Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 10-02-2008, 05:20 PM   #121
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
If you get GMPC, get it with the receiver that's bundled with it, or do research on the correct receiver to get.
If the geniouses here hadn't came up with the overlay, it would be totally usuless IMO.
And the UI ain't "all that" either.
Is it obvious i don't like the thing?
treetop777 is offline   Reply With Quote
Old 10-02-2008, 05:40 PM   #122
genie4x4's Avatar
genie4x4 is an unknown quantity at this point
I have it running and it works a treat, i am just waiting on a reply for the skin for the front end that i stumbled across on here that looks similar to the garmin software, not the osk but another one
genie4x4 is offline   Reply With Quote
Old 10-07-2008, 06:57 AM   #123
djmickyg's Avatar
djmickyg is on a distinguished road
I have modified my original garmin skin, i have modified the look of the garmin buttons to look like LSX.
if anyone is interested I have attached the files, NOTE atm they are only for 600x800 and the buttons when pressed are red
To use them download monkeyracer's original files and follow his instructions then copy my files over the top of his..
AND
copy img_pc.gir to you garmin folder.
djmickyg is offline   Reply With Quote
Old 10-07-2008, 10:22 AM   #124
Raw Wave
treetop777's Avatar
AND
Nice effort. Thanks for sharing.
Old 10-07-2008, 11:27 AM   #125
Dirtyrhino is an unknown quantity at this point
Right - i'm back off ma hloidays now - so i'm going to try and get GMPC to work again with the OSK like Treetop suggested.....fingers crossed
------------- edit-------------
HA ! it works at last.
Monkey - you were right - the button editor wasn't adding the string to the exectbl.ini file, so it wasn't calling the overlay and app properly.
Works like a dream now though
Dirtyrhino is offline   Reply With Quote
Old 10-10-2008, 02:51 AM   #126
wizz's Avatar
wizz is on a distinguished road
Any chance of a version of this to use in FreeICE ??
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
wizz is offline   Reply With Quote
Old 10-10-2008, 10:56 AM   #127
Wants to make it harder
monkeyracer's Avatar
monkeyracer is an unknown quantity at this point
Not likely to have support for FreeICE. There are three pieces to this puzzle; Elcamino's overlay, Thunder's sendkeys, and my graphics. The graphics are easy, but you'd have to find a way to make freeice do the same thing that the sendkeys and the overlay do to get it to work. Since I don't use FreeICE, it's not likely to happen.
Update on resolutions: I've been really busy in the real world trying to find a job, and that's been dominating my free time, so I haven't really gotten any headway on the new graphics and the new resolutions. It will happen, but my first priority is to find a job, then I can get back to this.
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 10-13-2008, 03:33 PM   #128
mdawg can only hope to improve
Ok I am having some problems with the overlay. I have a video here and to explain a little bit here is what its doing......When I load RR and use the navi button the overlay comes up BUT if I have not already loaded Garmin before the program it will no load. Only If I load Garmin then startup RR does it come up with the overlay YET there is no keyboard still. Also you can see when I close everything out and go to the start menu and load back Garmin it takes a really long time to load anyway(does anyone know why?). At the end I tried to zoom in on my config but it blurred so Ignore that part.
Broadcast Yourself.
You need to upgrade your Flash Player
mdawg is offline   Reply With Quote
Old 10-13-2008, 08:46 PM   #129
Raw Wave
treetop777's Avatar
I don't think you'll be able to use the "navi" button; you will have to change the command for a button you will never use, like i changed the "sirius" button to "GARMIN" and assigned it the command GMPC||GMPC_OVERLAY||RUNGMPC
First follow the instructions from the original plug-in then follow the instructions for the LSX mod. If you are on the right track, you will have to overwrite some files in the LSX folder. The last thing you should do is copy a file to the garmin folder; it will ask to overwrite also but i renamed the original file instead.
After all that, it still wont work untill you change the button command in LSX - do you know how to do that?
Old 10-14-2008, 12:05 AM   #130
Thanks treetop777,
Basically, if you do anything OTHER than FOLLOW THE INSTRUCTIONS PROVIDED you WILL have issues. If you have issues, you didn't follow instructions.
If you did follow the instructions EXACTLY as provided, and you still have issues, please post them here. Also, please post the steps you've taken to resolve it, the skin you are using, and your rr.ini and exectbl.ini (in code or quote tags, or as a .txt attachment) and I (we) can try an figure it out for you.
Thanks!
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 10-14-2008, 12:07 AM   #131
What are you talking about? I searched LSX Mod and came up with nothing? I have spent over a week trying to fix this with two different skins....its time to spoon feed me.
Monkey ima post my configs right now.
RR.ini
Quote:
[Debuging]
debugmode=false
debugfresh=true
xmdebug=false
srdebug=false
hddebug=false
[Player Setup]
player=Winamp
winamppath=C:\Program Files\Winamp\
hidewinamp=false
exitmute=true
[General]
garminpath=C:\Garmin\GarminMobilePC\Que.exe
launchpath=C:\Program Files\Road Runner\Launch\
voice=false
disableinternat=false
showicons=false
showextensions=false
hidemouse=false
hidetaskbar=false
hidedesktop=false
hidedots=false
gpstime=false
exitmode=0
dateformat=MM/DD/YY
timeformat=HH:MM AM/PM
locale=0
screentype=4:3
enableclipping=true
nozoom=false
usegestures=false
leavemousealone=false
closeapps=true
fastmode=-1
usedualmon=false
soundcard=0
screenlimit=10
mastervolmap=-1
hibernateaware=true
resumedelay=0
hibernatereload=true
usbsound=false
browsertype=0
usevoicecontrol=false
usecar2pc=false
fadeinvolume=false
usedx=true
picspath=To set path, Click --->
[MJSG UAS]
radiouasinput=0
xmuasinput=0
sruasinput=0
[Skins]
skinpath=C:\Program Files\Road Runner\Skins\LSX VOID 3.0\
nightskin=C:\Program Files\Road Runner\Skins\LSX VOID 3.0\
transition=-1
background=To set path, Click --->
TransitionTime=0.2
[Gamma]
gammamode=3
gpsgammamodeoffset=0
gammaday=0:0:0
gammanight=-50:-50:-50
gammadaytime=1:00
gammanighttime=1:00
autogammamode=1
autoskinmode=1
[Preload Screens]
[Music]
musicpath=Click here to set path
playlistpath=Click here to set path
useid3=0
singleclickaudio=false
noformat=false
listnumbers=true
listfollowssong=true
id3listformat=%title%
id3browseformat=%title%
titlesafter=-
albumart=*.txt
fadeimages=false
visuname=MilkDrop
scrollmode=1
circularlist=false
groupnumbers=false
resumemusic=0
audiorepeat=false
audioshuffle=false
transparentvisu=false
opacityvisu=40
[Radio]
radiomode=0
allowallfreqs=false
radioline=0
userbds=false
[XM]
xmport=0
xmline=0
xmlineinplugin=false
xmusecache=true
singleclickxm=false
xmformat=%station% %artist%
[SIRIUS]
srport=0
srline=0
srlineinplugin=false
singleclicksr=false
srusecache=true
srformat=%station% %artist%
[HDRadio]
hdradioport=
[Video]
videopath=Click here to set path
mpcpath=Click here to set path
videoautohide=true
videohidetime=4
builtinvideo=true
videoshuffle=false
[TV]
tvline=0
[GPS]
gpsmode=2
mapmonkeypath=Click here to set path
gpspath=GMPC||GMPC_OVERLAY||RUNGMPC
gpsname=Garmin Mobile PC
overspeed=55
gpsport=0
mappointmap=1
mapcountry=United States
mapcity=
mapautozoom=true
isunits=true
usegpsserv=false
gasfinderautorefresh=false
[IG Native]
[Speed Att Vol]
speedatt=false
[Phidget]
phidget1=0
phidget2=0
phidget3=0
phidget4=0
phidget5=0
phidget6=0
phidget7=0
phidget8=0
[4 Temps]
tcomport=0
tempscale=c
temp1=c
temp2=c
temp3=c
temp4=c
[Volt Meter]
vcomport=
[Phone]
phoconodesign=false
motophone=false
phonelistspath=Click here to set path
contactspicturespath=Click here to set path
ringtone=Click here to set path
smstone=Click here to set path
maxcalllistentries=100
phoconoincallevent=false
connecthsp=true
standardphonebook=0
phonebooksencoding=windows-1252
[Weather]
cityweather=
weatherunits=USA
weatherdegress=º
localdatacaptureinterval=0
[Extra's]
Ecectbl
Quote:
[lsxvoid]
"GMPC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|GMPCOL .skin"
"GMPCOSK","RUN;$SKINPATH$ElcosMenu.exe|GMPCOSK.ski n"
"X_OVERLAY","SENDMSG;ElcosMenu;Exit"
"GMPC","LOAD;GMPC.skin"
"RUNGMPC","RUN;$garminpath$;!CDP",GMPC.skin
"ESC","blank",menu.skin
/ turn off word wrap to best edit this file
/ a forward slash at the begining of any line tells RR to ignore that line of text.
/,-------------------------------------------------Chucks Main Menu Top Buttons------------<THANK YOU CHUCK>-----------------------------------------------------------------------------------
"ONSKINSTART"," ||SETUPANTISTATUS||SETTOPAPPSALL||SETUPMENULABEL01 ||SETTOPLABELALL||SETILIST||LSONSKINSTART||SETMPAT H||NOTESTAT||RUNSETUP||CHECKDRIVELETTERS||AUTOPLAY ||PLAYSOUND||"
"SETILIST","BYVAR;enableilist;ILISTON<<ILISTOF F"
"ILISTON","ILISTA||ILISTDirA||FBdisplaymode_on||CL ISTON"
"ILISTOFF","ILISTB||ILISTDirB||FBdisplaymode_off|| CLISTOFF"
"ILISTA","SETVAR;ilisttoggle;ALT\ilist\enabled\ili stenable.txt||SAVETOSKIN;ilisttoggle;$ilisttoggle$ "
"ILISTB","SETVAR;ilisttoggle;ALT\ilist\disabled\il istenable.txt||SAVETOSKIN;ilisttoggle;$ilisttoggle $"
"ILISTDirA","SETVAR;ilisttoggleDL;ALT\ilist\enable d\ilistenableDL.txt||SAVETOSKIN;ilisttoggleDL;$ili sttoggleDL$"
"ILISTDirB","SETVAR;ilisttoggleDL;ALT\ilist\disabl ed\ilistenableDL.txt||SAVETOSKIN;ilisttoggleDL;$il isttoggleDL$"
"CLISTON","setvar;ilistCL;ALT\ilist\enabled\iliste nableCL.txt||SAVETOSKIN;ilistCL;$ilistCL$"
"CLISTOFF","setvar;ilistCL;ALT\ilist\disabled\ilis tenableCL.txt||SAVETOSKIN;ilistCL;$ilistCL$"
"FBdisplaymode_on","setvar;displaymodeA;ALT\ilist\ enabled\filebrowserSD.txt||SAVETOSKIN;displaymodeA ;$displaymodeA$"
"FBdisplaymode_off","setvar;displaymodeA;ALT\ilist \disabled\filebrowserSD.txt||SAVETOSKIN;displaymod eA;$displaymodeA$"
"TURNLISTON","SETVAR;enableilist;0||SAVETOSKIN;ena bleilist;0||RELOADSKIN"
"TURNLISTOFF","SETVAR;enableilist;1||SAVETOSKIN;en ableilist;1||RELOADSKIN"
"PHONE","BYVAR;PHONESETTING;PHOCO<<FREEPHONE"
"STARTLOAD","MENU;LOADING.skin"
"ENDLOAD","ESC"
"SPLASH","RUN;LSTOOLS\splash.exe"
"RUNSETUP","BYVAR;HELPSYS;HELPMANUAL<<SHOWTIPOFDAY "
"HELPMANUAL","MENU;MANUAL1.skin"
"SHOWTIPOFDAY","BYVAR;TOD;<<TIP1"
/"LSONSKINSTART","ratecheck2||RUN;LSTOOLS\welcomeMS G\welcome.exe||locate"
"LSONSKINSTART","ratecheck2||locate"
/,"PRELOADGPS","RUN;$gpspath$"
"APCD_Y","RUN;$SKINPATH$autolaunch\AutoLaunch. exe"
"APCD_N",""
"APCD_Y1","SETVAR;AUTOPLAYCD;0||SAVETOSKIN;AUTOPLA YCD;0"
"APCD_N1","SETVAR;AUTOPLAYCD;1||SAVETOSKIN;AUTOPLA YCD;1"
"AUTOPLAY","BYVAR;AUTOPLAYCD;APCD_Y<<APCD_N"
"MAINBT1","BYVAR;MAINBUTTON1;$TOPAPPS$”
"MAINBT2","BYVAR;MAINBUTTON2;$TOPAPPS$”
"MAINBT3","BYVAR;MAINBUTTON3;$TOPAPPS$”
"MAINBT4","BYVAR;MAINBUTTON4;$TOPAPPS$”
"MAINBT5","BYVAR;MAINBUTTON5;$TOPAPPS$”
"MAINBT6","BYVAR;MAINBUTTON6;$TOPAPPS$”
"MAINBT7","BYVAR;MAINBUTTON7;$TOPAPPS$”
"MAINBT8","BYVAR;MAINBUTTON8;$TOPAPPS$”
"MAINBT9","BYVAR;MAINBUTTON9;$TOPAPPS$”
"MAINBT10","BYVAR;MAINBUTTON10;$TOPAPPS$”
"MAINBT11","BYVAR;MAINBUTTON11;$TOPAPPS$”
"MAINBT12","BYVAR;MAINBUTTON12;$TOPAPPS$”
"MAINBT13","BYVAR;MAINBUTTON13;$TOPAPPS$”
"MAINBT14","BYVAR;MAINBUTTON14;$TOPAPPS$”
"MAINBT15","BYVAR;MAINBUTTON15;$TOPAPPS$”
"MAINBT16","BYVAR;MAINBUTTON16;$TOPAPPS$”
"MAINBT17","BYVAR;MAINBUTTON17;$TOPAPPS$”
"MAINBT18","BYVAR;MAINBUTTON18;$TOPAPPS$”
"MAINBT19","BYVAR;MAINBUTTON19;$TOPAPPS$”
"MAINBT20","BYVAR;MAINBUTTON20;$TOPAPPS$”
"MAINBT21","BYVAR;MAINBUTTON21;$TOPAPPS$”
"MAINBT22","BYVAR;MAINBUTTON22;$TOPAPPS$”
"MAINBT23","BYVAR;MAINBUTTON23;$TOPAPPS$”
"MAINBT24","BYVAR;MAINBUTTON24;$TOPAPPS$”
"MAINBT25","BYVAR;MAINBUTTON25;$TOPAPPS$”
"MAINBT26","BYVAR;MAINBUTTON26;$TOPAPPS$”
"MAINBT27","BYVAR;MAINBUTTON27;$TOPAPPS$”
"MAINBT28","BYVAR;MAINBUTTON28;$TOPAPPS$”
"MAINBT29","BYVAR;MAINBUTTON29;$TOPAPPS$”
"MAINBT30","BYVAR;MAINBUTTON30;$TOPAPPS$”
"MAINBT31","BYVAR;MAINBUTTON31;$TOPAPPS$”
"MAINBT32","BYVAR;MAINBUTTON32;$TOPAPPS$”
"MAINBT33","BYVAR;MAINBUTTON33;$TOPAPPS$”
"MAINBT34","BYVAR;MAINBUTTON34;$TOPAPPS$”
"MAINBT35","BYVAR;MAINBUTTON35;$TOPAPPS$”
"MAINBT36","BYVAR;MAINBUTTON36;$TOPAPPS$”
"MAINBT37","BYVAR;MAINBUTTON37;$TOPAPPS$”
"MAINBT38","BYVAR;MAINBUTTON38;$TOPAPPS$”
"MAINBT39","BYVAR;MAINBUTTON39;$TOPAPPS$”
"MAINBT40","BYVAR;MAINBUTTON40;$TOPAPPS$”
"MAINBT41","BYVAR;MAINBUTTON41;$TOPAPPS$”
"MAINBT42","BYVAR;MAINBUTTON42;$TOPAPPS$”
"MAINBT43","BYVAR;MAINBUTTON43;$TOPAPPS$”
"MAINBT44","BYVAR;MAINBUTTON44;$TOPAPPS$”
"MAINBT45","BYVAR;MAINBUTTON45;$TOPAPPS$”
"MAINBT46","BYVAR;MAINBUTTON46;$TOPAPPS$”
"MAINBT47","BYVAR;MAINBUTTON47;$TOPAPPS$”
"MAINBT48","BYVAR;MAINBUTTON48;$TOPAPPS$”
"MAINBT49","BYVAR;MAINBUTTON49;$TOPAPPS$”
"MAINBT50","BYVAR;MAINBUTTON50;$TOPAPPS$”
"MAINBT51","BYVAR;MAINBUTTON51;$TOPAPPS$”
"MAINBT52","BYVAR;MAINBUTTON52;$TOPAPPS$”
"MAINBT53","BYVAR;MAINBUTTON53;$TOPAPPS$”
"MAINBT54","BYVAR;MAINBUTTON54;$TOPAPPS$”
"MAINBT55","BYVAR;MAINBUTTON55;$TOPAPPS$”
"MAINBT56","BYVAR;MAINBUTTON56;$TOPAPPS$”
"MAINBT57","BYVAR;MAINBUTTON57;$TOPAPPS$”
"MAINBT58","BYVAR;MAINBUTTON58;$TOPAPPS$”
"MAINBT59","BYVAR;MAINBUTTON59;$TOPAPPS$”
"MAINBT60","BYVAR;MAINBUTTON60;$TOPAPPS$”
"MAINBT61","BYVAR;MAINBUTTON61;$TOPAPPS$”
"MAINBT62","BYVAR;MAINBUTTON62;$TOPAPPS$”
"MAINBT63","BYVAR;MAINBUTTON63;$TOPAPPS$”
"MAINBT64","BYVAR;MAINBUTTON64;$TOPAPPS$”
"MAINBT65","BYVAR;MAINBUTTON65;$TOPAPPS$”
"MAINBT66","BYVAR;MAINBUTTON66;$TOPAPPS$”
"MAINBT67","BYVAR;MAINBUTTON67;$TOPAPPS$”
"MAINBT68","BYVAR;MAINBUTTON68;$TOPAPPS$”
"MAINBT69","BYVAR;MAINBUTTON69;$TOPAPPS$”
"MAINBT70","BYVAR;MAINBUTTON70;$TOPAPPS$”
"SETTOPAPPSALL","SETVAR;TOPAPPS;AP01<<AP02<<AP03<< AP04<<AP05<<AP06<<AP07<<AP08<<AP09<<AP10<<AP11<<AP 12<<AP13<<AP14<<AP15<<AP16<<AP17<<AP18<<AP19<<AP20 <<AP21<<AP22<<AP23<<AP24<<AP25<<AP26<<AP27<<AP28<< AP29<<AP30<<AP31<<AP32<<AP33<<AP34<<AP35<<AP36<<AP 37<<AP38<<AP39<<AP40<<AP41<<AP42<<AP43<<AP44<<AP45 <<AP46<<AP47<<AP48<<AP49<<AP50<<AP51<<AP52<<AP53<< AP54<<AP55<<AP56<<AP57<<AP58<<AP59<<AP60<<AP61<<AP 62<<AP63<<AP64<<AP65<<AP66<<AP67<<AP68<<AP69<<AP70 <<AP71”
/, if you add extra buttons, make sure that the MAINBUTTON# and AP# above specify your command number. By default it goes to 61, follow the pattern
/,-----------Step 1 add or modify app command------------Main Menu Top Buttons-Commands to Start Apps----------------------------------------------------------------------------
/default main menu buttons
"AP01","AUDIO||SELPL"
"AP02","VIDEO"
"AP03"," ||GPS3||FSDEF_LOAD"
"AP04","DVD"
"AP05"," ||PHONE"
"AP06","SAT"
"AP07","CLEANUP||VIZOFF||QUIT"
/default main menu 1 buttons
"AP08",".NET"
"AP09","MIXER"
"AP10","GAMESX"
"AP11","PICS_CHOOSER"
"AP12","TV"
"AP13","NOTES"
"AP14","WIDGETS"
"AP15","CALENDAR"
"AP16","WEATHER"
"AP17","EXITMENU"
/default main menu 2 buttons
"AP18","RADIO"
"AP19","XM"
"AP20","SIRIUS"
"AP21","LAUNCH"
"AP22","RRCAM"
"AP23"," ||CDRIP"
"AP24","SENSOR"
"AP25","JOOST"
"AP26","CONFIGOPT"
/extra commands
"AP27","CUSTOMSAT"
"AP28","OPERA"
"AP29","MMGPS"
"AP30","FREEDRIVE"
"AP31","GPS1"
"AP32","QUICKMENU"
"AP33","MOUSEWHEELINPUT"
"AP34","RATINGS"
"AP35","SCREENLOCK"
"AP36","BLACKOUT"
"AP37","Gaspricefinder"
"AP38","NEAVETV"
"AP39","WEB"
"AP40","MINIMIZE"
"AP41","LIST"
"AP42","BBART||DISKSEL2"
"AP43","MINI"
"AP44","AUDIO2||SELPL"
"AP45","IG2MENU"
"AP46","TRIP LOG"
"AP47","SHUFFLE/REPEAT"
"AP48","PLIST"
"AP49","MOBILEEMU"
"AP50","CUSTOMAPP1"
"AP51","CUSTOMAPP2"
"AP52","CUSTOMAPP3"
"AP53","CUSTOMAPP4"
"AP54","CUSTOMAPP5"
"AP55","CHECKDRIVELETTERS||FILEBROWSER"
"AP56","GE_START"
"AP57"," ||TRAFFIC2"
/below commands are ONLY for the .NET popup list with shortcuts to internet only features
"AP58","ESC||WEB"
"AP59","ESC||EMAIL"
"AP60","ESC||IM"
"AP61","ESC||MAPS1"
"AP62","ESC||FLICKR"
"AP63","ESC||SYNCFILES1"
"AP64","ESC||RSS"
"AP65","ESC||MAPS2"
"AP66","ESC||MAPS3"
"AP67","ESC||MILK1"
"AP68","ESC||TOKBOX"
"AP69","ESC||MOVIETIMES"
"AP70","ESC||OPERA"
"AP71","ESC||SULLR"
/, DONOT ADD COMMANDS OUT OF ORDER, TRUST ME YOU WILL HAVE ISSUES!!!!
