Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 11-10-2008, 09:48 PM   #181
soundoff's Avatar
soundoff is on a distinguished road
awesome mate. Thanks
I am just going to take a screenshot of the garmin logo and put that in the overlay to click on. should work perfectly.
soundoff is offline   Reply With Quote
Old 11-11-2008, 06:40 AM   #182
soundoff's Avatar
If anyone wants a minimalistic skin then see the attached. 800x600 only.
It uses the original GARMIN logo as the show / hide OSK button, and the CLOSE / MINIMISE icons to exit back to RR. There are no additional buttons for music control etc, and the bar covering the hotkeys down the bottom of the screen is removed. This means none of the labels in the app are hidden by the new buttons, and it generally looks perfect.
These were made from the 11/9/08 release. Many thanks to Monkeyracer for this app. It has made Garmin a viable option for touchscreen users.
Old 11-15-2008, 06:19 AM   #183
Kosti is on a distinguished road
Works great, thank you for sharing.
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Kosti is offline   Reply With Quote
Old 11-15-2008, 10:03 AM   #184
damato300 is on a distinguished road
Trouble with overlay?
I am having problems right now. I follow the instructions as descibed in the special instruction section.
What I have done so far: I have made sure no typos, made sure the paths were right.
Skin I am using: DFX4
Version Of RR: It is a brand new download & install so I do believe it is the latest version.
I have attached all three files in TXT format.
Thank
Dan
Menu.skin.txt
Exectbl.ini.txt
rr.ini.txt
damato300 is offline   Reply With Quote
Old 11-15-2008, 10:17 AM   #185
Wants to make it harder
monkeyracer's Avatar
monkeyracer is an unknown quantity at this point
Thank you for your files, what happens when you try to open GMPC?
Your settings look mostly right, in rr.ini you have:
Code:
[Extra's] GARMINPATH=C:\GarminMobilePC\Que.exe GARMINPATH=C:\GarminMobilePC\Que.exe
try changing it to only one line, and make GARMINPATH lowercase:
Code:
garminpath=C:\GarminMobilePC\Que.exe
in exectbl.ini you have the 5 lines correctly input:
Code:
"GMPC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|GMPCOL.skin" "GMPCOSK","RUN;$SKINPATH$ElcosMenu.exe|GMPCOSK.skin" "X_OVERLAY","SENDMSG;ElcosMenu;Exit" "GMPC","LOAD;GMPC.skin" "RUNGMPC","RUN;$garminpath$;!CDP",GMPC.skin
But you might try to make SKINPATH lowercase as well:
Code:
"GMPC_OVERLAY","RUN;$skinpath$ElcosMenu.exe|GMPCOL.skin" "GMPCOSK","RUN;$skinpath$ElcosMenu.exe|GMPCOSK.skin" "X_OVERLAY","SENDMSG;ElcosMenu;Exit" "GMPC","LOAD;GMPC.skin" "RUNGMPC","RUN;$garminpath$;!CDP",GMPC.skin
and your main.skin has the button code changed correctly:
Code:
B07,556,220,185,83,"GMPC||RUNGMPC||GMPC_OVERLAY",@HOLDMAINBT6@ ...
Just make sure you have garminsendkey.exe and ElcosMenu.exe in the skin folder, as well as the three .skin files, and the corresponding .pngs (depending on your resolution 800x600 or 800x480) and it should work.
It might just be the GARMINPATH and SKINPATH case sensitivity. I may change the User Guide into a different font that's not small caps so it's easier to distinguish.
Let me know if that helps.
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 11-15-2008, 08:46 PM   #186
Worked
Thanks monkey racer worked like a charm. all I can say is awesome. I have a Garmin Nuvi 350 and I thought that was nice this is just awesom.
Old 11-16-2008, 10:32 PM   #187
Dingodongo1 is an unknown quantity at this point
Hi, I successfully installed the skin in to elite lite, however I cant click the buttons on the garmin application. Currently, Garmin will load when I press the Navigation button. However, it prompts me to click agree or press Esc, which I cant do. Garmin will become unresponsive unless I end process to roadrunner. If I play around with garmin enough the blue windows bar at the top appears.
