10-22-2008, 09:56 AM
#151
Quote: Originally Posted by mdawg
Yes I made that changes to rr.ini. After I did the thing with Garmin that you told me and started up RR when I first clicked on the button it loaded up Garmin but it wasnt exactly full screen(there was some space left at the bottom) and once the overlay loaded it stretched Garmin to full screen and it became no longer lined up with the overlay. Now when garmin first loads and it still has that space at the bottom it lines up perfect with where the overlay is going to be but once it pops up like I said garmin goes full screen and its off sync.
Bumpin this, still has that problem but for some reason this morning when I turned it on it won't even throw up Garmin inmore. Just the overlay and a blank screen.
10-24-2008, 01:22 PM
#152
Ok monkey my RoadRunner will still not work so Ima post it publicly(in case someone else can fix the problem before you get back on).
Just to let you know when I load roadrunner it said it cannot find a skin or somethinglike that. The error started coming up when monkey made some changes to try and fix my overlay problem with the menu.skin file.
10-24-2008, 01:33 PM
#153
Wants to make it harder
This seems strange to me since the only thing I changed was what I posted in post 142:
Quote: Originally Posted by monkeyracer
change this button:
Code:
B03,313,39,158,77,"MAINBT3",@HOLDMAINBT3@
to this:
Code:
B03,313,39,158,77,"GMPC||RUNGMPC||GMPC_OVERLAY"
That should work.
Let me know.
Then I sent the file back to him to be saved over the old version.
10-24-2008, 11:45 PM
#154
Hmm man I dunno, I will try and delete all those files, replace them with the original, then try yours again. I'll let you know tomorrow.
10-26-2008, 06:31 PM
#155
Quote: Originally Posted by LordNikon
Im using Digital FX 4.0 and i cant see where i need to change the code for the button that loads the gps...anyone done this for dfx 4.0?
/EDIT Nevermind, figured it out, works absolutely perfectly!!
I wish you would have posted where/what you changed Lord Nikon. I have no idea how to find the button to change.
Can you or someone that knows what to change in DFX let me know?
10-26-2008, 09:44 PM
#156
Got it working but It still does not load Garmin....wtf I have done everything correct have I not?
10-27-2008, 06:21 PM
#157
Sorry guys, i should have posted what changes i made to get it to work...
Ok, for getting the overlay working in DFX 4.0...this is what i did:
Firstly, to make sure that you are getting Garmin Mobile PC to load, make sure you have these 2 lines in RR.ini:
gpsname=Garmin=C:\GarminMobilePC\Que.exe
garminpath=C:\GarminMobilePC\Que.exe
Then in your DFX4.0 skin folder, find Exectbl.ini and you need to make a few changes:
1st: Find the ------Embed External Applications------- section and make sure the Garmin/Gps line says this:
"Garmin","LOAD;Garmin_GPS.skin;!CDP_FIELD_WND;C:\G arminMobilePC\Que.exe;!CDP_FIELD_WND"
2nd: Find the ------Dynamic Menu Buttons------ section (down the bottom of the file) and make sure you have this line:
"MyApp53","GMPC||GMPC_OVERLAY||RUNGMPC"
3rd: Find the ----GPS Section By BlueZX3 & JohnWPB----- section (VERY bottom of the file) and then add these 5 lines:
"GMPC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|GMPCOL .skin"
"GMPCOSK","RUN;$SKINPATH$ElcosMenu.exe|GMPCOSK.ski n"
"X_OVERLAY","SENDMSG;ElcosMenu;Exit"
"GMPC","LOAD;GMPC.skin"
"RUNGMPC", "RUN;$garminpath$;!CDP"
When i was looking at how all the files talked to each other in DFX4.0, i noticed that it was all done in the ini's and not the skin files like the other skins. So if you have made any changes to the skin files, restore them to original, make the changes i listed above and it *should* work...did for me (wonderfully i might add)....and i am very grateful to Monkey for initially creating this...
10-27-2008, 11:41 PM
#158
YAY! Got it working, dunno what was up but I took the computer inside uninstalled everything and followed all the instructions you guys have posted and it works. Only problem is there is still a off sync problem with Garmin and the overlay, here is a screen shot and that you all that have helped so far!
10-27-2008, 11:51 PM
#159
oh thats an easy one :P That is because im assuming you installed the 800x480 skins for use on your car lcd, but running RR on an external monitor it defaults to 800x600 so the skins aren't quite lining up. If you put the 800x600 overlay skins on it will be sweet. Or you can just take your computer back out to your car and im pretty sure you'll find it will be just fine.
10-28-2008, 12:16 AM
#160
RR is set to 800x600 and I used the 800x600Overlay files.
10-28-2008, 09:48 AM
#161
Admin. Don't bug or I'll byte.
Quote: Originally Posted by the_big_1
Hi,
Figured it out!
In EXECTBL the setting was: "RUNGMPC","RUN;$Garminpath$;!CDP",GMPC.skin
But in RR it was: gpspath=C:\GarminMobilePC\Que.exeSo I changed EXECTBL to:
"RUNGMPC","RUN;$gpspath$;!CDP",GMPC.skin
WOW! Thanks for this! I was scouring this thread trying to figure out how to get GMPC to load.
I guess I got confused about gpspath and garminpath. I'm an RR noob.
10-31-2008, 11:59 AM
#162
hi monkeyracer, i tried to install this garmin overlay skin, but "nothing" appear on screen...i use DFX4 skin.
these steps i did:
1. L10,563,240,167,31,"GMPC||RUNGMPC||GMPC_OVERLAY" (added to c:\program files\roadrunner\skins\digitalfx4.0\garmin_gps , this button position i found from skin_editor, indicated button 6 that i assigned to run GMPC)
2. "GMPC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|GMPCOL .skin"
"RUNGMPC","RUN;$garminpath$;!CDP",GMPC.skin
(copy all above code to c:\program files\roadrunner\skins\digitalfx4.0\exectbl.ini)
3. garminpath=C:\Garmin\GarminMobilePC\Que.exe (added this to c:\program files\roadrunner\rr.ini)
4. copy all skin file (800x480) to c:\program file\roadrunner\skins\digitalfx4.0\
5. elcosmenu.exe and garminsendkey.exe copy them to c:\program files\roadrunner\digitalfx4.0\
Please help, any other step to do or i did wrong?
**my garminpc software installed and work OK.
phanaka
ROADRUNNER....HARD begin,COOL end
10-31-2008, 12:03 PM
#163
these steps i did:
The first step you changed the label for the button rather than the command the button performs. Find the Line that starts with B rather than L, and change that command and let me know if that works.
10-31-2008, 01:43 PM
#164
i changed it with:
B07,556,220,185,83,"GMPC||GMPC_OVERLAY||RUNGMPC",@ HOLDMAINBT6@
and WORKING!!
many thanks to guru mongkeyracer......
phanaka
10-31-2008, 01:58 PM
#165
glad to hear that worked out for you.
| Thread Tools |
| Display Modes |
Linear Mode