/,------------Step 2 add app Button Name---------Main Menu Top Buttons-Labels on skin----This will be the label you see on your cutom button---------------------------------------------------------------------------------------
"SETTOPLABELALL","SETVAR;MAINLABELS;=AUDIO<<=VIDEO <<=NAVI<<=DVD<<=PHONE<<=SAT<<=EXT<<=.NET<<=MIXER<< =GAMES<<=PHOTO<<=CAMERA<<=NOTES<<=WIDGETS<<=CALEND AR<<=WEATHER<<=POWER<<=RADIO<<=XM<<=SIRIUS<<=APPS< <=CAM<<=RIP CD<<=SENSOR<<=JOOST<<=OPT<<=VOID<<=OPERA<<=NAVI<<= NAVI<<=NAVI<<=IG MENU<<=MENU<<=RATINGS<<=LOCK<<=BLACKOUT<<=GAS<<=NE AVETV<<=WEB<<=MINIMIZE<<=LIBRARY<<=BBAA<<=MINI<<=A UDIO<<=IG2 MENU<<=TRIP LOG<<=SHUF/REP<<=PLIST<<=EMU<<=$FREE50$<<=$FREE51$<<=$FREE52$ <<=$FREE53$<<=$FREE54$<<=XPLORRER<<=G EARTH<<=TRAFFIC<<=BROWSER<<=EMAIL<<=IM<<=ORB<<=FLI CKR<<=FLDER SYNC<<=RSS<<=MAPS<<=MAPS<<=TASKS<<=TokBox<<=MOVIE TIMES<<=OPERA<<=SULLR"
/,---------Step 3 add Menu Label--,,,,,,----------Main Menu Top Buttons-Menu Labels------------------This will be the label you see in the pick command screens-------------------------------------------------------------------
"SETUPMENULABEL01","SETVAR;AP01LB;=Audio||SETUPMEN ULABEL02"
"SETUPMENULABEL02","SETVAR;AP02LB;=VIDEO||SETUPMEN ULABEL03"
"SETUPMENULABEL03","SETVAR;AP03LB;=IG3||SETUPMENUL ABEL04"
"SETUPMENULABEL04","SETVAR;AP04LB;=DVD||SETUPMENUL ABEL05"
"SETUPMENULABEL05","SETVAR;AP05LB;=PHOCO||SETUPMEN ULABEL06"
"SETUPMENULABEL06","SETVAR;AP06LB;=SAT||SETUPMENUL ABEL07"
"SETUPMENULABEL07","SETVAR;AP07LB;=EXIT RR||SETUPMENULABEL08"
"SETUPMENULABEL08","SETVAR;AP08LB;=.NET||SETUPMENU LABEL09"
"SETUPMENULABEL09","SETVAR;AP09LB;=MIXER||SETUPMEN ULABEL10"
"SETUPMENULABEL10","SETVAR;AP10LB;=GAMES||SETUPMEN ULABEL11"
"SETUPMENULABEL11","SETVAR;AP11LB;=PHOTO||SETUPMEN ULABEL12"
"SETUPMENULABEL12","SETVAR;AP12LB;=CAMERA||SETUPME NULABEL13"
"SETUPMENULABEL13","SETVAR;AP13LB;=NOTES||SETUPMEN ULABEL14"
"SETUPMENULABEL14","SETVAR;AP14LB;=WIDGETS||SETUPM ENULABEL15"
"SETUPMENULABEL15","SETVAR;AP15LB;=CALENDAR||SETUP MENULABEL16"
"SETUPMENULABEL16","SETVAR;AP16LB;=WEATHER||SETUPM ENULABEL17"
"SETUPMENULABEL17","SETVAR;AP17LB;=POWER||SETUPMEN ULABEL18"
"SETUPMENULABEL18","SETVAR;AP18LB;=RADIO||SETUPMEN ULABEL19"
"SETUPMENULABEL19","SETVAR;AP19LB;=XM||SETUPMENULA BEL20"
"SETUPMENULABEL20","SETVAR;AP20LB;=SIRIUS||SETUPME NULABEL21"
"SETUPMENULABEL21","SETVAR;AP21LB;=Ext Apps||SETUPMENULABEL22"
"SETUPMENULABEL22","SETVAR;AP22LB;=RRCAM||SETUPMEN ULABEL23"
"SETUPMENULABEL23","SETVAR;AP23LB;=RIP CD||SETUPMENULABEL24"
"SETUPMENULABEL24","SETVAR;AP24LB;=SENSOR||SETUPME NULABEL25"
"SETUPMENULABEL25","SETVAR;AP25LB;=JOOST||SETUPMEN ULABEL26"
"SETUPMENULABEL26","SETVAR;AP26LB;=CONFIG||SETUPME NULABEL27"
"SETUPMENULABEL27","SETVAR;AP27LB;=VOID||SETUPMENU LABEL28"
"SETUPMENULABEL28","SETVAR;AP28LB;=OPERA||SETUPMEN ULABEL29"
"SETUPMENULABEL29","SETVAR;AP29LB;=MAPMONKEY||SETU PMENULABEL30"
"SETUPMENULABEL30","SETVAR;AP30LB;=FREEDRIVE||SETU PMENULABEL31"
"SETUPMENULABEL31","SETVAR;AP31LB;=IG2||SETUPMENUL ABEL32"
"SETUPMENULABEL32","SETVAR;AP32LB;=IG MENU||SETUPMENULABEL33"
"SETUPMENULABEL33","SETVAR;AP33LB;=MENU||SETUPMENU LABEL34"
"SETUPMENULABEL34","SETVAR;AP34LB;=RATINGS||SETUPM ENULABEL35"
"SETUPMENULABEL35","SETVAR;AP35LB;=LOCKSCREEN||SET UPMENULABEL36"
"SETUPMENULABEL36","SETVAR;AP36LB;=BLACKOUT||SETUP MENULABEL37"
"SETUPMENULABEL37","SETVAR;AP37LB;=GAS||SETUPMENUL ABEL38"
"SETUPMENULABEL38","SETVAR;AP38LB;=NEAVE TV||SETUPMENULABEL39"
"SETUPMENULABEL39","SETVAR;AP39LB;=WEB||SETUPMENUL ABEL40"
"SETUPMENULABEL40","SETVAR;AP40LB;=MINIMIZE||SETUP MENULABEL41"
"SETUPMENULABEL41","SETVAR;AP41LB;=LIBRARY||SETUPM ENULABEL42"
"SETUPMENULABEL42","SETVAR;AP42LB;=BBAA||SETUPMENU LABEL43"
"SETUPMENULABEL43","SETVAR;AP43LB;=MINI||SETUPMENU LABEL44"
"SETUPMENULABEL44","SETVAR;AP44LB;=AUDIO old||SETUPMENULABEL45"
"SETUPMENULABEL45","SETVAR;AP45LB;=IG2 MENU||SETUPMENULABEL46"
"SETUPMENULABEL46","SETVAR;AP46LB;=TRIP LOG||SETUPMENULABEL47"
"SETUPMENULABEL47","SETVAR;AP47LB;=SHUF/REP||SETUPMENULABEL48"
"SETUPMENULABEL48","SETVAR;AP48LB;=PLIST||SETUPMEN ULABEL49"
"SETUPMENULABEL49","SETVAR;AP49LB;=EMU||SETUPMENUL ABEL50"
"SETUPMENULABEL50","SETVAR;AP50LB;=$FREE50$||SETUP MENULABEL51"
"SETUPMENULABEL51","SETVAR;AP51LB;=$FREE51$||SETUP MENULABEL52"
"SETUPMENULABEL52","SETVAR;AP52LB;=$FREE52$||SETUP MENULABEL53"
"SETUPMENULABEL53","SETVAR;AP53LB;=$FREE53$||SETUP MENULABEL54"
"SETUPMENULABEL54","SETVAR;AP54LB;=$FREE54$||SETUP MENULABEL55"
"SETUPMENULABEL55","SETVAR;AP55LB;=XPLORRER||SETUP MENULABEL56"
"SETUPMENULABEL56","SETVAR;AP56LB;=GEARTH||SETUPME NULABEL57"
"SETUPMENULABEL57","SETVAR;AP57LB;=TRAFFIC||SETUPM ENULABEL58"
"SETUPMENULABEL58","SETVAR;AP58LB;=BROWSER||SETUPM ENULABEL59"
"SETUPMENULABEL59","SETVAR;AP59LB;=EMAIL||SETUPMEN ULABEL60"
"SETUPMENULABEL60","SETVAR;AP60LB;=IM||SETUPMENULA BEL61"
"SETUPMENULABEL61","SETVAR;AP61LB;=ORB||SETUPMENUL ABEL62"
"SETUPMENULABEL62","SETVAR;AP62LB;=FLICKR||SETUPME NULABEL63"
"SETUPMENULABEL63","SETVAR;AP63LB;=SYNC FOLDER||SETUPMENULABEL64"
"SETUPMENULABEL64","SETVAR;AP64LB;=RSS||SETUPMENUL ABEL65"
"SETUPMENULABEL65","SETVAR;AP65LB;=MAPS 2||SETUPMENULABEL66"
"SETUPMENULABEL66","SETVAR;AP66LB;=MAPS 3||SETUPMENULABEL67"
"SETUPMENULABEL67","SETVAR;AP67LB;=TASKS||SETUPMEN ULABEL68"
"SETUPMENULABEL68","SETVAR;AP68LB;=TOKBOX||SETUPME NULABEL69"
"SETUPMENULABEL69","SETVAR;AP69LB;=MOVIES||SETUPME NULABEL70"
"SETUPMENULABEL70","SETVAR;AP70LB;=OPERA||SETUPMEN ULABEL71"
"SETUPMENULABEL71","SETVAR;AP71LB;=SULLR"
/,------------------------------------------------Main Menu Top Buttons-HOLD Commands-------------------------------------------------------------------------------------------
"HOLDMAINBT1","SETVAR;CHANGEBUTTON;MAINBUTTON1||LO AD;PICK_MENU.skin"
"HOLDMAINBT2","SETVAR;CHANGEBUTTON;MAINBUTTON2||LO AD;PICK_MENU.skin"
"HOLDMAINBT3","SETVAR;CHANGEBUTTON;MAINBUTTON3||LO AD;PICK_MENU.skin"
"HOLDMAINBT4","SETVAR;CHANGEBUTTON;MAINBUTTON4||LO AD;PICK_MENU.skin"
"HOLDMAINBT5","SETVAR;CHANGEBUTTON;MAINBUTTON5||LO AD;PICK_MENU.skin"
"HOLDMAINBT6","SETVAR;CHANGEBUTTON;MAINBUTTON6||LO AD;PICK_MENU.skin"
"HOLDMAINBT7","SETVAR;CHANGEBUTTON;MAINBUTTON7||LO AD;PICK_MENU.skin"
"HOLDMAINBT8","SETVAR;CHANGEBUTTON;MAINBUTTON8||LO AD;PICK_MENU.skin"
"HOLDMAINBT9","SETVAR;CHANGEBUTTON;MAINBUTTON9||LO AD;PICK_MENU.skin"
"HOLDMAINBT10","SETVAR;CHANGEBUTTON;MAINBUTTON10|| LOAD;PICK_MENU.skin"
"HOLDMAINBT11","SETVAR;CHANGEBUTTON;MAINBUTTON11|| LOAD;PICK_MENU.skin"
"HOLDMAINBT12","SETVAR;CHANGEBUTTON;MAINBUTTON12|| LOAD;PICK_MENU.skin"
"HOLDMAINBT13","SETVAR;CHANGEBUTTON;MAINBUTTON13|| LOAD;PICK_MENU.skin"
"HOLDMAINBT14","SETVAR;CHANGEBUTTON;MAINBUTTON14|| LOAD;PICK_MENU.skin"
"HOLDMAINBT15","SETVAR;CHANGEBUTTON;MAINBUTTON15|| LOAD;PICK_MENU.skin"
"HOLDMAINBT16","SETVAR;CHANGEBUTTON;MAINBUTTON16|| LOAD;PICK_MENU.skin"
"HOLDMAINBT17","SETVAR;CHANGEBUTTON;MAINBUTTON17|| LOAD;PICK_MENU.skin"
"HOLDMAINBT18","SETVAR;CHANGEBUTTON;MAINBUTTON18|| LOAD;PICK_MENU.skin"
"HOLDMAINBT19","SETVAR;CHANGEBUTTON;MAINBUTTON19|| LOAD;PICK_MENU.skin"
"HOLDMAINBT20","SETVAR;CHANGEBUTTON;MAINBUTTON20|| LOAD;PICK_MENU.skin"
"HOLDMAINBT21","SETVAR;CHANGEBUTTON;MAINBUTTON21|| LOAD;PICK_MENU.skin"
"HOLDMAINBT22","SETVAR;CHANGEBUTTON;MAINBUTTON22|| LOAD;PICK_MENU.skin"
"HOLDMAINBT23","SETVAR;CHANGEBUTTON;MAINBUTTON23|| LOAD;PICK_MENU.skin"
"HOLDMAINBT24","SETVAR;CHANGEBUTTON;MAINBUTTON24|| LOAD;PICK_MENU.skin"
"HOLDMAINBT25","SETVAR;CHANGEBUTTON;MAINBUTTON25|| LOAD;PICK_MENU.skin"
"HOLDMAINBT26","SETVAR;CHANGEBUTTON;MAINBUTTON26|| LOAD;PICK_MENU.skin"
"HOLDMAINBT27","SETVAR;CHANGEBUTTON;MAINBUTTON27|| LOAD;PICK_MENU.skin"
"HOLDMAINBT28","SETVAR;CHANGEBUTTON;MAINBUTTON28|| LOAD;PICK_MENU.skin"
"HOLDMAINBT29","SETVAR;CHANGEBUTTON;MAINBUTTON29|| LOAD;PICK_MENU.skin"
"HOLDMAINBT30","SETVAR;CHANGEBUTTON;MAINBUTTON30|| LOAD;PICK_MENU.skin"
"HOLDMAINBT31","SETVAR;CHANGEBUTTON;MAINBUTTON31|| LOAD;PICK_MENU.skin"
"HOLDMAINBT32","SETVAR;CHANGEBUTTON;MAINBUTTON32|| LOAD;PICK_MENU.skin"
"HOLDMAINBT33","SETVAR;CHANGEBUTTON;MAINBUTTON33|| LOAD;PICK_MENU.skin"
"HOLDMAINBT34","SETVAR;CHANGEBUTTON;MAINBUTTON34|| LOAD;PICK_MENU.skin"
"HOLDMAINBT35","SETVAR;CHANGEBUTTON;MAINBUTTON35|| LOAD;PICK_MENU.skin"
"HOLDMAINBT36","SETVAR;CHANGEBUTTON;MAINBUTTON36|| LOAD;PICK_MENU.skin"
"HOLDMAINBT37","SETVAR;CHANGEBUTTON;MAINBUTTON37|| LOAD;PICK_MENU.skin"
"HOLDMAINBT38","SETVAR;CHANGEBUTTON;MAINBUTTON38|| LOAD;PICK_MENU.skin"
"HOLDMAINBT39","SETVAR;CHANGEBUTTON;MAINBUTTON39|| LOAD;PICK_MENU.skin"
"HOLDMAINBT40","SETVAR;CHANGEBUTTON;MAINBUTTON40|| LOAD;PICK_MENU.skin"
"HOLDMAINBT41","SETVAR;CHANGEBUTTON;MAINBUTTON41|| LOAD;PICK_MENU.skin"
"HOLDMAINBT42","SETVAR;CHANGEBUTTON;MAINBUTTON42|| LOAD;PICK_MENU.skin"
"HOLDMAINBT43","SETVAR;CHANGEBUTTON;MAINBUTTON43|| LOAD;PICK_MENU.skin"
"HOLDMAINBT44","SETVAR;CHANGEBUTTON;MAINBUTTON44|| LOAD;PICK_MENU.skin"
"HOLDMAINBT45","SETVAR;CHANGEBUTTON;MAINBUTTON45|| LOAD;PICK_MENU.skin"
"HOLDMAINBT46","SETVAR;CHANGEBUTTON;MAINBUTTON46|| LOAD;PICK_MENU.skin"
"HOLDMAINBT47","SETVAR;CHANGEBUTTON;MAINBUTTON47|| LOAD;PICK_MENU.skin"
"HOLDMAINBT48","SETVAR;CHANGEBUTTON;MAINBUTTON48|| LOAD;PICK_MENU.skin"
"HOLDMAINBT49","SETVAR;CHANGEBUTTON;MAINBUTTON49|| LOAD;PICK_MENU.skin"
"HOLDMAINBT50","SETVAR;CHANGEBUTTON;MAINBUTTON50|| LOAD;PICK_MENU.skin"
"HOLDMAINBT51","SETVAR;CHANGEBUTTON;MAINBUTTON51|| LOAD;PICK_MENU.skin"
"HOLDMAINBT52","SETVAR;CHANGEBUTTON;MAINBUTTON52|| LOAD;PICK_MENU.skin"
"HOLDMAINBT53","SETVAR;CHANGEBUTTON;MAINBUTTON53|| LOAD;PICK_MENU.skin"
"HOLDMAINBT54","SETVAR;CHANGEBUTTON;MAINBUTTON54|| LOAD;PICK_MENU.skin"
"HOLDMAINBT55","SETVAR;CHANGEBUTTON;MAINBUTTON55|| LOAD;PICK_MENU.skin"
"HOLDMAINBT56","SETVAR;CHANGEBUTTON;MAINBUTTON56|| LOAD;PICK_MENU.skin"
"HOLDMAINBT57","SETVAR;CHANGEBUTTON;MAINBUTTON57|| LOAD;PICK_MENU.skin"
"HOLDMAINBT58","SETVAR;CHANGEBUTTON;MAINBUTTON58|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT59","SETVAR;CHANGEBUTTON;MAINBUTTON59|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT60","SETVAR;CHANGEBUTTON;MAINBUTTON60|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT61","SETVAR;CHANGEBUTTON;MAINBUTTON61|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT62","SETVAR;CHANGEBUTTON;MAINBUTTON62|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT63","SETVAR;CHANGEBUTTON;MAINBUTTON63|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT64","SETVAR;CHANGEBUTTON;MAINBUTTON64|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT65","SETVAR;CHANGEBUTTON;MAINBUTTON65|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT66","SETVAR;CHANGEBUTTON;MAINBUTTON66|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT67","SETVAR;CHANGEBUTTON;MAINBUTTON67|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT68","SETVAR;CHANGEBUTTON;MAINBUTTON68|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT69","SETVAR;CHANGEBUTTON;MAINBUTTON69|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT70","SETVAR;CHANGEBUTTON;MAINBUTTON70|| LOAD;PICK_PRESETMENU.skin"
"HOLDMAINBT71","SETVAR;CHANGEBUTTON;MAINBUTTON71|| LOAD;PICK_PRESETMENU.skin"
/IG2 START
/IG2.1
/path to GPS............................................... .......{ path to your gps application }{ window title}
"GPS1","GPS||RUN;LSTOOLS\SB2.9\iGuidance\IGCONTROL .exe"
