The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Search this Thread Display Modes
Old 03-13-2008, 12:06 PM   #316
My Photos: (0)
gestures
Thanks enforcer, I'll check it out!
hardcoreracing is offline   Reply With Quote
Sponsored Links
Old 03-13-2008, 12:20 PM   #317
morris_the_cat's Avatar
Vehicle: 2001 PT Cruiser
My Photos: (0)
John, I noticed a few things:
1. Can you please add the line "x,mp3art" to the menu.skin. I have all my album art embedded in the mp3's & need this to show it. I added this in my own copy, but others may wish this as well.
2. I am glad u made a skin for RREarth. Something isn't right in it though. I got it running fine under DXF2, but in DXF3 it doesn't properly embed the window & turn on GPS. Not sure if I should be posting this item here or in the rrearth folder, but since I have issues with it running in this skin only, then I thought here...
3. In the album art browser, It shows all my mp3's, but with no album art. I am assuming this is because the art is embedded in the mp3 & it isn't reading it. Is it a simple change to get it to also read the art embedded in the mp3's on this feature?
4. I love the fact the radio shows the RDS text from my ADS FM radio USB stick! Thanks!
2001 PT Cuiser
VoomPC with 1.5Ghz C7
M2 power supply
in dash slim tray dvd drive
DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
See my install here
morris_the_cat is offline   Reply With Quote
Old 03-13-2008, 12:29 PM   #318
My Photos: (0)
first of all, great skin, thanx
i'm having only 2 problems.
-when i'm ending a call in the phone menu, roadrunner crashes (using a k800i)
-can't get freedrive to work, when i push the button for destinator nothing happens.
can someone help me? it's driving me crazy
callirider is offline   Reply With Quote
Old 03-13-2008, 12:36 PM   #319
Raw Wave
Blue ZX3's CarPC Specs
Blue ZX3's Avatar
Vehicle: 01 Ford ZX3
My Photos: (16)
FYI to everyone...
(plugin, add, remove, disable)
To add a plug-in or disable one thats already included, go into the skin folder and open up the plugins.txt, then add or comment out (add "/" infront of the line). Save and reload the skin (tap "Album" label on main Menu.)
I will try and get/help John to be able to do all the plug-in on/off from with in the skin in the next release.
Blue ZX3 is offline   Reply With Quote
Old 03-13-2008, 12:54 PM   #320
bmsgaffer86's CarPC Specs
My Photos: (0)
Quote: Originally Posted by Blue ZX3 View Post
You will have to edit them. This is something that John is already aware of and has been looking for a solution for some time.... This will occur anytime the skin is resized to anything other than the native 800*600 resolution.
It has to do with the fact that the font that he is using as all the button symbols is his own custom font. And for some reason or another when rr resizes the screens this is the after lying artifacts..
Thank you for the info! I will go search on how to do that!
bmsgaffer86 is offline   Reply With Quote
Sponsored Links
Old 03-13-2008, 01:43 PM   #321
Zogg's Avatar
Vehicle: 2006 Toyota Sienna
My Photos: (0)
Quote: Originally Posted by mnickolson View Post
Ok I got the info working in the wireless screen. Here are the things that need to be changed.
In the \DigitalFX 3.0\Scripts\WirelessList dir change Wirelessrr.exe to Wireless.exe
In the ExecTBL.ini change "WirelessLabels","Runq;$SKINPATH$Scripts\wifi_man. exe" to "WirelessLabels","Run;$SKINPATH$Scripts\wifi_man.e xe"
Add this line to your rr.ini startcommand=RUN;$SKINPATH$Scripts\wifi_man.exe
Hope this helps.
Is this supposed to allow the connection info to show up in the lower area of the skin? I made the changes but the last one you show, the one for rr.ini, causes an error because of the $SKINPATH$ variable. I changed it to the actual path but it doesn't seem to do anything.
The Windows wireless networks list shows up in the upper area for me, and did before these changes. Just wondering what is supposed to be different.
Thanks,
Z
Carputer progress:
95% [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓-]
Motorola MW800, Xenarc 700IDT, M1-ATX, RR & DFX 3.0. Need to do a bit of custom bezel work and reroute some cables.
