The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 03-13-2008, 05:04 PM   #331
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
Quote: Originally Posted by treetop777 View Post
..with internet explorer only..
That's what I meant.
I'm testing Vista, I blame that.
Enforcer is offline   Reply With Quote
Sponsored Links
Old 03-13-2008, 07:36 PM   #332
mnickolson's CarPC Specs
Vehicle: 1994 Sport Trac
My Photos: (0)
Quote: Originally Posted by Zogg View Post
Is this supposed to allow the connection info to show up in the lower area of the skin? I made the changes but the last one you show, the one for rr.ini, causes an error because of the $SKINPATH$ variable. I changed it to the actual path but it doesn't seem to do anything.
The Windows wireless networks list shows up in the upper area for me, and did before these changes. Just wondering what is supposed to be different.
Thanks,
Z
Zogg
Yes it should fix the connection info. Not sure why your getting a error. Did you just put it at the end of your rr.ini? Mine looks like this...
[Wirelees Fix]
startcommand=RUN;$SKINPATH$Scripts\wifi_man.exe
2004 Sport Trac PC Project.
mnickolson is offline   Reply With Quote
Old 03-13-2008, 08:53 PM   #333
Freddieanto's CarPC Specs
Freddieanto's Avatar
Vehicle: 2005 Ford F250
My Photos: (10)
Quote: Originally Posted by BREWDOG52 View Post
Weird, I downloaded and unzipped with no problem, someone else mentioned it was corrupt though. I made a new zip, try this one out.
http://www.fileden.com/files/2007/3/...nu%20ICONS.zip
I did have problems, but this new zip file works.
Fred
Freddieanto is offline   Reply With Quote
Old 03-13-2008, 10:03 PM   #334
digeratix's CarPC Specs
digeratix's Avatar
Vehicle: 2002/Dodge/Intrepid
My Photos: (1)
Quote: Originally Posted by japeeler View Post
Anyone having issues with the "GASPRICES" area? I have my zip and such, but nothing loads into the Locations for each station. i can click on the gasprice.html file in the DFX dir, and get to msn-auto.com website, it shows the information, but I am not getting it to parse to the DFX/RR GasPrice screens... I got it to work a while back in DFX 2.5, but had to redo the skin/RR install, and never got it back working..
man I LOVE this new way of changing your buttons and colors, everything in this version! Simply AMAZING work and help form the beta testers and this community...
YOU ALL, YA'LL ROX! (yep, I am a Texan! YEEEEHAWWW!)
I am having the same trouble.
Carputer: VIA EPIA M10000 1Ghz CPU with 1 Gig Mem, 100 Gig Hitachi Travelstar, Slotload CDRW/DVD, VoomPC2 Enclosure, Lilliput 7" Touchscreen, Wifi, Phoco, Iguidance 4.0, Bluetooth. Powered By XP Pro (Nlite), Road Runner & the DigitalFX Skin My Site
digeratix is offline   Reply With Quote
Old 03-13-2008, 10:18 PM   #335
My Photos: (0)
hi john,
i found a little bug..
in the execTBL file under "MyApp17" there is a double " in the line at the beginning and the end..
that is the reason i could not get freedrive to run.
callirider is offline   Reply With Quote
Old 03-13-2008, 11:44 PM   #336
redls1bird's CarPC Specs
redls1bird's Avatar
My Photos: (0)
Quote: Originally Posted by redls1bird View Post
Any one have a problem with their dvd/video screen controls staying up even after changing the screen?
So no one else has this problem? Its happened on both 2.5 and 3.0. Any help?
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
redls1bird is offline   Reply With Quote
Old 03-14-2008, 02:30 AM   #337
Vehicle: 2004 kia Sorento
My Photos: (0)
Quote: Originally Posted by hardcoreracing View Post
These are simple problems that I'm having, they are by no means a big deal. Just thought I'd mention it.
I tried to load solitaire game today, all the other games work fine, but when I choose solitaire nothing loads.
When I use scribble pad, when I start to drag a line across the screen it will mute the mp3 that is playing.
Other than that, skin has been awesome!
I just want to add aslo that solitare does not load for me. I checked the dfx games folder and the flash swf file for solitarie is not in there.. We may have to find a good one online and save the webpage then extract the flash.
Quote: Originally Posted by mnickolson View Post
Zogg
[Wirelees Fix]
I tried it also. It did not work 100% . the labels did appear but then dfx3.0 closed down hard and never populated the top information. IT also spiked my 2.0ghz pc to 100% and the hour glass kept comming up like it was looking for another script or stuck in a loop.
Ok I got the info working in the wireless screen. Here are the things that need to be changed.
