The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Search this Thread Display Modes
Old 05-20-2008, 10:38 AM   #46
WaRFiElD's CarPC Specs
Vehicle: BMW E46
My Photos: (0)
Thanks ALOT Dan! I love the new look of the BMW screen! Gotta try this tonight
WaRFiElD is offline   Reply With Quote
Sponsored Links
Old 05-21-2008, 02:26 AM   #47
My Photos: (0)
Dan, you are my god ;-). The Last screen with all ligths are very good.
jarro_25 is offline   Reply With Quote
Old 05-21-2008, 02:40 PM   #48
Jaskari's CarPC Specs
Vehicle: 2003/BMW/E46
My Photos: (0)
This is a great skin with BMW IBus functions, I love it! With FreeFone it would be perfect Browsing music with steering wheel buttons is great (although page up and page down are backwards, dunno if it is iGoBMW issue?).
There is one thing I haven't figured out yet: how to turn off vis in audio player skin (to show CD cover)?
Anyway, thanks for great skin!
Jaskari is offline   Reply With Quote
Old 05-21-2008, 04:54 PM   #49
dan32500's CarPC Specs
Vehicle: BMW E46 325Ci
My Photos: (1)
Click the CD cover again to turn it off, but you need to set VIS to transparent in RRconfig first. (I noticed the albumart does not show back after this - need to reload playlist I think)
The IbusRR.ini in my skin should have the correct UP/DOWN for the audio player screen.
Thanks all for the feedback!
OT: Go on Man U!
dan32500 is offline   Reply With Quote
Old 05-23-2008, 01:14 AM   #50
My Photos: (0)
part from your IBusRR.ini:
Code:
[audio_player.skin] PREV_PRES="DOWN" PREV_QUICK_REL="" PREV_HOLD_REL="" PREV_HOLD="PGUP" NEXT_PRES="UP" NEXT_QUICK_REL="" NEXT_HOLD_REL="" NEXT_HOLD="PGDOWN" PLUS_PRES="" MINUS_PRES="" PHONE_PRES="!SWITCHSCREENS!" RT_PRES="PLAY" REPEAT_HOLD_CMD=1
I think PGUP and PGDOWN should be placed the other way around, but I guess it is a matter of opinion.
Dan do you know the code for changing Fahrenheits to Celsius in OBC (like consumption unit is changed in SET_OBC_TO_L100Km)? I don't have OBC in my car and BMW skin shows fahrenheits instead of celsius in outside temp. Or is there a way in Roadrunner to take part of $OUTSIDETEMP$ (stripping + and C) and then doing a conversion (C=F-32x5/9)?
Also one thing is bugging me.. after stopping the engine RPM meter wont go to 0. Is this normal?
Sponsored Links
Old 05-23-2008, 04:20 AM   #51
My Photos: (1)
Oh yeah, I only changed the single press command, I have't noticed the hold command cose I didn't use it.
I'm not sure of a code to change C/F and 12H/24H - I used the right knob on the cluster. Maybe warfield knows cose he gave me the code for L/100Km.
You can try editing bmw.skin to convert F to C:
L,610,271,167,19,240,240,240,14,"Arial:B","=OUTSID E: $OUTSIDETEMP$","CENTER"
TO
L,610,271,167,19,240,240,240,14,"Arial:B","=OUTSID E: $OUTSIDETEMP$","F2C"
I think the RPM thing is cose of the pugin not updating the variable to 0 when doesn't find a value in IBUS.
Old 05-23-2008, 05:29 AM   #52
My Photos: (0)
TO
Tried F2C instead of CENTER, but it didn't help. Maybe it wont work because $OUTSIDETEMP$ variable shows +54 C and not +54 F (RR thinks, that it is already fahrenheits). Gotta ask from Warfield if he can think of something..
Maybe Warfield could add something to IBusRR for detecting when motor is not running and then reset RPM variable inside IBusRR and update RPM to RR..
Old 05-23-2008, 01:53 PM   #53
Dave323Ci's CarPC Specs
My Photos: (0)
Nice Skin! The IBUS stuff is terrific. One question.... do you have a code to switch OBC back to MPG? (Edit: Disconnecting the battery works!) However a code would be a lot more elegant. Not to mention easier to do while driving
Dave323Ci is offline   Reply With Quote
Old 05-24-2008, 10:23 PM   #54
My Photos: (0)
Excellent BMW skin. iGo is now my main RR skin. One thing I couldn't figure out:
I used to be able to use my Navi right knob to scroll through the menu items and pressing on the knob acted as [ENTER] with LSX, Simplistque, or FX skin. I couldn't do the same with iGoBMW. Any ideas or help is appreciated. Thx!
mjassbong is offline   Reply With Quote
Old 05-26-2008, 06:13 AM   #55
My Photos: (0)
i am only getting a vertical small (pink) bar with this skin where i can see half of the compass/speedo, although background path set. anything to do with flash - special version or player required?
upspace is offline   Reply With Quote
Old 05-26-2008, 06:39 AM   #56
My Photos: (0)
I had the same problem... check your rr.ini file for fastmode line.. it should be "fastmode=-1".
Old 05-26-2008, 01:32 PM   #57
My Photos: (0)
hhhm not for me. any other tips?
Old 05-26-2008, 02:40 PM   #58
My Photos: (1)
Check again and make sure a valid background is set.
You will need to update IbusRR.ini with your previous settings but in the new format.
Sorry, I don't, will have to wait for WaRFiElD to come back.
Old 05-26-2008, 03:54 PM   #59
My Photos: (0)
Hi, where can I download or buy iGo8 please?
I use actually sygic but I always get problems with RR using any GPS software
AzN_Tuan is offline   Reply With Quote
Old 05-31-2008, 07:21 AM   #60
Asterix1965's Avatar
My Photos: (0)
Hello,
Despite its adobe flasplayer installed in PCs used by car makes me not view the files *.swf menu Bmw.skin
Also in the menu change background I do not see backgrounds
Do you know how to solve the problem ?
Tanks
Asterix1965 is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Digital FX 2.0 Transparent Released JohnWPB RR Skins 3759 03-07-2008 12:23 PM
Need help. transparent _EMPTY files and invisible buttons austin683 RR Skins 5 01-06-2008 09:36 PM
transparent tutorial? davidp RR Skins 3 08-28-2007 09:24 PM
Winamp transparent visualization issues TSur Road Runner 1 06-12-2007 05:54 PM
Transparent skins possible??? Supergong FreeDrive 4 01-13-2006 02:25 PM
Sponsored Links
Ad Management by RedTyger
