Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 04-06-2008, 06:59 AM   #1
我的RR不能用含有png格式图片的
我的Road Runner不能用包含有“.png”格式圖片的皮膚(skin),只要用含有“.png”格式的皮膚(s kin)就變成如附件所示的顯示,並導致不能使用。請問是什麼問題?
請精通中文的朋友給翻譯一下。
以下是啟動Road Runner後出錯的螢屏抓取:
cgjt is offline   Reply With Quote
Old 04-07-2008, 07:46 AM   #2
Valheru's Avatar
in a DOS box, goto your Roadrunner folder and type in the following ...
C:\windows\system32\regsvr32 GDIPlusWrapper.dll
Then re run roadrunner.
Check out the TEKNIK skins here
Valheru is offline   Reply With Quote
Old 04-07-2008, 11:38 AM   #3
Воя смотрю япошка мы с тобой оба как шланги сидим с незнанием английского языка
RUSSIA - WINER!!!
pafftis is offline   Reply With Quote
Old 04-08-2008, 07:43 PM   #4
Ok, i can't understand anything that the OP said. But, as they say, a picture says a thousand words.
My RR is doing it at the moment too.
How do i do a DOS box to input
hydie is offline   Reply With Quote
Old 04-08-2008, 07:50 PM   #5
Fusion Brain Creator
2k1Toaster's Avatar
Start-->Run-->cmd
Or if you dont have the Run box Start-->Programs-->Accessories-->Run-->cmd
that will bring up the DOS emulator.
Also you dont really need that full path if your globals are set correct. So if you just type regsvr32 it should know what you mean
Old 04-08-2008, 09:16 PM   #6
MGD
MGD's Avatar
I am out of here.
This is getting way over my head.
I think I will relax a little.
ad watch it from the distance.
MGD is online now   Reply With Quote
Old 04-08-2008, 09:26 PM   #7
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by 2k1Toaster View Post
开始-> "运行- >" C M D公司
或者如果你不用有运行框开始-> "程序" - >配件-> "运行- >" CM D公司
这将造就的DOS模拟器。
此外,你不用真的需要这种全路径,如果你的全局变量是一套正确的。因此,如果你只需要输入regsvr32 应该知道你的意思
if the OP can't write english, I suspect he also can't read it.
Enforcer is online now   Reply With Quote
Old 04-08-2008, 09:27 PM   #8
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by Valheru View Post
在一个多盒,直接到你的RoadRunner文件夹,并键入下列… …
在C : \ Windows \ \ regsvr32 gdipluswrapper.dll
然后重新运行的RoadRunner 。
JIC
Old 04-08-2008, 09:29 PM   #9
MGD
MGD's Avatar
Yea you bablefish
Old 04-08-2008, 09:33 PM   #10
Confusion Master
Enforcer's Avatar
Google language tools actually
fcuk knows what it will read like to the OP.
Old 04-08-2008, 09:38 PM   #11
MGD
MGD's Avatar
Do you ever go to sleep?
Old 04-08-2008, 09:51 PM   #12
Confusion Master
Enforcer's Avatar
I'm at work.
Old 04-08-2008, 09:57 PM   #13
MGD
MGD's Avatar
Then do your work! I'm not paying you for goofinG off....
I am going to bed now, have to be up at 4:00 in the morning..
Old 04-08-2008, 10:30 PM   #14
2k1Toaster's Avatar
Good wording if you know what his "job" is.
Old 04-08-2008, 10:35 PM   #15
Confusion Master
Enforcer's Avatar
Integrate fusion brain commands into road runner buttons scotty562 FB Software 15 09-22-2008 08:02 AM
Digital FX 2.0 Transparent Released JohnWPB RR Skins 3759 03-07-2008 12:23 PM
Road Runner Setup skin... bati Road Runner 3 09-07-2006 01:44 AM
Issues with volume buttons in road runner, simplistique skin. BavarianBuilt Road Runner 2 08-28-2006 10:55 PM
FS/FT - xdjxklusivex's 'get this **** off my hands cuz im moving sale thread' xdjxklusivex Classified Archive 78 09-08-2005 06:29 PM
