIO<<=LAUNCH<<=SKINS<<=SYS DIAG<<=G. EARTH<<=Lyrics<<=JUKEBOX<<=TASK MAN<<=G MAPS<<=THEME<<=WIRELESS<<=THEATERS<<=RRMEDIA<<=CNN NEWS<<=DAYTIME<<=GPS<<=CLEAN SCREEN<<=Garmin"
/ These are the labels for the application that will show
/ up on the screen that gives the selection of buttons to choose from
"SetCommandLabels48","SETVAR;MyApp48LB;Garmin||Set CommandLabels49"
however being the total noob to skin editing whenever I run RR and make a button for Garmin and then push said button, it loads the skin editor...
clues? Garmin seems to embed fine...I've just run into a road block with this skin editing issue.
:EDIT: Nevermind...I got it
I'll post a screenshot in a few
Screenshot as promised:
Old 05-28-2008, 12:28 PM   #1215
[EDITED By JohnWPB Removed quote of the entire first post in this thread]
John,
I am trying to get freefone to work with my motorola q. I am on Verizon. I have a bluetooth dongle that goes through Widcomm's audio gateway. Is there a way to change the comport on freefone? Also what other things do I have to do to get it to work?
Thanks,
Cameron
Last edited by JohnWPB; 05-28-2008 at 02:33 PM. Reason: Removed the quote of the ENTIRE first post of this thread!
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
