Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Notices
Old 03-16-2008, 02:08 AM   #376
I dont understand it, i just installed xp pro and now when i click on manage playlists, RR freezes up and i have to ctrl alt del. Can someone help
sveliov is offline   Reply With Quote
Old 03-16-2008, 02:10 AM   #377
maniaxzero's Avatar
Quote: Originally Posted by Blue ZX3 View Post
He burried it on the search button as the hold down cmd, but don't get too used to it being there in the next release, which will have my Media plugin doing all that...
ahh i see. thanks mucho. Even though im currently 99% satisfy with the library search, im really looking forward to your media plugin. Keep up the good work dood!
maniaxzero is offline   Reply With Quote
Old 03-16-2008, 07:39 AM   #378
Looks great, can't wait to fiddle around with it!
Are you 2x? Because I want to integrate you from 10 to 13!
elimenohpee is offline   Reply With Quote
Old 03-16-2008, 10:11 AM   #379
Machinehead's Avatar
Quote: Originally Posted by JohnWPB View Post
The templates for the XM / Sirius favorites is in the DigitalFX 3.0/Helper Files/ folder. The icons are in Road Runner/XM. Just drag the icons onto the template in Photoshop or your favorite image folder. You will need to edit the XM Favorites skin to change the channel numbers to match your stations.
NOTE: The XM icons are in PNG format, and just renamed to .gif so RR will display them. If you attempt to load them into Photoshop, it will complain that the file can not be loaded, as it things it is a gif, and cant load it as such. Road Runner is smart enough to look at the header in the image file to determine what kind of image it actually is, believe it or not, Photoshop is not that smart
The templates are actually out of date, it looks like they're for the 2.5 version of DFX. I went and pulled together my own photoshop file with the 3.0 version.
Enjoy.
Edit: I noticed after the fact that there was some bad blending with lighter backgrounds, so I tweaked that so it looks less half-arsed. Also, you will need to modify the XM_Favorite.skin, there are issues with the selection areas, and of course you need to set your channels as well.
Machinehead is online now   Reply With Quote
Old 03-16-2008, 11:08 AM   #380
blk02si's Avatar
Very Nice! Everything stable over here, every time I play with DFX I discover something new about it! The only request I have is a release in binary form. I really don't like the installer at all, maybe its just me, but I find the installer to actually complicate the install of a skin. I use non-standard paths so these types of skins packaged with an installer I just extract to a temp directory and start working from there.
My carPC - www.shocknet.us
blk02si is offline   Reply With Quote
Old 03-16-2008, 12:56 PM   #381
Quote: Originally Posted by chuckctv View Post
I have it mostly working myself. anyone have the XM-radio working? if so did they have to do anything special?
I have XM working. There is nothing to do other than ordinary setup in RRConfig. If it was working before there's no reason why it won't work with the new version of the skin.
kbreeden is offline   Reply With Quote
Old 03-16-2008, 01:03 PM   #382
I realize you installed flash, but this is still 100% a flash issue. That screen embeds a .swf (Shockwave flash file) Something with the flash install is not working somewhere. Try installing with Internet explorer, even completely removing it and try installing again.... Each machine reacts differently with flash, so its unfortunately a bit of trial and error.
Ok, two installs of flash later and it is working. I removed the first, then tried the link in the FAQ a second time. That didn't work. So I removed it again. Then I just installed directly from Adobe and now it works.
Looking good!
klundy is offline   Reply With Quote
Old 03-16-2008, 01:58 PM   #383
Confusion Master
Enforcer's Avatar
Enforcer is offline   Reply With Quote
Old 03-16-2008, 02:14 PM   #384
i installed xport its workin good but am getting a error message from RR when am playin music...
shot598 is offline   Reply With Quote
Old 03-16-2008, 09:08 PM   #385
fixinstuff's Avatar
Quote: Originally Posted by utd09bry View Post
I have mine working.. did you download and place the zipped package of files from mitch? should have gone in the RR folder called HD Radio
Let me know what all you did and maybe I can help you out. It's flippin sweet once you get it running
Ok, done this several times, I click on HD Radio, I can hear the reciever turn on and back off. The skin never opens, RR freezes up, and I have to reboot and start all over. Even before I connected the reciever, RR froze up. It also freezes up with the radio skin. The same download opens on the test computer.
Plan for project = 100%
Part the project. = 99%
Built...................= 90%
Install ...............= 99%
Forever In Progress
Scott AFB, IL
fixinstuff is offline   Reply With Quote
Old 03-17-2008, 12:29 AM   #386
When i click next or previous on dfx3.0 or 2.5 it only rewinds or forwards the video or movie. How do i get preview and next to work? please help. just pm me and thanks in advance
Morpheus2010 is offline   Reply With Quote
Old 03-17-2008, 01:38 AM   #387
Color quality keeps resetting to 8-bit on main menu???
I have just installed DXF-3.0, and I love it. Great job to all... I wasplayin around with setting my screen resolution to 1024x768 the other day, and my 7" Lilliput didn't like it. So I changed it back to 800x600. Now every time when I start RR w/ DXF-3.0 something is resetting the color quality back to 8-bit. If I min RR and reset it in display properties, all the screens eccept the main screen will display 16-bit or 32-bit. Is there a setting in the ini file, or something in winamp that might be causing this. This has me really stumped. And when I changed the screen res I also set it in RR config, I have also reset it to 800x600. This will not solve my problem either.
nhra no 2 is offline   Reply With Quote
Old 03-17-2008, 02:33 AM   #388
maniaxzero's Avatar
so the new library search feature is buried within the regular search button...is there anyway to remap the search button to the library button? cuz i really dont need the regular search and holding it down for the library search is a problem for me cuz it doesnt play nice with my touch screen. It only works half the times...
Sorry for this noob question, this is probably an easy fix for most of y'all but im having a tough time figuring it out.
thanks
//EDIT:
nvm, i figured it out from looking at the digital fx 2.5 audio_browser.skin
I changed this line in Audio_Browser.skin for version 3.0
Quote:
B08,595,164,100,89,"SEARCHFILES",@Load;Audio_Searc h.skin@
into
Quote:
B08,595,164,100,89,"Load;Audio_Search.skin",
Everything seems to be working fine. I'm a happy man!
Old 03-17-2008, 03:21 AM   #389
maniaxzero's Avatar
BTW i just wanna point out that iList doesnt work in library search. Not sure if that was intentional or not...
Old 03-17-2008, 03:29 AM   #390
utd09bry's Avatar
Don't know if I understood what you meant by "same download opens on the test computer."
But also, it freezes even without the radio connected to the pc? Are you using RRConfig to setup your radio settings? Set everything to HD Radio?
When I hit HD Radio, I do get a slight pause as the unit clicks on but no more than a few seconds. Also when going back to the Music screen to kick-off the radio there is another pause... unit clicks off... mutes Line-in... then Music screen loads.
I would double check your config settings next if you already have all the right files... in rr.ini set HDRadioport=3 (or whatever port you are using), radiomode=8 (for HDRadio)
Just trying to cover all bases. It seemed really simple in my setup so it may be a small bug on your end
utd09bry is offline   Reply With Quote
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 06:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 06:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 06:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 02:50 AM
