02-10-2009, 06:01 PM
#16
this and the BMW iDrive are my two favorites. very professional, to the point.
02-11-2009, 11:13 AM
#17
ty for posting your current work  will have a snoop around, see if i can help at all
Ive had a little play around with the skin, removed some features i wont ever be using (XM/sirus radio, navigation and TV) and re-arranged the icons as appropriate.
All the other things such as grammer and all the functions i have tested have all worked perfectly fine so well done on that. Il be eagerly awaiting the settings and EQ screens and then its pretty complete for me.
route78, what was the font you used. The standard font on the newer iPods is Helvetica anyway. If you can give me your fonts name i can maybe try to find an immitation font.
Reason: added more text
02-11-2009, 01:59 PM
#18
great skin any change you can have a 800X600 version?
02-14-2009, 07:48 PM
#19
GREAT WORK!
I love it. is there radio/xm/sirius?
02-14-2009, 09:44 PM
#20
Raw Wave
Change the paths in skin.ini and the backgrounds will work.
03-18-2009, 12:51 PM
#21
Terminal flasher
i love the overall layout of this skin. Hope it gets finished.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
03-24-2009, 10:01 PM
#22
ok i'm trying to get the individual background screens to work and all I can get to work is the menu.skin and then the first one that is defined in ExecTBL.ini no other ones work.
here is the ExecTBL.ini
Code:
/,-----------------------------------------------------------Play List-----------------
"Playlist",AUDIO_LIST.SKIN
"ONSKINSTART","SETVAR;BACKGROUND;$playlist$"
/,Audio Browser
"AudioBrowser",audio_browser1.SKIN
"ONSKINSTART","SETVAR;BACKGROUND;$audiobrowser$"
here is the skin.ini
Code:
background=C:\Program Files\Road Runner\Skins\iphone\backimg\main.jpg
[background img path]
playlist=C:\Program Files\Road Runner\Skins\iphone\backimg\6.jpg
audioplayer=C:\Program Files\Road Runner\Skins\iphone\backimg\6,jpg
videoplayer=C:\Program Files\Road Runner\Skins\iphone\backimg\
videobrowser=C:\Program Files\Road Runner\Skins\iphone\backimg\8,jpg
dmb=C:\Program Files\Road Runner\Skins\iphone\backimg\
photo=C:\Program Files\Road Runner\Skins\iphone\backimg\
setting=C:\Program Files\Road Runner\Skins\iphone\backimg\
from what i've read i don't think onskinstart is right to use or any of that for that matter
i thought that maybe all i had to do was for each .skin file put the following code in
Code:
"SETVAR;BACKGROUND;C:\MYCAR.JPG"
but that did not seem to work
any help would be appreciated thank.
03-25-2009, 12:00 AM
#23
You have to set the background before the initial loading the skin. Won't work on any preloaded skins.
i.e. ExecTBL.ini
"Playlist","SETVAR;background;C:\Pic.jpg||LOAD;AUD IO_LIST.SKIN"
Furthermore, "ONSKINSTART" is only executed when the skin starts.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
03-25-2009, 08:15 AM
#24
so i tried what you said, but it only loads the menu.skin main background for all the .skin files, this is what i have now
ExecTBL.ini
Code:
"AudioBrowser","SETVAR;background;C:\Program Files\RideRunner\Skins\skin\backimg\5.jpg||LOAD;audio_browser.SKIN"
"VideoBrowser","SETVAR;background;C:\Program Files\RideRunner\Skins\skin\backimg\7.jpg||LOAD;video_browser.SKIN"
"Navi","SETVAR;background;C:\Program Files\RideRunner\Skins\skin\backimg\8.jpg||LOAD;navi.SKIN"
"Weather","SETVAR;background;C:\Program Files\RideRunner\Skins\skin\backimg\9.jpg||LOAD;weather.SKIN"
skin.ini
Code:
background=C:\Program Files\RideRunner\Skins\skin\backimg\main.jpg
03-25-2009, 10:50 AM
#25
ExecTBL.ini
Code:
skin.ini
Code:
Hmmm...should be working. You're not preloading the skins on startup, right?
EDIT: Just looked at the skin. It looks like the skin author uses jpg's for some of the skin's layout. jpgs don't support transparency, which could explain why you're not seeing your selected background.
03-25-2009, 11:54 AM
#26
hmm, i'm not preloading any screens and i don't think it is a jpg problem b/c the main menu.skin background is shown on the other .skin screens
03-25-2009, 12:50 PM
#27
menu.skin uses pngs. The images the author has used has tranparency available.
