06-14-2008, 07:21 PM
#91
Super Moderator & Wal-Mart Greeter
Got it figured out. The invalid procedure call I was getting is related to not opening the skins from the skins path that was set in the Skin Editor proggy. Once I created c:\program files\Road Runner\skins, moved my skins to that folder, then opened, they open fine.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
07-19-2008, 06:39 PM
#92
Hi guys, im trying to put together a light weight skin and am getting to know the RR skin editor quite well, I do however have a couple of questions.
Am i able to remove the measurements from certain object values? example, when showing a songs' Kbps, it displays 320 Kbps, i want to remove the "Kbps" from this, and add that in as a label or graphic (so it can be a different color from the value itself). or is it possible to set it as two different colors?
the same with volume percentage, i want to remove the "%" symbol as it does not look quite right with my design.
also, is there any information regarding setting up ilists/browser lists? i think i saw one somwhere but lost track of it..
All the best for now
-2k
07-19-2008, 06:54 PM
#93
Wants to make it harder
-2k
Check this thread out:
http://www.mp3car.com/vbulletin/rr-p...es-plugin.html
Did you look in skincommands.txt for help with iLists? Also, most skins now use them, so copying tags might help understand them a little.
09-09-2008, 02:26 PM
#94
The Skin Editor V0.71 link is down. Is there another link i can download from?
09-18-2008, 05:42 AM
#95
The Curator
10-28-2008, 04:26 PM
#96
This skin editor is awesome.
A few questions though. Is it possible for INC objects to show up? My whole top bar is an INC but it's just blank. It would be nice if there was a way to save a skin as an INC file also to cut down on copy/paste when building templates.
Also images won't display in the skin editor but show up fine in RR.
10-28-2008, 05:17 PM
#97
The Curator
The Save As Inc shouldn't be too hard to do. Adding the Inc to be displayed as well and being able to save w/o issues would be a dash more harder.
I can see about quickly adding the first part. Latter today maybe....
10-31-2008, 05:00 PM
#98
i'm haccing trouble w/ RICHTX32.OCX on XP I tryed to register and unregister the OCX and still no luck
I just have no idea how to fix it
11-07-2008, 02:32 PM
#99
Copy your ocx file into the windows\system32 folder then right click the reg.bat file and use "run as administrator"
should work fine then. did for me
11-07-2008, 02:35 PM
#100
file is alredy there and properly re-registred
do luck
I just use my other comp and it works fine, but no luck on development machine...
11-07-2008, 06:47 PM
#101
I'm getting a File Not Found error, when i try and make a new skin, and choose a saved filed location. A window pops up saying "There is no general.ini" file in this folder, would you like to copy the default.
I click yes and i get "Run time error 53" File not found.
I've tried saving the general.ini from RR to the same folder where im trying to save a new skin, but no luck.
11-07-2008, 07:31 PM
#102
The Curator
The default general.ini file that it is looking for should be your skin editor folder if not then try copying one from another skin's folder the same folder that you have your skin editor exe.
11-09-2008, 12:36 AM
#103
Would it be possible to add snap to grid or rulers or something like that? It's nearly impossible to line up multiple elements without switching to the test editor.
I tried zooming but zoom doesn't work on my PC. The image doesn't match whats being clicked.
11-19-2008, 03:23 AM
#104
You can always use the arrow keys to move and adjust boxes for alignment. I think a multiple selection and alignment tool would be nice. Like align to top, left, right, bottom or middle. Or make same size.
11-20-2008, 01:11 PM
#105
The Curator
Try this version 0.72, it includes a "Save Current as INC" in the file menu.
[Edit]
File removed, due to additions to this version. see few posts below for newer 0.72 update
| Thread Tools |
| Display Modes |
Linear Mode
