The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 03-07-2008, 11:00 AM   #1
Road Runner Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
DigitalFX 3.0 [Released]
DigitalFX 3.0 Skin is FINALLY released after almost a 2 month delay! (See Post #2 below for Frequently asked questions and solutions)
I hope to have a video up of the skin going through some of its features here soon.
Literally countless hours have went into creating this skin! If you use the skin, a donation in any amount is greatly appreciated, but of course is not mandatory. Again, it is just greatly appreciated
Many MANY thanks to the people who have made donations, it is VERY much appreciated!!!!!!!!!!!:
kbreeden(x3), Dave, AfterDigital(x2), Arnis, K&M, SteveC, DeadlyAP1(x2) , Jarred(x2), Damien, jmciver, swwesq, Volsfan(x2 + a Fusion Brain!) ,klundy(x2),Dan, Jarred(x2), jjnit, Tabamoura,
Abertano, Nasa, sentiensx Treetop777, Grahm, gkapog, Felix509, Mtnet2000, Smitty0881, INH, TechsatHome, swwesq che420H, chgrec, barnyard, TimmyM, Carputer1, KShoes, cherrybomb, sprungjeep, ckny & spongerd82, Jarred, DaveDog(HD Radio Donation!), ToNNo, digeratix, LookAtTheCat,wingnut75,Charly, vicky_obee, Ralphie, Esko, gla502, 2 girls one cup, morpheus2010, japeeler, devin98 and kegbus
Sorry, from the PayPal emails, I do not know some of your screen names on the forums, if you want me to replace your name with you screen name on the forums, just drop me a PM.....
You can Download the skin at JohnWPB.com
Main Menu with Visualizations turned on:
Current Weather:
Audio Player
Audio Rating
Gauges & GPS Status
iGuidance Full Screen with the overlayed button to switch back to standard view
Vehicle Maintenance to keep track of oil changes, tire rotation ect
Main Skin Settings to change color, backgrounds, font colors, and ilist preferences
Weather Live map that is draggable and zoomable
HD Radio Skin. Top Right shows HDRadio is active, meaning you are listening to a station that is broadcasting HD. Status shows that Sub Chanel 1 of 3 is playing. To change Sub Channels, click the Sub 1-6 buttons lower on the screen.
"Save Title" will save the name of the currently plynig song (If the stations transmists the RDS signals) to a text file you can review later to purchase that song.
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0, 7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 3.0 Skin
http://www.johnwpb.com
JohnWPB is offline   Reply With Quote
Sponsored Links
Old 03-07-2008, 11:03 AM   #2
JohnWPB's Avatar
My Photos: (0)
FAQ Frequently Asked Questions (FAQ)
Question: System appears to hang with 3D logo's, Clocks, Color Changer, and/or there is a white Background where flash objects should be, whats wrong?
Solution: Download This file from Adobe.com, then close all web browsers and run it to install the latest flash files.
Question: The wireless manager skin is not showing anything, or information is incomplete or incorrect, how do I fix this?
Solution: you have to be using the windows wireless manager. Many WiFi cards come with their own software. Just uninstall the software, and only install the drivers for your card. You can try using add/remove programs to remove the manufacturer provided drivers. If all else fails, remove the wireless software from the manufacturer, and the wireless device in device manager, then unplug it. Plug it in, and windows will then prompt you for the drivers. Insert the CD and windows will install the drivers to enable the device. If the CD auto runs, and tries to install their software, just cancel it.
Question: Do I need to uninstall DigitalFX 2.0 before installing 3.0?
Solution: It is recommended you leave 2.0 installed, to refer back to for settings and such that you may have made. Both can reside as separate skins on the same system, and you can easily switch back and forth.
Question: How do I change the buttons on the main menu?
Solution: Press and HOLD one of the menu buttons. You will then have 2 screens of choices that you can assign to that button.
Question: I do not see a list of music files, logos or other lists in the skin, whats wrong?
Solution: Go to the settings skin, digitalFX skin settings, and turn off iLists. about 1 out of 10 systems have issues with using the ilists.
Question: How can I have a music CD or DVD start when it is inserted in the drive automatically?
Solution: Open the skins/DigitalFX 3.0/Scripts folder and find the AutoLaunch.ini file. Open it in notepad. Change the drive letter to your CD.DVD Drive. Now, when you insert a CD/DVD in the drive it will automatically play. When ejected, it will resume the song you were listing to, at the position it was at before you inserted the CD.
Question: How do I change the default location where it's zoomed to, and the zoom level?
Solution: This has to be done manualy (for now at least) Open the Weather_Interactive.skin in notepad, and find this line:
F,-14,-15,839,541,"WeatherMap.swf?&lat=26.61&long=-80.12&viewPortWidth=830&viewPortHeight=550&initialWeath erLayerType=radar&initialZoomLevel=8&wxAnimateOnStart=true"
Change the &Lat= &long= values (Bolded above) to your lat and lon. Optionally you can play with the zoom setting on the end of the line, to change the level the map is zoomed when you open it.
Question: How do I change the icons displayed on the main menu screens?
Solution: Simply open the Road Runner/Skins/DigitalFX 3.0/Menu Icons folder, and replace any of the PNG's with your custom icons. Make sure to use the same name for the icon you are replacing.
