Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 04-25-2008, 08:22 AM   #931
the_crooked_toe's Avatar
Quote: Originally Posted by treetop777 View Post
^^^ Seems to me that won't do it. The OP is talking about a trigger when there is NO MOVEMENT - it has to be something tied to the GPS or something.
And BTW - Not all of us live in a warzone! FORTUNATELY!
i understand he wants something involved with the GPS, but that just means more work for john
here is shutcontrol
so when he turns off his car the PC will shutdown automatically after a given period of time
EDIT**
I just thought about this myself... Even shutcontrol might not work at times (i've got a laptop also) and if for some reason the AC/DC inverter becomes unplugged, or the cord jiggles out, etc, removing power from your system while you are driving then this program will execute. I still go to Menu -> Shutdown when i get out of the car.
the_crooked_toe is offline   Reply With Quote
Old 04-25-2008, 10:07 AM   #932
A laptop with correctly configured power profiles will take care of all that. I have mine setup up to hibernate 1 minute after switching to battery. That means that it will hibernate 1 minute after turning off the car. Whenever I need to vnc in to do some adjustments, I need to modify the power profile to stop it from hibernating because it WILL hibernate at the first chance it gets
silvi4000 is offline   Reply With Quote
Old 04-25-2008, 12:50 PM   #933
I agree that it can be done. I'm merely stating that if for some reason you lose your A/C power supply connection from hitting a bump in the road, wire disconnection, etc. Your PC will default to your software's configuration.
OK no more thread crapping from me. this is about DFX and not about laptop users.
Old 04-25-2008, 08:34 PM   #934
why does after loading the skin goes back to the original?
any clue?
I could not find any answers.
russoxley187 is offline   Reply With Quote
Old 04-26-2008, 12:18 AM   #935
when i edit "temp 1" to SFT 1 or to waht ever my value is in menu.ini and menu2.ini to get the temp display on the menu skin , it works perfectly after saving the file.
buttttttt when i exit road runner and load it again then the " sft1" goes back to TEMP1 again in both the files!! why is it so ?
can any one help me.
and John can we have another clock for the clock_logo please?
monty9991 is offline   Reply With Quote
Old 04-26-2008, 02:04 AM   #936
BREWDOG52's Avatar
change all the menu/menu2.skin files...
/menus/compass
/menus/digitalclock
/menus/photo
/menus/spinninglogo
as for a different clock...google for flash clocks, then save it in the 3dlogos folder, then you can select your new clock within DFX..
EDIT* here's some sites to look @
http://edmullen.net/fclock.php
http://www.csalim.com/gallery.php
http://toolshell.org/
http://www.clocklink.com/gallery.php...ry=TRANSPARENT
http://www.adamdorman.com/gallery.ph...e=flash_clocks
this ones kinda cool...
http://edmullen.net/glow.php
BREWDOG52 is offline   Reply With Quote
Old 04-26-2008, 02:12 AM   #937
Raw Wave
Blue ZX3's Avatar
The next release is so much nicer to work with, no more having 4 different menu skins to edit...
Blue ZX3 is offline   Reply With Quote
Old 04-26-2008, 02:34 AM   #938
/menus/compass
/menus/digitalclock
/menus/photo
/menus/spinninglogo
thanks for the help.. but were can i find these menus?
and i want a clock in which i can put my logo in it.
Old 04-26-2008, 02:36 AM   #939
hope it get more easy to use DFX'x next version..
and BTW when is it comming out? waiting for it eagerly
Old 04-26-2008, 02:43 AM   #940
BREWDOG52's Avatar
C:\Program Files\Road Runner\skins\DigitalFX 3.0\Menus\Compass
C:\Program Files\Road Runner\skins\DigitalFX 3.0\Menus\DigitalClock
C:\Program Files\Road Runner\skins\DigitalFX 3.0\Menus\Photo
C:\Program Files\Road Runner\skins\DigitalFX 3.0\Menus\SpinningLogo
sorry... my psychic powers are failing me
learn to make one I guess.......unless someone has already made one using your logo
Old 04-26-2008, 02:52 AM   #941
thaks for the file locations and i was talking about this kind of clock .. this was way easy which john made. you can put any logo in it. and i want to change the clock if possible while using the power of switching logos inside it.
http://www.mp3car.com/vbulletin/1203686-post898.html
Old 04-26-2008, 03:01 AM   #942
BREWDOG52's Avatar
ok now I understand what your after....but can't help you out there.
Old 04-26-2008, 03:09 AM   #943
no worries.. but i appricite your help though
Old 04-26-2008, 03:21 AM   #944
BREWDOG52's Avatar
Here's one for bmw i whipped up real quick....if you give me your logo I can see what i can do.. it's kind of a "permanent" fix...it can be changed outside of RR though..
if you want a different clock it has to be transparent..just post what you want...
John could probably make it simpler though.
Edit*
guess I should post the SS
Edit**
fixed dimensions of the logo...SS updated
Old 04-26-2008, 03:25 AM   #945
oh k.. now this is kooooollll... pm me your email add ill send as atachment.
thanks
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