/....................-path to GPS and EXITFS utility..........{ path to your gps application }{window title}
"GPSFS1","LOAD;EXTERNAL_GPS_FS.skin;RUN;;iGuidance ||RUN;LSTOOLS\SCRIPTS\EXIT_FS.exe"
/this command is used only on External_GPS.skin, close button on bottom left
/"EXIT2","RUN;LSTOOLS\SB2.9\iGuidance\kill.exe||EXI T"
/"LASTSCR2","RUN;LSTOOLS\SB2.9\iGuidance\kill.exe|| LASTSCR"
"IG2MENU","RUN;LSTOOLS\SCRIPTS\torch.exe"
/IG2 END
/IG3 START
/"GPS","LOAD;EXTERNAL_GPS.skin;RUNQ;LSTOOLS\SB2.9_I G3\SKINbedder.exe;SKINbedder||RUN;LSTOOLS\SB2.9_IG 3\iGuidance\IGCONTROL.exe"
/"GPSFS","LOAD;EXTERNAL_GPS_FS.skin;RUNQ;LSTOOLS\SB 2.9_IG3\SKINbedder.exe;SKINbedder||RUN;LSTOOLS\SB2 .9_IG3\iGuidance\EXIT_FS.exe||RUN;LSTOOLS\SB2.9_IG 3\iGuidance\IGCONTROL_FS.exe"
/IG3 NATIVE
"GPSFS","LOAD;external_gps_full.skin;RUN;;iGuidanc e||RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\EXIT_FS.exe||R UN;LSTOOLS\SB2.9_IG3\iGuidance\IGCONTROL_FS.exe"
"GPS3","GPS||RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\IGCO NTROL2\IGCONTROL2.exe||SETVAR;isigopen;1||SAVETOSK IN;isigopen;1"
"GPSADV","LOAD;EXTERNAL_GPS_ADV.skin;RUN;$GPSPATH$ ;iGuidance||RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\IGCON TROL2\IGCONTROL2.exe"
/global IG3 commands
"EXIT2","RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\kill.exe ||EXIT"
"LASTSCR2","RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\kill. exe||LASTSCR"
"QUICKMENU","RUN;LSTOOLS\IG3scripts\torch.exe"
"HIDEIGMON","SendMsg;IGMonitor;ShowHideButtons "
"EXITFS","EXIT||RUNQ;LSTOOLS\SB2.9_IG3\iGuidance\I GCONTROL2\IGCONTROL2.exe"
/igautosw
/"PAUSE","SETVAR;ispaused;1"
/"RESUME","SETVAR;ispaused;0"
/"IGPAUSE","BYVAR;ispaused;IGPAUSEDO<<"
"IGPAUSE","!PRESET;IG3;WINAMP||SETVOL;WINAMP;$igpa usevol$"
"IGRESUME","PRESET;IG3;WINAMP"
"IGAUTOGPSEXIT","LASTSCR"
"AUTOSWITCHON","SETVAR;igautosw;1||SAVETOINI;igaut osw;$igautosw$"
"AUTOSWITCHOFF","SETVAR;igautosw;0||SAVETOINI;igau tosw;$igautosw$"
"AUTOGPS","BYVAR;igautosw;AUTOSWITCHON<<AUTOSWITCH OFF"
"IGSPEAKON","SETVAR;pauseonvoice;1||SAVETOINI;paus eonvoice;$pauseonvoice$"
"IGSPEAKOFF","SETVAR;pauseonvoice;0||SAVETOINI;pau seonvoice;$pauseonvoice$"
"IGSPEAK","BYVAR;pauseonvoice;IGSPEAKON<<IGSPEAKOF F"
"IGAUTOSWCONFIG","LOAD;IGAUTOSW_CONFIG.skin"
"SWITCHTIME","MENU;IGAUTOSW_SWITCHTIME.skin"
"GPSVOICEON","SETVAR;gpsonvoice;1||SAVETOINI;gpson voice;$gpsonvoice$"
"GPSVOICEOFF","SETVAR;gpsonvoice;0||SAVETOINI;gpso nvoice;$gpsonvoice$"
"GPSVOICE","BYVAR;gpsonvoice;GPSVOICEON<<GPSVOICEO FF"
"IGAUTOSWHELP","MENU;IGAUTOSW_HELP.skin"
"IGAUTOSWHELP2","MENU;IGAUTOSW_HELPb.skin"
"DINGOFF","SETVAR;igding;0||SAVETOSKIN;igding;$igd ing$"
"DINGON","SETVAR;igding;1||SAVETOSKIN;igding;$igdi ng$"
"IGDINGTOGGLE","RUN;$skinpath$toggleding.exe"
"CLOSE_FS","ESC||CLOSEWINDOW;IGCONTROL||CLOSEWINDO W;audio_ctrl"
"LOADFS"," ||RUN;$skinpath$\ALT\MAGIC\MAGICBUTTON.exe|CLOSE_F S EXIT_FS 660 0 1||CUSTOM_COMMAND_1"
"FSDEF_LOAD"," ||BYVAR;FS;<<LOADFS"
"GM2IG","ESC||WAIT;2||MENU;wait_calc_route.ski n"
"SEND2IG","RUN;$SKINPATH$sendroute2IG.exe"
/IG3 END
/MAPMONKEY START
/MAPMONKEY support
"MMGPS","LOAD;EXTERNAL_GPS.skin;RUN;C:\destinatorA pps\Map Monkey\MapMonkey.exe;Map Monkey - [GPS]"
"EXIT2","EXIT"
/"MMGPS","DESTINATOR"
/MAPMONKEY END
/FREEDRIVE START
/FREEDRIVE support
"FREEDRIVE","LOAD;EXTERNAL_GPS.skin;RUN;C:\Pro gram Files\FreeDrive\FreeDrive.exe;FreeDrive"
"EXIT2","EXIT"
/FREEDRIVE END
"AUDIO2","LOAD;ALT\Audioplayer\OLD\audio_player.sk in"
"AUDIO3","LOAD;ALT\Audioplayer\OLD2\audio_player.s kin"
/path to Mobile Emulator 2.0c download app at http://thequiltcupboard.net/mobileimpact/download.htm also see this thread http://www.mp3car.com/vbulletin/software-software-development/58928-true-touch-screen-friendly-all-nintendo-sega-emulator.html
/"GAMES","LOAD;N64.skin;RUN;C:\Program Files\Mobile Impact\Me.exe;Game Emulator"
/path to RRConfig.exe
"CONFIG","RUN;RRConfig.exe;RRConfig"
/"CONFIGOPT","LOAD;configoptions_main.skin"
/path to mousewheelinput utility download app from http://www.phoco.net (remove forward slash in line below to enable)
/"MOUSEWHEELINPUT","RUN;LSTOOLS\SCRIPTS\MMB.exe "
/ disable this line if the above line is enabled (disable by putting forward slash in line below)
"MOUSEWHEELINPUT","MENU;POPUP.skin"
"SAT","XM"
"SAT2","SIRIUS"
/this is a custom command specific to my setup, you dont want to use this for anything.
"CUSTOMSAT",""
/This is for the circle button in the audio player screen, right of the battery meter, by default it pauses RR and mutes the wave line.
/"CUSTOM1","PLAY||RUN;LSTOOLS\LINE\TOGGLEWAVE\LineT oggle.exe"
/weather sat images.... DONOT edit any of the below text
"WEATHERSAT","RUNQ;$SKINPATH$WEATHER_LSXVOID.exe|| LOAD;WEATHER_IMG.skin"
/[yahoo widgets support]. If you install yahoo widgets this will switch RR to an all black screen with 10% visibility and send the F8 command to yahoo widgets to invoke the heads up display. Set all of your widgets to only show during heads up display. To exit out of this mode, click anywhere outside of a widget and RR returns to the previous screen.
"WIDGETS","MINIMIZE||RUN;LSTOOLS\SCRIPTS\widget.ex e"
/this is for the Calendar, go to http://www.rainlendar.net and download Rainlendar, install in default location
"CALENDAR","RUN;C:\Program Files\Rainlendar\Rainlendar.exe"
/custom commands found in the Ext Apps screen, each of these commands are associated with the first 4 buttons on this screen (LAUNCH.skin). Configure them to do what u want, by default they do nothing. The labels are C1-C4, edit Launch.skin in skineditor to change the labels.
"CUSTOM1","LOAD;SKYPE.skin;RUN;C:\Program Files\Skype\Phone\Skype.exe;Skype"
"CUSTOM2",""
"CUSTOM3",""
"CUSTOM4",""
"MOBILEEMU","LOAD;N64.skin;RUN;C:\Program Files\Mobile Impact\Me.exe;Game Emulator"
"GAMESX","LOAD;games.skin"
"GAMES1","LOAD;gameplayer4.skin"
"GAMES2","LOAD;gameplayer.skin;RUN;LSTOOLS\games\p acman.exe;Form1"
"GAMES3","LOAD;gameplayer.skin;RUN;LSTOOLS\games\T etris.exe;Form1"
"GAMES4","LOAD;gameplayer.skin;RUN;LSTOOLS\nintend o.exe;nintendo"
"GAMES5","LOAD;gameplayer1.skin"
"GAMES6","LOAD;gameplayer6.skin"
"GAMES7","LOAD;gameplayer.skin;RUN;LSTOOLS\games\T ictactoe.exe;Form1"
"GAMES8","LOAD;gameplayer.skin;RUN;LSTOOLS\games\a llout.exe;All Out 1.4"
"GAMES9","LOAD;gameplayer2.skin"
"GAMES10","LOAD;gameplayer3.skin"
"GAMES11","LOAD;gameplayer5.skin"
/"BROWSER","LOAD;explorer.skin;RUN;C:\WINDOWS\explo rer.exe;!ExploreWClass"
"SYSMAN","LOAD;sysman.skin;RUN;C:\Program Files\System-Manager\System-Manager.exe;System Manager"
"SENSOR","LOAD;sensor.skin"
/;"TVCONFIG","RUNW;LSTOOLS\TV\config.exe"
/;"TVSCAN","RUNW;LSTOOLS\TV\scan.exe"
"RELOADME","||RUN;$SKINPATH$RESTARTRR.exe||WAIT;3| |QUIT"
/cool app to paint when your really bored/stuck in traffic or to jot down a quick scribble
"PAINT","LOAD;paint.skin;RUN;C:\Program Files\Ambient Design\ArtRage 2\ArtRage.exe|default.ptg;ArtRage"
/,[ONLINE LINKS]
"OFFLINE","MENU;offline.skin"
/"MAIL","LOAD;MAIL.skin;RUN;C:\Program Files\Mozilla Thunderbird\thunderbird.exe;Thunderbird"
"EMAIL","BYIND;ONLINE;OFFLINE<<EMAILA"
"EMAILA","BYVAR;browsertype;EMAIL2<<EMAIL1"
"EMAIL1","Load;ALT\web\gmail\wbrowser.skin||RUN;$s kinpath$gmail.exe;gmail||SETTOPMOST;gmail;TRUE"
"EMAIL2","Load;ALT\web\gmail\wbrowser.skin||RUN;$s kinpath$gmail.exe;gmail||SETTOPMOST;gmail;TRUE"
"IM","BYIND;ONLINE;OFFLINE<<IMA"
"IMA","BYVAR;browsertype;IM2<<IM1"
"IM1","Load;ALT\web\gmail\wbrowser.skin||RUN;$skin path$meebo.exe;meebo||SETTOPMOST;meebo;TRUE"
"IM2","Load;ALT\web\gmail\wbrowser.skin||RUN;$skin path$meebo.exe;meebo||SETTOPMOST;meebo;TRUE"
"TRAFFIC","Load;ALT\web\fullscreen\wbrowser.skin|| RUN;;Mozilla Firefox||Weburl;H:\Traffic\Traffic\traffic.html"
"TRAFFIC2","SETVAR;REFRESHTRAFFIC;1||LOAD;TRafficD ETAILS2.SKIN||RUNQ;$skinpath$TrafficDetails\trdeta ils.exe||SETLABEL;!last;Last Updated:||WAIT;3||SETVAR;REFRESHTRAFFIC;0"
"TRAFFIC3","LOAD;TRafficpick.SKIN||RUNQ;$skinpath$ TrafficDetails\trdetails.exe|TotalMode||SETLABEL;! last;Last Updated:"
"MAPS1","ORB"
"MAPS2","BYIND;ONLINE;OFFLINE<<MAPS2a"
"MAPS2a","BYVAR;browsertype;MAPS2a2<<MAPS2a1"
"MAPS2a1","Load;ALT\web\fullscreen\wbrowser.skin|| RUN;$skinpath$freshlogic.exe;freshlogic"
"MAPS2a2","Load;ALT\web\fullscreen\wbrowser.skin|| RUN;RUN;$skinpath$freshlogic.exe;freshlogic"
"MAPS3","BYIND;ONLINE;OFFLINE<<MAPS3a"
"MAPS3A","BYVAR;browsertype;MAPS3A2<<MAPS3a1"
"MAPS3a1","Load;gmaps.skin||RUN;$skinpath$gmaps.ex e|2 0;gemaps"
"searchme","SETTOPMOST;gemaps;TRUE||RUN;$skinpath$ mapsearch.exe|$searchbar$"
"SEARCHMAP","OSKTOCMD;searchbar;searchme"
"mapzoom_out","SETTOPMOST;gemaps;TRUE||RUN;$skinpa th$mapzoom_out.exe"
"mapzoom_in","SETTOPMOST;gemaps;TRUE||RUN;$skinpat h$mapzoom_in.exe"
"MAPS3aSB","SAVETOSKIN;searchbar;$searchbar$||Run; $skinpath$killmap.exe||Load;gmaps.skin||RUN;$skinp ath$gmaps.exe|3 $qt$$searchbar$$qt$;gemaps||SETTOPMOST;gemaps;TRUE "
"mymaps","RUN;$skinpath$mymaps.exe"
"close_bar","RUN;$skinpath$close_bar.exe"
"search_res","RUN;$skinpath$gmap_search_res.ex e"
"FINDME","RUN;$skinpath$findme.exe"
"SEARCHMAPS","RUN;$SKINPATH$gmaps.exe|gas 3"
"MAPS3a2","Load;ALT\web\fullscreen\wbrowser.skin|| RUN;$browserpath$;Mozilla Firefox||Weburl;http://local.live.com/Default.aspx?enc=0"
"RSS","BYIND;ONLINE;OFFLINE<<RSSa"
"RSSa","BYVAR;browsertype;RSSa2<<RSSa1"
"RSSa1","Load;ALT\web\reader\wbrowser.skin||RUN;$s kinpath$googlereader.exe;google reader||SETTOPMOST;google reader;TRUE"
"RSSa2","Load;ALT\web\reader\wbrowser.skin||RUN;$s kinpath$googlereader.exe;google reader||SETTOPMOST;google reader;TRUE"
"RSS_FS","RUN;$skinpath$RSS_FS.exe"
"RSS_STAR","RUN;$skinpath$RSS_star.exe"
"RSS_NEXT_ITEM","RUN;$skinpath$RSS_nextitem.ex e"
"RSS_PREV_ITEM","RUN;$skinpath$RSS_previtem.ex e"
"RSS_UP","RUN;$skinpath$RSS_pageup.exe"
"RSS_DOWN","RUN;$skinpath$RSS_pagedown.exe"
"RSS_STARGO","RUN;$skinpath$RSS_stargo.exe"
"STUMBLE","BYIND;ONLINE;OFFLINE<<STUMBLE2"
"STUMBLE2","BYVAR;browsertype;STUMBLEa2<<STUMBLEa1 "
"STUMBLEa1","Load;ALT\web\FS2\wbrowser.skin||RUN;$ browserpath$; - Windows Internet Explorer||Weburl;http://video.stumbleupon.com||RUN;LSTOOLS\SCRIPTS\EXIT_we b.exe"
"STUMBLEa2","Load;ALT\web\FS2\wbrowser.skin||RUN;$ browserpath$;Mozilla Firefox||Weburl;http://video.stumbleupon.com||RUN;LSTOOLS\SCRIPTS\EXIT_we b.exe"
"SYNCFILES1","BYIND;ONLINE;OFFLINE<<SYNCFILES2 "
"SYNCFILES2","BYVAR;browsertype;SYNCFILESa2<<SYNCF ILESa1"
"SYNCFILESa1","Load;ALT\web\foldershare\wbrowser.s kin||RUN;$skinpath$foldershare.exe;folder share||SETTOPMOST;folder share;TRUE"
"SYNCFILESa2","Load;ALT\web\foldershare\wbrowser.s kin||RUN;$skinpath$foldershare.exe;folder share||SETTOPMOST;folder share;TRUE"
"MILK1","BYIND;ONLINE;OFFLINE<<MILKb"
"MILKb","BYVAR;browsertype;MILKa2<<MILKa1"
"MILKa1","Load;ALT\web\gmail\wbrowser.skin||RUN;$s kinpath$milk.exe;remember the milk"
"MILKa2","Load;ALT\web\gmail\wbrowser.skin||RUN;$s kinpath$milk.exe;remember the milk"
"ALLYOURBASEAREBELONGTOGOOGLE","BYIND;ONLINE;OFFLI NE<<ALLYOURBASEAREBELONGTOGOOGLE_a"
"ALLYOURBASEAREBELONGTOGOOGLE","BYVAR;browsertype; ALLYOURBASEAREBELONGTOGOOGLE2<<ALLYOURBASEAREBELON GTOGOOGLE1"
"ALLYOURBASEAREBELONGTOGOOGLE1","Load;ALT\web\gmai l\wbrowser.skin||RUN;$browserpath$; - Windows Internet Explorer||Weburl;www.google.com/base"
