03-02-2008, 11:04 PM
#46
The Curator
See sig for a newer ver..
03-02-2008, 11:32 PM
#47
Thanks for posting that. I try to run it and I get an error 53, file not found. Any thoughts?
03-03-2008, 04:36 AM
#48
The Curator
I updated the file on the mp3car DL but it will take 1-2 days for it to be reapproved..
So i have changed my sig to a temp DL location, and have also included the whole zip file instead...
03-03-2008, 04:52 AM
#49
Hey Blue,
what has changed in ver.06
03-03-2008, 04:53 AM
#50
The Curator
This is a modified version of the v.5 Skin Editor. Now v.6
I have added the following:
3 MRUS(Most Recently Used Skins w/ shortcut keys) file menu items, to jump right into editing a skin.
Enable/disalbe the "Skin saved" Conformation Msgbox, in the Editor Setting's window. Disabled by default!
03-03-2008, 04:56 AM
#51
cool, Thank you.
03-03-2008, 11:04 AM
#52
Thanks blue. Got it working now.
03-03-2008, 01:07 PM
#53
Thanks Blue, The MRUS option is very nice
The road is long but we are getting there.
03-03-2008, 01:28 PM
#54
The Curator
It only made sence to me....
I hated to constantly browse to the skin(s) that I was working on.
03-03-2008, 09:21 PM
#55
Raw Wave
Thanks. Very nice feature.
03-15-2008, 02:51 AM
#56
The Curator
Ver 0.7 now avail!!
See sig
NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE
NOTE: Once you start using this version, you will have to delete your
"settings.txt" file before going back to the 0.6 version. If you
do not do that, you will get an "Error: 53", File not found message.
You have been worned!
Changes/Additions
These 3 Screen Menu items have been moved to a new "Actions" Menu and the "skin" part changed to "screen"
Create new skin
Copy current skin
Delete current skin
A New "Recent" Menu added next to the "Screens" menu to easly navigate back to a previously viewed screens
Upon saving a skin, it also remembesr the Recent history for next time.
03-15-2008, 03:22 AM
#57
is there a chance you could put a prompt to save the current skin when you close the editor. i know if you choose quit you get prompted just not if you click the close X or if you do ALT F4.
even better if you could put a cancel option in too
more than once ive closed the wrong window (of many) half way thru doing something
thanks for the new editor too btw
03-15-2008, 11:41 AM
#58
Raw Wave
 Many a times i've hit the X and everything closes without warning and without saving.
How about also a copy n paste function - sometimes you have a complicated command and want to have it on several different screens; it would be fantastic if one could just copy it from one screen and paste it in another (or many others).
EDIT: And thanks for V7
03-15-2008, 11:52 AM
#59
while at it, how about adding find/replace(common) fuction? i use notepad to do the mass change of color and font... If not, that's fine blue... I can just use both editor.. no biggie..
03-15-2008, 01:26 PM
#60
I try to run V0.7 (but also V0.6) and bothe gove me the same result:
Run time error 429 ActiveX component can't create object.
Allready placed the OCX file inside my SYSTEM32 map, but probleem is still there
I work with Vista.
What more can I do to make this work??
Gods right foot!!
Mercedes ML320. Intel D945GCLF2,1024mb DDRII,160Gb S-ATA HD,HDradio,7"Touchscreen,2x 7"build in headrest screens,OBDII reader,Centrafuse.
| Thread Tools |
| Display Modes |
Linear Mode
