03-20-2008, 07:13 AM
#466
Quote: Originally Posted by Enforcer
Method 2. Create your own font where the work Play shows a play symbol, Pause a || and Stop a Square, replace the font name for the font name (DFXFont1) in the first line of BottomButtons.txt andd change the "=2" to "STATUS".
L,314,511,71,67,#DFX1R#,#DFX1G#,#DFX1B#,55,"<Your Font Name>","STATUS","CENTER"
This option seems like a viable fix, can anyone with font creation expertise create a font for us to try? I would give it a go but I have no skills I am just a lame end-user
Also does this mean the change only occurs in one place or are we still editing all the skins?
03-20-2008, 07:34 AM
#467
Quote: Originally Posted by Blue ZX3
Confused?? How? No music heard being played, it's paused. Music playing in background, uh..it's not paused.
If I sound cranky, blame it on all the time in the last 2 days with little sleep trying to go through all the upcoming media features in the next release with john. Working out the remaining bugs and making sure that everything is as user friendly as the rest of the skin is of which John has already put huge effort into making it this way....
 I noticed the lack of a pause 'symbol', but it doesnt bother me. Figure, like you said, if ya hear music, it playing, no music, paused....
I'm just glad this thing works and for all the effort all the people involved put in it. Now, all I need to do is make my double din carputer case and stick everything in it.
03-20-2008, 07:42 AM
#468
screen_lock.skin at start
I am trying to put the "screen_lock.skin as the start skin, but when I set it with ONSKINSTART in the ExecTBL.ini from RR folder, nothing happens, and when I try it on the ExecTBL.ini from the DFX3 folder, it works fine, but when I replace the wallpaper of the skin, it minimize the RR...
Could someone help me to solve that?
Thanks!!
Engineering: Where the rubber meets the road!
03-20-2008, 07:57 AM
#469
Quote: Originally Posted by brandensin
oops... sounds like it's gonna require a lot more than a editor..
Forgot about all that dynamic stuffs.... Personally i am good.. I hear nothing, that's good enuf of an indicator..
It's one of those projects that really begs for someone else to take it and run with it since John has enough on his plate.
03-20-2008, 08:13 AM
#470
Quote: Originally Posted by PacketSniffer
It shouldn't matter. It's pinging an IP address. As long as you have a network adapter that can access the Internet and ping the specific address listed, it will show "Online".
Nope, always says offline when using a wireless card - on two different computers.
VIA EPIA-MII12000 • M2-ATX 160W DC-DC • WinXP Pro SP2 • 1 Gb Mem • 160GB HD • Xenarc MDT-X7000 • BU-353 Weather-proof GPS Receiver • iGuidance • D-Link AirPlus DWL-G650
03-20-2008, 08:23 AM
#471
Does it work though? The indicator doesn't really matter if your connection works.
03-20-2008, 09:01 AM
#472
Can you ping a website through that connection....the online detector uses ping to verify it's online. I ended up creating a different online detector that doesn't use ping as most of the places I use WIFI block ping. The latest version (not released yet) can be configured to work with DFX3.
03-20-2008, 09:23 AM
#473
Is this what is causing the windows warning box that keeps popping up and says "cannot connect to web" or something to that effect? I thought I had a virus on my laptop when this was happening (looks like one of those hacker wanabe's with a dialer program). I just built a new system to replace the laptop in my car, fresh install of windows, RR, DFX3 and immediately started to get the same pop up's on that machine! guess I can quit scanning the laptop for viruses and such!
03-20-2008, 09:26 AM
#474
Confusion Master
If I can find the PC that has the font editor on it I will have a look at doing it.
And it should need (for the main part) only one file to change, but I haven't gone through all of johns .skin files to check, but knowing that the External plugins skins (like CDRip for example) do not support INC they will need to be changed manually.
03-20-2008, 09:49 AM
#475
Method 1. Create 3 gif graphics files, one with a play symbol (play.gif), one with a pause symbol (pause.gif)and one with a stop symbol (stop). In BottomButtons.txt file comment out the first line
/L,314,511,71,67,#DFX1R#,#DFX1G#,#DFX1B#,55,"DFXFon t1","=2","CENTER"
and add
I,298,516,97,80,"STATUS"
Not usre how well the button will work under an indicator you may need to play with it.
Method 1 you will not have the colour change, Method 2 you will.
Couple Q's if i may: with the gif option, do you just drop the gif's in the skin forlder? and do they have to be called out in the 3rd line of the .skin file?
03-20-2008, 09:55 AM
#476
Confusion Master
I have only read skincommands.txt and not actually tried method 1. (not tried method 2. either but I'm sure that will work)
But my understanding is, just drop those gif files into the skin directory.
#477
Quote: Originally Posted by cirovi
- Is possible enlarge the text of the lyrics ?
Sorry if I quote me but no idea on this ?
AND we can also add a "scrolling" feature to the text ?
03-20-2008, 12:04 PM
#478
If you don't like those popups (I can't stand them as they get in my way exactly as I'm trying to hit mute or something) you can disable them pretty easily if you don't mind changing a key in regedit.
Since I hate using the touchscreen OSK more than I have to, I just use a reg file that I open from my computer - you're welcome to use it if you like. Hit the windowsxptips link here and save/open the .reg files for systray and start menu. Feel free to open to check that I'm not doing anything bad either. Or if you don't trust that, just open the file with notepad and add the dword value at the path seen.
http://mirror.point808.com/
MySpace - Yeah, I'm an addict
03-20-2008, 12:11 PM
#479
i am using DFX3 and
1. i dont have internet in car yet. so when i start RR the dail-up window pops as well with RR. how do i get rid of it
2. when i exit RR for some reason and click on RR.exe again then winamp wont start till abouta minute. winap does same thing when i open it w/o RR when i exit RR. how do i get rid of this problem.
3. whats the use of "SENSORS" in tbe RRconfig. and how can we set it up if its something useful.
4. i am using Tay Firefly RR6 for girder. and its not working at all. i got everythign setup with gider as ive been using girder with WMP11 and worked perfectly. but unable to use it with RR. any how to around. or any one can spoon feed it to me.. lol.. as when ever i search for it i find some one explaning the last prat or some one the middel part or may be 1st part. and this is really making me confused.
HELP ME PLEASE WITH GIRDER( most imp for me) as i cant look down to my screen everytime to change the song.
5. when i touch in the middle on the screen I.e. where there is a logo or clock RR exits. i dont want that as it is presse accidently while turnig the visualization on.
thanks.
03-20-2008, 12:34 PM
#480
Well, as you approach perfection, people have to look closer to find stuff "wrong" with it!
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Lucky13ESP
| Thread Tools |
| Display Modes |
Linear Mode