List of skins that doesn't use pngs:
audio_browser1.skin
audio_player.skin
dmb.skin
loader.skin
navi.skin
picviewer.skin
video_player.skin
Open the skins where the bg images are not being shown and check the screen image setting.
GL
03-25-2009, 01:12 PM
#28
sorry i forgot to mention that i changed some of the .skins and i also changed the .jpg's to .png's to include transparency
not sure what you mean by screen image setting
here is my menu.skin
Code:
RoadRunner Skin
RRScreen menu
B,0,0,40,40,"LOAD;upd8.skin",
I,47,1,38,38,"SHUFFLE"
I,95,1,38,38,"REPEAT"
I,139,1,38,38,"MUTE"
Y,"slider_vol\slider_*.png"
S,643,18,28,16,640,011,028,016,H,01,"slider_vol\pointer.gif",01,"MASTER",""
L,187,9,425,27,255,255,255,13,"Frutiger 57Cn:B","TRACKNAME","SCROLL-CENTER"
L,718,15,41,20,255,255,255,13,"Frutiger 45 Light:B","VOLUME","LEFT"
L,1,24,800,70,255,255,255,64,"comic","TIME","CENTER"
L,1,114,800,21,255,255,255,12,"comic","DATE","CENTER"
B,669,338,70,82,"EXIT",""
B,233,338,70,82,"VIDEO",""
B,496,338,70,82,"WEB",""
B,582,338,70,82,"RELOADSKIN",""
B,408,338,70,82,"LOAD;weather.skin",""
B,321,338,70,82,"LOAD;external_gps.skin",""
B,147,338,70,82,"LOAD;coverjuke.skin",""
B,99,425,70,55,"MUTE",""
B,695,426,70,55,"MIXER",""
B,623,426,70,55,"REPEAT",""
B,550,426,70,55,"SHUFFLE",""
B,464,426,70,55,"NEXT",""
B,353,424,90,55,"PLAY",""
B,259,425,70,55,"PREV2",""
B,171,425,70,55,"VOL+",""
B,27,425,70,55,"VOL-",""
B,61,338,70,82,"LOAD;audio_browser1.skin",""
END
here is audio_browser1.skin
Code:
RoadRunner Skin
RRScreen audio_browser1
audio_browser_off.png,audio_browser_off.png,audio_browser_on.png,audio_browser_on.png
B,638,376,36,28,"PGDOWN",
B,637,347,37,28,"DOWN",
B,638,55,33,28,"PGUP",
B,636,84,36,30,"UP",
B,685,53,102,55,"BACK",""
B,688,352,96,55,"DELETEFILE",""
B,686,175,101,55,"SELECT",""
B,685,108,102,64,"BROWSE",""
B,687,292,98,55,"SearchFiles||Load;osk.skin",""
B,687,234,99,55,"RENAMEFILE||Load;osk.skin",""
Y01,"slider_vol\slider_*.png"
Y02,"slider_play\slider_*.png"
S01,640,17,028,016,640,011,028,016,H,01,"slider_vol\pointer.gif",01,"MASTER",""
/, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
IL,DL,transparent.bmp,sel.bmp,end.bmp,2,50,80
S,637,111,36,238,620,100,40,245,V,03,"list_pointer.png",35,"DLSLIDER",""
S,103,63,522,336,254,222,41,0,0,0,2,153,244,255,255,255,255,128,0,0,0,128,,12,"Myriad Pro Light:B"
L,180,6,436,27,255,255,255,13,"Frutiger 57Cn:B","TRACKNAME","SCROLL-CENTER"
L,718,14,41,20,255,255,255,13,"Frutiger 45 Light:B","VOLUME","LEFT"
I,43,1,38,38,"SHUFFLE"
I,91,1,38,38,"REPEAT"
I,135,2,38,38,"MUTE"
B,107,425,55,55,"MUTE",""
B,744,1,52,38,"EXIT",""
B,702,426,55,55,"MIXER",""
B,628,425,55,55,"REPEAT",""
B,557,425,55,55,"SHUFFLE",""
B,472,425,55,55,"NEXT",""
B,364,425,70,55,"PLAY",""
B,267,424,55,55,"PREV2",""
B,178,425,55,55,"VOL+",""
B,36,425,55,55,"VOL-",""
END
03-26-2009, 08:50 AM
#29
here is my debug.txt if that helps
Code:
3/26/2009 8:48:59 AM: Start -- Version: 2/2/2009
3/26/2009 8:48:59 AM: OS Type: XP
3/26/2009 8:48:59 AM: Master Vol: Play Control/4
3/26/2009 8:48:59 AM: Source: Wave=&H1008/1
3/26/2009 8:48:59 AM: Source: CD Player=&H1005/2
3/26/2009 8:48:59 AM: Source: Microphone=&H1003/3
3/26/2009 8:48:59 AM: Source: Auxiliary=&H100A/4
3/26/2009 8:48:59 AM: Source: Line-In=&H1002/5
3/26/2009 8:48:59 AM: Source: MIDI Synth=&H1004/6
3/26/2009 8:48:59 AM: Source: Digital-In=&H1001/7
3/26/2009 8:48:59 AM: Source: Wave=&H1008/8
3/26/2009 8:48:59 AM: GetLineControl Failed: 401
3/26/2009 8:48:59 AM: Can't Open Source
3/26/2009 8:48:59 AM: No Mute for Source
3/26/2009 8:49:00 AM: No Phidgets interface detected.
