05-17-2008, 03:09 PM
#1156
i used the newest one on xport site,now i'm using the one provided in dfx 3.0. what version should i be using? thanx.
05-17-2008, 03:12 PM
#1157
Raw Wave
Vehicle: 01 Ford ZX3
Just check which ver he includes with the install and it looks like an older one like the one that i use.
Do you see the Lat,Lon,Alt,Spd labels being updated in that screen(Gauges)?
05-17-2008, 03:18 PM
#1158
oh yeah i see it active, but sometimes from hib nothing is active . lat,lon,alt etc. and gps pointer not active green. and it must be an older xport because ya' don't have the options to check you hubs,etc. in a list.thanx again.
05-17-2008, 05:02 PM
#1159
Vehicle: 2004 / Acura / TL 6sp Dyanmic
Quote: Originally Posted by VmtSquad
I understand that, my COM port is set in RRconfig and my GPS is working flawless. I get all the data in the GPS info without efforts. But when I go in Gauges....nothing.
Xport config
GPS pluged in COM3 (XPORT Input)
Enabled ports Output
COM4 -- for iGuidance program (working)
COM6 -- for RR (working without Gauges)
COM7 -- free
Anybody know why my GAUGES still doesnt work even if my GPS is working in RR ??
Thanks again!
Never mind guys I FINALLY FIND WHAT WAS MY ERROR!!!!!!
In RRconfig>GPS> GPS Port: I had COM6 but I had to place only the number of the port!!!! F**KIN NOOB ERROR! lol
I post this because Im surely not the only one!!!
VmtSquad
05-17-2008, 05:06 PM
#1160
Raw Wave
No offence!
But that was just too funny...
Glad to see that you did figure it out and got it working, though!
I will also add that to the next config update, to only accept numbers for the port number..
05-17-2008, 05:18 PM
#1161
Confusion Master
Vehicle: 1997 BMW E36 328I
Yeah, it's all Blue's fault.
05-17-2008, 07:58 PM
#1162
Vehicle: 1981 Ford F-100
VmtSquad
You sure?
05-17-2008, 08:11 PM
#1163
Vehicle: 2003 Dodge Stratus
I've been using 2.5 for a while and love it. I installed 3.0 but have yet to get it to work correctly.
1) I cannot get the Streets and Trips application to open by pressing the GPS button that is assigned to Streets and Trips. The skin loads, but the app doesn't open.
2) In the Sirius skin I have no sat strength icon (or the ter icon) and I have not buttons for scrolling up, down, or select. It just has a slider looking icon that I can't interact with.
3) If I hold down favorites for icons in the Sirius skin, I get 1 screen full of icons like expected. I thought it was strange there was only 1 page of them, and I could see no way of scrolling or moving to another page, so I pressed the >>| button and Streets and Trips opened in the proper skin! WTF?!
4) Weather is messed up but I haven't tried fixing it yet. Only maps work, not location data is displayed.
I really like the way this skin is layed out and how it works. I just need to get these things resolved...
05-18-2008, 09:16 AM
#1164
Vehicle: 2000 Accord Coupe
Weird Jibberish
OK , I have DFX 3.0 on 2 different PCs. On one it works fine. On the other one after the main menu loads up I hear the PC say (as far as I can make it out), " background is set...set command labels 48....check icons.." What the heck is that??
I uninstall the skin and re-installed it and it still does it. This is the only skin it does it on. I also tried it on DFX2,BlueDevil, and BMV. Those are fine. So I figure it has to be something in the skin file and not RR file, right??
05-18-2008, 03:33 PM
#1165
Raw Wave
#1,2 & 3 As I don't use xxx, you'll have to look further up in the thread or look in the help file included with the skin in the helper folder.
#4 This is a known problem now, the weather feed that rr pulls that data from changed and messed up a whole lot of peoples websites and such. Check the Weather no working thread for a slightly older and modified "RoadRunner.exe" that would fix your weather problem
Do you have the voice enabled? That is about the only way that you would even hear RR speaking.
05-18-2008, 03:53 PM
#1166
Quote: Originally Posted by Blue ZX3
No offence!
LOL I wasnt laughing when I found my error!! But now I AM! lol Im always working late on my system, so its opening the door for stupid errors!! LOL
Its a good idea to add it to the next config, but then again its not a SKIN issue it was in the RR CONFIG!!
Well I hope my stupidity will help others!
VmtSquad - I sold my soul to Honda!
Final Install
CarPC progress: 95%
05-18-2008, 03:54 PM
#1167
Quote: Originally Posted by treetop777
You sure?
lol no comments lol
Final Install
CarPC progress: 95%
05-19-2008, 03:38 PM
#1168
Quote: Originally Posted by briansh73
The artist information on the main menu seems to be cut off at the bottom. Any ideas what would cause this? Everything else seems to be perfect.
Don't know if this has been posted but...
Here's how to solve this small display problem:
1)Open menu.skin edit those line :
Code:
L,525,85,255,29,#DFX1R#,#DFX1G#,#DFX1B#,23,"Trebuchet MS","TAGALBUM","LEFT"
L,91,85,359,33,#DFX1R#,#DFX1G#,#DFX1B#,23,"Trebuchet MS","TAGARTIST","SCROLL-LEFT"
L01,91,35,523,42,#DFX1R#,#DFX1G#,#DFX1B#,25,"Trebuchet MS","TAGTITLE","SCROLL-LEFT"
Change the RED number by 50.
2) Do the same modification with menu2.skin
This mods will change the height of the labels so that way the names won't be truncate. You can also change the font if you want by replacing the "trebuchet" by your favorite font.
Final Install
CarPC progress: 95%
05-19-2008, 04:12 PM
#1169
Vehicle: 2007 Honda Accord LX
VMT, I think there is another place that these changes need to be made if memory serves me correct. I think if you change the theme then these numbers will get overridden, I could be wrong.
05-19-2008, 04:49 PM
#1170
Vehicle: 2005 Acura TL
This is a known issue. John forgot to add the indicators to the skin. Somebody posted a patch earlier in the thread, but I forget whether it was just for XM or both Sirius and XM. Search the thread for XM or Sirius and it should come up.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
iseeroger
| Thread Tools |
| Display Modes |
Linear Mode