Question: I Don't have a temperature board on my CarPC. How can I remove the labels from the top of the main menu?
Solution: Open the Menu.skin, and Menu2.skin files and remove the following lines:
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP2","left"
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial", "=Computer:","right"
L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," =Interior:","right"
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP1","left"
NOTE: This must be done in all skins in the DigitalFX 3.0/Menus folder or when you change the menu layout, your changes will be overwritten.
Question: The Internet radios is not working, What do I need to do?
Solution: You need to associate your MP3 files with Winamp in windows. Also make sure you have a decent speed Internet connection.
Question: Why are the Traffic Camera's and CDRip screens black?
Solution: These are external plugins, and do not support transparency.
Question: How do I get the lyrics to display in the skin?
Solution: The Lyrics need to be embedded in the actual MP3 file's ID3 Tags. Use a program like Zortam to look for the lyrics on the net, and embed them in your files. There is also a small free program a member on thh forums wrote here, its not perfect, but it does a pretty good job.
Question: My HDRadio will not work with the DigitalFX skin, whats wrong?
Solution: I have been told by at least 10 people that the HD Radio Skin in DigitalFX 3.0 works well for them (And works here as well), so I know its nothing to do with the skin at this point. It has to be a setting or hardware problem somewhere. This is unfortunately not a skin related issue, and thus nothing I can really do to help. You can check this thread for problems and solutions from other users.
Old 03-07-2008, 11:04 AM   #3
JohnWPB's Avatar
My Photos: (0)
Exclamation Reserved
Reserved
Old 03-07-2008, 12:25 PM   #4
wingnut75's CarPC Specs
wingnut75's Avatar
Vehicle: 2002/Ford/F-250
My Photos: (0)
4th to download load !! WOW !! Great job John
Why buy it if you can build it? Even if it cost twice as much to build.
wingnut75 is offline   Reply With Quote
Old 03-07-2008, 12:26 PM   #5
morris_the_cat's Avatar
Vehicle: 2001 PT Cruiser
My Photos: (0)
Yay! 1st post of likely thousands!
edit, dang 2nd....
2001 PT Cuiser
VoomPC with 1.5Ghz C7
M2 power supply
in dash slim tray dvd drive
DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
See my install here
morris_the_cat is offline   Reply With Quote
Old 03-07-2008, 12:28 PM   #6
john1701's Avatar
Vehicle: 2001 Ford Crown Victoria
My Photos: (1)
Nice going! no problems so far!
CAR:2001 Ford Crown Victoria
PC: Dell 600 NoteBook with Vista
CPU:specs
Memory:1G
Drives:usb 250gig
WI-FI:Cingular
misc:inverter 300w
GPS:IG 4
Screen:Xenarc 700TSV
Simple Fix to Road Runner and Vista
john1701 is offline   Reply With Quote
Old 03-07-2008, 12:37 PM   #7
krnpimpsta's CarPC Specs
krnpimpsta's Avatar
Vehicle: 2008 Ford Mustang GT
My Photos: (0)
Sweet, I can't wait to get off work.. I'll be sitting in my office's parking lot for half an hour today downloading, installing, and playing with 3.0.
Thanks for the great skin. Donations en route.
2008 Mustang GT CarPC
krnpimpsta is offline   Reply With Quote
Old 03-07-2008, 12:40 PM   #8
tigergibb's CarPC Specs
tigergibb's Avatar
Vehicle: 2003 Nissan Xterra
My Photos: (0)
w00t! 9th download. installing it as i type
btw.. THANK YOU!
2003 Nissan Xterra Worklog
Total amount spent so far: $1196.64
You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
2003 Nissan Xterra - Modifications
tigergibb is offline   Reply With Quote
Old 03-07-2008, 12:44 PM   #9
slvrsol's Avatar
My Photos: (0)
thanks for your hard work!
slvrsol is offline   Reply With Quote
Old 03-07-2008, 12:46 PM   #10
My Photos: (4)
First of all thanks John... we've all been looking forward to the new skin!
A little problem though, the installer keeps hanging at 30% Any ideas?
Also a teeny tiny bug, notice it says 2.0:
VIA EPIA M10000
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
barnyard is offline   Reply With Quote
Sponsored Links
Old 03-07-2008, 12:46 PM   #11
tigergibb's Avatar
My Photos: (0)
maybe i'm doing something wrong but as soon as i hit load skin, day skin, or night skin, it closes roadrunner wont let me change to any skin from 2.0
^Fixed by using RoadRunner Config
Old 03-07-2008, 12:55 PM   #12
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
Darn, all this excitement and i'm at work! I hope John's server don't blow up before i get home.
treetop777 is offline   Reply With Quote
Old 03-07-2008, 12:59 PM   #13
My Photos: (4)
Ok, a reboot got me past that, now I'm stuck here: ***EDIT***N/M, it came up after I hit exit
VIA EPIA M10000
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
Old 03-07-2008, 01:01 PM   #14
My Photos: (0)
very nice.. cant wait til i install it!
nysaz is offline   Reply With Quote
Old 03-07-2008, 01:04 PM   #15
Vehicle: 2004 acura TL
My Photos: (0)
does dfx3.0 work on vista
shot598 is offline   Reply With Quote
Sponsored Links
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
kyjoe, ZARTASL
vB code is On
Trackbacks are Off
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