"ALLYOURBASEAREBELONGTOGOOGLE2","Load;ALT\web\gmai l\wbrowser.skin||RUN;$browserpath$;Mozilla Firefox||Weburl;www.google.com/base"
"SHOWTIME","setvarbycode;locateme;currentzip||save toskin;currentlocation;$locateme$||LOAD;SHOWTIMES. skin;||RUN;$SKINPATH$movietimes.exe|$locateme$;sho wtimes||SETTOPMOST;showtimes;TRUE"
"MOVIETIMES","BYIND;ONLINE;OFFLINE<<MOVIETIMES b"
"MOVIETIMESb","BYVAR;browsertype;MOVIETIMESa2<<MOV IETIMESa1"
/"MOVIETIMESa1","Load;ALT\web\gmail\wbrowser.skin|| RUN;$browserpath$; - Windows Internet Explorer||Weburl;http://www.google.com/movies?hl=en&client=ig&q=movie:+movies+$cityweathe r$"
/"MOVIETIMESa2","Load;ALT\web\gmail\wbrowser.skin|| RUN;$browserpath$;Mozilla Firefox||Weburl;http://www.google.com/movies?hl=en&client=ig&q=movie:+movies+$cityweathe r$"
"MOVIETIMESa1"," ||SHOWTIME"
"MOVIETIMESa2"," ||SHOWTIME"
"SETSULLR","SETTOPMOST;sullr;TRUE"
"SULLR","Load;ALT\web\wosk\wbrowser.skin||RUN;$SKI NPATH$sullr.com.exe;sullr||SETTOPMOST;sullr;TRUE"
"TOKBOX","LOAD;SHOWTIMES.skin;||Run;$skinpath$\tok abox.exe|$userid$;tokabox"
"HIPCAL","BYIND;ONLINE;OFFLINE<<HIPCALb"
"HIPCALb","BYVAR;browsertype;HIPCALa2<<HIPCALa 1"
"HIPCALa1","Load;ALT\web\gmail\wbrowser.skin||RUN; $browserpath$; - Windows Internet Explorer||Weburl;http://hipcal.com/"
"HIPCALa2","Load;ALT\web\gmail\wbrowser.skin||RUN; $browserpath$;Mozilla Firefox||Weburl;http://hipcal.com/"
"EXITWEB","SENDMSG;WebPlugin;EXIT"
;RUN;I:\Composite\RssAggregator.exe;Composite"
/RUNW;$skinpath$copy_web_FS.exe||
/RUNW;$skinpath$copy_web_ST.exe||
"OPENMENU","MENU;MENUOPEN.skin"
"FAA","GIDLE"
"IDLE","FAA",menu.skin
"GIDLE","MENU;IDLE.SKIN"
"IDLE","GIDLE",audio_player.skin
BYVAR;autoAA;<<load;audio_player_AA.skin
/"IDLE","ESC",audio_player_AA.skin
"IDLE","ESC",POPUP.skin
"IDLE","ESC",ratings.skin
"IDLE","ESC",popup_list.skin
"IDLE","ESC",exit_menu.skin
"IDLE","ESC",configoptions.skin
"IDLE","ESC",PICK_menu.skin
"IDLE","ESC",PickMenu2.skin
"TIMER","||SETSULLR",wbrowser.skin
"TIMER"," ||OPENMENU",menu.skin
"TIMER","CLOSE",success.skin
"TIMER","ESC",offline.skin
"TIMER","ESC",MANUAL1.skin
"TIMER","CLOSE",fail.skin
"TIMER","ESC",NEWHITS1.skin
"TIMER","BYVAR;SLIDESHOW;<<NEXTPIC",picviewer. skin
"TIMER","BYVAR;SLIDESHOW;<<NEXTPIC",picpopup.s kin
"TIMER","BYVAR;SLIDESHOW;<<NEXTPIC",bigpic.ski n
"TIMER","ESC",PLISTSAVE_CONFIRM.skin
"TIMER","ESC",EMAIL_SENT.skin
"TIMER"," ||ESC||wait;02||RELOADRR",REGMSG.skin
/"LIST","LOAD;audio_browser3.skin",audio_player.ski n
/"LIST","LOAD;audio_browser3.skin",ALT\Audioplayer\ OLD\audio_player.skin
/"QUIT","RUNW;LSTOOLS\welcomeMSG\bye.exe||EXIT"
"MESSAGE1","MENU;MESSAGE1.skin"
"IGMON_PAUSE", "SETVAR;pause_state;1||PAUSE", PAUSE
"IGMON_PAUSE", "SETVAR;pause_state;0||PAUSE"
"IGMON_RESUME", "BYVAR;pause_state;RESUME<<DO_NOTHING"
".NET","MENU;popup_list.skin"
/"NOTES","LOAD;draw.skin"
"BBART","LOAD;audio_browser2.skin"
/,[OPERA BROWSER SUPPORT]
"OPERA","RUN;$skinpath$launch_opera.exe||LOAD;FILE MAN.skin;RUN;$OPERAPATH$;Opera"
"OPERA_GO"
"OPERA_FAVADD","RUN;$skinpath$OPERA_FAVADD.exe "
"OPERA_BACK","RUN;$skinpath$OPERA_BACK.exe"
"OPERA_FWD","RUN;$skinpath$OPERA_FWD.exe"
"OPERA_FAV","RUN;$skinpath$OPERA_FAV.exe"
"OPERA_NEWTAB","RUNW;$skinpath$OPERA_newtab.exe||O SK"
"OPERA_CLOSETAB"
"OPERA_PGUP","RUN;$skinpath$OPERA_pageup.exe"
"OPERA_PGDN","RUN;$skinpath$OPERA_pagedown.exe "
"OPERA_ZOOMIN","RUN;$skinpath$OPERA_ZOOMIN.exe "
"OPERA_ZOOMOUT","RUN;$skinpath$OPERA_ZOOMOUT.e xe"
"MINI","LOAD;min.skin"
"SCREENLOCK","PAUSE||MENU;ScreenLock.skin"
"BLACKOUT","MENU;blank.skin"
"DIMSCREEN","MENU;dim.skin"
"RELOADPLIST","SETPATH;$PLAYLISTPATH$"
"PLIST","LOAD;LIST2.skin"
"NEAVETV","BYIND;ONLINE;OFFLINE<<NEAVETVa"
"NEAVETVa","LOAD;neavetv.skin;RUN;LSTOOLS\neavetv. exe;neavetv"
/"YAHOO","LOAD;yahoo.skin;RUN;C:\Program Files\Google\Google Earth\googleearth.exe;Google Earth"
/"WEB","RUNW;$skinpath$copy_web_ST.exe||PLUGIN;WebP lugin;$rrpath$WebPlugin.exe"
"MENUOPT","MENU;MENUOPT.skin"
"IENAV","SETVAR;q;"||RUN;LSTOOLS\IENAV.exe|$SI TE$"
"OSKTOCMD;SITE;IENAV"
"ONSONGSTART","SETVARBYCODE;curtrack;trackpath||ra techeck",audio_player.skin
"ONSONGSTART","SETVARBYCODE;curtrack;trackpath||ra techeck",audio_player_old.skin
"ONSONGSTART","SETVARBYCODE;curtrack;trackpath||ra techeck",audio_player_AA.skin
"ONSONGSTART","SETVARBYCODE;curtrack;trackpath||ra techeck",menu.skin
"ONSONGSTART","RUN;$SKINPATH$LYRICS\LyricsFinder.e xe",audio_player_lyrics.skin
"ratecheck","setind;CUSTOM1starindicator;OFF||seti nd;CUSTOM2starindicator;OFF||setind;CUSTOM3starind icator;OFF||setind;CUSTOM4starindicator;OFF||setin d;CUSTOM5starindicator;OFF||SETVARBYCODE;curtrack; trackpath||RunQ;$skinpath$Ratings\ratecheck.exe|$c urtrack$"
"ratecheck2","RunQ;$skinpath$Ratings\ratecheck.exe |$curtrack$"
"RATINGS","MENU;ratings.skin||RunQW;$skinpath$Rati ngs\ratecheck.exe|$curtrack$"
"RATEA","RATE1||HOLDUP||SAVERATE"
"RATEB","RATE2||HOLDUP||SAVERATE"
"RATEC","RATE3||HOLDUP||SAVERATE"
"RATED","RATE4||HOLDUP||SAVERATE"
"RATEE","RATE5||HOLDUP||SAVERATE"
"RATEA1","RATE1||HOLDUP||SAVERATE2"
"RATEB2","RATE2||HOLDUP||SAVERATE2"
"RATEC3","RATE3||HOLDUP||SAVERATE2"
"RATED4","RATE4||HOLDUP||SAVERATE2"
"RATEE5","RATE5||HOLDUP||SAVERATE2"
"RATE1","setind;CUSTOM1starindicator;ON||setind;CU STOM2starindicator;OFF||setind;CUSTOM3starindicato r;OFF||setind;CUSTOM4starindicator;OFF||setind;CUS TOM5starindicator;OFF||RUNQW;$skinpath$Ratings\Sta r Rating.exe|1"
"RATE2","setind;CUSTOM1starindicator;ON||setind;CU STOM2starindicator;ON||setind;CUSTOM3starindicator ;OFF||setind;CUSTOM4starindicator;OFF||setind;CUST OM5starindicator;OFF||RUNQW;$skinpath$Ratings\Star Rating.exe|2"
"RATE3","setind;CUSTOM1starindicator;ON||setind;CU STOM2starindicator;ON||setind;CUSTOM3starindicator ;ON||setind;CUSTOM4starindicator;OFF||setind;CUSTO M5starindicator;OFF||RUNQW;$skinpath$Ratings\Star Rating.exe|3"
"RATE4","setind;CUSTOM1starindicator;ON||setind;CU STOM2starindicator;ON||setind;CUSTOM3starindicator ;ON||setind;CUSTOM4starindicator;ON||setind;CUSTOM 5starindicator;OFF||RUNQW;$skinpath$Ratings\Star Rating.exe|4"
"RATE5","setind;CUSTOM1starindicator;ON||setind;CU STOM2starindicator;ON||setind;CUSTOM3starindicator ;ON||setind;CUSTOM4starindicator;ON||setind;CUSTOM 5starindicator;ON||RUNQW;$skinpath$Ratings\Star Rating.exe|5"
"SAVERATE","SETLABEL;CUSTOMrated;||SETLABEL;CUSTOM stars;||RunQW;$skinpath$Ratings\ratewriter.exe||SE TVARBYCODE;CURTRACK;TRACKPATH||RUNQ;$skinpath$Rati ngs\Ratings.exe|$CURTRACK$||Close"
"SAVERATE2","SETLABEL;CUSTOMrated;||SETLABEL;CUSTO Mstars;||RunQW;$skinpath$Ratings\ratewriter.exe||S ETVARBYCODE;CURTRACK;TRACKPATH||RUNQ;$skinpath$Rat ings\Ratings.exe|$CURTRACK$||"
"STAR1","LOADLIST;$playlistpath$1 stars.m3u;1 STAR"
"STAR2","LOADLIST;$playlistpath$2 stars.m3u;2 STARS"
"STAR3","LOADLIST;$playlistpath$3 stars.m3u;3 STARS"
"STAR4","LOADLIST;$playlistpath$4 stars.m3u;4 STARS"
"STAR5","LOADLIST;$playlistpath$5 stars.m3u;5 STARS"
"HOLDUP","Wait;2"
"NOTEPAD","RUN;$RRPATH$LSTOOLS\JOT\launch.exe||LOA D;notepad.skin;RUN;$RRPATH$LSTOOLS\JOT\notepad.exe |notes.txt;notes.txt - Notepad"
"EXITNP","RUNQW;$RRPATH$LSTOOLS\JOT\save.exe||WAIT ;1||CLOSE"
"REMOTEDESKTOP","LOAD;RDT.skin;RUN;C:\WINDOWS\syst em32\mstsc.exe;Remote Desktop"
"TRIP LOG","LOAD;tripmeter.skin"
/"UPDATECHECK","MENU;updatecheck.skin||RUN;RR_Updat er.exe;Road Runner Updater"
"UPDATECHECK","RUN;RR_Updater_EmbedVer.exe"
/,[SAVE TRACK POSITION]
"SAVEPOS1","SETVARBYCODE;TRACKNUM_P1;LISTPOS||SAVE TOSKIN;TRACKNUM_P1;$TRACKNUM_P1$||SETVARBYCODE;SON GPOS_P1;CURRENTTRACKTIME||SAVETOSKIN;SONGPOS_P1;$S ONGPOS_P1$"
"SAVEPOS2","SETVARBYCODE;TRACKNUM_P2;LISTPOS||SAVE TOSKIN;TRACKNUM_P2;$TRACKNUM_P2$||SETVARBYCODE;SON GPOS_P2;CURRENTTRACKTIME||SAVETOSKIN;SONGPOS_P2;$S ONGPOS_P2$"
"SAVEPOS3","SETVARBYCODE;TRACKNUM_P3;LISTPOS||SAVE TOSKIN;TRACKNUM_P3;$TRACKNUM_P3$||SETVARBYCODE;SON GPOS_P3;CURRENTTRACKTIME||SAVETOSKIN;SONGPOS_P3;$S ONGPOS_P3$"
"SAVEPOS4","SETVARBYCODE;TRACKNUM_P4;LISTPOS||SAVE TOSKIN;TRACKNUM_P4;$TRACKNUM_P4$||SETVARBYCODE;SON GPOS_P4;CURRENTTRACKTIME||SAVETOSKIN;SONGPOS_P4;$S ONGPOS_P4$"
"SAVEPOS5","SETVARBYCODE;TRACKNUM_P5;LISTPOS||SAVE TOSKIN;TRACKNUM_P5;$TRACKNUM_P5$||SETVARBYCODE;SON GPOS_P5;CURRENTTRACKTIME||SAVETOSKIN;SONGPOS_P5;$S ONGPOS_P5$"
"SAVEPOS6","SETVARBYCODE;TRACKNUM_P6;LISTPOS||SAVE TOSKIN;TRACKNUM_P6;$TRACKNUM_P6$||SETVARBYCODE;SON GPOS_P6;CURRENTTRACKTIME||SAVETOSKIN;SONGPOS_P6;$S ONGPOS_P6$"
"SAVEPOS7","SETVARBYCODE;TRACKNUM_P7;LISTPOS||SAVE TOSKIN;TRACKNUM_P7;$TRACKNUM_P7$||SETVARBYCODE;SON GPOS_P7;CURRENTTRACKTIME||SAVETOSKIN;SONGPOS_P7;$S ONGPOS_P7$"
"SAVEPOS8","SETVARBYCODE;TRACKNUM_P8;LISTPOS||SAVE TOSKIN;TRACKNUM_P8;$TRACKNUM_P8$||SETVARBYCODE;SON GPOS_P8;CURRENTTRACKTIME||SAVETOSKIN;SONGPOS_P8;$S ONGPOS_P8$"
"SAVEPOS9","SETVARBYCODE;TRACKNUM_P9;LISTPOS||SAVE TOSKIN;TRACKNUM_P9;$TRACKNUM_P9$||SETVARBYCODE;SON GPOS_P9;CURRENTTRACKTIME||SAVETOSKIN;SONGPOS_P9;$S ONGPOS_P9$"
"SAVEPOS10","SETVARBYCODE;TRACKNUM_P10;LISTPOS||SA VETOSKIN;TRACKNUM_P10;$TRACKNUM_P10$||SETVARBYCODE ;SONGPOS_P10;CURRENTTRACKTIME||SAVETOSKIN;SONGPOS_ P10;$SONGPOS_P10$"
"SKIPME","SEEKTO;$SONGPOS_P2$"
/,[LOADPRESETS]
"PRESET1","||SAVEPOS5||MUTE||LOADLIST;$playlistpat h$PRESET1.m3u;$PSETNAME1$||STOP||SELPL||SETLIST;$T RACKNUM_P1$||PLEXEC||SETVAR;SLOT;1||SAVETOSKIN;SLO T;$SLOT$||SEEKTO;$SONGPOS_P1$||MUTE"
"PRESET2","||SAVEPOS1||MUTE||LOADLIST;$playlistpat h$PRESET2.m3u;$PSETNAME2$||STOP||SELPL||SETLIST;$T RACKNUM_P2$||PLEXEC||SETVAR;SLOT;2||SAVETOSKIN;SLO T;$SLOT$||SEEKTO;$SONGPOS_P2$||MUTE"
"PRESET3","||SAVEPOS2||MUTE||LOADLIST;$playlistpat h$PRESET3.m3u;$PSETNAME3$||STOP||SELPL||SETLIST;$T RACKNUM_P3$||PLEXEC||SETVAR;SLOT;3||SAVETOSKIN;SLO T;$SLOT$||SEEKTO;$SONGPOS_P3$||MUTE"
"PRESET4","||SAVEPOS3||MUTE||LOADLIST;$playlistpat h$PRESET4.m3u;$PSETNAME4$||STOP||SELPL||SETLIST;$T RACKNUM_P4$||PLEXEC||SETVAR;SLOT;4||SAVETOSKIN;SLO T;$SLOT$||SEEKTO;$SONGPOS_P4$||MUTE"
"PRESET5","||SAVEPOS4||MUTE||LOADLIST;$playlistpat h$PRESET5.m3u;$PSETNAME5$||STOP||SELPL||SETLIST;$T RACKNUM_P5$||PLEXEC||SETVAR;SLOT;5||SAVETOSKIN;SLO T;$SLOT$||SEEKTO;$SONGPOS_P5$||MUTE"
"PRESET1b","||SAVEPOS2||MUTE||LOADLIST;$playlistpa th$PRESET1.m3u;$PSETNAME1$||STOP||SELPL||SETLIST;$ TRACKNUM_P1$||PLEXEC||SETVAR;SLOT;1||SAVETOSKIN;SL OT;$SLOT$||SEEKTO;$SONGPOS_P1$||MUTE"
"PRESET2b","||SAVEPOS3||MUTE||LOADLIST;$playlistpa th$PRESET2.m3u;$PSETNAME2$||STOP||SELPL||SETLIST;$ TRACKNUM_P2$||PLEXEC||SETVAR;SLOT;2||SAVETOSKIN;SL OT;$SLOT$||SEEKTO;$SONGPOS_P2$||MUTE"
"PRESET3b","||SAVEPOS4||MUTE||LOADLIST;$playlistpa th$PRESET3.m3u;$PSETNAME3$||STOP||SELPL||SETLIST;$ TRACKNUM_P3$||PLEXEC||SETVAR;SLOT;3||SAVETOSKIN;SL OT;$SLOT$||SEEKTO;$SONGPOS_P3$||MUTE"
"PRESET4b","||SAVEPOS5||MUTE||LOADLIST;$playlistpa th$PRESET4.m3u;$PSETNAME4$||STOP||SELPL||SETLIST;$ TRACKNUM_P4$||PLEXEC||SETVAR;SLOT;4||SAVETOSKIN;SL OT;$SLOT$||SEEKTO;$SONGPOS_P4$||MUTE"
"PRESET5b","||SAVEPOS1||MUTE||LOADLIST;$playlistpa th$PRESET5.m3u;$PSETNAME5$||STOP||SELPL||SETLIST;$ TRACKNUM_P5$||PLEXEC||SETVAR;SLOT;5||SAVETOSKIN;SL OT;$SLOT$||SEEKTO;$SONGPOS_P5$||MUTE"
"PRESET1PL","||SAVEPOS5||LOADLIST;$playlistpath$PR ESET1.m3u;$PSETNAME1$||SETVAR;SLOT;1||SAVETOSKIN;S LOT;$SLOT$"
"PRESET2PL","||SAVEPOS1||LOADLIST;$playlistpath$PR ESET2.m3u;$PSETNAME2$||SETVAR;SLOT;2||SAVETOSKIN;S LOT;$SLOT$"
