The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 05-22-2008, 11:01 AM   #1186
Vehicle: 2004 Honda Civic Hybrid
My Photos: (0)
Quote: Originally Posted by kbreeden View Post
Add "m3u" (no quotes) as an audio file type in the music portion of RRConfig and see if that does the trick.
Hi Kbreeden,
I put the m3u without quotes in the audio file type in the music section of RR configirations. Nothing happened. Is there a certain way to set it up in winamp or to set up the directory in RR config? I can browse all the songs of the directory that I put in RR config, but no artwork is coming up. Do you know what I might be doing wrong?
cameronlazzari is offline   Reply With Quote
Sponsored Links
Old 05-22-2008, 11:26 AM   #1187
kbreeden's CarPC Specs
Vehicle: 2005 Acura TL
My Photos: (0)
Quote: Originally Posted by cameronlazzari View Post
Hi Kbreeden,
My "add m3u" post was in response to an earlier poster who couldn't get his playlists to appear. That has nothing to do with album art.
There's nothing you need to do with Winamp in order for album art to appear. Are you seeing your album art when you're viewing the full player? Or is it just when you're trying to browse by album art that it doesn't appear?
kbreeden is online now   Reply With Quote
Old 05-22-2008, 11:28 AM   #1188
My Photos: (0)
Quote: Originally Posted by PacketSniffer View Post
John,
It's not in weather, color chooser, or the gauges. I seldom use those. However, I am in the Music browser, Play list menu, or main screen a lot. It locks up here, especially the music browser. There are some others too but can't remember exactly which ones. I know about the flash issues and can resolve that one on my own like I did initially and that's how I got the logo (I'm using the multi clock, speedo, tach, etc one) to work in the first place. So, flash *seems* to be fine for me fwiw.
What version of Winamp are you using? I had similar issues when I was using any version other than 2.95 or 5.13. You need to be using one of those versions.
Old 05-22-2008, 11:41 AM   #1189
My Photos: (0)
Kbreeden,
Neither. I don't see any art at all. I looked in my music directory and all the jpg were not there. When I went into my control panel I checked to show hidden files and they appeared. ..But when I look at the properties they are marked hidden and won't let me uncheck them. Can the jpg be in the same folder as the audio files?
Cameron
Old 05-22-2008, 11:48 AM   #1190
carputer1's Avatar
My Photos: (0)
Cameron
have alook here about albumart
http://www.mp3car.com/vbulletin/rr-f...et-images.html
MKIII Skin,RoadRunner,D7 , Gatso Hunter ,MediaLaunch ,Tag Editor ,
carputer1 is offline   Reply With Quote
Sponsored Links
Old 05-22-2008, 05:05 PM   #1191
marteline's CarPC Specs
marteline's Avatar
Vehicle: 2006/VW/Gol Power 1.6
My Photos: (0)
media copy
Hello John, long time form our last talk...
I am trying to use the media copy, but I canīt access my pen drive or other external device trought him... I click into refresh, it show the drive letter, but donīt change to the respective drive letter when I click it...
I tried into the explorer and the device works great... and when I try the media copy with a hard drive partition, it is working very well... The problem just happens with external drives...
Could you help me?
I search in the forum... but canīt find the solution...
Thanks...
Engineering: Where the rubber meets the road!
marteline is offline   Reply With Quote
Old 05-22-2008, 08:36 PM   #1192
My Photos: (0)
John,
I too have experienced those freezes. You can move the mouse around but the skin wont respond to input. Not having a keyboard available, the only solution is to press the power button until the carputer shuts down.
At some point I thought that it was caused when going to hibernation while listening to internet radio, and then resuming with the data card not connected so internet was not available to resume playing radio. Tried to reproduce the hangs doing this but they only happen once in a while.
silvi4000 is offline   Reply With Quote
Old 05-23-2008, 02:53 AM   #1193
kyjoe's CarPC Specs
Vehicle: 2000 Accord Coupe
My Photos: (0)
I am also having problems with it not responding to the mouse. I notice it mostly on the Iguidance screen where the buttons are at the top and bottom.(not on the left/right side) I can hit "IG Menu" and nothing happens. The toggle button works, but basically none of the other ones do. Try it maybe 10 min later, and they all work!
I have been using DFX 2 all this week and no problems at all.
kyjoe is offline   Reply With Quote
Old 05-23-2008, 02:50 PM   #1194
drewbp's CarPC Specs
My Photos: (0)
+1
drewbp is online now   Reply With Quote
Old 05-24-2008, 11:32 AM   #1195
My Photos: (0)
Thanks carcomputer for the link. I got the artwork to show. It turns out all the jpegs we hidden by window...which is a common thing that happens when you rip cd from WMP. Any way what worked is I went in to my start menu to run and typed in command. I told it to go to "attrib -r -s -h *.* /S " with out quotes and changed the artwork from hidden to unhidden. I hope this helps others since it took me a while to get this figured out. Here is another link I found.
http://www.mediamonkey.com/forum/viewtopic.php?p=118637
Old 05-24-2008, 11:39 AM   #1196
carputer1's Avatar
My Photos: (0)
Old 05-24-2008, 11:39 AM   #1197
My Photos: (0)
Minimize in DigitalFX3.0
I can't figure out how to set up a button or can't find the button for minimizing in DigitalFX3.0 Anybody out there know where it is or has solved this issue?
Old 05-24-2008, 11:53 AM   #1198
carputer1's Avatar
My Photos: (0)
minamize is top RIGHT corner
change button press and hold any menu button
Last edited by JohnWPB : 05-27-2008 at 12:01 PM. Reason: The minimise is in the top right corner on the main menu, not the top left
Old 05-24-2008, 12:03 PM   #1199
Ramanator's CarPC Specs
Vehicle: 05 Dodge Ram
My Photos: (3)
Check the Helper Files. The Minimize button is hidden and is in the top Right Corner on the main menu. (Tried to upload pic)
If you cant DODGE em, RAM em.
Ramanator is offline   Reply With Quote
Old 05-24-2008, 12:08 PM   #1200
carputer1's Avatar
My Photos: (0)
lol forgot my left and rights , damn this deafness is screwing with me lol...
Sponsored Links
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
kbreeden
vB code is On
Trackbacks are Off
Scribble Pad Slow in RR DigitalFX CornEggz Road Runner 3 03-07-2008 05:04 PM
iG 3.0 Crashes When Driving Through Tree Shaded Areas? LiquidKernel GPS 10 08-22-2007 05:10 AM
IGuidance 3.0 and Embedding RR EricE GPS 7 03-06-2007 05:48 PM
Sproggy Mk 3.0 Kits For Sale Mastero Classified Archive 26 11-09-2003 01:50 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
