04-09-2008, 02:36 PM
#826
Road Runner & Mp3car Gatherings Moderator
Vehicle: 99 Mitsubishi Eclipse
Quote: Originally Posted by brandensin
YEAP.. i was gonna ask about that too... that sometimes rr doesn't close winamp, endedup up having a winamp processor hanging in the memory.. So, when rr starts nexttime, new instance of winamp having some issue with the one hanging in the memory..... Most of the time, rr will successfully close winamp, but not all the time...
This has happened to me a LOT during testing the skin. Having to end Task Winamp all the time when restarting the skin ect. I can't beleive it took me so long, but I finally resolved it  When you exit the skin now, Winamp is end tasked  I have been running the skin like that for a few days now, and it works perfectly, with no ill side effects such as drowsiness, diarrhea , sore throat, blurred vision and so forth
04-09-2008, 04:23 PM
#827
cool... now i don't have to have task manager opened all the time, sort it, find winamp and KILL it...  Became my routine...
04-09-2008, 04:47 PM
#828
JohnWPB, your work on the software is outstanding. Calling Streets and trips, the buttons are dark, your thoughts on same? Would it be possible to access CoPilot within the program?
Thanks Johnnie
04-09-2008, 04:53 PM
#829
JohnWPB, oops, disregard the streets question, saw the answer.
Johnnie
04-10-2008, 12:05 AM
#830
Quote: Originally Posted by copter
Try installing DFX 2.5 and then trying it in both skins. I had the same problem after I uninstalled DFX 2.5. After I re-installed 2.5, 3.0 works again. Don't ask, it just works and the un-install was the only thing that changed. Hope this helps.
Well that was the trick. At least on my test computer. That got it working. Thanks for reading through the posts and responding. I am finding that once you post a question, you might get one or two quick responses but then it gets lost in the vastness of this thread.
Once again thanks for the help.
04-10-2008, 12:53 AM
#831
Quote: Originally Posted by megagoo
to get the temperature to display properly, do i simply go to menu.skin and menu2.skin and look for:
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP2","left"
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial", "=Computer:","right"
L,212,4,89,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," =Interior:","right"
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," TEMP1","left"
and replace TEMP2 and TEMP1 with the variables from ShowSpeedFanData.exe ?
Quote: Originally Posted by monty9991
yes you hvae to change temp1 and temp2 to the speedfan variables.
ok i did this so it looks like:
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT0","left"
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT1","left"
and it didn't work, i think it said in the skin
Quote:
Computer: right Interior: right
......i just noticed though on my monitor there is a space before the 'temp1' and 'temp2' that i probably didnt put in. maybe thats it?
04-10-2008, 07:33 AM
#832
S&t
Normally I can figure things out and learn, but I'm stumped on this one. I can't get streets & Trips to load when I select Streets & trips button on the button selector. If I choose the IG Button S&T will load with the IG png file ? I know in 2.5 I had to edit the button skin to read "GPS" as supposed to "Remembergps"
"B06,559,261,240,83,"RememberGPS",@gaspricefinder@ " this was changed to -
B06,559,261,240,83,"GPS",@gaspricefinder@ for it to load S&T .. I tried the exectbl file and it still won't work ? I can select the IG button get S&T to load then go back and select the S&T button and it will load, but once I reboot it won't load again ?
Stumped !
Mini Sumo Was Here
04-10-2008, 08:33 AM
#833
Vehicle: 93 Twin Turbo Dodge Stealth
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT0",""
L,311,4,87,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial"," SFT1",""
I removed the "left" phrase, try it again.
04-10-2008, 10:22 AM
#834
Update: Well that worked on the car pc as well. It seems to solve a couple of other issues with the way songs are displayed in the music browser also. There must have been a couple of files in DFX 2.5 that did not make it into or are different in the installer for DFX 3.0.
04-10-2008, 06:42 PM
#835
On my GPS screen, I dont get an option to select which GPS I want to use. Id like to use my copy of streets and trips but it never gives me the option to choose it. When I hit the GPS button, it loads S&T but it loads it separately from the skin. Any ideas?
MantisX
04-11-2008, 04:51 AM
#836
Vehicle: 2005 Acura TL
Black, is this working for you? Are you able to see the computer temp on the menu screens?
04-11-2008, 07:13 AM
#837
MantisX
You need to adjust your RRconfig settings for S&T.
04-11-2008, 08:58 AM
#838
Yes it works for me. You need to keep the speed fan programming running at all times.
Is anyone using IGQwerty program? The ABC keyboard on iGuidance drives me crazy, and I just discovered that cool program that converts it into a QWERTY keyboard. It works great, but I'm not happy with the colors. JohnWPB made some skins for it and I've been unable to locate his IGQwertyBlueDevilSkins.zip file. The old links are dead. Can someone provide those skins again? Thanks.
04-11-2008, 12:44 PM
#839
Vehicle: '05 Subaru Impreza Outback Sport
Great, so can I just re-download the installer and install over the top, or how do I add the fix so I can keep my already-configured skin (button choices, theme, etc)?
CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
04-11-2008, 05:01 PM
#840
Click On My Mp3 List To Play ?
Hi,I'm Trying To Click On My Mp3 List of songs for each album to play but ,the only way it plays back is if you put in play lists? why, i didn't have to do this with brush metal skin ,i tapped (click) once the song played. what I'm trying to say is i don't want to populate a play list to be able to play back my tunes. In Need Of Help , Thanx a Bunch.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
spamminator
| Thread Tools |
| Display Modes |
Linear Mode