"PRESET3PL","||SAVEPOS2||LOADLIST;$playlistpath$PR ESET3.m3u;$PSETNAME3$||SETVAR;SLOT;3||SAVETOSKIN;S LOT;$SLOT$"
"PRESET4PL","||SAVEPOS3||LOADLIST;$playlistpath$PR ESET4.m3u;$PSETNAME4$||SETVAR;SLOT;4||SAVETOSKIN;S LOT;$SLOT$"
"PRESET5PL","||SAVEPOS4||LOADLIST;$playlistpath$PR ESET5.m3u;$PSETNAME5$||SETVAR;SLOT;5||SAVETOSKIN;S LOT;$SLOT$"
"PRESET6","LOADLIST;$playlistpath$PRESET6.m3u;$PSE TNAME6$||SETLIST;$TRACKNUM_P6$||PLEXEC||SEEKTO;$SO NGPOS_P6$||SETVAR;SLOT;6||SAVETOSKIN;SLOT;$SLOT$"
"PRESET7","LOADLIST;$playlistpath$PRESET7.m3u;$PSE TNAME7$||SETLIST;$TRACKNUM_P7$||PLEXEC||SEEKTO;$SO NGPOS_P7$||SETVAR;SLOT;7||SAVETOSKIN;SLOT;$SLOT$"
"PRESET8","LOADLIST;$playlistpath$PRESET8.m3u;$PSE TNAME8$||SETLIST;$TRACKNUM_P8$||PLEXEC||SEEKTO;$SO NGPOS_P8$||SETVAR;SLOT;8||SAVETOSKIN;SLOT;$SLOT$"
"PRESET9","LOADLIST;$playlistpath$PRESET9.m3u;$PSE TNAME9$||SETLIST;$TRACKNUM_P9$||PLEXEC||SEEKTO;$SO NGPOS_P9$||SETVAR;SLOT;9||SAVETOSKIN;SLOT;$SLOT$"
"PRESET10","LOADLIST;$playlistpath$PRESET10.m3u;$P SETNAME10$||SETLIST;$TRACKNUM_P10$||PLEXEC||SEEKTO ;$SONGPOS_P10$||SETVAR;SLOT;10||SAVETOSKIN;SLOT;$S LOT$"
"SAVEPLIST","MENU;SAVEPLIST.skin"
"PSETERROR","MENU;PSETERROR.skin"
"HISTORY1","||SAVEPOS5||MUTE||LOADLIST;$playlistpa th$HISTORY1.m3u;$PSETNAME1$||STOP||SETLIST;$TRACKN UM_P1$||PLEXEC||SETVAR;SLOT;1||SAVETOSKIN;SLOT;$SL OT$||SEEKTO;$SONGPOS_P1$||MUTE"
"HISTORY2","||SAVEPOS1||MUTE||LOADLIST;$playlistpa th$HISTORY2.m3u;$PSETNAME2$||STOP||SETLIST;$TRACKN UM_P2$||PLEXEC||SETVAR;SLOT;2||SAVETOSKIN;SLOT;$SL OT$||SEEKTO;$SONGPOS_P2$||MUTE"
"HISTORY3","||SAVEPOS2||MUTE||LOADLIST;$playlistpa th$HISTORY3.m3u;$PSETNAME3$||STOP||SETLIST;$TRACKN UM_P3$||PLEXEC||SETVAR;SLOT;3||SAVETOSKIN;SLOT;$SL OT$||SEEKTO;$SONGPOS_P3$||MUTE"
"HISTORY4","||SAVEPOS3||MUTE||LOADLIST;$playlistpa th$HISTORY4.m3u;$PSETNAME4$||STOP||SETLIST;$TRACKN UM_P4$||PLEXEC||SETVAR;SLOT;4||SAVETOSKIN;SLOT;$SL OT$||SEEKTO;$SONGPOS_P4$||MUTE"
"HISTORY5","||SAVEPOS4||MUTE||LOADLIST;$playlistpa th$HISTORY5.m3u;$PSETNAME5$||STOP||SETLIST;$TRACKN UM_P5$||PLEXEC||SETVAR;SLOT;5||SAVETOSKIN;SLOT;$SL OT$||SEEKTO;$SONGPOS_P5$||MUTE"
/, [SAVE PRESETS]
"SAVEPLIST1","SAVELIST;$playlistpath$PRESET1.m3u|| SETVARBYCODE;PSETNAME1;PLAYLIST||SAVETOSKIN;PSETNA ME1;$PSETNAME1$||ESC||RELOADPLIST"
"SAVEPLIST2","SAVELIST;$playlistpath$PRESET2.m3u|| SETVARBYCODE;PSETNAME2;PLAYLIST||SAVETOSKIN;PSETNA ME2;$PSETNAME2$||ESC||RELOADPLIST"
"SAVEPLIST3","SAVELIST;$playlistpath$PRESET3.m3u|| SETVARBYCODE;PSETNAME3;PLAYLIST||SAVETOSKIN;PSETNA ME3;$PSETNAME3$||ESC||RELOADPLIST"
"SAVEPLIST4","SAVELIST;$playlistpath$PRESET4.m3u|| SETVARBYCODE;PSETNAME4;PLAYLIST||SAVETOSKIN;PSETNA ME4;$PSETNAME4$||ESC||RELOADPLIST"
"SAVEPLIST5","SAVELIST;$playlistpath$PRESET5.m3u|| SETVARBYCODE;PSETNAME5;PLAYLIST||SAVETOSKIN;PSETNA ME5;$PSETNAME5$||ESC||RELOADPLIST"
"SAVEPLISTNOW1","SAVELIST;$playlistpath$PRESET1.m3 u||SETVARBYCODE;PSETNAME1;PLAYLIST||SAVETOSKIN;PSE TNAME1;$PSETNAME1$||RELOADPLIST"
"SAVEPLISTNOW2","SAVELIST;$playlistpath$PRESET2.m3 u||SETVARBYCODE;PSETNAME2;PLAYLIST||SAVETOSKIN;PSE TNAME2;$PSETNAME2$||RELOADPLIST"
"SAVEPLISTNOW3","SAVELIST;$playlistpath$PRESET3.m3 u||SETVARBYCODE;PSETNAME3;PLAYLIST||SAVETOSKIN;PSE TNAME3;$PSETNAME3$||RELOADPLIST"
"SAVEPLISTNOW4","SAVELIST;$playlistpath$PRESET4.m3 u||SETVARBYCODE;PSETNAME4;PLAYLIST||SAVETOSKIN;PSE TNAME4;$PSETNAME4$||RELOADPLIST"
"SAVEPLISTNOW5","SAVELIST;$playlistpath$PRESET5.m3 u||SETVARBYCODE;PSETNAME5;PLAYLIST||SAVETOSKIN;PSE TNAME5;$PSETNAME5$||RELOADPLIST"
"SAVEPLISTNOW1A","SAVELIST;$playlistpath$HISTORY1. m3u||SETVARBYCODE;PSETNAME1;DLTEXT||SETVAR;SLOT;2| |SAVETOSKIN;SLOT;2"
"SAVEPLISTNOW2B","SAVELIST;$playlistpath$HISTORY2. m3u||SETVARBYCODE;PSETNAME2;DLTEXT||SETVAR;SLOT;3| |SAVETOSKIN;SLOT;3"
"SAVEPLISTNOW3C","SAVELIST;$playlistpath$HISTORY3. m3u||SETVARBYCODE;PSETNAME3;DLTEXT||SETVAR;SLOT;4| |SAVETOSKIN;SLOT;4"
"SAVEPLISTNOW4D","SAVELIST;$playlistpath$HISTORY4. m3u||SETVARBYCODE;PSETNAME4;DLTEXT||SETVAR;SLOT;5| |SAVETOSKIN;SLOT;5"
"SAVEPLISTNOW5E","SAVELIST;$playlistpath$HISTORY5. m3u||SETVARBYCODE;PSETNAME5;DLTEXT||SETVAR;SLOT;1| |SAVETOSKIN;SLOT;1"
"INSTANTPLISTSAVE","BYVAR;SLOT;<<SAVEPLISTNOW1<<SA VEPLISTNOW2<<SAVEPLISTNOW3<<SAVEPLISTNOW4<<SAVEPLI STNOW5||MENU;PLISTSAVE_CONFIRM.skin"
"INSTANTPLISTSAVE2","BYVAR;SLOT;<<SAVEPLISTNOW1A<< SAVEPLISTNOW2B<<SAVEPLISTNOW3C<<SAVEPLISTNOW4D<<SA VEPLISTNOW5E"
"LIST1SET","SAVELIST;$playlistpath$PRESET1.m3u||SE TVAR;PSETNAME1;$PSETNAME1$||SAVETOSKIN;PSETNAME1;$ PSETNAME1$||SAVEPOS1||LOADLIST;$playlistpath$PRESE T1.m3u;$PSETNAME1$||SETLIST;$TRACKNUM_P1$||PLEXEC| |SEEKTO;$SONGPOS_P1$||SETVAR;SLOT;1||SAVETOSKIN;SL OT;$SLOT$"
"LIST2SET","SAVELIST;$playlistpath$PRESET2.m3u||SE TVAR;PSETNAME2;$PSETNAME2$||SAVETOSKIN;PSETNAME2;$ PSETNAME2$||SAVEPOS2||LOADLIST;$playlistpath$PRESE T2.m3u;$PSETNAME2$||SETLIST;$TRACKNUM_P2$||PLEXEC| |SEEKTO;$SONGPOS_P2$||SETVAR;SLOT;2||SAVETOSKIN;SL OT;$SLOT$"
"LIST3SET","SAVELIST;$playlistpath$PRESET3.m3u||SE TVAR;PSETNAME3;$PSETNAME3$||SAVETOSKIN;PSETNAME3;$ PSETNAME3$||SAVEPOS3||LOADLIST;$playlistpath$PRESE T3.m3u;$PSETNAME3$||SETLIST;$TRACKNUM_P3$||PLEXEC| |SEEKTO;$SONGPOS_P3$||SETVAR;SLOT;3||SAVETOSKIN;SL OT;$SLOT$"
"LIST4SET","SAVELIST;$playlistpath$PRESET4.m3u||SE TVAR;PSETNAME4;$PSETNAME4$||SAVETOSKIN;PSETNAME4;$ PSETNAME4$||SAVEPOS4||LOADLIST;$playlistpath$PRESE T4.m3u;$PSETNAME4$||SETLIST;$TRACKNUM_P4$||PLEXEC| |SEEKTO;$SONGPOS_P4$||SETVAR;SLOT;4||SAVETOSKIN;SL OT;$SLOT$"
"LIST5SET","SAVELIST;$playlistpath$PRESET5.m3u||SE TVAR;PSETNAME5;$PSETNAME5$||SAVETOSKIN;PSETNAME5;$ PSETNAME5$||SAVEPOS5||LOADLIST;$playlistpath$PRESE T5.m3u;$PSETNAME5$||SETLIST;$TRACKNUM_P5$||PLEXEC| |SEEKTO;$SONGPOS_P5$||SETVAR;SLOT;5||SAVETOSKIN;SL OT;$SLOT$"
"LIST6SET","SAVEPLIST6||SAVETOSKIN;PSETNAME6;$PSET NAME6$||RELOADPLIST"
"LIST7SET","SAVEPLIST7||SAVETOSKIN;PSETNAME7;$PSET NAME7$||RELOADPLIST"
"LIST8SET","SAVEPLIST8||SAVETOSKIN;PSETNAME8;$PSET NAME8$||RELOADPLIST"
"LIST9SET","SAVEPLIST9||SAVETOSKIN;PSETNAME9;$PSET NAME9$||RELOADPLIST"
"LIST10SET","SAVEPLIST10||SAVETOSKIN;PSETNAME10;$P SETNAME10$||RELOADPLIST"
"LOADPLIST","MENU;LOADPLIST.skin"
"NEXTPSET","BYVAR;SLOT;<<SAVEPOS1||PRESET2<<SAVEPO S2||PRESET3<<SAVEPOS3||PRESET4<<SAVEPOS4||PRESET5< <SAVEPOS5||PRESET1"
"PREVPSET","BYVAR;SLOT;<<PRESET5<<PRESET1<<PRESET2 <<PRESET3<<PRESET4"
/START DIR PLAYER
"SETMPATH","WRITETOFILE;$skinpath$path.txt;=$music path$||WRITETOFILE;$skinpath$path2.txt;=$playlistp ath$||WRITETOFILE;$skinpath$path3.txt;=$skinpath$| |WRITETOFILE;$rrpath$LSTOOLS\path.txt;=$musicpath$ ||WRITETOFILE;$rrpath$LSTOOLS\path2.txt;=$playlist path$||WRITETOFILE;$rrpath$LSTOOLS\path3.txt;=$ski npath$||WRITETOFILE;$skinpath$rrpath.txt;=$rrpath$ ||WRITETOFILE;$skinpath$path4.txt;=$winamppath$"
/"SETBASE","SETVAR;BASE;FALSE||EVAL;BASE;strcomp("$ hidedots$";"$BASE$")||SETVAR;BASE;$BASE$||SETVAR;D ISKCHG;1||EVAL;DISKCHG;$DISKCHG$+$BASE$||"
/"NEXTDISK","SELDL||EVAL;DISKCHG;$DISKCHG$+1||SETLI ST;$DISKCHG$||!SELECT||BACK||SELPL"
/"PREVDISK","SELDL||EVAL;DISKCHG;$DISKCHG$-1||SETLIST;$DISKCHG$||!SELECT||BACK||SELPL"
/END DIR PLAYER
"DISKDOWN","RUNQ;$skinpath$dirplayer.exe"
"DISKUP","RUNQ;$skinpath$dirplayer_neg.exe"
"DISKSET1","SELDL||BACK||!SELECT||BACK||SELPL"
"DISKSEL","SELDL||SETPATH;H:\My Music\Clipse"
"DISKSEL2","SETPATH;H:\1MUSICTEST"
"ABOUT","MENU;about.skin"
/WHATS NEW
"WHATSNEW","MENU;NEWHITS.skin"
"LOADNEW","LOADLIST;$PLAYLISTPATH$new hits.m3u;NEW HITS"
"1DAYNEW","RUN;$skinpath$New Hits.exe|1day||MENU;NEWHITS1.skin"
"1WEEKNEW","RUN;$skinpath$New Hits.exe|1week||MENU;NEWHITS1.skin"
"2WEEKSNEW","RUN;$skinpath$New Hits.exe|2weeks||MENU;NEWHITS1.skin"
"1MONTHNEW","RUN;$skinpath$New Hits.exe||MENU;NEWHITS1.skin"
/,[SETUP CUSTOM APPS]
"SETUPHELP","LOAD;SETUPHELP.skin"
"CUSTOMAPP1","LOAD;EXTAPP1.skin;RUN;$custompat h1$"
"CUSTOMAPP2","LOAD;EXTAPP2.skin;RUN;$custompat h2$"
"CUSTOMAPP3","LOAD;EXTAPP3.skin;RUN;$custompat h3$"
"CUSTOMAPP4","LOAD;EXTAPP4.skin;RUN;$custompat h4$"
"CUSTOMAPP5","LOAD;EXTAPP5.skin;RUN;$custompat h5$"
"CUSTOMAPP6","LOAD;EXTAPP6.skin;RUN;$custompat h6$"
"SETUPCUS1","CHECKDRIVELETTERS||LOAD;SETUPCUS1A.sk in"
"SETUPCUS2","CHECKDRIVELETTERS||LOAD;SETUPCUS2B.sk in"
"SETUPCUS3","CHECKDRIVELETTERS||LOAD;SETUPCUS3C.sk in"
"SETUPCUS4","CHECKDRIVELETTERS||LOAD;SETUPCUS4D.sk in"
"SETUPCUS5","CHECKDRIVELETTERS||LOAD;SETUPCUS5E.sk in"
"SETUPCUS6","CHECKDRIVELETTERS||LOAD;SETUPCUS6F.sk in"
"SAVECUSNAME01","SETVARBYCODE;FREE50;$FREE50$||REL OADSKIN"
/,[ANTISTATUS]
"SETUPANTISTATUS","SETVARBYCODE;VSTATUS;STATUS||EV AL;B_ANTISTATUS;strcomp("PLAY";"$VSTATUS$")||BYVAR ;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING"
"ISPLAYING","SETVAR;ANTISTATUS;PAUSE||SETVAR;STATU SSYM;0"
"ISNTPLAYING","SETVAR;ANTISTATUS;PLAY||SETVAR;STAT USSYM;1"
"PLAY","PLAY||SETUPANTISTATUS"
"ONPLCLICK","WAIT;0.1||SETUPANTISTATUS"
/ANTISTATUS END
/ATT CODE START/================================================== ======
"OFF","!PRESET;ATT||SETVOL;Master;10"
"ON","PRESET;ATT"
/"SETUPATT","SETVAR;attvol_low;120||SETVAR;attvol_h igh;255||SAVETOSKIN;attvol_low;$attvol_low$||SAVET OSKIN;attvol_high;$attvol_high$||SETVAR;ATTENTION; $ATTENTION$||SAVETOSKIN;ATTENTION;$ATTENTION$"
/"SETVAR;ATTENTION;$ATTENTION$||SAVETOSKIN;ATTENTIO N;$ATTENTION$"
"ATTON","!PRESET;IG3;WINAMP||SETVOL;WINAMP;$attvol _low$||SETVAR;ATTENTION;1||SAVETOSKIN;ATTENTION;$A TTENTION$"
"ATTOFF","PRESET;IG3;WINAMP||SETVOL;WINAMP;$attvol _high$||SETVAR;ATTENTION;0||SAVETOSKIN;ATTENTION;$ ATTENTION$"
/thE command "DUCK" is used for all att buttons
"DUCK","BYVAR;ATTENTION;ATTON<<ATTOFF"
/ATT CODE END/================================================== ======
/,[STARTUP SOUND]
"PLAYSOUND","RUN;$skinpath$playsound.exe"
/,[SYNC NOTES]http://www.cynapse.com/
"NEWNOTE","RUN;$skinpath$newstickynote.exe||SETVAR ;NOTES;0"
"NOTESTAT","SETVAR;NOTES;0"
"SHOWHIDEN","BYVAR;NOTES;SHOWNOTES<<HIDENOTES"
"SHOWNOTES","RUN;$skinpath$shownotes.exe||SETVAR;N OTES;1"
"HIDENOTES","RUN;$skinpath$hidenotes.exe||SETVAR;N OTES;0"
"SYNCNOTES","RUN;$skinpath$syncnotes.exe"
/,[TOGGLE FLASH COMPASS]
"COMPASSON","SETVAR;FLCOMPASS;0||SAVETOSKIN;FLCOMP ***;0||RELOADSKIN"
"COMPASSOFF","SETVAR;FLCOMPASS;1||SAVETOSKIN;FLCOM PASS;1||RELOADSKIN"
"HEADINGON","SETVAR;IMGCOMPASS;0||SAVETOSKIN;IMGCO MPASS;0||RELOADSKIN"
"HEADINGOFF","SETVAR;IMGCOMPASS;1||SAVETOSKIN;IMGC OMPASS;1||RELOADSKIN"
"TOGGLECOMPASS","RUN;$SKINPATH$toggle_compass. exe"
"TOGGLECOMPASSARROWS","RUN;$SKINPATH$toggle_arrow_ compass.exe"
/,[TIPOFTHEDAY]
"TIP1","LOAD;TIPOFDAY.skin||SETVAR;TODS;1||SAVETOS KIN;TODS;$TODS$"
"TIP2","LOAD;TIPOFDAY2.skin||SETVAR;TODS;2||SAVETO SKIN;TODS;$TODS$"
"TIP3","LOAD;TIPOFDAY3.skin||SETVAR;TODS;3||SAVETO SKIN;TODS;$TODS$"
"TIP4","LOAD;TIPOFDAY4.skin||SETVAR;TODS;4||SAVETO SKIN;TODS;$TODS$"
"TIP5","LOAD;TIPOFDAY5.skin||SETVAR;TODS;5||SAVETO SKIN;TODS;$TODS$"
"TIP6","LOAD;TIPOFDAY6.skin||SETVAR;TODS;6||SAVETO SKIN;TODS;$TODS$"
"TIP7","LOAD;TIPOFDAY7.skin||SETVAR;TODS;7||SAVETO SKIN;TODS;$TODS$"
"TIP8","LOAD;TIPOFDAY8.skin||SETVAR;TODS;8||SAVETO SKIN;TODS;$TODS$"
"TIP9","LOAD;TIPOFDAY9.skin||SETVAR;TODS;9||SAVETO SKIN;TODS;$TODS$"
"TIP10","LOAD;TIPOFDAY10.skin||SETVAR;TODS;10||SAV ETOSKIN;TODS;$TODS$"
"NEXTTIP","BYVAR;TODS;<<TIP2<<TIP3<<TIP4<<TIP5<<TI P6<<TIP7<<TIP8<<TIP9<<TIP10<<TIP1"
