Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 12-04-2007, 11:46 AM   #31
GuMiSZu's Avatar
GuMiSZu is an unknown quantity at this point
Hi!
I found this link: http://www.kompassist.co.uk/RRSkinEditor.zip
this is the V0.3019
where can i download the new version?
Englishlessness :(
GuMiSZu is offline   Reply With Quote
Old 12-04-2007, 12:27 PM   #32
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
That is V.5!! make sure you don't have it on cache or something -- check the window title for the version.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 12-04-2007, 01:03 PM   #33
GuMiSZu's Avatar
Yes, but it drop me an error
ActiveX component can't create an object...
Englishlessness :(
Old 12-04-2007, 03:45 PM   #34
GuMiSZu's Avatar
Ok
it works, some missing Dll and OCX
THX
Englishlessness :(
Old 12-06-2007, 04:34 AM   #35
FUBAR_nz is an unknown quantity at this point
hI ALL
fantastic job on RR
i had thought about building a car years ago but here in new zealand pc and parts arnt cheap, anyways i have now got one in my car for about 6 mths, nothing flash
but im making my own skin now and just downloaded this skin ed, i like the idea or a virtaul editor, loaded up my skin and hit the VE tab and get popup window with run time error '339" and RICHTX32.OCX error
any ideas?
ta
FUBAR
EDIT
got it working
http://www-1.ibm.com/support/docview...id=swg21171121
FUBAR_nz is offline   Reply With Quote
Old 12-14-2007, 09:54 PM   #36
ccisat1rxp is an unknown quantity at this point
Help runtime error
Hello all,
I am trying to use the new skin editor but i am getting a runtime error 339
component 'ComDlg32.ocx or one of its dependencies is not correctly registered: a file is missing or invalid. can anyone help with this. I have loaded the vb runtime file but still am unable to get the skin editor to work. thank you in advance for your help.
ccisat1rxp is offline   Reply With Quote
Old 12-14-2007, 10:13 PM   #37
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Quote: Originally Posted by ccisat1rxp View Post
Hello all,
Seen that before. Download only that file (plug it in google); copy it to c:\windows\system32 then register it manually. The problem will be fixed.
treetop777 is online now   Reply With Quote
Old 12-15-2007, 12:56 AM   #38
Hello all,
the post above yours is same error
this fixed worked and havnt had any problems
Old 12-15-2007, 11:12 AM   #39
runtime eror
problem resolved copied OCX files to system32 directory and all is well. thanks for the help.
Old 12-17-2007, 01:50 AM   #40
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
I have just found another bug..
When saving the skin, it does not put a blank line under any INC lines or at least the last one. I was editing the DFX 3.0 skin and couldn't figure out why my plugin wasn't getting initialized.
Origanal skin file(top few lines):
Code:
RoadRunner Skin RRScreen menu. menu_OFF.png,menu_OFF.png,menu_ON.png,menu_OFF.png INC,DFX_Font_Color.txt INC,Plugins.txt L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","TEMP2","left" L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","=Computer:","right"
To fix it I had to manually edit the skin file to add a blank line for rr to read it correctly.
Saved skin file, the one that doesn't work:
Code:
Manually fixed file looks like below, and now works again.
Code:
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 12-17-2007, 09:32 AM   #41
guino's Avatar
That's interesting.. the lack of the empty lines should not affect how RR parses it.. still, it should be placing those spaces.
Old 12-17-2007, 10:39 AM   #42
The Curator
Blue ZX3's Avatar
Thats what I thought, but rr seems to not like it, as the plugin line doesn't get read until there's at least one line below it...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 01-09-2008, 07:59 PM   #43
The Curator
Blue ZX3's Avatar
I have also found out that its not just the INC lines that have this prob, it can happen with the X,xxx plugin lines too...
Please fix or have a look at when you get a chance..
Many Thanks!!
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 01-16-2008, 10:42 PM   #44
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Well I've been successfully using v0.5 for some time now, then I go to fire it up to do some skinning and I am greeted with an error. Re-Download the archive from the mirror site and same thing. Any ideas what this is or how it can happen? Just started throwing this error tonight. Only thing I did different to my system is update to RR 12/13/07 release which really has nothing to do with the skin editor. Anyway I'm stumped.
EDIT
Well opened up photoshop and started more art, hit the skineditor shortcut and bam it launched. Seems to be solved, come to think of it I always have photoshop open when skineditor is running and update art "on the fly" so I think the editor just doesn't feel like playing unless his partner in crime, adobe is running.
blk02si is offline   Reply With Quote
Old 03-02-2008, 09:44 PM   #45
moeman_49 is on a distinguished road
I've been tryin to download the skin editor but the link seems to be dead. Anyone have a different link?
moeman_49 is offline   Reply With Quote
RockCar Front End v0.0.154 - Skin Editor Updates Hessian Software & Software Development 1 11-21-2008 11:40 PM
error skin editor 0,5 ammerelli RR Skins 14 11-18-2007 08:25 AM
Error with skin editor JDizzle RR Skins 3 06-13-2007 01:47 AM
CF Skin Editor RC1 djerik CF Skins 12 10-19-2006 01:10 PM
Road Runner Skin Editor rikblacketer Software & Software Development 1 10-17-2006 07:30 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
