03-15-2008, 06:55 PM
#61
The Curator
Quote: Originally Posted by seninha
I try to run V0.7 (but also V0.6) and bothe gove me the same result:
Run time error 429 ActiveX component can't create object.
Allready placed the OCX file inside my SYSTEM32 map, but probleem is still there
I work with Vista.
What more can I do to make this work??
Did you register it after you moved it?
03-15-2008, 07:38 PM
#62
The Curator
Quote: Originally Posted by Woofnstuff
is there a chance you could put a prompt to save the current skin when you close the editor. i know if you choose quit you get prompted just not if you click the close X or if you do ALT F4.
even better if you could put a cancel option in too
more than once ive closed the wrong window (of many) half way thru doing something
thanks for the new editor too btw
Done v0.71
03-15-2008, 07:46 PM
#63
The Curator
Quote: Originally Posted by brandensin
while at it, how about adding find/replace(common) fuction? i use notepad to do the mass change of color and font... If not, that's fine blue... I can just use both editor.. no biggie..
Well see about this one, its just not as simple as the changes that I have already made. Its within my reach though...
03-15-2008, 07:54 PM
#64
cheers blue your a champ
gimme a msg if you need a mirror too
03-15-2008, 07:59 PM
#65
The Curator
Seen your post in the installer thread, deff wouldn't hurt..
03-16-2008, 03:18 AM
#66
Still no luck. Placed the OCX file in my System32, run Reg.bat. Get info that that work is doen, but still same error
Same problem with V0.71
Gods right foot!!
Mercedes ML320. Intel D945GCLF2,1024mb DDRII,160Gb S-ATA HD,HDradio,7"Touchscreen,2x 7"build in headrest screens,OBDII reader,Centrafuse.
03-16-2008, 10:38 AM
#67
Raw Wave
I just moved the whole folder into the rr folder then ran reg.bat..it is working fine for me.
03-16-2008, 06:12 PM
#68
The Curator
The two main requirements for the editor is the richtext.ocx and the gdipluswrapper.dll file.
If you have transparent skins working in rr then the gdipluswrapper.dll file is not the problem, it would be the richtext.ocx file.
And not too sure on the work-ability of the editor in vista. Don't have it, and certainly don't want it!
03-17-2008, 03:53 AM
#69
Thanks, will download it and try it again.
Quote: vista. Don't have it, and certainly don't want it! : People said the same when XP came out,and look now!!
Gods right foot!!
03-17-2008, 06:34 AM
#70
i waited till about a year, when there was the hardware support and SP1, and it was mainly to get driver support that was lacking in windows 9x.
at the moment xp is fine, and for a car pc vista offers no merits. perhaps if you are sticking in a full computer system thats quad core or somethign .. then why not.
all i need is an OS to run my music player and nav system, anything else is a bonus
03-20-2008, 03:39 PM
#71
What it?
03-21-2008, 06:57 AM
#72
Piple UP!
I need help!
RUSSIA - WINER!!!
03-21-2008, 07:03 AM
#73
A bit more information would help. When do you get this dialog, is it when you start the app, or when your doing something in the app ?
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
03-21-2008, 07:13 AM
#74
As soon as I try to start the program
RUSSIA - WINER!!!
03-24-2008, 10:53 AM
#75
help me
RUSSIA - WINER!!!
| Thread Tools |
| Display Modes |
Linear Mode