"TODON","SETVAR;TOD;1||SAVETOSKIN;TOD;$TOD$"
"TODOFF","SETVAR;TOD;0||SAVETOSKIN;TOD;$TOD$"
"TODONt","SETVAR;TOD;1||SAVETOSKIN;TOD;$TOD$||MENU ;TIPSTATUS.skin"
"TODOFFt","SETVAR;TOD;0||SAVETOSKIN;TOD;$TOD$||MEN U;TIPSTATUS.skin"
"TIPOFDAY","BYVAR;TOD;TODON<<TODOFF"
"TIPOFDAYTOGGLE","MENU;TIPSTATUS.skin"
/,[GOOGLE VIDEO WEATHER FORCASTS]
"FORECAST","BYIND;ONLINE;OFFLINE<<FORECASTa"
"FORECASTa","LOAD;CHICAGOWEATHER.skin"
/,[VOICE RECORDER]
"MONTH","BYVAR;myDpath;<<MONTH1<<MONTH2<<MONTH3<<M ONTH4<<MONTH5<<MONTH6<<MONTH7<<MONTH8<<MONTH9<<MON TH10<<MONTH11<<MONTH12"
"MONTH1","SETVAR;MONTH;JANUARY"
"MONTH2","SETVAR;MONTH;FEBRUARY"
"MONTH3","SETVAR;MONTH;MARCH"
"MONTH4","SETVAR;MONTH;APRIL"
"MONTH5","SETVAR;MONTH;MAY"
"MONTH6","SETVAR;MONTH;JUNE"
"MONTH7","SETVAR;MONTH;JULY"
"MONTH8","SETVAR;MONTH;AUGUST"
"MONTH9","SETVAR;MONTH;SEPTEMBER"
"MONTH10","SETVAR;MONTH;OCTOBER"
"MONTH11","SETVAR;MONTH;NOVEMBER"
"MONTH12","SETVAR;MONTH;DECEMBER"
"vPATH","SETVAR;SLASH;\||SETVARBYCODE;myDpath;DATE ;MM||MONTH||SETVARBYCODE;myT;TIME;HH_MM_AM/PM||SETVARBYCODE;myD;DATE;MM-DD-YYYY||SETVAR;myTD;$myD$@$myT$||SETVAR;quotes;"||SE TVAR;vfolderpath;-{VOICE_RECORDINGS}-\$myDpath$_$MONTH$\||SETVAR;VOICEPATH;$quotes$$mus icpath$$vfolderpath$||SETVAR;FILE;$myTD$-vNOTE.mp3||SETVAR;vBROWSE;$musicpath$-{VOICE_RECORDINGS}-"
"vPATH2","SETVAR;SLASH;\||SETVARBYCODE;myT;TIME;HH _MM_AM/PM||SETVARBYCODE;myD;DATE;MM-DD-YYYY||SETVAR;myTD;$myD$@$myT$||SETVAR;quotes;"||SE TVAR;vfolderpath;-{VOICE_RECORDINGS}-$SLASH$$myDpath$_$MONTH$\||SETVAR;VOICEPATH;$quote s$$musicpath$$vfolderpath$||SETVAR;FILE;$myTD$-$FILENAME$$TYPE$"
"START_RECORD","RUN;LSTOOLS\UNMUTEMIC.exe||PAUSE|| SETIND;!VRECORDCOUNT;ON||vPATH||WAIT;3||SETIND;!VR ECORD;ON||RUNQ;LSTOOLS\voice record\Harddisk.exe|-nofocus -record -output $VOICEPATH$$FILE$" -minimize -overwrite -sequential"
"START_RECORD_CUSTOM","SETVAR;TYPE;.mp3||OSKTOCMD; FILENAME;START_CUSTOM"
"START_CUSTOM","RUN;LSTOOLS\UNMUTEMIC.exe||PAUSE|| SETIND;!VRECORDCOUNT;ON||vPATH2||WAIT;3||SETIND;!V RECORD;ON||RUNQ;LSTOOLS\voice record\Harddisk.exe| -nofocus -record -output $VOICEPATH$$FILE$" -minimize -overwrite -sequential"
"STOP_RECORD","RUN;LSTOOLS\MUTEMIC.exe||RESUME||SE TIND;!VRECORD;OFF||SETIND;!VRECORDCOUNT;OFF||RUNQ; LSTOOLS\voice record\Harddisk.exe|-nofocus -stop -minimize"
"STOP_RECORD2","RUN;LSTOOLS\MUTEMIC.exe||SETIND;!V RECORD;OFF||SETIND;!VRECORDCOUNT;OFF||RUNQ;LSTOOLS \voice record\Harddisk.exe|-nofocus -stop -minimize"
"PAUSE_RECORD","RUN;LSTOOLS\MUTEMIC.exe||RESUME||S ETIND;!VPAUSED;ON||RUNQ;LSTOOLS\voice record\Harddisk.exe|-pause -nofocus -minimize"
"RESUME_RECORD","RUN;LSTOOLS\UNMUTEMIC.exe||PAUSE| |SETIND;!VPAUSED;OFF||RUNQ;LSTOOLS\voice record\Harddisk.exe|-nofocus -resume -minimize"
"NOTES","LOAD;VOICE.skin||SHOWFLASH;1;FALSE||vPATH "
"BROWSE_VNOTES","LOAD;VOICE_BROWSER.skin"
"EXIT_VOICE","ESC"
"RUN;LSTOOLS\voice record\Harddisk.exe|-quit"
"PLAYVOICE","setvar;voiceplaying;1||SETVARBYCODE;V OICEPATH;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SE TVAR;fullvoicepath;$VOICEPATH$$VOICEFILE$||RUN;LST OOLS\VOICESCRIPTS\PlayVoice.exe|$fullvoicepath$"
"DELETEVOICE","RUN;LSTOOLS\VOICESCRIPTS\DeleteVoic e.exe|$fullvoicepath$"
"STOPVOICEPLAY","setvar;voiceplaying;0||RUN;LSTOOL S\VOICESCRIPTS\STOP.exe"
"DELETEVOICE_ASK","SETVARBYCODE;VOICEPATH;DLPATH|| SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR;fullvoicepat h;$VOICEPATH$$VOICEFILE$||MENU;VOICE_DELETE.skin"
"PLAYVOICEBACK","BYVAR;voiceplaying;PLAYVOICE<<STO PVOICEPLAY"
/,[TALK TO ME BABY]
"SPEAK_1","SETVAR;quote;"||RUN;LSTOOLS\SPEECH\Spee chCmd.exe|$quote$Good Morning!$quote$"
"SPEAK_2","SETVAR;quote;"||RUN;LSTOOLS\SPEECH\Spee chCmd.exe|$quote$Good Afternoon!$quote$"
"SPEAK_3","SETVAR;quote;"||RUN;LSTOOLS\SPEECH\Spee chCmd.exe|$quote$Good Night!$quote$"
"SPEAK_4","SETVAR;quote;"||RUN;LSTOOLS\SPEECH\Spee chCmd.exe|$quote$Good Bye!$quote$"
"SPEAK_5","SETVAR;quote;"||RUN;LSTOOLS\SPEECH\Spee chCmd.exe|$quote$Good Morning!$quote$"
"SPEAK_6","SETVAR;quote;"||RUN;LSTOOLS\SPEECH\Spee chCmd.exe|$quote$Good Morning!$quote$"
/,[TEXT NOTES]
"COUNTP","EVAL;COUNTER;$COUNTER$+1||SAVETOSKIN;COU NTER;$COUNTER$"
"COUNTS","EVAL;COUNTER;$COUNTER$-1||SAVETOSKIN;COUNTER;$COUNTER$"
"EDITTNOTE","OSKTOSKIN;TNOTES$COUNTER$"
"EDITMINITNOTE","OSKTOSKIN;TNOTES$COUNTER$;MENU;SH OWTEXTNOTES.skin"
"SAVETNOTES","SAVETOSKIN;TNOTES$COUNTER$;$TNOTES$C OUNTER$"
/"SAVEALLNOTES","SAVETOINI;TNOTES;<<$TNOTES1$<<$TNO TES2$<<$TNOTES3$<<$TNOTES4$<<$TNOTES5$<<$TNOTES6$< <$TNOTES7$<<$TNOTES8$<<$TNOTES9$<<$TNOTES10$<<$TNO TES11$<<$TNOTES12$<<$TNOTES14$<<$TNOTES15$<<$TNOTE S16$<<$TNOTES17$<<$TNOTES18$<<$TNOTES19$<<$TNOTES2 0$"
/"LOADALLNOTES","SETVARFROM;TNOTES;<<TNOTES1<<TNOTE S2<<TNOTES3<<TNOTES4<<TNOTES5<<TNOTES6<<TNOTES7<<T NOTES8<<TNOTES9<<TNOTES10<<TNOTES11<<TNOTES12<<TNO TES14<<TNOTES15<<TNOTES16<<TNOTES17<<TNOTES18<<TNO TES19<<TNOTES20"
"NOTE_EMAIL_BODY","BYVAR;COUNTER;<<=$TNOTES1$<<=$T NOTES2$<<=$TNOTES3$<<=$TNOTES4$<<=$TNOTES5$<<=$TNO TES6$<<=$TNOTES7$<<=$TNOTES8$<<=$TNOTES9$<<=$TNOTE S10$<<=$TNOTES11$<<=$TNOTES12$<<=$TNOTES14$<<=$TNO TES15$<<=$TNOTES16$<<=$TNOTES17$<<=$TNOTES18$<<=$T NOTES19$<<=$TNOTES20$"
"SETTEXTBODY1","SETVAR;textbody;$TNOTES1$"
"SETTEXTBODY2","SETVAR;textbody;$TNOTES2$"
"SETTEXTBODY3","SETVAR;textbody;$TNOTES3$"
"SETTEXTBODY4","SETVAR;textbody;$TNOTES4$"
"SETTEXTBODY5","SETVAR;textbody;$TNOTES5$"
"SETTEXTBODY6","SETVAR;textbody;$TNOTES6$"
"SETTEXTBODY7","SETVAR;textbody;$TNOTES7$"
"SETTEXTBODY8","SETVAR;textbody;$TNOTES8$"
"SETTEXTBODY9","SETVAR;textbody;$TNOTES9$"
"SETTEXTBODY10","SETVAR;textbody;$TNOTES10$"
"SETTEXTBODY11","SETVAR;textbody;$TNOTES11$"
"SETTEXTBODY12","SETVAR;textbody;$TNOTES12$"
"SETTEXTBODY13","SETVAR;textbody;$TNOTES13$"
"SETTEXTBODY14","SETVAR;textbody;$TNOTES14$"
"SETTEXTBODY15","SETVAR;textbody;$TNOTES15$"
"SETTEXTBODY16","SETVAR;textbody;$TNOTES16$"
"SETTEXTBODY17","SETVAR;textbody;$TNOTES17$"
"SETTEXTBODY18","SETVAR;textbody;$TNOTES18$"
"SETTEXTBODY19","SETVAR;textbody;$TNOTES19$"
"SETTEXTBODY20","SETVAR;textbody;$TNOTES20$"
"SENDNOTE2EMAIL"," ||SETVAR;q;"||BYVAR;COUNTER;<<SETTEXTBODY1<<SETTEX TBODY2<<SETTEXTBODY3<<SETTEXTBODY4<<SETTEXTBODY5<< SETTEXTBODY6<<SETTEXTBODY7<<SETTEXTBODY8<<SETTEXTB ODY9<<SETTEXTBODY10<<SETTEXTBODY11<<SETTEXTBODY12< <SETTEXTBODY13<<SETTEXTBODY14<<SETTEXTBODY15<<SETT EXTBODY16<<SETTEXTBODY17<<SETTEXTBODY18<<SETTEXTBO DY19<<SETTEXTBODY20||RUN;LSTOOLS\email.exe|$email_ SmtpServer$ $email_FromName$ $email_FromAddress$ $email_ToAddress$ $q$TEXT NOTE$q$ $q$$textbody$$q$ $q$$noattatch$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDNOTE2EMAIL1"," ||SETVAR;q;"||BYVAR;COUNTER;<<SETTEXTBODY1<<SETTEX TBODY2<<SETTEXTBODY3<<SETTEXTBODY4<<SETTEXTBODY5<< SETTEXTBODY6<<SETTEXTBODY7<<SETTEXTBODY8<<SETTEXTB ODY9<<SETTEXTBODY10<<SETTEXTBODY11<<SETTEXTBODY12< <SETTEXTBODY13<<SETTEXTBODY14<<SETTEXTBODY15<<SETT EXTBODY16<<SETTEXTBODY17<<SETTEXTBODY18<<SETTEXTBO DY19<<SETTEXTBODY20||RUN;LSTOOLS\email.exe|$email_ SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address1$ $q$TEXT NOTE$q$ $q$$textbody$$q$ $q$$noattatch$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDNOTE2EMAIL2"," ||SETVAR;q;"||BYVAR;COUNTER;<<SETTEXTBODY1<<SETTEX TBODY2<<SETTEXTBODY3<<SETTEXTBODY4<<SETTEXTBODY5<< SETTEXTBODY6<<SETTEXTBODY7<<SETTEXTBODY8<<SETTEXTB ODY9<<SETTEXTBODY10<<SETTEXTBODY11<<SETTEXTBODY12< <SETTEXTBODY13<<SETTEXTBODY14<<SETTEXTBODY15<<SETT EXTBODY16<<SETTEXTBODY17<<SETTEXTBODY18<<SETTEXTBO DY19<<SETTEXTBODY20||RUN;LSTOOLS\email.exe|$email_ SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address2$ $q$TEXT NOTE$q$ $q$$textbody$$q$ $q$$noattatch$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDNOTE2EMAIL3"," ||SETVAR;q;"||BYVAR;COUNTER;<<SETTEXTBODY1<<SETTEX TBODY2<<SETTEXTBODY3<<SETTEXTBODY4<<SETTEXTBODY5<< SETTEXTBODY6<<SETTEXTBODY7<<SETTEXTBODY8<<SETTEXTB ODY9<<SETTEXTBODY10<<SETTEXTBODY11<<SETTEXTBODY12< <SETTEXTBODY13<<SETTEXTBODY14<<SETTEXTBODY15<<SETT EXTBODY16<<SETTEXTBODY17<<SETTEXTBODY18<<SETTEXTBO DY19<<SETTEXTBODY20||RUN;LSTOOLS\email.exe|$email_ SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address3$ $q$TEXT NOTE$q$ $q$$textbody$$q$ $q$$noattatch$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDNOTE2EMAIL4"," ||SETVAR;q;"||BYVAR;COUNTER;<<SETTEXTBODY1<<SETTEX TBODY2<<SETTEXTBODY3<<SETTEXTBODY4<<SETTEXTBODY5<< SETTEXTBODY6<<SETTEXTBODY7<<SETTEXTBODY8<<SETTEXTB ODY9<<SETTEXTBODY10<<SETTEXTBODY11<<SETTEXTBODY12< <SETTEXTBODY13<<SETTEXTBODY14<<SETTEXTBODY15<<SETT EXTBODY16<<SETTEXTBODY17<<SETTEXTBODY18<<SETTEXTBO DY19<<SETTEXTBODY20||RUN;LSTOOLS\email.exe|$email_ SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address4$ $q$TEXT NOTE$q$ $q$$textbody$$q$ $q$$noattatch$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDNOTE2EMAIL5"," ||SETVAR;q;"||BYVAR;COUNTER;<<SETTEXTBODY1<<SETTEX TBODY2<<SETTEXTBODY3<<SETTEXTBODY4<<SETTEXTBODY5<< SETTEXTBODY6<<SETTEXTBODY7<<SETTEXTBODY8<<SETTEXTB ODY9<<SETTEXTBODY10<<SETTEXTBODY11<<SETTEXTBODY12< <SETTEXTBODY13<<SETTEXTBODY14<<SETTEXTBODY15<<SETT EXTBODY16<<SETTEXTBODY17<<SETTEXTBODY18<<SETTEXTBO DY19<<SETTEXTBODY20||RUN;LSTOOLS\email.exe|$email_ SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address5$ $q$TEXT NOTE$q$ $q$$textbody$$q$ $q$$noattatch$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDNOTE2EMAIL6"," ||SETVAR;q;"||BYVAR;COUNTER;<<SETTEXTBODY1<<SETTEX TBODY2<<SETTEXTBODY3<<SETTEXTBODY4<<SETTEXTBODY5<< SETTEXTBODY6<<SETTEXTBODY7<<SETTEXTBODY8<<SETTEXTB ODY9<<SETTEXTBODY10<<SETTEXTBODY11<<SETTEXTBODY12< <SETTEXTBODY13<<SETTEXTBODY14<<SETTEXTBODY15<<SETT EXTBODY16<<SETTEXTBODY17<<SETTEXTBODY18<<SETTEXTBO DY19<<SETTEXTBODY20||RUN;LSTOOLS\email.exe|$email_ SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address6$ $q$TEXT NOTE$q$ $q$$textbody$$q$ $q$$noattatch$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDNOTE2EMAIL7"," ||SETVAR;q;"||BYVAR;COUNTER;<<SETTEXTBODY1<<SETTEX TBODY2<<SETTEXTBODY3<<SETTEXTBODY4<<SETTEXTBODY5<< SETTEXTBODY6<<SETTEXTBODY7<<SETTEXTBODY8<<SETTEXTB ODY9<<SETTEXTBODY10<<SETTEXTBODY11<<SETTEXTBODY12< <SETTEXTBODY13<<SETTEXTBODY14<<SETTEXTBODY15<<SETT EXTBODY16<<SETTEXTBODY17<<SETTEXTBODY18<<SETTEXTBO DY19<<SETTEXTBODY20||RUN;LSTOOLS\email.exe|$email_ SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address7$ $q$TEXT NOTE$q$ $q$$textbody$$q$ $q$$noattatch$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDNOTE2EMAIL8"," ||SETVAR;q;"||BYVAR;COUNTER;<<SETTEXTBODY1<<SETTEX TBODY2<<SETTEXTBODY3<<SETTEXTBODY4<<SETTEXTBODY5<< SETTEXTBODY6<<SETTEXTBODY7<<SETTEXTBODY8<<SETTEXTB ODY9<<SETTEXTBODY10<<SETTEXTBODY11<<SETTEXTBODY12< <SETTEXTBODY13<<SETTEXTBODY14<<SETTEXTBODY15<<SETT EXTBODY16<<SETTEXTBODY17<<SETTEXTBODY18<<SETTEXTBO DY19<<SETTEXTBODY20||RUN;LSTOOLS\email.exe|$email_ SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address8$ $q$TEXT NOTE$q$ $q$$textbody$$q$ $q$$noattatch$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"MAILSENT","MENU;EMAIL_SENT.skin"