In the \DigitalFX 3.0\Scripts\WirelessList dir change Wirelessrr.exe to Wireless.exe
In the ExecTBL.ini change "WirelessLabels","Runq;$SKINPATH$Scripts\wifi_man. exe" to "WirelessLabels","Run;$SKINPATH$Scripts\wifi_man.e xe"
Add this line to your rr.ini startcommand=RUN;$SKINPATH$Scripts\wifi_man.exe
Hope this helps.
I just added to end of rr.ini and inside the exectbl.ini. Maybe since i used rrconfig the first time maybe i need to use that to edit the .ini s' since this time i just used notepad.
edit--- EUREKA figured it out. Okay for us newbies using rrconfig.. do not cut and paste
"WirelessLabels","Run;$SKINPATH$Scripts\wifi_man.e xe" or startcommand=RUN;$SKINPATH$Scripts\wifi_man.exe
Nicholoson's fix figures we are smarter than the normal user, instead us newbies have to put the auctual skin path. example this is what i have in the rr config ini app for exectbl.ini
"WirelessLabels","Run;"C:\Program Files\Road Runner\skins\DigitalFX 3.0\Scripts\wifi_man.exe"
note i used the whole path not "$skinpath$" god i feel stupid for not thinking of it as a variable.Now put this in the ini extras. That is if you use the default paths.
startcommand=RUN;C:\Program Files\Road Runner\skins\DigitalFX 3.0\Scripts\wifi_man.exe
thank you Nicholoson for the instructions on fixing this..
Okay now i still need to figure out why winamp wont freaking pause or mute when ig gives directions but will work perfectly in carwings skin when ig says directions..
using Mobile Impact,Waiting on the rds radio.
nigwhyrito is offline   Reply With Quote
Old 03-14-2008, 05:28 AM   #338
kbreeden's CarPC Specs
Vehicle: 2005 Acura TL
My Photos: (0)
Quote: Originally Posted by digeratix View Post
That also raises yet another question... whats the Ter for? I was in a metro area once and it was lit up full bars for the first time ever.
XM has a bunch of land based (terrestrial) towers around, mostly near big cities, in addition to the satellites. The Ter indicator will show when you're tapping into those.
kbreeden is offline   Reply With Quote
Old 03-14-2008, 05:59 AM   #339
My Photos: (0)
Quote: Originally Posted by itech View Post
But I still want to know if there is a way I can change the Favorite Icons to display my favorite channels
One needs to edit XM_Favorites.skin to change the channel number for each button and edit XM_Favorites_On.png and XM_Favorites_Off.png to add the channel icons to the appropriate buttons. Once upon a time, John supplied the channel icons and the necessary PSD files, so that editing was pretty easy. I don't see them in this release, so don't know if he intends to make them available. I assume he does and has just forgotten to include them, but that will be up to him.
Old 03-14-2008, 07:47 AM   #340
Machinehead's CarPC Specs
Machinehead's Avatar
My Photos: (0)
Add on note: Mainly because the buildings block the sat signal. XM has tons of towers to fill in the blank spots because of their geosynchronous satellites.
Machinehead is offline   Reply With Quote
Sponsored Links
Old 03-14-2008, 07:52 AM   #341
My Photos: (0)
It would be handy if that skin was modifiable the same way the main menus can be changed on the fly.
Old 03-14-2008, 10:25 AM   #342
Raw Wave
Blue ZX3's CarPC Specs
Blue ZX3's Avatar
Vehicle: 01 Ford ZX3
My Photos: (16)
What did you find wrong with using cut & paste??
No, not true. RoadRunner will convert $skinpath$ to whatever you have it set to in the ini/config, before it executes the run cmd. Using the variable or the whole path will result in the same.
Blue ZX3 is offline   Reply With Quote
Old 03-14-2008, 10:29 AM   #343
Raw Wave
Blue ZX3's Avatar
My Photos: (16)
I have done some work on being able to have a menu where you will be able to now turn on/off the plugins instead of editing the plugin.txt from within the skin.
I'll show it to John when he returns, while we are getting the media plugin intergrated in the next release.
Old 03-14-2008, 12:03 PM   #344
fixinstuff's CarPC Specs
fixinstuff's Avatar
Vehicle: 1999/Ford/F150
My Photos: (0)
HD Radio will not work in DFX, it freezes up RR. I can get it to load in LSX, it also works with the stand alone program from Mitch.
Anybody have an idea what may be causing this. Am I missing a driver or something?
Before anyone says it yes I have checked the settings in the config file.
Plan for project = 100%
Part the project. = 99%
Built...................= 90%
Install ...............= 99%
Forever In Progress
Scott AFB, IL
fixinstuff is offline   Reply With Quote
Old 03-14-2008, 12:51 PM   #345
My Photos: (0)
Niguhyrito,
Not sure why you think you have to dash me for trying to help and as to being smarter than the normal use, I am working on my first carpc and install. I just did a little reading on this site. It will work just as I posted it if your rr and skin install is normal and has no issues.
Sponsored Links
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
spamminator
vB code is On
Trackbacks are Off
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