3/26/2009 8:49:00 AM: Plugin Manager: loading Global Plugins...
3/26/2009 8:49:00 AM: Plugin Manager: Plugin Found: SkinTool plugin found but will be unable to create (most likely NOT registered)[skipped].
3/26/2009 8:49:00 AM: Plugin Manager: loading Global Plugins Completed.
3/26/2009 8:49:00 AM: LoadSkin: C:\Program Files\RideRunner\Skins\skin\
3/26/2009 8:49:00 AM: Plugin Manager: loading SkinDir Plugins...
3/26/2009 8:49:00 AM: Plugin Manager: loading SkinDir Plugins Completed.
3/26/2009 8:49:00 AM: CheckResume: ResumeMusic=0 WasRadio=0
3/26/2009 8:49:00 AM: Enter Exec: False, menu.skin, , False
3/26/2009 8:49:00 AM: Que Exec: True, menu.skin, "ONSKINSTART", False
3/26/2009 8:49:00 AM: Executing: ONSKINSTART
3/26/2009 8:49:00 AM: Leave Exec: False, menu.skin, ONSKINSTART, False
3/26/2009 8:49:01 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||LOAD;audio_browser1.skin", False
3/26/2009 8:49:01 AM: Que Exec: True, menu.skin, "ONBTNPRESS||LOAD;audio_browser1.skin", False
3/26/2009 8:49:01 AM: Executing: ONBTNPRESS
3/26/2009 8:49:01 AM: Que Exec: True, menu.skin, "LOAD;audio_browser1.skin", False
3/26/2009 8:49:01 AM: Executing: LOAD;audio_browser1.skin
3/26/2009 8:49:01 AM: Que Exec: True, audio_browser1.skin, "ONSCREENCHANGE", False
3/26/2009 8:49:01 AM: Executing: ONSCREENCHANGE
3/26/2009 8:49:01 AM: Leave Exec: False, audio_browser1.skin, ONSCREENCHANGE, False
3/26/2009 8:49:03 AM: Enter Exec: False, audio_browser1.skin, "ONBTNPRESS||EXIT", False
3/26/2009 8:49:03 AM: Que Exec: True, audio_browser1.skin, "ONBTNPRESS||EXIT", False
3/26/2009 8:49:03 AM: Executing: ONBTNPRESS
3/26/2009 8:49:03 AM: Que Exec: True, audio_browser1.skin, "EXIT", False
3/26/2009 8:49:03 AM: Executing: EXIT
3/26/2009 8:49:03 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
3/26/2009 8:49:03 AM: Executing: ONSCREENCHANGE
3/26/2009 8:49:03 AM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
3/26/2009 8:49:04 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||LOAD;video_browser.skin", False
3/26/2009 8:49:04 AM: Que Exec: True, menu.skin, "ONBTNPRESS||LOAD;video_browser.skin", False
3/26/2009 8:49:04 AM: Executing: ONBTNPRESS
3/26/2009 8:49:04 AM: Que Exec: True, menu.skin, "LOAD;video_browser.skin", False
3/26/2009 8:49:04 AM: Executing: LOAD;video_browser.skin
3/26/2009 8:49:04 AM: Que Exec: True, video_browser.skin, "ONSCREENCHANGE", False
3/26/2009 8:49:04 AM: Executing: ONSCREENCHANGE
3/26/2009 8:49:04 AM: Que Exec: True, video_browser.skin, "ONSOURCECHANGE", False
3/26/2009 8:49:04 AM: Executing: ONSOURCECHANGE
3/26/2009 8:49:04 AM: Leave Exec: False, video_browser.skin, ONSOURCECHANGE, False
3/26/2009 8:49:05 AM: Enter Exec: False, video_browser.skin, "ONBTNPRESS||EXIT", False
3/26/2009 8:49:05 AM: Que Exec: True, video_browser.skin, "ONBTNPRESS||EXIT", False
3/26/2009 8:49:05 AM: Executing: ONBTNPRESS
3/26/2009 8:49:05 AM: Que Exec: True, video_browser.skin, "EXIT", False
3/26/2009 8:49:05 AM: Executing: EXIT
3/26/2009 8:49:05 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
3/26/2009 8:49:05 AM: Executing: ONSCREENCHANGE
