Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 07-25-2008, 09:26 PM   #1666
LinuxRacr's Avatar
Quote: Originally Posted by Dougw133 View Post
Well it's working great. My only issue (on my end) is that my CPU load has increased marginally...
I can't afford to have that happen with my PC I don't think..
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Current build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Old 07-25-2008, 09:50 PM   #1667
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
Please, post your experience with building the database, either that it worked no problems for you, or if you had issues. I can't stand the silence!
Also any bugs that you find, as soon as you find them, so I can get them fixed as soon as possible.
Please feel free to contact me on Yahoo Messenger at JohnWPBFL. I am usually up late, and if I am sleeping the speakers are off.
Front End of Choice: Road Runner (Is there anything else??? )
& Powered by the DigitalFX 4.0 Skin
Available at www.JohnWPB.com
JohnWPB is offline   Reply With Quote
Old 07-25-2008, 09:56 PM   #1668
TimmyM's Avatar
Yeah, start a FX4, I've already found bugs
TimmyM is offline   Reply With Quote
Old 07-25-2008, 10:00 PM   #1669
SD beats everything. So there.
danielkh's Avatar
Did a quick load on my laptop and have not even looked at any special loading instructions that might be out there, but since you asked. Tried building database and got an endless stream of com errors.
Oh yeah, it also changed the fonts on my computer. Time to restore! lol
Nissan Carwings Inspired Skin for StreetDeck Here
My opinion is my own.
danielkh is offline   Reply With Quote
Old 07-25-2008, 10:02 PM   #1670
Changed my whole OS font to the default skin font. Changed font back to Ariel in skin and remained the DFX4 default font.
I'm running this on Cy2.0 GHZ Board, 1mb of ram, 250GB sata drive and it is very sluggish.. Any ideas?
Dougw133 is offline   Reply With Quote
Old 07-25-2008, 10:14 PM   #1671
No issues loading the db. Loaded 834 songs in 3min 43 sec. Only issue so far is on the gauges, the cpu jumps from ~8% to 100% then back down to and holds at 78%. I currently have this installed on a desktop with no gps receiver attached. That could be the cause of increased cpu usage as it may be searching for the receiver. I'll update once I install in vehicle.
rsrblade is offline   Reply With Quote
Old 07-25-2008, 10:16 PM   #1672
treetop777's Avatar
This MF is BAD AS*! No problems so far
treetop777 is offline   Reply With Quote
Old 07-25-2008, 10:24 PM   #1673
JohnWPB's Avatar
Not sure what the font issue that you guys are talking about, it installs 4 new fonts in the windows font folder. These are not set for use by windows in any way, and when you change the font in the skin, it simply save the font name to a include.txt file so the skin uses that font name. For instance if you set the font to ariel, it saves a include file with dfxfont="ariel" then in the skins it uses #dfxfont# as the name of the font.
Bottom line is that the font, when selected, just writes the name to a text file that the skin uses. It in no way changes the font that the OS is using.
Old 07-25-2008, 10:46 PM   #1674
John, the font on my OS changed upon the completion of install/restart. Not when changed in skin. The font was changed before i even opened RR for the first time to see the DFX4.
I also am getting a flashing mouse/hour glass on top of the skin, If I close the running Scripts in the taskbar it stops..
Otherwise, it is amazing.. Absolutely phenomenal.
Old 07-25-2008, 10:48 PM   #1675
I am playing with it on my desktop as well and at Idle in the skin my CPU is 1%. I have no gps hooked up on the desktop either. It is also a AMD FX Dual core, 2GB Ram, and Nvidia 8800GTX running the graphics so.....
Old 07-25-2008, 11:37 PM   #1676
So I am going to chalk up the poor performance to my motherboards on board video chipset. I have it running lowest possible and it is a little better. Also switching to a static logo away from animated analog clock cut my CPU use by 35%.
Only other issue, I have had RR freeze in the Gauges screen twice now.
On a good not, It fixed my newly installed HD radio that wouldn't work.
Old 07-25-2008, 11:51 PM   #1677
I'm so lonely on here
Where is everyone?
Old 07-26-2008, 12:14 AM   #1678
I noticed the cpu issue in dfx3.0 with the animated logo. Going to a still logo fixed that issue as well.
Old 07-26-2008, 12:20 AM   #1679
Jebus's Avatar
LOL Dougw133
John, The Install changed my fonts also, although I believe it just made them "bold".
As for Flash, It is what it is, so, I also just reduce its use in the skin..
Very NICE Job!!!! I cant wait to dive in!
ROAD RUNNER Needs it's own Board!!!
....JJG
Jebus is offline   Reply With Quote
Old 07-26-2008, 01:07 AM   #1680
DFX Menu Button Editor AutoIt Error
Error: Array Variable has incorrect number of subscripts or subscript dimension range exceeded.
This is what was on the screen when trying to run the DFX Menu Button Editor with DFX4
drewbp is offline   Reply With Quote
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
