Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 07-21-2008, 01:28 PM   #1546
Quote:
have a look in my signature's[Some Tools] link, i use this software, with skinbedder you can get a better integration.
Skinbedder? I don't see it there.
Dougw133 is offline   Reply With Quote
Old 07-21-2008, 01:29 PM   #1547
Oh...I haven't slept in a long time... Disregard that please..... Or just take it out. I read it wrong. You meant the OBD will embed easier.
Old 07-21-2008, 01:35 PM   #1548
Thanks AGAIN drew... I honestly couldn't find the difference but copied new line and it embeds nicely..!
Old 07-21-2008, 02:06 PM   #1549
EL CAMINO's Avatar
this is how i have mine.
MY RR SKIN |-POLARIS-| R.I.P.
EL CAMINO is offline   Reply With Quote
Old 07-21-2008, 02:29 PM   #1550
Now the question is, Is there a MPH version of the OBD Program?
drewbp is offline   Reply With Quote
Old 07-21-2008, 03:40 PM   #1551
I hope so. It looks good. Embeds well at least.
I was messing around a little because I have this dyer need for a Dial Up Network Manager in the skin sicne i use my phone for EVDO. I thought it would be cool to just have button for connect and disconnect but from little feedback on it in other Posts for RR don' think it's happening. So next best thing, embed a third party. I found one that works for me. It's not pretty but has what I need and most importantly an "EXIT" button on the bottom for I do not know how to size it and it overlaps the menu button.
Here its.
It's called SP Dialer 1.40
Only problem I cannot figure out is the Icon PNG image I chose (the phone) does not show up. I am using Blue ZX's button editor to allocate this. I can change every other button's icon's though.
Old 07-21-2008, 03:46 PM   #1552
How did you get the EXIT and Back button up there?
Old 07-21-2008, 03:53 PM   #1553
Did you put the icon in the C:\Program Files\Road Runner\skins\DigitalFX 3.0\MenuIcons
Folder?
The OBD program is skinnable, although beyond the time that I have to spend, and I am sure that it was photoshopped and command added to the button similar to Road Runner.
Old 07-21-2008, 03:55 PM   #1554
It is an existing Icon already in there that suits me. It even created a copy with the button name automatically I guess..? Still won't show up in skin.
Old 07-21-2008, 03:58 PM   #1555
John: Going through the settings of this SP Dialer I see an option for Dial/Hangup hot key. A single command for both.. What do you think..?
Old 07-21-2008, 04:17 PM   #1556
I can't even get the labels to show up let alone the icon. Are you editing a preexisting button, or creating a new one.
If you are creating a new button, use the same logic as I showed you for the OBD Diag program to manually add the items to the EXECTbl. Might not be the fastest way, but will get the job done. It will change buttons because there is already command lines to associate the icon with. Just tried this myself.
Remember it is called an EDITOR, not CREATOR, so there must be something to edit in place first. At least that is the logic I will convince myself with.
Old 07-21-2008, 04:50 PM   #1557
Yeah I have been looking how to do it manually but cannot seem to figure it out. I don't see where the ICONS are linked to the actual button.
I believe I created a new one. I didn't know what it would if I jumped in the middle of the whole numbering sequence (IE:"SetCommandLabels49","SETVAR;MyApp49LB;SP Dialer||SetCommandLabels50")
Old 07-21-2008, 04:52 PM   #1558
Just copy the info discussed earlier in post 1540 and change the myapp number to the next number in your sequence. MYAPP53 etc.
Then you can open the editor and change the icon etc. If there is no code to associate it with to start, it won't let you add it. If the code is their it will show up as a duplicate button and then you can edit it.
Old 07-21-2008, 05:12 PM   #1559
Raw Wave
Blue ZX3's Avatar
That is really not the the way the internal logic is supposed to work.. There is an updated Btn Editor/Creator for the next release as we ran out of btns on the app chooser screens.
Me & John will test and if no probs with an 3.0 exectbl file, i'll have him post the newer one up..
Blue ZX3 is offline   Reply With Quote
Old 07-21-2008, 05:15 PM   #1560
Alright!... I finally figured out that the lavel in the bottom of the menu ski had to be associated with the icon/png. I changed it to the same as "Sp Dialer" in the menu skin and we are golden. THANKS!
Another cool feature for the SP Dialer, if it were some how incorporated into a single button Connect/Disconnect, the program plays a wav of your choice for for acknowledgment. In my case a lady says "Connected", for "" and then "Goodbye" for disc. So you would only have to have this program in the tray and not even in the skin.
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
