Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Notices
Old 09-23-2008, 03:49 PM   #2431
I've seen a number of skins which have .ini files for the various components which have "C:\Program Files\Road Runner" hard coded in any number of places causing a bunch of things to fail if you installed in "RoadRunner".
Sicarius is offline   Reply With Quote
Old 09-23-2008, 03:50 PM   #2432
at risk of being "capslocked" can I ask if DFX and the garmin OSK work together nicely ?
I'm sat on a train on my PDA ATM, so can't do a proper search ( joys of crap UK roaming )
Dirtyrhino is offline   Reply With Quote
Old 09-23-2008, 05:15 PM   #2433
Raw Wave
Blue ZX3's Avatar
Any hard code paths anywhere in a plugin or any app for that matter shows bad programing style...
Blue ZX3 is offline   Reply With Quote
Old 09-23-2008, 05:35 PM   #2434
Confusion Master
Enforcer's Avatar
quickly goes and checks his plugin paths
Enforcer is offline   Reply With Quote
Old 09-23-2008, 05:46 PM   #2435
treetop777's Avatar
YEAH, IT WORK FINE. JUST GOT TO SETUP A BUTTON IN DFX WITH THE COMMAND TO CALL IT.
treetop777 is offline   Reply With Quote
Old 09-23-2008, 07:51 PM   #2436
Raw Wave
Blue ZX3's Avatar
Should have seen that coming...
Old 09-24-2008, 07:34 AM   #2437
How do i disable iList in the new DFX 4.0? it's not where it says it is in the original post
reason i need to disable it is because i can't see any lists of anything when i go to music -> browser or to digital fx settings to change the logos and stuff. it's just blank and if i click "Browser" after going to "Music" the whole program locks up.
i have the most up-to-date flash player, the most up-to-date DFX and most up-to-date directx.
thanks
Current Build
- Commell LV-677 Motherboard
- Intel Core 2 Duo T5500 CPU
- Dual 512MB PC5300\667MHz RAM
- Seagate 80GB SATA HDD
- M2-ATX 160W PSU
- Dynamix 8" LCD Touchscreen
- VoomPC I Mini-ITX Case (Black)
Last edited by JohnWPB; 09-24-2008 at 03:50 PM. Reason: Moved from Road Runner Bug Reports thread
iNcArCeRaTiOn is offline   Reply With Quote
Old 09-24-2008, 07:51 AM   #2438
Quote: Originally Posted by treetop777 View Post
yeah, it work fine. Just got to setup a button in dfx with the command to call it.
lol !
Old 09-24-2008, 11:39 AM   #2439
iNcArCeRaTiOn, have you tried updating your graphics driver ?
I had similar problem after reloading XP on my PC, and after much deliberation, found it to be the driver that I hadn't reloaded at that point.
Otherwise, I think (not in front of DFX at the mo) that you'll find it somewhere in settings, DFX skin settings, and is an option to turn ilists on or off.
Hope this helps
Impartialise is offline   Reply With Quote
Old 09-24-2008, 03:53 PM   #2440
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
To turn off iLists globally, put this in the RR.ini:
usedx=false
This is something that was added in the latest build of RR that was not documented.
Front End of Choice: Road Runner (Is there anything else??? )
& Powered by the DigitalFX 4.0 Skin
Available at www.JohnWPB.com
JohnWPB is offline   Reply With Quote
Old 09-24-2008, 05:15 PM   #2441
impartial, that's where it was in the menu in the build before 4.0 but it's not there now...
thanks for the reply john, i put that in my rr.ini and restarted and tried it and it still is having the same issue =\
Current Build
- M2-ATX 160W PSU
Old 09-24-2008, 05:21 PM   #2442
Loving RR, and with dfx4 the combo makes for a great frontend
I've got a few "issues" i'd like to iron out before it goes into my showcar though - any pointers are appreciated :wink:
Is there a reliable, functional phone plugin out there ? I've tried all of them, and either get one-way connections, and no audio, or a "one call wonder" app.
I'd like to use GarminMPC to work with the OSK in one click, but the included scrpit just opens the OSK, not GMPC at the same time ?
It's no big deal, as I'm running Destinator with no problems at all ( even though the routing is kinda...erm....."off" sometimes
Keep it up everyone - awesome work going on here.
Hell, once I get back off ma holidays i'll put my skin up for feedback.
Old 09-24-2008, 08:06 PM   #2443
JohnWPB's Avatar
Yea, I removed the option from the skin, intending to move the button to somewhere else.... and I forgot It is now in the skin settings / change colors / screen for the next release.
If it's not working, make sure you have the latest build of Road Runner, as that rr.ini option will not work on older RR. versions
Old 09-25-2008, 03:34 AM   #2444
I'm new to RR. I installed the program and this skin, but
how do i change colors and clock? and the buttons on the bottom are not previous,play,next buttons, but it's diplayed with numbers, 0,1,2,3,4,4,5 like this.
how can i fix that?
bongta029 is offline   Reply With Quote
Old 09-25-2008, 04:34 AM   #2445
Hello!
I'm new at this forum and I've read most of posts of Roadrunner themes...
I must admit I've learned EVERYTHING I needed to know about this program and skins thanks to you guys!
Oe question---Does this skin upport GAMES?I saw some skins having games,but i don't like the skins looking themselves...So---Is there possibility of GAMES?
Alix is offline   Reply With Quote
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 06:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 06:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 06:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 02:50 AM
