Quote: Originally Posted by
funkyphil
1.how do i access more buttons, such as tv, sirius, and so on, I would like to switch them around from screen to screen as well.
Hold in on the button you want to change and a list of buttons will appear for you to choose.
funkyphil
2.how do i get the visualization to work up a the top while the songs are playing on the main screen?
Use winamp 5.13...can be downloaded from
www.oldversion.com
You'll have to read about the setting for the vis as i dont have time to explain them all to you...
funkyphil
3. It says in the readme file to install media player classic. WHERE do i download that from and where do I install that to?
It's already installed with the roadrunner installer....you may just have to point to it in the config application....using the browse....its in the roadrunner folder/mplayerc.exe i believe...
funkyphil
4. I will be buying iGuidance next and want to make sure this one is the correct one and the newest or at least the best working one for RR. Please advise
iGuidance N. America v4 Software DVD + BR355 Mouse Receiver
Cable Options: USB (for laptop)
I'm pretty sure 4.0 works with DFX3...but i know 100% that version 3.0 work perfectly....its up to you if you want to try 4.0
funkyphil
5. Why does RR freeze when I click on VIDEOS?
Make sure you use the config application and point out everything it asks for....there is a setting asking for the default video folder...use the browse and point it to the folder where your videos are...
funkyphil
6. How can I change the clock from reading Military time?
Again using the
CONFIG APPLICATION Under General -> Page 1 -> Uncheck "Use Internationalization"
The guys above are right....search the forums....ALOT!....there is a ton of information in these forums already....the search button is your friend....a good start for you is to go through the Config application thoroughly....
