Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 06-06-2008, 02:37 PM   #1
Sal R.'s Avatar
Anyone know how to set an indicator state...
...if there are no more folders to browse?
Basically, as you browse a folder in a DL, an indicator stays "ON" if the current DLPATH has a folder in it and shows a state "OFF" if there are no more folders in it.
I can do it using AI, but I'd much rather not have to do it that way...
Anyway to do this solely in RR?
nLite'd XP Pro / RR v09/10/2008 / Winamp v5.13
Sal R. is offline   Reply With Quote
Old 06-06-2008, 02:40 PM   #2
MySQL Error
Sonicxtacy02's Avatar
doesnt the BOTTOMDL indicator do this? only opposite.. its off when theres more stuff and on when your at the bottom of the directory list. (least i think so.. never used it personally)
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Developer of: RRFusion, MovieTimes, (new)RRMail
Coming Soon:RRChrome, RR Plugin Browser & CentraFusion
Old 06-06-2008, 03:10 PM   #3
Sal R.'s Avatar
BOTTOMDL just indicates if you can pgdown past the current screen regardless of the DL content.
All the arrows in the skin above are indicators. What I want to do is to turn "off" the right arrow indicator if there are no more folders to browse in the DL window. I've been wrapping my head around this for a few days now with no RR-based solution in sight.
Old 06-06-2008, 03:20 PM   #4
MySQL Error
yea i dont see a way of doin that in RR either. I dont believe rr stores a folder count to measure its folder position.
03 Acura RSX Coupe
Old 06-06-2008, 10:05 PM   #5
tundra2000's Avatar
you could use flash to set up an "if" statement: (obviously not flash code)
-SETVARBYCODE;DLTEXT1;DLTEXT
-button w/ command BROWSE
-IF statement:
if DLTEXT == DLTEXT1
fscommand(set indicator off)
ETC.... basically it will turn the indicator off if you hit browse and the current selected item doesnt change. thats the only way i could think of it recognizing whether the folder has changed or not. as for turning it ON, not sure yet.
tundra2000 is offline   Reply With Quote
Old 06-07-2008, 07:18 PM   #6
Sal R.'s Avatar
-IF statement:
I used something similar using RR's EVAL function in one of my earlier attempts, but it's not as clean working as I would like...
Old 06-19-2008, 11:22 PM   #7
blk02si's Avatar
what skin is that Sal?
My carPC - www.shocknet.us
blk02si is offline   Reply With Quote
Old 07-07-2008, 02:46 PM   #8
Sal R.'s Avatar
Just a new skin I'm working on. I've gotten bored w/ MMI and wanted to have something more visually appealing in my carPC.
The Skin Browser:
It really is amazing how flexible RR is.
StreetDeck Functions god_of_cpu DigitalMods (Scripts / API) 22 01-15-2008 10:44 PM
car sterio set up what you think franco90 Car Audio 5 10-29-2005 05:37 PM
Recommend a set of 6.5" components... hd54321 Car Audio 3 10-22-2005 12:55 PM
2 sub set up GeeZeR Car Audio 2 07-30-2005 12:26 AM
How to set Freedrive directions volume Phythorian Road Runner 2 07-28-2005 05:35 AM