3/26/2009 8:49:05 AM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
3/26/2009 8:49:06 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||LOAD;external_gps.skin", False
3/26/2009 8:49:06 AM: Que Exec: True, menu.skin, "ONBTNPRESS||LOAD;external_gps.skin", False
3/26/2009 8:49:06 AM: Executing: ONBTNPRESS
3/26/2009 8:49:06 AM: Que Exec: True, menu.skin, "LOAD;external_gps.skin", False
3/26/2009 8:49:06 AM: Executing: LOAD;external_gps.skin
3/26/2009 8:49:06 AM: Que Exec: True, external_gps.skin, "ONSCREENCHANGE", False
3/26/2009 8:49:06 AM: Executing: ONSCREENCHANGE
3/26/2009 8:49:06 AM: Leave Exec: False, external_gps.skin, ONSCREENCHANGE, False
3/26/2009 8:49:08 AM: Enter Exec: False, external_gps.skin, "ONBTNPRESS||exit||CLOSEWINDOW;CWiG", False
3/26/2009 8:49:08 AM: Que Exec: True, external_gps.skin, "ONBTNPRESS||exit||CLOSEWINDOW;CWiG", False
3/26/2009 8:49:08 AM: Executing: ONBTNPRESS
3/26/2009 8:49:08 AM: Que Exec: True, external_gps.skin, "exit||CLOSEWINDOW;CWiG", False
3/26/2009 8:49:08 AM: Executing: exit
3/26/2009 8:49:08 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
3/26/2009 8:49:08 AM: Executing: ONSCREENCHANGE
3/26/2009 8:49:08 AM: Que Exec: True, menu.skin, "CLOSEWINDOW;CWiG", False
3/26/2009 8:49:08 AM: Executing: CLOSEWINDOW;CWiG
3/26/2009 8:49:08 AM: Leave Exec: False, menu.skin, CLOSEWINDOW;CWiG, False
3/26/2009 8:49:09 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||LOAD;weather.skin", False
3/26/2009 8:49:09 AM: Que Exec: True, menu.skin, "ONBTNPRESS||LOAD;weather.skin", False
3/26/2009 8:49:09 AM: Executing: ONBTNPRESS
3/26/2009 8:49:09 AM: Que Exec: True, menu.skin, "LOAD;weather.skin", False
3/26/2009 8:49:09 AM: Executing: LOAD;weather.skin
3/26/2009 8:49:10 AM: Enter Exec: True, weather.skin, , False
3/26/2009 8:49:10 AM: Que Exec: True, weather.skin, "ONSCREENCHANGE", False
3/26/2009 8:49:10 AM: Executing: ONSCREENCHANGE
3/26/2009 8:49:10 AM: Leave Exec: False, weather.skin, ONSCREENCHANGE, False
3/26/2009 8:49:10 AM: Enter Exec: False, weather.skin, "ONBTNPRESS||MAIN", False
3/26/2009 8:49:10 AM: Que Exec: True, weather.skin, "ONBTNPRESS||MAIN", False
3/26/2009 8:49:10 AM: Executing: ONBTNPRESS
3/26/2009 8:49:10 AM: Que Exec: True, weather.skin, "MAIN", False
3/26/2009 8:49:10 AM: Executing: MAIN
3/26/2009 8:49:10 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
3/26/2009 8:49:10 AM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
3/26/2009 8:49:12 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||EXIT", False
3/26/2009 8:49:12 AM: Que Exec: True, menu.skin, "ONBTNPRESS||EXIT", False
3/26/2009 8:49:12 AM: Executing: ONBTNPRESS
3/26/2009 8:49:12 AM: Que Exec: True, menu.skin, "EXIT", False
3/26/2009 8:49:12 AM: Executing: EXIT
3/26/2009 8:49:12 AM: Enter Exec: True, menu.skin, "ONEXIT", False
3/26/2009 8:49:12 AM: Queued: "ONEXIT"
3/26/2009 8:49:12 AM: Plugin Manager: ALL Plugins unloaded.
3/26/2009 8:49:12 AM: Shutdown
03-26-2009, 10:31 AM
#30
You need to change the button code in the skin that loads all the other skins w/ the commands you defined in ExecTbl.ini.
| Thread Tools |
| Display Modes |
Linear Mode
