Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 10-27-2007, 03:16 AM   #16
davidp is an unknown quantity at this point
Quote: Originally Posted by guino View Post
This is happening because you didn't place a background.jpg file in the editor's folder. So RR doesn't have a background and it's keeping the previous screen as a background. Save a background.jpg file and you'll be good to go.
iLists are not transparent due to performance limitations. I may re-visit that sometime, but I saw considerable performance limitations with making a transparent iList.
the background.jpg fixed it for me, thanks.
how much performance would the trans. ilists take? as you can see some of us have very powerful pcs instead of the regular mini itx boards that would probably be able to handle it pretty easy. im not trying to put the ilists down at all, i love them whether they are trans or not (i actually just finished redoing my skin so i can have them ). i was just wondering, is there any way to be able to code them to be selectable (trans or solid) so that the people with overkill pcs (like mine ) can try it out?
either way, the new release is amazing as always. i cant wait to get it updated in my car
thanks,
david
davidp is offline   Reply With Quote
Old 10-27-2007, 03:44 AM   #17
slvrsol's Avatar
slvrsol is an unknown quantity at this point
How about applying the bitmap to the entire list instead of each item? Perhaps by dividing the bitmap up.. probably gonna be tricky though.
slvrsol is offline   Reply With Quote
Old 10-28-2007, 01:49 AM   #18
pRoFiT's Avatar
pRoFiT will become famous soon enough
Guess ive been slacking on the skin editor lateley huh? Anyways I grabbed a copy to check out the added features and i get an active x error.
Is this due to the GDI+ stuff. Do i need the GDi Wrapper DLL to fix this error?
I guess i dont need to update this anymore then I was feeling bad that i havn't been keeping up with your changes.
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
pRoFiT is offline   Reply With Quote
Old 10-28-2007, 10:26 AM   #19
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
It will always be "pRofit's SkinEditor" that made it easy for us to modify a skin to individual preferences; and most important to learn about the inner workings of a skin. For me at least, only after starting to use SkinEditor is when things became clear. Thanks for this outstanding program.
P.S. There is still one feature missing that would make it perfect - C&P
The updated version makes it easy to line-up labels and stuff using the background Thanks Guino!
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 10-29-2007, 12:47 AM   #20
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Just make sure the GDIPlusWrapper that comes with RR is registered and you should not get this error. I simply updated the code to always use GDI+ (which works with stardard files and PNG files) -- the source is also available in my site in any case.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 10-29-2007, 08:23 PM   #21
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
i remember "nomader" said something about a bug in this ver. well i have another issue, if i use it, some skin dont load at all, when using a code like this.
Code:
"MENU;popup_success.skin"
this happends if the 2 first lines in the skin file uses.
Code:
RoadRunner Skin RRScreen popup_success
if a change back to Mediacar
it works again.
Code:
Mediacar Skin Mediacar popup_success
EL CAMINO is offline   Reply With Quote
Old 10-30-2007, 12:47 AM   #22
guino's Avatar
What version of RR are you running ??
I've edited different skins with popups in them and they all work fine.. in fact, there's no discretion between the commands the skin editor saves.. if it's not working with Road Runner/RRScreen then you must be running a rather old version of RR or you're using the skin in something else than RR (i.e. plugin etc).
Old 10-30-2007, 01:11 AM   #23
EL CAMINO's Avatar
latest road runner version(10/26/07), and yes, i use autoit to load some skins, but everything works if mediacar is used instead of Road Runner/RRScreen. i have a lot of scripts using Road Runner's sdk, and they do load skins just fine.
Old 10-30-2007, 09:34 AM   #24
guino's Avatar
That's weird.. maybe you want to make a debug log of when it doesn't work so we can look at it.
Old 10-30-2007, 02:11 PM   #25
EL CAMINO's Avatar
WTH! now is working again, cut be when i was running some test's scripts?. if it does happen again i'll do that, thanks guino.
Old 11-07-2007, 09:50 PM   #26
slammedsl1 is on a distinguished road
I have the same problem
How do I fix this?
slammedsl1 is offline   Reply With Quote
Old 12-03-2007, 07:23 PM   #27
Jaf
Jaf is an unknown quantity at this point
Start --> Run
Type:
regsvr32 GDIPlusWrapper.dll
Where the location to GDIPlusWrapper.dll is in its entirety much like:
regsvr32 "C:\Documents and Settings\*****\Desktop\RoadRunner\GDIPlusWrapper.d ll"
Jaf is offline   Reply With Quote
Old 12-04-2007, 09:25 AM   #28
GuMiSZu's Avatar
GuMiSZu is an unknown quantity at this point
Hi!
A downloaded the SkinEditor, but it's the v.03 version.
Could anybody send me the correct URL?
Englishlessness :(
GuMiSZu is offline   Reply With Quote
Old 12-04-2007, 09:30 AM   #29
Jaf
You can download it from here:
http://www.kompassist.co.uk/
Enjoy!
Old 12-04-2007, 09:55 AM   #30
GuMiSZu's Avatar
That is the V0.3019 Not V 0.5
i downloaded it
Englishlessness :(
RockCar Front End v0.0.154 - Skin Editor Updates Hessian Software & Software Development 1 11-21-2008 11:40 PM
error skin editor 0,5 ammerelli RR Skins 14 11-18-2007 08:25 AM
Error with skin editor JDizzle RR Skins 3 06-13-2007 01:47 AM
CF Skin Editor RC1 djerik CF Skins 12 10-19-2006 01:10 PM
Road Runner Skin Editor rikblacketer Software & Software Development 1 10-17-2006 07:30 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
