Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 05-13-2008, 12:55 AM   #1096
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
Nice install tabamoura! Unfortunately the fonts are not scaling correctly in Road Runner. Road Runner is scaling everything else correctly, but not the font sizes for some reason. The skin was created to work at an 800 x 600 resolution, and the fonts just do not scale to the correct location at non standard resolutions. (640 x 480, 800 x 600 & 1024 x768 all work correctly)
Front End of Choice: Road Runner (Is there anything else??? )
& Powered by the DigitalFX 4.0 Skin
Available at www.JohnWPB.com
JohnWPB is online now   Reply With Quote
Old 05-13-2008, 09:10 PM   #1097
what kinda cable do I need so I can view my OBDII parameters?
Werm9 is offline   Reply With Quote
Old 05-14-2008, 02:37 AM   #1098
Question Can't Get iGuidance 4.0 To Work In DFX 3.0
I TRIED,AND TRIED... I installed iGuidance 4.0 ,w/ BU-353 and followed the directions on rr and dfx pages ,I checked and unchecked and made iGuidance native in the rr.ini setup program .I even downloaded and tried xport .I clicked on GPS button in DFX 3.0 skin and nothing happens.The skin for iGuidance doesn't even open .It works outside of skin with no problems. So can i have a step by step of directions with pics (PLEASE) from somebody that could direct me in the right area . (someone said it works right out of the box?) I differ. also what part of iGuidance is every one using,regular or UMPC version. i tried both and still nothing.so again, i really appreciate if anyone could give me a hand in this.It's also very difficult to find a straight foreword answer for this gps how to's on 74+ pages and counting...........phew! This is the very last program to add to this robust and very thought out skin. Thanks Again.
THEREALRAWPWR is offline   Reply With Quote
Old 05-14-2008, 06:26 AM   #1099
funkyphil's Avatar
Here is how my IG 4.0 is setup in RR. I also am having no problems with it. It actually works really well and has got me out of some pretty bad areas with the quickness! Good luck.
Phil
www.philscustomcomputers.com
funkyphil is offline   Reply With Quote
Old 05-14-2008, 06:31 AM   #1100
funkyphil's Avatar
John thanks a Million with all your help. Hey peeps here is the reply to my PM that john sent. Just wanted to add it incase someone else had the same question. Most websites have their own built in player, and do not offer streaming that winamp can use. The key is if you can get it to play in winamp (stand alone) you can save it as a playlist and load it up at any time.
Thanks again John
Phil
Old 05-14-2008, 06:54 AM   #1101
treetop777's Avatar
That works? i thought it supposed to be "iGuidance" - then again, i haven't tried it any other way so i guess it does - learn something new every day!
treetop777 is offline   Reply With Quote
Old 05-14-2008, 07:07 AM   #1102
JohnWPB's Avatar
Yea, the window titles for RR are not case sensitive.
Old 05-14-2008, 09:39 AM   #1103
Sorry guys ,but i did all that .Treetop777 did you use xport for your setup or not ? and on the two RR pages showing ya' how to set up iGuidance (how to setup iGuidance) is very confusing,do i need to follow that to the letter? whats weird is the skin showed up when i first installed skin some while ago to see what each screen skin looked like ,now it doesn't even show up?and also the other setup screen for seting this up keeps getting grayed out every time i reopen rr.config.this is not normal.oh and another thing i forgot to mention ,i installed 2.0 after 3.0 because someone said that some options or settings in some files in 2.0 didn't make it in 3.0 so i installed it over 3.0 . i didn't think it would matter . would it?......thanx again all.
Old 05-14-2008, 09:59 AM   #1104
treetop777's Avatar
Yeah, you must use xport if you want to feed gps data to both iguidance and roadrunner.
I would do a fresh intall of 3.0 first, i did on a formatted drive and haven't had any problems with missing settings - i'm sure there's nothing in 2.0 that 3.0 needs to run IG.
IG should work right out of the box.
Report back..
Old 05-14-2008, 10:24 AM   #1105
Thanks Treetop777 , i guess i'm gonna haveta' reinstall 3.0 .also what settings are used in xport to work right? this addon did not have a how to readme setup file in the download ???? so where do ya' install this .in RR directory , in C: or in My Programs? hey thanks bud......
Old 05-14-2008, 10:31 AM   #1106
Did you replace the Iguidance.exe with the patched one from JohnWPB's site?
If not, give it a try
silvi4000 is offline   Reply With Quote
Old 05-14-2008, 10:41 AM   #1107
Thanks silvi4000,where do ya' install this .in RR dir.,DFX skin or in iGuidance dir.........
Old 05-14-2008, 11:09 AM   #1108
Machinehead's Avatar
Xport can be installed anywhere. It's completely independent of RR, iGuidance, etc.
Machinehead is online now   Reply With Quote
Old 05-14-2008, 11:42 AM   #1109
treetop777's Avatar
Yep, and here's a good wiki on it: http://www.mp3car.com/wiki/index.php/GPS_Splitter
Old 05-14-2008, 04:25 PM   #1110
IT WORKS NOW .....YEAH !!! I deleted DFX 3.0 and reinstalled and what do ya' know the iGuidance works now.it's embedded and works pretty well. now another problem raised it's ugly mug- NO MORE HDRADIO ! i rereg. the files and nothing.the hdradio skin loads no problem .i can see all the channels that i saved recently ,but nothing ,no sound and no indicators ? it doesn't even click on .so now what? please help .thanks all for your help here people......
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