My setup is running on the second screen, which required me to use /POSX=1280 in GMPCOL.skin and GMPCOSK.skin for the skin to line up with garmin. Are these the only changes I need to make for it to work correctly, or are there more coord changes?
My primary screen is 1280x800, and second is 800x480 touch. Unfortunately, I cannot change the second monitor to primary due to driver restrictions.
Below are the Changes I made to the .skin files:
RoadRunner Skin
RRScreen gmpcol
/POSX=1280
/POSY=000
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B05,0,1,347,53,"X_OVERLAY||WAIT;0.5||GMPCOSK",
B01,637,1,161,53,"X_OVERLAY||EXIT",
B02,350,1,91,53,"PREV",
B03,449,1,91,53,"PLAY",
B04,543,1,91,53,"NEXT",
B06,711,389,86,45,"VOL+",
B07,711,435,86,45,"VOL-",
END
RoadRunner Skin
RRScreen gmpc
gmpcback.png,gmpcback.png,gmpcback.png,gmpcback.pn g
/, A, x, y, w, h, color;RGB
A01,0,0,800,480,
END
RoadRunner Skin
RRScreen GMPCOSK
/POSX=1280
/POSY=000
B05,0,1,347,53,"X_OVERLAY||WAIT;0.5||GMPC_OVERLAY" ,
B101,0,104,65,69,"RUN;$skinpath$garminsendkey.exe| Q",
B102,66,104,60,69,"RUN;$skinpath$garminsendkey.exe |W",
B103,127,104,60,69,"RUN;$skinpath$garminsendkey.ex e|E",
B104,188,104,60,69,"RUN;$skinpath$garminsendkey.ex e|R",
B105,249,104,59,69,"RUN;$skinpath$garminsendkey.ex e|T",
B106,310,104,59,69,"RUN;$skinpath$garminsendkey.ex e|Y",
B107,371,104,59,69,"RUN;$skinpath$garminsendkey.ex e|U",
B108,432,104,59,69,"RUN;$skinpath$garminsendkey.ex e|I",
B109,492,104,59,69,"RUN;$skinpath$garminsendkey.ex e|O",
B110,552,104,59,69,"RUN;$skinpath$garminsendkey.ex e|P",
B111,612,104,59,69,"RUN;$skinpath$garminsendkey.ex e|1",
B112,673,104,59,69,"RUN;$skinpath$garminsendkey.ex e|2",
B113,734,104,64,69,"RUN;$skinpath$garminsendkey.ex e|3",
B201,29,174,65,69,"RUN;$skinpath$garminsendkey.exe |A",
B202,95,174,60,69,"RUN;$skinpath$garminsendkey.exe |S",
B203,156,174,60,69,"RUN;$skinpath$garminsendkey.ex e|D",
B204,217,174,60,69,"RUN;$skinpath$garminsendkey.ex e|F",
B205,278,174,60,69,"RUN;$skinpath$garminsendkey.ex e|G",
B206,340,174,60,69,"RUN;$skinpath$garminsendkey.ex e|H",
B207,401,174,60,69,"RUN;$skinpath$garminsendkey.ex e|J",
B208,463,174,60,69,"RUN;$skinpath$garminsendkey.ex e|K",
B209,524,174,60,69,"RUN;$skinpath$garminsendkey.ex e|L",
B210,612,174,60,69,"RUN;$skinpath$garminsendkey.ex e|4",
B211,673,174,60,69,"RUN;$skinpath$garminsendkey.ex e|5",
B212,734,174,64,69,"RUN;$skinpath$garminsendkey.ex e|6",
B301,60,244,65,69,"RUN;$skinpath$garminsendkey.exe |Z",
B302,126,244,60,69,"RUN;$skinpath$garminsendkey.ex e|X",
B303,188,244,60,69,"RUN;$skinpath$garminsendkey.ex e|C",
B304,248,244,60,69,"RUN;$skinpath$garminsendkey.ex e|V",
B305,309,244,60,69,"RUN;$skinpath$garminsendkey.ex e|B",
B306,370,244,60,69,"RUN;$skinpath$garminsendkey.ex e|N",
B307,431,244,60,69,"RUN;$skinpath$garminsendkey.ex e|M",
B310,613,244,60,69,"RUN;$skinpath$garminsendkey.ex e|7",
B311,673,244,60,69,"RUN;$skinpath$garminsendkey.ex e|8",
B312,734,244,64,69,"RUN;$skinpath$garminsendkey.ex e|9",
B401,0,314,211,69,"RUN;$skinpath$garminsendkey.exe |{BS}",
B402,211,314,193,69,"RUN;$skinpath$garminsendkey.e xe|{SPACE}",
B403,404,314,199,69,"RUN;$skinpath$garminsendkey.e xe|{ENTER}",
B404,673,314,60,69,"RUN;$skinpath$garminsendkey.ex e|0",
END
Dingodongo1 is offline   Reply With Quote
Old 11-16-2008, 11:03 PM   #188
After looking at it some more, it looks like garmin is freezing up. The blue windows bar at the top of garmin will appear when i play around with it.