"SENDNOTE2_OTHER_EMAIL"," ||SETVAR;ID;9||SETVAR;q;"||BYVAR;COUNTER;<<SETTEXT BODY1<<SETTEXTBODY2<<SETTEXTBODY3<<SETTEXTBODY4<<S ETTEXTBODY5<<SETTEXTBODY6<<SETTEXTBODY7<<SETTEXTBO DY8<<SETTEXTBODY9<<SETTEXTBODY10<<SETTEXTBODY11<<S ETTEXTBODY12<<SETTEXTBODY13<<SETTEXTBODY14<<SETTEX TBODY15<<SETTEXTBODY16<<SETTEXTBODY17<<SETTEXTBODY 18<<SETTEXTBODY19<<SETTEXTBODY20||RUN;LSTOOLS\emai l.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $q$$email_TootherAddress$$q$ $q$TEXT NOTE$q$ $q$$textbody$$q$ $q$$noattatch$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDNOTE2_OTHER_EMAIL_ASK"," ||OSKTOCMD;email_TootherAddress;SENDNOTE2_OTHER_EM AIL"
"SENDNOTESTO","MENU;EMAIL_CHOOSE.skin"
/,[FILE BROWSER]
"CHECKDRIVELETTERS","RUNQW;$skinpath$DriveLetters. exe"
"FILEBROWSER","LOAD;FILEBROWSER.skin"
"REMOVEFILES_ASK","SETVAR;QUOTES;"||SETVARBYCODE;B ROWSERPATH;DLPATH||SETVARBYCODE;BROWSERFILE;DLTEXT ||SETVAR;DELETEME;$BROWSERPATH$$BROWSERFILE$||MENU ;FILEBROWSER_DELETE.skin"
"REMOVEFILES","RUN;$skinpath$FileDELETE.exe|$QUOTE S$$DELETEME$$QUOTES$"
"COPY2MUSIC","SETVARBYCODE;LISTTEXT;LISTTEXT||SETV ARBYCODE;DLPATH;DLPATH||SETVAR;QUOTES;"||RUN;$SKIN PATH$FileCopy.exe|$QUOTES$$DLPATH$$LISTTEXT$$QUOTE S$ $QUOTES$$MUSICPATH$$QUOTES$"
"COPY2VIDEO","SETVARBYCODE;LISTTEXT;LISTTEXT||SETV ARBYCODE;DLPATH;DLPATH||SETVAR;QUOTES;"||RUN;$SKIN PATH$FileCopy.exe|$QUOTES$$DLPATH$$LISTTEXT$$QUOTE S$ $QUOTES$$videopath$$QUOTES$"
"COPY2PICS","SETVARBYCODE;LISTTEXT;LISTTEXT||SETVA RBYCODE;DLPATH;DLPATH||SETVAR;QUOTES;"||RUN;$SKINP ATH$FileCopy.exe|$QUOTES$$DLPATH$$LISTTEXT$$QUOTES $ $QUOTES$$picspath$$QUOTES$"
"OPENFILES","SETVARBYCODE;OPENBROWSERPATH;DLPATH|| SETVARBYCODE;OPENBROWSERFILE;DLTEXT||SETVAR;QUOTES ;"||SETVAR;OPENME;$QUOTES$$OPENBROWSERPATH$$OPENBR OWSERFILE$$QUOTES$||RUN;$skinpath$openfiles.exe|$O PENME$||MINIMIZE"
"COPYFILES","SETVAR;FILESREADY;1||SETVARBYCODE;COP YBROWSERPATH;DLPATH||SETVARBYCODE;COPYBROWSERFILE; DLTEXT||SETVAR;QUOTES;"||SETVAR;COPYME;$QUOTES$$CO PYBROWSERPATH$$COPYBROWSERFILE$$QUOTES$||"
"PASTEFILES","SETVAR;FILESREADY;0||SETVARBYCODE;PA STEBROWSERPATH;DLPATH||SETVARBYCODE;PASTEBROWSERFI LE;DLTEXT||SETVAR;QUOTES;"||SETVAR;PASTEME;$QUOTES $$PASTEBROWSERPATH$$PASTEBROWSERFILE$$QUOTES$||RUN ;$SKINPATH$FileCopy.exe|$COPYME$ $PASTEME$"
"EMPTY_TRASH_ASK","MENU;FILEBROWSER_TRASH.skin "
"EMPTY_TRASH","RUN;$skinpath$empty_Recyclebin. exe"
"FILEBROWSER_INFO","LOAD;FILEBROWSER_INFO.skin "
"RELOAD_DRIVES","RUN;$skinpath$DriveLetters.ex e"
/,[SEND EMAIL]
"EMAIL_CONFIG","LOAD;EMAIL_config.skin"
/"SENDMAIL","RUN;LSTOOLS\email.exe|$QUOTES$$email_S mtpServer$$QUOTES$ $QUOTES$$email_FromName$$QUOTES$ $QUOTES$$email_FromAddress$$QUOTES$ $QUOTES$$email_ToAddress$$QUOTES$ $QUOTES$$email_Subject$$QUOTES$ $QUOTES$$email_Body$$QUOTES$ $QUOTES$$email_AttachFiles$$QUOTES$ $QUOTES$$email_Username$$QUOTES$ $QUOTES$$email_Password$$QUOTES$ $QUOTES$$email_IPPort$$QUOTES$ $QUOTES$$email_secure$$QUOTES$"
"SENDMAIL","SETVAR;q;"||RUN;LSTOOLS\email.exe|$ema il_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_ToAddress$ $q$$email_Subject$$q$ $q$$email_Body$$q$ $q$$email_AttachFiles$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICE","SETVAR;EID;10||SETVARBYCODE;VOICEPATH ;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR;ful lvoicepath;$VOICEPATH$$VOICEFILE$||SETVAR;q;"||RUN ;LSTOOLS\email.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_ToAddress$ $q$$VOICEFILE$$q$ $q$$VOICE RECORDING$$q$ $q$$fullvoicepath$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICE1","SETVAR;EID;1||SETVARBYCODE;VOICEPATH ;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR;ful lvoicepath;$VOICEPATH$$VOICEFILE$||SETVAR;q;"||RUN ;LSTOOLS\email.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address1$ $q$$VOICEFILE$$q$ $q$$VOICE RECORDING$$q$ $q$$fullvoicepath$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICE2","SETVAR;EID;2||SETVARBYCODE;VOICEPATH ;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR;ful lvoicepath;$VOICEPATH$$VOICEFILE$||SETVAR;q;"||RUN ;LSTOOLS\email.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address2$ $q$$VOICEFILE$$q$ $q$$VOICE RECORDING$$q$ $q$$fullvoicepath$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICE3","SETVAR;EID;3||SETVARBYCODE;VOICEPATH ;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR;ful lvoicepath;$VOICEPATH$$VOICEFILE$||SETVAR;q;"||RUN ;LSTOOLS\email.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address3$ $q$$VOICEFILE$$q$ $q$$VOICE RECORDING$$q$ $q$$fullvoicepath$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICE4","SETVAR;EID;4||SETVARBYCODE;VOICEPATH ;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR;ful lvoicepath;$VOICEPATH$$VOICEFILE$||SETVAR;q;"||RUN ;LSTOOLS\email.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address4$ $q$$VOICEFILE$$q$ $q$$VOICE RECORDING$$q$ $q$$fullvoicepath$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICE5","SETVAR;EID;5||SETVARBYCODE;VOICEPATH ;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR;ful lvoicepath;$VOICEPATH$$VOICEFILE$||SETVAR;q;"||RUN ;LSTOOLS\email.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address5$ $q$$VOICEFILE$$q$ $q$$VOICE RECORDING$$q$ $q$$fullvoicepath$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICE6","SETVAR;EID;6||SETVARBYCODE;VOICEPATH ;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR;ful lvoicepath;$VOICEPATH$$VOICEFILE$||SETVAR;q;"||RUN ;LSTOOLS\email.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address6$ $q$$VOICEFILE$$q$ $q$$VOICE RECORDING$$q$ $q$$fullvoicepath$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICE7","SETVAR;EID;7||SETVARBYCODE;VOICEPATH ;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR;ful lvoicepath;$VOICEPATH$$VOICEFILE$||SETVAR;q;"||RUN ;LSTOOLS\email.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address7$ $q$$VOICEFILE$$q$ $q$$VOICE RECORDING$$q$ $q$$fullvoicepath$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICE8","SETVAR;EID;8||SETVARBYCODE;VOICEPATH ;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR;ful lvoicepath;$VOICEPATH$$VOICEFILE$||SETVAR;q;"||RUN ;LSTOOLS\email.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_address8$ $q$$VOICEFILE$$q$ $q$$VOICE RECORDING$$q$ $q$$fullvoicepath$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICEOTHER","SETVAR;EID;9||SETVARBYCODE;VOICE PATH;DLPATH||SETVARBYCODE;VOICEFILE;DLTEXT||SETVAR ;fullvoicepath;$VOICEPATH$$VOICEFILE$||SETVAR;q;"| |RUN;LSTOOLS\email.exe|$email_SmtpServer$ $email_FromName$ $email_FromAddress$ $email_Tovoice_otherAddress$ $q$$VOICEFILE$$q$ $q$$VOICE RECORDING$$q$ $q$$fullvoicepath$$q$ $email_Username$ $email_Password$ $email_IPPort$ $email_secure$ "
"SENDVOICE_ASK","MENU;VOICE_CHOOSE.skin"
"MV_UP","RUN;$skinpath$MV_pageup.exe"
"MV_DOWN","RUN;$skinpath$MV_pagedown.exe"
"MV_BACK","RUN;$skinpath$MV_back.exe"
/,[TOOLS]
"CALC","RUN;LSTOOLS\calc\Skalc.exe"
"SLEEPCPU","ESC||RUNQ;sleep.exe"
/,[FLASH TRAFFIC]
"TRAFFIC_FLOW","Runwait;LSTOOLS\TRAFFIC\traffi c data updater.exe||LOAD;FLASH_TRAFFIC.skin"
"ADDY1","OSKTOSKIN;email_address1"
"ADDY2","OSKTOSKIN;email_address2"
"ADDY3","OSKTOSKIN;email_address3"
"ADDY4","OSKTOSKIN;email_address4"
"ADDY5","OSKTOSKIN;email_address5"
"ADDY6","OSKTOSKIN;email_address6"
"ADDY7","OSKTOSKIN;email_address7"
"ADDY8","OSKTOSKIN;email_address8"
/,[Dynamic backgrounds]
"COPY2BKGND","SETVARBYCODE;LISTTEXTBK;LISTTEXT||SE TVARBYCODE;DLPATHBK;DLPATH||SETVAR;QUOTES;"||SETVA R;BKGND;$DLPATHBK$$LISTTEXTBK$||SETVAR;BACKGROUND; $BKGND$||SAVETOSKIN;BACKGROUND;$BKGND$||RELOADSKIN "
"EDITBKGND","Load;picviewer.skin||wait;1||SETPATH; $SKINPATH$backgrounds\backups"
/,[REGISTER PLUGINS] registers dll files used by all plugins included with skin
"REGISTERDLL"," ||RUNQ;$skinpath$pluginDLLs\runreg.exe"
"UNREGISTER"," ||RUNQ;$skinpath$pluginDLLs\unrunreg.exe"
"PLUGINREG","MENU;REGMSG.skin"
/,[GPS LAYOUTS]
"GPSLAYOUT1","SETVAR;FS;1||SAVETOSKIN;FS;1||RUNW;$ skinpath$copy_GPSADVa.exe||RELOADSKIN"
"GPSLAYOUT2","SETVAR;FS;0||SAVETOSKIN;FS;0||RUNW;$ skinpath$copy_GPSADVb.exe||RELOADSKIN"
"GPSLAYOUT3","SETVAR;FS;0||SAVETOSKIN;FS;0||RUNW;$ skinpath$copy_gpsfull.exe||RELOADSKIN"
/,[GOOGLE EARTH]
"GEMENU1","MENU;GEMENU1.skin"
"SATVIEW","GE_START"
/,LOAD;EXTERNAL_GPS_GE.skin||GE_EMBED"
/"GE_ERROR","MENU;GE_ERROR.skin"
"GE_ERROR",""
"MINIMIZE","load;xminimize.skin"
/,[MEDIA PATHS]
"MEDIAPATHS","CHECKDRIVELETTERS||LOAD;MEDIAPATHS.s kin"
"MEDIAPATHCLOSE","BYVAR;mediapathchanged;ESC<<MEDI APATHCLOSE1"
"MEDIAPATHCLOSE1","MENU;MESSAGE2.skin||wait;5||REL OADRR"
/,-------------------------------------Tags Editor--------------------------------------
"TAGS_TITLE","RUNQ;$RRPATH$\tags\tags.exe|tags_tit le"
"TAGS_ARTIST","RUNQ;$RRPATH$\tags\tags.exe|tags_ar tist"
"TAGS_GENRE","RUNQ;$RRPATH$\tags\tags.exe|tags_gen re"
"TAGS_ALBUM","RUNQ;$RRPATH$\tags\tags.exe|tags_alb um"
"TAGS_NUMBER","RUNQ;$RRPATH$\tags\tags.exe|tags_nu mber"
"TAGS_YEAR","RUNQ;$RRPATH$\tags\tags.exe|tags_year "
"TAGS_COMMENTS","RUNQ;$RRPATH$\tags\tags.exe|tags_ comments"
"TIMER","CLOSE",writing.skin
/,------------------------------------- Preview Video---------------------------------------------------------------------------------------
/, REMOVED
"LIST_INFO","setind;CUSTOM1starindicator;OFF||seti nd;CUSTOM2starindicator;OFF||setind;CUSTOM3starind icator;OFF||setind;CUSTOM4starindicator;OFF||setin d;CUSTOM5starindicator;OFF||SETVARBYCODE;curtrack; trackpath||RunQ;$rrpath$Ratings\ratecheck.exe|$cur track$||MENU;TRACK_INFO.skin"
"cameraoid","load;camera2.skin||RUN;camera2.exe;ca meraoid"
"SMARTPHONE","MENU;WMD.skin"
"SMARTPHONE_VIEW","LOAD;DEVICE_OPTIONS.skin"
"SETMUSIC","SETPATH;$DEVICE$"
"SETPICS","SETPATH;$DEVICE$"
"SETVIDEO","SETPATH;$DEVICE$"
"THUMBDRIVE","MENU;USB.skin"
"EXITSS","ESC||SETVAR;SLIDESHOW;0"
"SYNC_USB","SYNC_AUDIO||SYNC_VIDEO||SYNC_PICS"
"PICS_MORE","MENU;PICS_MORE.skin"
"ZOOM2X","load;bigpic2x.skin"
"ZOOM4X","load;bigpic4x.skin"
/"JOOST","LOAD;JOOST.skin||RUN;$skinpath$JOOST.exe| $qt$$JOOSTPATH$$qt$;Joost"
"JOOST","LOAD;JOOST.skin||RUN;$JOOSTPATH$|...\appl ication.ini;Joost"
"VEOH","LOAD;VEOH.skin||RUN;$SKINPATH$veoh.exe;veo hplayer"
"SearchSong"," ||OSKTOCMD;MySearch;SearchSongTitle"
"SearchSongTitle","RUNQW;wscript.exe" "$skinpath$\SmartPlayLists\queryWinamp.vbs" "$winamppath$" "title HAS "$MySearch$"" "||RELOADLIST||"
/,---------------------------------------------- BLANK ---------------------------------------------------------------------
/,flickr
"flickr","Load;flickr.skin||"
"F_usersearch","OSKTOVAR;F_user"
"F_tagsearch","OSKTOVAR;F_tag"
"flickr_user","Load;flickr2.skin||RUN;$skinpahh$fl icker2.exe|$F_user$;flickr"
"flickr_tag","Load;flickr2.skin||RUN;$skinpahh$fli cker.exe|$F_tag$;flickr"
"RRCAM","LOAD;RRCam.skin;RRCam;$skinpath$RRCam\RRC am.exe;RRCam.exe"
"RRCAM_RECORD","SENDMSG;RRCam.exe;REC||SETVAR;CamR ecord;1||SWITCHBUTTON;1>>SENDMSG;RRCam.exe;REC||SE TVAR;CamRecord;0||SWITCHBUTTON;1"
"RRCAM_MIRROR","SENDMSG;RRCam.exe;MIRROR"
"RRCAM_STILL","SENDMSG;RRCam.exe;STILL"
"RRCAM_SHOWSPEED","SENDMSG;RRCam.exe;GPSspeed"
/,----------------------------------------------Delete current --------------------------
/,this 2 lines are to close the popup skins.
"TIMER","CLOSE",delete_done.skin
"TIMER","CLOSE",cancel_delete.skin
/,launch the confirm skin, the name of the skin has to be(confirm_delete.skin)
"DELETE_CURRENT","RUNQ;$SKINPATH$\deletecurrent\de lete.exe|confirm"
/,to delete the track.
"DELETE_NOW","RUNQ;$SKINPATH$\deletecurrent\delete .exe|delete"
/,to cancel deletion if needed.