Zogg is offline   Reply With Quote
Old 03-13-2008, 02:17 PM   #322
Nola111's CarPC Specs
Nola111's Avatar
Vehicle: 2006 VW Passat 2.0t
My Photos: (1)
John, what service does the Jukebox function connect to?
Nola111 is offline   Reply With Quote
Old 03-13-2008, 02:38 PM   #323
digeratix's CarPC Specs
digeratix's Avatar
Vehicle: 2002/Dodge/Intrepid
My Photos: (1)
I think it gets it from seeqpod.com or something.
Carputer: VIA EPIA M10000 1Ghz CPU with 1 Gig Mem, 100 Gig Hitachi Travelstar, Slotload CDRW/DVD, VoomPC2 Enclosure, Lilliput 7" Touchscreen, Wifi, Phoco, Iguidance 4.0, Bluetooth. Powered By XP Pro (Nlite), Road Runner & the DigitalFX Skin My Site
digeratix is offline   Reply With Quote
Old 03-13-2008, 02:51 PM   #324
My Photos: (0)
help
i have downloaded dg2 and 3 within last couple of weeks i am a newbie to programing i am having same problem on both of them, but laptop works ok i am getting a white box behind clock or logo on main screen. i presume it is a flash problem can any one help
cheers neil
neil21 is offline   Reply With Quote
Old 03-13-2008, 02:54 PM   #325
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
cheers neil
Did you read the FAQ post for this skin? Post #3
Simple stuff, learning to read the FAQ's before posting will help you a lot.
Enforcer is online now   Reply With Quote
Old 03-13-2008, 03:02 PM   #326
My Photos: (0)
trying to get through it all slowly just to much info when you are learning
cheers yet again will have a look
neil
Old 03-13-2008, 03:24 PM   #327
My Photos: (0)
hi enforcer tried that this morning still no joy is there any way to check if flash is working ok
neil
Old 03-13-2008, 04:26 PM   #328
japeeler's CarPC Specs
japeeler's Avatar
Vehicle: 2006 Ford F150 5.4L XLT 4x4 Screw
My Photos: (0)
Anyone having issues with the "GASPRICES" area? I have my zip and such, but nothing loads into the Locations for each station. i can click on the gasprice.html file in the DFX dir, and get to msn-auto.com website, it shows the information, but I am not getting it to parse to the DFX/RR GasPrice screens... I got it to work a while back in DFX 2.5, but had to redo the skin/RR install, and never got it back working..
man I LOVE this new way of changing your buttons and colors, everything in this version! Simply AMAZING work and help form the beta testers and this community...
YOU ALL, YA'LL ROX! (yep, I am a Texan! YEEEEHAWWW!)
EDIT: It's a miracle!! I had to go to a REAL City (Broken Arrow, Tulsa, OK - My Trip I mentioned) and HOLA! hahah had somem major freezinf of RR/DFX3.0 when I got here, NO LESS while I was showing off my new truck/truckpc/DFX3... UGH.. reason... Always check your Wireless or Network connections to make sure you do NOT have a Static IP in them!! LOL.. Werking Perfect right! WooHoo Thanx again everyone for all yur help and JOHN.. U ROX!!
EDITx2: BTW.. My mom Lovd playing the Games, Need more! hahahaha (Drove my mom up here, as well, LOVES MY TRUCK, because of all the Technology I put into it..)
-=- TruckPC Progress -=- 98% Complete -=-
-=- 2006 Ford F-150 Screw 4x4 -=-
@@@@@@@@@@ <-- Planning Phase
@@@@@@@@@@ <-- Purchasing (Never End)
@@@@@@@@@@ <-- Construction Phase
@@@@@@@@@@ <-- Installation Phase
My TruckPC WorkLog @ MP3Car.com
japeeler is offline   Reply With Quote
Old 03-13-2008, 04:53 PM   #329
Confusion Master
Enforcer's Avatar
My Photos: (1)
neil
did you update the flash in explorer, if not try it through explorer.
Old 03-13-2008, 04:58 PM   #330
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
Quote: Originally Posted by Enforcer View Post
did you update the flash in windows, if not try it through windows.
..with internet explorer only..
treetop777 is offline   Reply With Quote
Sponsored Links
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
slvrsol
Search this Thread:
Advanced Search
Trackbacks are Off
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
Sponsored Links
Ad Management by RedTyger
