10-23-2007, 12:37 PM
#1
The Curator
Skin Editor [ v0.76d Updated 10/29/09 ]
NEW FEATURES IN v0.76d (By BlueZX3) - Fixed issue with File not found problem.
NEW FEATURES IN v0.76c (By BlueZX3) - Added a "Settings" header to the general.ini of saved skins
NEW FEATURES IN v0.76a (By BlueZX3) - Fixed visible property error when creating a new skin in a folder that contained no skin files.
NEW FEATURES IN v0.76 (By BlueZX3) - Added "KEEPLOADED" option to skin. Supported in RR 4/2009
- Re-Enabled "DISCARDABLE" option as it is fixed in RR 4/2009
NEW FEATURES IN v0.75 (By BlueZX3) - Fixed Object list being too tall for window
- Added "Start Maximized" option for the Editor, see the option in the skin editor settings menu
- Added if not starting Maximized, will set window size to last used size when editor was closed
- Changed main editor window name to Ride Runner...
- Removed the ver from the exe name, so now its just "RRSkinEditor.exe" with the version in the window title
NEW FEATURES IN v0.74 (By BlueZX3) - Fixed Dublicate Background.jpg entries in the Background Menu
- Added a combobox to pick which layer of the screen to be shown, all or selected one.
NEW FEATURES IN v0.72 (By BlueZX3)
- Added Backgrounds Menu to select a different one to use. Other background images need to be in the skin editor path/folder
- Added a Skin Loading progress bar with name of current loading screen
- Added a way to set the default zoom level ( Settings > Editor Settings )
- Added Copy and Paste multiple objects from one screen to another ( using the CTRL key to select multiple objects )
- Added Undo in the graphic editor when moving objects via click n drag method ( CTRL-Z or toolbar )
- Added Align multiple selected objects by: Top,Bottom,Left,Right
- Added Make all selected objects the same: Width,Height,Both
- Added Center all selected objects: vertically, Horizontally
- Added Evenly space mulitple selected objects: Vertically, Horizontally
- Note: All align methods use the first selected objects for the one to align to
- Note: Undo in graphic editor will NOT undo any align moves
NEW FEATURES IN v0.71 (By BlueZX3)
- Added a new "Actions" Menu
- Moved the Create,Copy,Delete items from the skin toolbar menu to the new "Actions" toolbar menu
- Added a "Recent" toolbar menu to easly navigate back to a previously viewed screens
- Also upon saving a skin, it also remembesr the Recent history for the loaded skin for the next time.
- Added a conformation asking if you really want to exit the editor, instead of just closing and possibily loosing unsaved changes
- Note: Newly created, and copied skins will show at the very bottom of the list
NEW FEATURES IN v0.6 (By BlueZX3)
- 3 MRUS (Most Recently Used Skins w/ shortcut keys) items added to the file menu, to jump right into editing a skin.
- Enable/disalbe the "Skin saved" Conformation Msgbox, in the Editor Setting's window. Disabled by default!
- Added a simple non invasive "Skin Saved" popup bar confirming its been saved.
NEW FEATURES IN v0.5
- Fix for displaying FontNames defined with /DEFINE
- Added Comments and Sections to Object Lists
- Merged Code with PROFIT's latest changes:
- * Added direct Toggle of /DISCARDABLE option
- * Ability to move objects with the mouse
- * Ability to lock/unlock objects
- * Virtual Skin Editor with Undo/Redo
NEW FEATURES IN v0.45
- Added Support to load/edit/save /<Options>
- Added Support to keep definitions
- Fixed ... buttons over text boxes
- Fixed issue with displaying background size different than skin size
- Updated Objects.txt with all available Commands/Labels/Indicator codes and Objects
- Support for PNG files and transparent skins
- -Just save a Background.jpg file to the Skin Editor's path and it will load it
- Support for folder/media icons in the header of skins
- Added INC, IMG, SD and IL objects
- NOTE: This version FORCIBLY uses GDI+ -- so make sure you have it working in RR.
Reason: Version update
10-23-2007, 12:43 PM
#2
this sounds sweet!
Is it just the download for the skin editor?
10-23-2007, 01:06 PM
#3
RoadRunner Mastermind
For now, yes.. I'm still debugging on a few things in RR.
Ride Runner RR's Myspace
10-23-2007, 01:38 PM
#4
Raw Wave
OUTSTANDING! Thanks
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
10-23-2007, 05:12 PM
#5
you did it again guino, thanks a million!!.
10-23-2007, 05:45 PM
#6
New version -- Thread updated.
10-23-2007, 08:17 PM
#7
Raw Wave
 I must have downed the wrong file  There is no FILE>CREATE; FILE>EXIT; i don't see any option to load/edit/save...
M2-ATX Power Supply
Windows XP SP3
10-24-2007, 12:08 AM
#8
There's no File->Exit, that is easily added (but you can close it using the RED X on the top right)..
To create a brand new screen: Click File->Open, hit "Make New Folder", name it, hit OK -- it will ask you to create a blank general.ini file, say YES, then from the Screen menu, click create new screen as many times as needed.
10-24-2007, 03:58 AM
#9
Super Moderator
Older RRSkin Editor Source Code
Guino, the source you have is quite a bit older. pRoFiT added a lot of nice stuff to the skin editor. He said he is sending me the latest source in email. As soon as I get it it, I will forward to you.
Since the version you are working with, he added the ability to move the buttons and labels using your mouse (Version posted above, you can not move or resize the objects with your mouse on the screen), it has an Undo Feature, as well as a "Virtual Editor" to view the skin in text format. Lastly it has a way to lock objects on the screen, so you can edit something behind something else Like a label on a button, many times you cant get to to the label to edit it, as the button is on top of it. You can lock the button, then are able to edit the label).
10-24-2007, 08:37 AM
#10
Well, I worked with what I had in hands.. if I get his version, I'll merge my changes to it..
10-26-2007, 03:33 PM
#11
New version 0.5 Out -- thread and mirror site updated.
10-26-2007, 09:20 PM
#12
hi, i think i may have found a bug with skin editor .5, when you load a transparent skin, and then go to a different screen of it, the previous screen shows through the current one. also if you load a skin, and then open a different (transparent) skin, the first skin is still visible through the newly opened trans. skin. the previous screens stay in the background until they end up be opaque because they just pile up (dont know how to describe it well).
here is a screenshot of whats happening:
other than that, its great, i love the new ilists (although i wish they could be transparent).
thanks,
david
10-27-2007, 12:49 AM
#13
This is happening because you didn't place a background.jpg file in the editor's folder. So RR doesn't have a background and it's keeping the previous screen as a background. Save a background.jpg file and you'll be good to go.
iLists are not transparent due to performance limitations. I may re-visit that sometime, but I saw considerable performance limitations with making a transparent iList.
10-27-2007, 01:36 AM
#14
One Sharp Cheddar
I have to say this skin editor rocks. I have been using profits version for a while now, but with all the recently added features to RR, I was manually coding quite a bit on my own.
Thanks again for another great addition to Road Runner...
10-27-2007, 02:48 AM
#15
first time of using your new editor i thought i had graphic faults.
when the cursor is in field of a box, the graphic inside the box shift 1 pixel up.
in profit's editor you cant see this because the selected box is white.
but some wishes i have to the editor.
a girder would be helpfull for skins like GASPRICEFINDER or WEATHER with a lot of information to bring the messages in a row.
the backgroundskin.jpg, dont fix it in your program.... take the file "SETTINGS" for it.
i use 6-8 different screens to find the best textcolour. always rename a file is no nice job.
| Thread Tools |
| Display Modes |
Linear Mode