"CANCEL_DELETE","RUNQ;$SKINPATH$\deletecurrent\del ete.exe|cancel"
/, MAGIC BUTTON
,,................................................ .................................................. ..........................arguments[COMMAND] [wintitle] [ X] [Y] [Exit NO/YES]
/,"CUSTOM_COMMAND_1","RUN;$skinpath$\ALT\MAGIC\MAGI CBUTTON.exe|ESC mymagic 660 0 1"
"CUSTOM_COMMAND_1","RUN;$skinpath$\ALT\MAGIC\AUDIO _CTRL.exe|PREV2 PLAY NEXT DUCK audio_ctrl 500 280 1"
/"color","load;COLORPICKER.skin||RUN;$skinpath$colo rpicker.exe|SETCOLOR colorpicker 660 0 1;colorpicker"
"SETCOLOR","SAVETOINI;background;$colorvalue$"
/"color","RUN;$skinpath$colorpicker.exe|SETCOLO R colorpicker 660 0 1"
"color","load;COLORPICKER.skin"
"colorpick","RUN;$skinpath$pick_color.exe"
/,----------------------------------------------REMINDERS --------------------------
"SETRVALUES","SETVAR;R_NAME;NAME||SETVAR;PROXIMITY ;5||SETVAR;RNOTE1;NOTE1||SETVAR;RNOTE2;NOTE2||SETV AR;RNOTE3;NOTE3||SETVAR;RNOTE4;NOTE4||SETVAR;RNOTE 5;NOTE5||"
"SAVE_REMINDER"," ||SETRVALUES||SETVARBYCODE;LAT1;GPSLAT||SETVARBYCO DE;LON1;GPSLON||SETVARBYCODE;HEADING1;GPSHDG||ADDT OFILE;$rrpath$\reminders.dat;=$LAT1$$CM$$LON1$$CM$ $R_NAME$$CM$AUDIO$CM$$HEADING1$$CM$$PROXIMITY$$CM$ $RNOTE1$$CM$$RNOTE2$$CM$$RNOTE3$$CM$$RNOTE4$$CM$$R NOTE5$"
"BLACKJACK","load;winmobile_wide.skin||Run;V:\User s\liquidsmoke\Desktop\My Mobile\MyMobiler\MyMobiler.exe;My Mobiler"
/, TESTING
"car","load;Maintenance.skin"
"SaveMaint","SAVETOSKIN;VMDATE01;$VMDATE01$||SAVET OSKIN;VMDATE02;$VMDATE02$||SAVETOSKIN;VMDATE03;$VM DATE03$||SAVETOSKIN;VMDATE04;$VMDATE04$||SAVETOSKI N;VMDATE05;$VMDATE05$||SAVETOSKIN;VMDATE06;$VMDATE 06$||SAVETOSKIN;VMDATE07;$VMDATE07$||SAVETOSKIN;VM DATE08;$VMDATE08$||SAVETOSKIN;VMDATE09;$VMDATE09$| |SAVETOSKIN;VMNAME01;$VMNAME01$||SAVETOSKIN;VMNAME 02;$VMNAME02$||SAVETOSKIN;VMNAME03;$VMNAME03$||SAV ETOSKIN;VMNAME04;$VMNAME04$||SAVETOSKIN;VMNAME05;$ VMNAME05$||SAVETOSKIN;VMNAME06;$VMNAME06$||SAVETOS KIN;VMNAME07;$VMNAME07$||SAVETOSKIN;VMNAME08;$VMNA ME08$||SAVETOSKIN;VMNAME09;$VMNAME09$||SAVETOSKIN; VMLAST01;$VMLAST01$||SAVETOSKIN;VMLAST02;$VMLAST02 $||SAVETOSKIN;VMLAST03;$VMLAST03$||SAVETOSKIN;VMLA ST04;$VMLAST04$||SAVETOSKIN;VMLAST05;$VMLAST05$||S AVETOSKIN;VMLAST06;$VMLAST06$||SAVETOSKIN;VMLAST07 ;$VMLAST07$||SAVETOSKIN;VMLAST08;$VMLAST08$||SAVET OSKIN;VMLAST09;$VMLAST09$||SAVETOSKIN;VMNEXT01;$VM NEXT01$||SAVETOSKIN;VMNEXT02;$VMNEXT02$||SAVETOSKI N;VMNEXT03;$VMNEXT03$||SAVETOSKIN;VMNEXT04;$VMNEXT 04$||SAVETOSKIN;VMNEXT05;$VMNEXT05$||SAVETOSKIN;VM NEXT06;$VMNEXT06$||SAVETOSKIN;VMNEXT07;$VMNEXT07$| |SAVETOSKIN;VMNEXT08;$VMNEXT08$||SAVETOSKIN;VMNEXT 09;$VMNEXT09$||SAVETOSKIN;VMINTERV01;$VMINTERV01$| |SAVETOSKIN;VMINTERV02;$VMINTERV02$||SAVETOSKIN;VM INTERV03;$VMINTERV03$||SAVETOSKIN;VMINTERV04;$VMIN TERV04$||SAVETOSKIN;VMINTERV05;$VMINTERV05$||SAVET OSKIN;VMINTERV06;$VMINTERV06$||SAVETOSKIN;VMINTERV 07;$VMINTERV07$||SAVETOSKIN;VMINTERV08;$VMINTERV08 $||SAVETOSKIN;VMINTERV09;$VMINTERV09$"
"CalcMaint","EVAL;VMNEXT01;$VMLAST01$+$VMINTERV01$ ||EVAL;VMNEXT02;$VMLAST02$+$VMINTERV02$||EVAL;VMNE XT03;$VMLAST03$+$VMINTERV03$||EVAL;VMNEXT04;$VMLAS T04$+$VMINTERV04$||EVAL;VMNEXT05;$VMLAST05$+$VMINT ERV05$||EVAL;VMNEXT06;$VMLAST06$+$VMINTERV06$||EVA L;VMNEXT07;$VMLAST07$+$VMINTERV07$||EVAL;VMNEXT08; $VMLAST08$+$VMINTERV08$||EVAL;VMNEXT09;$VMLAST09$+ $VMINTERV09$"
"MaintAll","SaveMaint||wait;1||CalcMaint"
"mousewheel","Run;$skinpath$\mousewheel.exe|15 15 730 up 3"
"PICS_CHOOSER","LOAD;PIC_CHOOSE.skin"
"WALLPAPER","Load;WALLPAPER.skin"
/,----------------------------------------------VISUALS --------------------------
"VISUALON","BYVAR;VIZSTAT;AUDIO<<VISSTART"
"CLOSE_VISUALON","BYVAR;VIZSTAT;ESC<<VISSTART2 "
"VISSTART","VISU||AUDIO||VISU"
"VISSTART2","VISU||ESC||VISU"
/"VISUOFF","VISU"
"VIZON","SETVAR;VIZSTAT;1||SAVETOSKIN;VIZSTAT; 1"
"VIZOFF","SETVAR;VIZSTAT;0||SAVETOSKIN;VIZSTAT ;0"
"VIZON2","SETVAR;VIZSTAT;1||SAVETOSKIN;VIZSTAT;1|| VISU"
"VIZOFF2","SETVAR;VIZSTAT;0||SAVETOSKIN;VIZSTAT;0| |VISU"
"VISUALON2","BYVAR;VIZSTAT;VIZON||VISU<<VIZOFF||VI SU"
"SHOWALBUMART","Load;audio_player_AA.skin"
/,---------------------------------------------- screenlock password set ---------------------------------------------------------------------
"SAVEPW","RUN;$SKINPATH$setpassword.exe|$qt$$rrpat h$\screenlock.ini$qt$ $password$"
"SETPW","NUMOSKTOCMD;password;SAVEPW"
/,---------------------------------------------- cover flow ---------------------------------------------------------------------
"COVERFLOW","LOAD;coverflow.skin"
/,this runs a script to load the list in the playlist, and update the genre, album, and artist info.
/,see my coverflow_browser.skin for a proper setup of labels and buttons.
"CVRFLOW_LIST","RUNQ;$SKINPATH$\COVERFLOW\loadlist .exe"
/,this is to tell road runner to play, after you double click the coverart.you can use "CLEARLIST||!SELECT"
/,if you want to stay in coverflow skin.
"CVRFLOW_SELECT","CLEARLIST||!SELECT||"
/,to update the database, from within road runner.
"CVRFLOW_UPDATE","RUN;$SKINPATH$\COVERFLOW\XML\gen erate_xml.exe"
/,---------------------------------------------- history option ---------------------------------------------------------------------
"HISTORY_ON","SETVAR;historytype;0||SAVETOSKIN;his torytype;0"
"HISTORY_OFF","SETVAR;historytype;1||SAVETOSKIN;hi storytype;1"
"PRESET_ON","SETVAR;historytype;1||SAVETOSKIN;hist orytype;1"
"PRESET_OFF","SETVAR;historytype;0||SAVETOSKIN;his torytype;0"
"HISTORY_OPTION","MENU;audio_player_config.ski n"
"BROWSER2","LIST"
"BROWSER1","LOAD;audio_browser3.skin"
"LISTTYPE","BYVAR;historytype;BROWSER1<<BROWSE R2"
"AUTOAA_ON","SETVAR;autoAA;1||SAVETOSKIN;autoA A;1"
"AUTOAA_OFF","SETVAR;autoAA;0||SAVETOSKIN;autoAA;0 "
/,---------------------------------------------- SONG LYRICS -----------
"GETLYRICS","Load;audio_player_lyrics.skin||RUN;$S KINPATH$LYRICS\LyricsFinder.exe"
/,----------------------------------------------HIGHLIGHT COLORS-----------
"HIGHLIGHTS","load;HIGHLIGHTS.skin"
"RED_HIGHLIGHT","savetoskin;BACKGROUND;$skinpath$$ bloody_mary$||RUN;$skinpath$copy_red_highlight.exe "
"BLUE_HIGHLIGHT","savetoskin;BACKGROUND;$skinpath$ $no_sex$||RUN;$skinpath$copy_blue_highlight.exe"
"AMBER_HIGHLIGHT","savetoskin;BACKGROUND;$skinpath $$asbestos$||RUN;$skinpath$copy_amber_highlight.ex e"
"GREEN_HIGHLIGHT","savetoskin;BACKGROUND;$skinpath $$envy$||RUN;$skinpath$copy_envy_highlight.exe"
"GREEN_PEPPERS_HIGHLIGHT","savetoskin;BACKGROUND;$ skinpath$$green_peppers$||RUN;$skinpath$copy_GREEN _PEPPERS_highlight.exe"
"AQUA_BLUE_HIGHLIGHT","savetoskin;BACKGROUND;$skin path$$aqua$||RUN;$skinpath$copy_AQUA_BLUE_highligh t.exe"
"MUTED_BLUE_HIGHLIGHT","savetoskin;BACKGROUND;$ski npath$$muted_blue$||RUN;$skinpath$copy_MUTED_BLUE_ highlight.exe"
"MUTED_TAN_HIGHLIGHT","savetoskin;BACKGROUND;$skin path$$muted_tan$||RUN;$skinpath$copy_MUTED_TAN_hig hlight.exe"
"CLEANUP","RUN;$SKINPATH$cleanup.exe"
/,--------------------DISABLED .SKIN CODE used only in .skin files---------------
/,"HISTORY_ON||SWITCHBUTTON;1>>HISTORY_OFF||SWITCHB UTTON;1" audio_player_config.skin history on switch
/,"PRESET_ON||SWITCHBUTTON;2>>PRESET_OFF||SWITCHBUT TON;2" history off switch
/,----------------------- Task_Man -----------------------------
"TM","LOAD;task_man.skin;Task Manager;;||WINDOWS_LIST"
"PROCESS_LIST","RUNQ;$SKINPATH$TaskMan.exe|load_pr ocess||setvar;taskmanager;1"
"WINDOWS_LIST","RUNQ;$SKINPATH$TaskMan.exe|load_wi ndows||setvar;taskmanager;0"
"KILL_PROCESS","RUNQ;$SKINPATH$TaskMan.exe|kill_pr ocess"
"CLOSE_WINDOW","RUNQ;$SKINPATH$TaskMan.exe|close_w indow"
"OPEN_PROCESS","RUNQ;$SKINPATH$TaskMan.exe|run_pro cess"
"Confirm_Process","SETVARBYCODE;process2kill;cldes c||menu;Confirm_Process.skin"
/,-----------------------FM/HD RADIO TOGGLE-------------------
"HDRADIO_ENABLE","RUN;$SKINPATH$copy_HDRADIO.exe|| RELOADSKIN"
"FMRADIO_ENABLE","RUN;$SKINPATH$copy_FMRADIO.exe|| RELOADSKIN"
/,--------------------------jukebox------coded by johnwpb----------------------
"IJ","Load;Jukebox.skin"
"JukeboxSearch"," ||OSKTOCMD;JukeBoxSearch;JukeBoxSend"
"JukeBoxSend","RUNQ;$SKINPATH$jukebox\JukeBoxSearc h.exe|$qt$$JukeBoxSearch$$qt$ $qt$$jukebox_searchmax$$qt$ $qt$$jukebox_timeout$$qt$"
"JukeBoxDownload","SETVARBYCODE;ListURL;CLTEXT||SE TVARBYCODE;FileName;CLDESC||RUNQ;$SKINPATH$jukebox \JukeBoxDownload.exe|$qt$$ListURL$$qt$ $qt$$FileName$$qt$ $qt$$musicpath$$qt$"
"FileGone","menu;JukeBox_Confirm.skin"
"kPS","RUN;$skinpath$jukebox\stopsong.exe||setvar; previewjb;0||savetoskin;previewjb;0"
"CANCELSEARCH","RUNQ;$SKINPATH$jukebox\JukeBoxCanc elSearch.exe"
"PS","PAUSE||RUN;$skinpath$jukebox\stopsong.exe||S ETVARBYCODE;ListURL;CLTEXT||RUN;$skinpath$jukebox\ playsong.exe|$qt$$ListURL$$qt$||setvar;previewjb;1 ||savetoskin;previewjb;1"
"SEARCHOPT","MENU;jukebox_opt.skin"
"EXITJB","byvar;STATUSSYM;EXIT1<<EXIT2"
"EXITJB1"," ||kPS||CANCELSEARCH||ESC||RESUME"
"EXITJB2"," ||kPS||CANCELSEARCH||ESC||"
"PREVIEWJB","byvar;previewjb;PS<<kPS"
/,-----------------HDRADIO SUPPORT--------------
"FMRADIOSWITCH","RUN;$SKINPATH$copy_FMRADIO.exe||S ETVAR;RADIOTYPE;0||SAVETOSKIN;RADIOTYPE;0||RELOADS KIN"
"HDRADIOSWITCH","RUN;$SKINPATH$copy_HDRADIO.exe||S ETVAR;RADIOTYPE;1||SAVETOSKIN;RADIOTYPE;1||RELOADS KIN"
/,------------------FREEFONE---------------------
"SETFREEFONE","SETVAR;PHONESETTING;1||SAVETOSKIN;P HONESETTING;1"
"SETPHOCO","SETVAR;PHONESETTING;0||SAVETOSKIN;PHON ESETTING;0"
"FREEPHONE","LOAD;freefone.skin;FreeFone;$skinpath $FreeFone.EXE;FreeFone||SETTOPMOST;FreeFone;TRUE"
"ASFREEFONE","RUNQ;$skinpath$FreeFone.EXE"
/,-------------------OPTIONS LIST SCREEN ---------------------
"ONCLCLICK","EDITOPT",OPTIONS_LIST.skin
"ONCLCLICK","EDITOPT2",OPTIONS_LIST2.skin
"ONCLCLICK","EDITOPT3",OPTIONS_LIST3.skin
"CONFIGOPT","LOAD;OPTIONS_LIST.SKIN||CLCLEAR;ALL|| clload;$SKINPATH$skin_options.txt;true||SETVARBYCO DE;optedit;LISTPOS"
"GEN_OPT","LOAD;OPTIONS_LIST2.skin||CLCLEAR;ALL||c lload;$SKINPATH$skin_options2.txt;true||SETVARBYCO DE;optedit2;LISTPOS"
"PERSONAL","LOAD;OPTIONS_LIST3.skin||CLCLEAR;ALL|| clload;$SKINPATH$skin_options3.txt;true||SETVARBYC ODE;optedit3;LISTPOS"
"TIMER","ESC",TIPSTATUS.skin
"TIMER","ESC",ATT_VOL_OPT.skin
"GPS_OPT","LOAD;GPS_options.skin"
"EMAIL_OPT","LOAD;EMAIL_config.skin"
"800600","RUN;$skinpath$copy_800x600.exe||RELOADSK IN"
"800480","RUN;$skinpath$copy_800x480.exe||RELOADSK IN"
"ATTSET","MENU;ATT_VOL_OPT.skin"
"STARTWINAMP2","STARTWINAMP||PLAY"
"SETPHONE","MENU;PHONESET.skin"
"EDITOPT","SETVARBYCODE;optedit;LISTPOS||BYVAR;opt edit;<<GEN_OPT<<MEDIAPATHS<<HISTORY_OPTION<< <<GPS_OPT<<PERSONAL<<EMAIL_OPT<<TM<<SETPHONE<<ATTS ET<<CALC<<ABOUT"
"EDITOPT2","SETVARBYCODE;optedit2;LISTPOS||BYVAR;o ptedit2;<<CONFIG<<NUMOSKTOCMD;password;SAVEPW<<SKI N<<UPDATECHECK<<DAYNIGHTSKIN<<RELOADRR<<CLOSEWINAM P<<STARTWINAMP2<<CLEARLIST<<800600<<800480<<TURNLI STON<<TURNLISTOFF<<TIPOFDAYTOGGLE<<ABOUT"
"EDITOPT3","SETVARBYCODE;optedit3;LISTPOS||BYVAR;o ptedit3;<<LOAD;MENUOPT.skin<<wallpaper<<LOAD;BBAA_ OPT.skin<<LOAD;BBAA_OPT.skin"
/,-------------------ORB ---------------------
"orb","LOAD;orb.skin;ORB10FT||RUN;$skinpath$orb.ex e;ORB10FT"
"ORB_BACK","RUN;$skinpath$orb_back.exe"
mdawg is offline   Reply With Quote
Old 10-14-2008, 01:46 AM   #132
Wants to make it harder
monkeyracer's Avatar
monkeyracer is an unknown quantity at this point
geez, that's a long-a$$ exectbl.ini...
anyways, have you downloaded the elcosmenu and the garminsendkeys? both of these need to be in the LSX folder.
Also, the button that references the NAVI command needs to be changed accordingly.
That should be as much as it takes to get it working. If it still doesn't, I can try LSX and see if I have any problems with that skin.
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 10-14-2008, 04:33 AM   #133
mdawg can only hope to improve
Alright lets get as noobish as possible here lol. Yes I have Elcos menu and such now how do I change the button to what I want, I think this may be where Im going wrong.
Old 10-14-2008, 06:05 AM   #134
djmickyg's Avatar
djmickyg is on a distinguished road
LSX works fine for me, the way i did it without messing up LSX's exectbl.ini was to use FREEDRIVE as the button command which makes it alot easier.
"GMPC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|GM PCOL .skin"
"GMPCOSK","RUN;$SKINPATH$ElcosMenu.exe|GMPCOSK .ski n"
"X_OVERLAY","SENDMSG;ElcosMenu;Exit"
"GMPC","LOAD;GMPC.skin"
"freedrive","RUN;$garminpath$;!CDP",GMPC.skin
"ESC","blank",menu.skin
then delete this line from the exectbl.ini
/FREEDRIVE START
/FREEDRIVE support
"FREEDRIVE","LOAD;EXTERNAL_GPS.skin;RUN;C:\Pro gram Files\FreeDrive\FreeDrive.exe;FreeDrive"
"EXIT2","EXIT"
/FREEDRIVE END
djmickyg is offline   Reply With Quote
Old 10-14-2008, 12:02 PM   #135
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
OK. Don't break the computer yet, i'm going to try to put something together step-by-step for you.
The LSX mod referes to the modified overlay for LSX designed by "djmickyg" that he posted a few posts above - install that first, to the letter.
Also looking through your rr.ini, i noticed your gpspath is wrong; it should point the garmin's .exe, not the command you have in there. It really don't matter anyway since the overlay is indipendent from the rr.ini setings - just change it back to whatever it was.
Stay tuned...
treetop777 is offline   Reply With Quote
How can I get Garmin and HD Radio to start when RR starts? mstaedt Road Runner 12 09-23-2008 09:09 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