The software works without any problems outside of RR.
Thanks,
Dingodongo1
Old 11-18-2008, 12:43 AM   #189
I haven't worked with dual screen set-ups, and I am wondering if that has anything to do with it.
There are three skin files that are included:
GMPCOL.skin, GPMCOSK.skin, GMPC.skin,
Add the position tags:
Code:
/POSX=1280 /POSY=000
to the GMPC.skin, and see if that solves anything.
I'm thinking it might be that rr wants gmpc to load at 0,0 instead of 1280,0 and when you press in that 800x480 area, nothing happens becuase the program is actually at 0,0 but hiding behind the what is displayed on the first screen. (Best Guess)
(BTW, what is typically on the first screen when you use GMPC? And how are you doing two screens? Seperate instances of RR?)
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 11-18-2008, 01:48 AM   #190
Dirtyrhino is an unknown quantity at this point
Why can't you make the other display a Primary display ?
What drivers are you using ?
How are you setting the Primary and secondary screens ?
I use two, sometimes three displays for various software builds and testing setups, and i've never had a problem. In fact when I was building RR, i used My lillput touch as a fourth display, set as primary, and it worked a treat.......
Dirtyrhino is offline   Reply With Quote
Old 11-18-2008, 01:04 PM   #191
My laptop, which is for my test setup, is a Toshiba L30 (PSL30L) from asia. Toshiba doesnt recognize the model on their site, which makes drivers difficult to find. Anyway, there were problems making the screen primary and having powerstrip recognize the screen to change the resolution.
The chipset is an ATI 200m Express. Most of the 200M driver updates available do not match the hardware ID to install. I havent tried any driver tweaks, I just stuck with the basics since this is my temporary setup. Right now I am selecting extended desktop from windows display, and then changing the resolution of the monitor to 800x480 with powerstrip. If I clone the monitors and set the resolution, my touch screen software (Xenarc) doesnt work.
I added the /posx=1280 to all the .skin files with no luck.
After trying GarminRR included in the Havoc skin, it worked successfully. Thank you for the suggestions.
Old 11-18-2008, 06:06 PM   #192
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Off-topic, what video card are you using? are you using special software to configure and manipulate the displays?
treetop777 is offline   Reply With Quote
Old 11-19-2008, 12:55 AM   #193
After changing some video settings around, I managed to force the screen to be primary. Thanks for attempting to help me.
Old 12-04-2008, 02:44 PM   #194
lacning74's Avatar
lacning74 is an unknown quantity at this point
thanks! this is exactly what i wanted especially since i don't need volume controls.
lacning74 is offline   Reply With Quote
Old 12-04-2008, 04:25 PM   #195
SpecialEd is an unknown quantity at this point
Has anyone thought of tweaking the overlay so we can have a scrolling read-out of the track that is playing in RR as we are looking at the Garmin screen? I love that there are track function (fwd/rev skip, play/pause) buttons, but I have no idea what I'm listening to unless I recognize the song.
I was thinking of moving the command for the OSK to where the BACK button is on the overlay, and changing the image to INPUT or something like that. Then I would change the GARMIN RR button to the command to return to RR (the music screen if possible), with a scrolling track name/artist name/track length in the button area.
Would this be possible?
Never tweaked an overlay before, been awhile since I jacked with skin editor too!
SpecialEd is offline   Reply With Quote
How can I get Garmin and HD Radio to start when RR starts? mstaedt Road Runner 12 09-23-2008 09:09 PM
