09-05-2008, 02:50 PM
#16
Wants to make it harder
did you copy over the 800x600 files?
if so, then I will have to look at it a little later today, I use 800x480, and that would work fine, maybe I missed something getting it into the 600 version.
09-05-2008, 03:32 PM
#17
Yes, the files are copied over. They also pop up when I only use this part of the line:
"GMPC","LOAD;GMPC.skin"
Also the overlay works correctly at 800x600.
BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
Bezel Worklog- My Install - iDrive F01 RR Skin
09-05-2008, 06:37 PM
#18
Ok, I think I found a workaround that seems to do the trick.
In Exectbl.ini I've split the "GMPC" command and made a command called "RUNGMPC"
Now my Exectbl.ini looks like this:
Code:
"GMPC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|GMPCOL.skin"
"GMPCOSK","RUN;$SKINPATH$ElcosMenu.exe|GMPCOSK.skin"
"X_OVERLAY","SENDMSG;ElcosMenu;Exit"
"RUNGMPC","RUN;$garminpath$;!CDP"
In my skin file it now looks like this:
Code:
B11,400,533,100,67,"GMPC||GMPC_OVERLAY||RUNGMPC",""
Now everything seems to work except for the fact that the GMPC.skin isn't transparent. It's red instead?
Since I didn't install any maps yet I couldn't check how and if the keyboard works. But I by the looks of it now this is gonna be a great little add on! I wanted to put Garmin Mobile PC in the car for quite some time now but the lack of a keyboard always kept me from doing it. I think my doubt's are over now.
09-05-2008, 07:56 PM
#19
Thank You MonkeyRacer!
While my setup isn't used on a daily basis( I live less than 2 miles from work ) I love my GMPC and have been waiting and hoping someone (with more know-how than I) would work on a solution to this problem. John has done well with DFX 4 to get Garmin into RR but, you including an OSK (with the help of others) is a great stride toward getting GMPC to work like some of the other satnav systems. Although I haven't had a chance to try your mod I hope you will continue (as well as others who add to RR) to get this to work.
09-06-2008, 12:30 AM
#20
Location: Singapore - Smallest country in Southeast Asia
hi,
any support for 1024x600?
09-06-2008, 07:38 AM
#21
One Sharp Cheddar
Quote: Originally Posted by Fiberoptic
I blogged about this on the home page. Let us know if your bandwidth gets out of control and we can host the rar. Very cool.
Nice to see that my plugin was put to good use...
09-06-2008, 07:39 AM
#22
One Sharp Cheddar
Nice work, I will also be releasing my OSK probably in the next few days.
09-06-2008, 12:07 PM
#23
Raw Wave
Was having the exact same problem as Bimmerstyle; the changes he made fixed it.  However, it's still not quite right, it's showing bigger than 800X600
Might be conflicting with the resolution on my laptop so i'll transfer it to the truck and see what happens.
Still fantastic work.
09-06-2008, 01:07 PM
#24
Works great!!
Spent a lot of time the other night getting Sygic configured due to GMPC having no OSK, then this comes along! Great work fellas!!
Only worked for me using bimmerstyles' recommendations though. But now i cant get the long button push to work so i can choose sygic OR GMPC. Any ideas anyone please?? I have my button in my menu.skin set exactly as bimmerstyle does atm.
09-06-2008, 01:21 PM
#25
@bimmerstyle and treetop777:
What version of rr? I'm wondering if that has anything to do with it.
This should resize GMPC to the dimensions of the skin file you copied over. If it's bigger than the skin area, try to open GMPC outside of rr, and stretch it to the smallest size it will go, then reload RR. It should resize.
I don't have a legit copy of RR, and I use 800x480, so this is hard for me to test.
@kwchan - 1024 x 600 support may come soon, I'll have to explore that some more.
09-06-2008, 03:26 PM
#26
i receive an error with the overlay plugin saying that rr is not running but it is. what version is needed for that overlay thing. i have something from dec. 2007
09-06-2008, 03:32 PM
#27
Raw Wave
IT WORKS PERFECT
The skin (i used BMV2) has to be native 800X600 for GMPC to resize correctly, go figure!
I had the problem testing with Shock which is 800X480.
Time to go play - Thanks.
09-06-2008, 04:58 PM
#28
I got mine working with the latest RR and bimmerstyles' recommendations only. It did not work "out of the box" GREAT work though! I appreciate all the work very much.
09-06-2008, 05:00 PM
#29
In general.ini (in the skin's folder) the resolution of the files used must match the show width and height.
So, if I stretch hAv1c+ to 800x600, but use the 480 files, it will not fill the screen.
@upspace - the overlay should work will all versions after 10/26/2007, but the only thing I can think of is that your version may not be correctly named (RoadRunner.exe vs. Road Runner.exe - notice the space) I will do some more research later and get back to you.
09-06-2008, 06:11 PM
#30
One Sharp Cheddar
In order for the overlay to work correctly with RR, you will need a script to display the overlay menu when the gps command is called. How I did it, is the scripts waits for RR to be running, then waits for garmin to open. Once it sees that there is a garmin window then waits a second for garmin to finish loading and then will display the menu.
the problem comes with trying to switch to GPS using one of the RR features. Like gasnav or voice control being able to use a different path other than the standard c:\garminmobilepc path. For instanct mine is installed on the E:. So in order to include this in my skin I needed a work around to allow me to open garmin with nothing more than the standard GPS command.
This mehtod works great. If you have a little coding skill you can probably figure out autoit. I have done any coding since highschool which was in QBasic, old school I know and a lot of the methods still remain true.
So see what you can figure out, or wait till my skin is released to see what the script looks like. In the original fetured OSK skin, I think all these checks were in there but that is what slowed it down so much. Now the script is nothing more than a send key and relies alot on the user for configuring everything else to work right.
| Thread Tools |
| Display Modes |
Linear Mode
