Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 03-10-2008, 06:21 PM   #196
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by BREWDOG52 View Post
I wonder how you got that many posts.
Don't make me tell you to stop posting if it doesn't contribute to the thread Enforcer, cause I will.
EDIT** I mean we all want to get to that 9000 post count
Careful, otherwise Oregon might just fall off the map
Enforcer is offline   Reply With Quote
Old 03-10-2008, 06:29 PM   #197
Quote: Originally Posted by boriman View Post
Just downloaed and install it on my work pc and have that famous vertical bar instead of the skin. I fixed this problem before for a few piople a while back, but can't remember waht it is now :-(
Can someone pleas help me?
ooh i know this one..
I was playing with my settings and ceated that.. if you are using road runner config app by blue zx3 you need to make sure "video redraw" or something like that is set to "gdi" not on , not off,.
using Mobile Impact,Waiting on the rds radio.
nigwhyrito is offline   Reply With Quote
Old 03-10-2008, 07:20 PM   #198
does any1 nows how to Disable Motion Lock on Video Screens?
shot598 is offline   Reply With Quote
Old 03-10-2008, 07:57 PM   #199
Raw Wave
Blue ZX3's Avatar
skin folder > plugins.txt
chanege X,Motion > /X,Motions
save and close...
Done
Blue ZX3 is offline   Reply With Quote
Old 03-10-2008, 08:54 PM   #200
DaveDog's Avatar
save and close...
Done
uh, no. Plugins.txt file contains the following:
X,Motionlock
X,MOVIETIMES
According to the readme file, you remove the X,Motionlock line.
Why is my laptop all wet?!
DaveDog is offline   Reply With Quote
Old 03-10-2008, 08:58 PM   #201
thanks got it
Old 03-10-2008, 09:01 PM   #202
can the vol goes up to a 100 mine is on 50
Old 03-10-2008, 09:09 PM   #203
esko's Avatar
Quote: Originally Posted by treetop777 View Post
Lots of good info flowing already - Don't forget the DFX Wiki..stick this info in there.
HA Ha ha I know what I'll being doing this weekend!
esko is offline   Reply With Quote
Old 03-10-2008, 09:20 PM   #204
Confusion Master
Enforcer's Avatar
X,Motionlock
X,MOVIETIMES
Don't worry, that's what Blue meant, he just hasn't quite got the hang of Notepad yet.
Either that or he's having trouble with his motions.
Old 03-10-2008, 11:28 PM   #205
BREWDOG52's Avatar
dang it, now I have to create a new user name just so I can talk shi.....I mean, sorry Enforcer
BREWDOG52 is offline   Reply With Quote
Old 03-10-2008, 11:36 PM   #206
Confusion Master
Enforcer's Avatar
6 5 more to go
Old 03-11-2008, 12:19 AM   #207
BREWDOG52's Avatar
6 5 more to go
8877 for me
I hope a mod bans you
Old 03-11-2008, 12:24 AM   #208
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
Q&A Time
Damn, this thread is growing too fast! Checked it this morning, and now there are 3 more pages. I will try to keep up with the questions, if I misses something let me know.
GPS in the main menu. That would take some doing, as there is an application area at the top of the skin defined for the visualization. Only one application can be on any single skin at a time.
HD Radio switching between AM & FM: This is due to something with the hardware, or the way the plugin was written. Check the HDRadio thread, there is something you have to manually create and rename a text file or something, then the AM/FM Toggle will work.
Numbers instead of buttons: Somehow the font was uninstalled. The icons are now actually a font, and not graphics so the color can be changed.
Video menu bar not hiding. That is a new one to me! I have never seen it on any other skin than on the Video Player skin. Something is really screwy somewhere, and I have no idea where to look for it. Sorry....
Sirius and XM signal strength not showing correctly: Unfortunately I do not have either here, so I have no way of testing that one. If someone fixes it, please share the fix/code with me and I will make sure it is in the next release
Image viewer: It was installed with the skin and is in Road Runner/ImageViewer
You will need to open the imageviewer,ini and set the path to your images for them to show up. FOr more info on it check the help file.
Quote: Originally Posted by shot598 View Post
does the movie showtime
I think so
I don't
Me either.
8877 for me
Huh? What did I miss?
I will be out of town.... well actually out of country, in Canada on business for a week or so. I'm not looking forward to the weather, I am told there is 2 feet of snow on the ground! I will have to dig and even see if I have a winter coat somewhere! I am not sure how much time I will have to check the forums, so if I appear to have deserted the questions, I will be back early next week and will try to answer any questions then.
On a final note, BlueZX3 and I talked for almost 5 hours last night working on his music database for Road Runner. He has done an amazing job with it, now I have to do my best to incorporate it into the skin, in an easy and user friendly way. There are just SO MANY options available, (Sorting, Searching, 10 Disk Changers, Virtual play lists, browsing modes, Ratings, all with a database that stores everything so it is lightning fast!) I could fill 2 screens with just buttons to take advantage of everything that it can do! If all goes well, this should, and hopefully will be available in the next release.
Front End of Choice: Road Runner (Is there anything else??? )
& Powered by the DigitalFX 4.0 Skin
Available at www.JohnWPB.com
JohnWPB is offline   Reply With Quote
Old 03-11-2008, 12:40 AM   #209
BREWDOG52's Avatar
Just messing with Enforcer.
Old 03-11-2008, 08:08 AM   #210
the_crooked_toe's Avatar
Quote: Originally Posted by esko View Post
A few questions:
2. Can someone explain how Lyrics work? Do I need the lyrics installed prior to running the DFX3? Where do we get them? PM. Thanks
You have to embedd the lyrics into the ID3v2 tags of ALL your mp3s. it's fun I know. This program actually does remarkably well. There is going to be some trickery involved into getting it to work.
Start here: http://www.mp3car.com/vbulletin/road...ic-tagger.html
Then start here: http://www.mp3car.com/vbulletin/rr-s...eased-175.html
Posts 2612-2659 in the original DFX 2.0 thread, was the progress I had into getting the program to work correctly.
the_crooked_toe is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Lucky13ESP
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
