05-09-2008, 10:37 AM
#1066
Hi
Sorry john I am using freephone, this dose not come up when you use the stand alone version so I put down to the skin that’s all I can think of. Ill try and put a picture up.
Thanks.....
05-09-2008, 11:02 AM
#1067
I have one question.
When i try to browse music nothing shows up.My directory in RR setting is that folder but no music appears in music player.My dir is My doc and folder named music
One more.
Whats the best Win amp to use?
05-09-2008, 12:09 PM
#1068
Raw Wave
Vehicle: 01 Ford ZX3
5.13...Nothing newer, Nothing Older! Has been tested to be the most stable and most compatible with this skin..
05-09-2008, 12:27 PM
#1069
Vehicle: 2007 Honda Accord LX
anyone think about developing a skin for Garmin Mobile PC?
05-09-2008, 12:54 PM
#1070
Road Runner Moderator
Vehicle: 99 Mitsubishi Eclipse
I'm not going to be skinning the new Garmin app anytime soon, so someone else is welcome to.
Main reason it uses the same maps iGuidance uses (Provided by iNav Corp.), and iGuidance is natively supported in Road runner.
Another good reason is the Garmin app does not even have an OSK, thus not very CarPC friendly really.
05-09-2008, 01:52 PM
#1071
Thanks........I also did a fresh install of windows so hopefully everything pans out but again thanks......
05-09-2008, 02:30 PM
#1072
can't get HDRadio to work in dfx 3.0 skin
hi, i tried and tried but not luck. i followed the directions on how to install dlls from mitch........... (make sure
HDRadioComm.dll
RegAsm.exe
RunMe1st.cmd
UnRegMe.cmd
are in the same directory
and run RunMe1st.cmd
this will register the .dll as a com object
and generate a .tlb for programming
a good dir is
C:\Program Files\Common\MJS Gadgets\
-Mitch i did this over and over and still no luck. i could play my visteon hd radio with the HDRadio PCR Program outside of roadrunner and dfx 3.0 skin no problem but, it won't work inside rr. What could i be doing wrong?  Please Help......... Thanx a Bunch.
05-09-2008, 02:37 PM
#1073
OK still the music browser shows no music......Im missing something i jus know it
05-09-2008, 02:41 PM
#1074
Vehicle: Baja 302 Compensator
did you set the audio file types in rrconfig?
you need to add at least .mp3
Why is my laptop all wet?!
05-09-2008, 02:49 PM
#1075
HDRadioComm.dll
RegAsm.exe
RunMe1st.cmd
UnRegMe.cmd
a good dir is
check your rr.ini file for radiomode=8 and hdradioport=? (whatever port # you are connected to)
05-09-2008, 03:24 PM
#1076
Yes its set. The only way to get anything to play is if i open win amp before RR and move files into there then open RR i can play the files but browser still empty.
#1077
HDRadio still won't work.......
hi, davedog thanks for helping but i still can't get hdradio to work. this is whats in my rr.ini file - [Radio]
radiomode=8
allowallfreqs=true
radiatorpath=C:\Program Files\Radiator\
radioline=1
uselineinplugin=true
lineinpar=line://title=Radio,srate=44100,bps=16,nch=2
resetradio=
userbds=false where is hdradioport= ?  it's not in the rr.ini file .i did everything i was suppose to do right? i was wondering if you could type down in easy to do steps on how you made hd work . as i said it works ok outside rr and dfx 3.0 . i need this to work i don't want to use radiator and d-link radio anymore which suck ***. thanx again.
05-09-2008, 03:28 PM
#1078
Vehicle: 2007 Gmc Yukon Xl
I have come to the conclusion that there is a configuration problem somewhere in the DigitalFx Hd Radio skin.
I can get HD radio to work perfect in every skin I try EXCEPT the DigitalFx 3.0 skin.
Must be a problem with certain settings. I'm running Vista so that may be a problem also.
05-09-2008, 03:35 PM
#1079
radiomode=8
allowallfreqs=true
radioline=1
resetradio=
add the line
hdradioport=x
to the rr.ini file. this needs to be done manually, x= the com port number, i.e. 3
my rr.ini file reads as follows
[Radio]
radiomode=8
allowallfreqs=false
radioline=5
userbds=false
hdradioport=3
05-09-2008, 03:44 PM
#1080
Vehicle: 2002 Ford Explorer
yeah you need to add the hdradioport line... its not automatically there.
| Thread Tools |
| Display Modes |
Linear Mode
